Walked through solution here but it isn’t quite my issue. I was following the steps here. I have 30_os_prober and 60_memtest chmod’ed to 644 (won’t execute) in /etc/grub.d and I added the windows boot loader stanza to 40_custom. It does appear in /boot/grub/grub.cfg after running grub-install and update-grub. However the usual Manjaro Grub menu doesn’t appear. Instead, it boots immediately to Manjaro (well after the 5 second GRUB_TIMEOUT) without showing the grub menu. GRUB_TIMEOUT_STYLE=hidden but I think that’s default?
Seeing the menu but no Windows entry. Here’s the output of update-grub:
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
done
and here’s my /boot/grub/grub.cfg showing a windows menuitem but doesn’t appear in the Grub menu for some reason:
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
menuentry 'Windows Boot Manager (on /dev/sda2)' --class windows --class os $menu
entry_id_option 'osprober-efi-092B-6AA4' {
savedefault
insmod part_gpt
insmod fat
set root='hd0,gpt2'
if [ x$feature_platform_search_hint = xy ]; then
search --no-floppy --fs-uuid --set=root --hint-bios=hd0,gpt2 --hint-efi=hd0,gpt2 --hint-baremetal=ahci0,gpt2 092B-6AA4
else
search --no-floppy --fs-uuid --set=root 092B-6AA4
fi
chainloader /EFI/Microsoft/Boot/bootmgfw.efi
