No display signal after graphics card upgrade to RX 6800
Hi everyone,
i am using Manjaro Linux Gnome - Wayland and have a problem with my graphics card/ display.
Until today i had a Radeon Vega 56 installed and it was working fine.
Now i upgraded it to an RX 6800 and wanted to try it out in Manjaro but unfortunately after i booted to the system the display stays black and reports “no signal - check conntection”.
I tried it with Display Port and HDMI but the problem stays the same.
Interestingly i can still boot to Windows (Dual-Boot, both HDMI and Display Port works fine there) and even Manjaro KDE - Wayland works normally, which i had also installed.
But when I try to boot to Manjaro Gnome, the BIOS logo shows up, then comes Grub, and after that nothing more.
I connected my display to the mainboard HDMI port and there it is working fine.
It is just the ports of my graphics card that don’t work.
Any ideas what is going wrong here? I am happy to post some logs/ additional information if you tell me what you need.
Thanks in advance!
Edit: So i disabled early KMS which i had enabled a long time ago to fix some boot problems IIRC. It changed nothing unfortunately.
I also tried booting from a live USB stick (also Manjaro Gnome ofc) and this worked without problems, so i guess it must be some configuration that is wrong on my system.
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
You can also use Maxi
to collect information about the boot process. This works,
  • when you are in your running system (with CTRL+ALT+F2).
  • And also in a live environment
Hi here you go that’s the inxi output
~ ❯ inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.10.105-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    root=UUID=45146617-5296-480c-9f18-8a4d5f9a1fa7 rw quiet apparmor=1
    security=apparmor resume=UUID=6389b853-0b03-4ad3-a7c6-72bc181ca603
    udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
  Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: 1: GDM
    v: 41.3 2: LightDM v: 1.30.0 note: stopped Distro: Manjaro Linux
    base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: Z370 KRAIT GAMING (MS-7B46) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.A0
    date: 01/07/2020
  RAM: total: 15.5 GiB used: 2.46 GiB (15.9%)
  RAM Report:
  Info: model: Intel Core i5-8600K bits: 64 type: MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
  Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
    desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
    desc: 1x9 MiB
  Speed (MHz): avg: 4188 high: 4200 min/max: 800/4300 scaling:
    driver: intel_pstate governor: powersave cores: 1: 4200 2: 4146 3: 4198
    4: 4192 5: 4200 6: 4194 bogomips: 43212
    arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
    cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
    ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle
    ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
    nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
    pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
  Type: l1tf
    STIBP: disabled, RSB filling
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT disabled
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Micro-Star MSI
    driver: i915 v: kernel ports: active: HDMI-A-2 empty: HDMI-A-3
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
    driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: none empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:73bf class-ID: 0300
  Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 1-14:7 chip-ID: 0c45:63ab class-ID: 0102 serial: <filter>
  Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
    compositor: gnome-shell driver: X: loaded: radeon unloaded: modesetting
    alternate: fbdev,vesa gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-2 model: Acer S222HQL serial: <filter> built: 2011
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  OpenGL: renderer: AMD Radeon RX 6800 (SIENNA_CICHLID DRM 3.40.0
    5.10.105-1-MANJARO LLVM 13.0.1)
    v: 4.6 Mesa 21.3.7 direct render: Yes
  Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
    class-ID: 0403
  Device-2: AMD Navi 21 HDMI Audio [Radeon RX 6800/6800 XT / 6900 XT]
    bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
  Device-3: Plantronics Plantronics BT600 type: USB
    driver: plantronics,snd-usb-audio,usbhid bus-ID: 1-10:5 chip-ID: 047f:02f7
    class-ID: 0300 serial: <filter>
  Device-4: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
  Device-5: Holtek HT82A834R Audio MCU type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-8.4:8 chip-ID: 04d9:2834
    class-ID: 0300
  Sound Server-1: ALSA v: k5.10.105-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
    v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  Device-2: Microsoft Xbox 360 Wireless Adapter type: USB driver: xpad
    bus-ID: 1-1:2 chip-ID: 045e:0719 class-ID: ff00 serial: <filter>
  IF-ID-1: br-1125090fbab4 state: down mac: <filter>
  IF-ID-2: br-194df280c5a4 state: down mac: <filter>
  IF-ID-3: br-70a7ea3b42c1 state: down mac: <filter>
  IF-ID-4: br-c8c098874c9b state: down mac: <filter>
  IF-ID-5: br-e3c1c965a357 state: down mac: <filter>
  IF-ID-6: br-f45983ae15f1 state: down mac: <filter>
  IF-ID-7: br-f8e2a9abf42c state: down mac: <filter>
  IF-ID-8: docker0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
  IP v6: <filter> scope: link
  IF-ID-9: moduleworks state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> type: noprefixroute scope: global
  IF-ID-10: vethb43e773 state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Local Storage: total: 2.04 TiB used: 1.15 TiB (56.2%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    rev: 111110WD temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDHII240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 00RL scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1SB10C
    type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH10LS30 rev: 1.01
    dev-links: cdrom
  Features: speed: 40 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 914.16 GiB size: 898.81 GiB (98.32%)
    used: 729.85 GiB (81.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 45146617-5296-480c-9f18-8a4d5f9a1fa7
    used: 25.6 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: DC00-6178
  ID-3: /mnt/8d2954fc-ff7f-41e1-9784-945a947b25b0 raw-size: 724.37 GiB
    size: 712 GiB (98.29%) used: 443.18 GiB (62.2%) fs: ext4 dev: /dev/sdb1
    maj-min: 8:17 label: Festplatte Neu
    uuid: 8d2954fc-ff7f-41e1-9784-945a947b25b0
  ID-1: swap-1 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: 6389b853-0b03-4ad3-a7c6-72bc181ca603
  ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/sda2 maj-min: 8:2 size: 223.55 GiB fs: ntfs label: N/A
    uuid: 00461D84461D7B9A
  ID-3: /dev/sdb2 maj-min: 8:18 size: 207.14 GiB fs: ext4 label: N/A
    uuid: fa740ffa-2ea1-4de6-b4c4-0b2a44767d6b
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:2 info: Microsoft Xbox 360 Wireless Adapter type: WiFi
    driver: xpad interfaces: 8 rev: 2.0 speed: 12 Mb/s power: 260mA
  Device-2: 1-7:3 info: ROCCAT Kone Pure Mouse type: Mouse,Keyboard
    driver: konepure,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 200mA
    chip-ID: 1e7d:2dbe class-ID: 0300
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-8.3:6 info: Solid Year Thermaltake MEKA G-Unit Gaming Keyboard
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 060b:5253 class-ID: 0300
  Device-2: 1-8.4:8 info: Holtek HT82A834R Audio MCU type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 500mA chip-ID: 04d9:2834 class-ID: 0300
  Device-3: 1-10:5 info: Plantronics Plantronics BT600 type: Audio,HID
    driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 047f:02f7 class-ID: 0300
    serial: <filter>
  Device-4: 1-14:7 info: Microdia USB 2.0 Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:63ab class-ID: 0102 serial: <filter>
  Hub-3: 2-0:1 info: Super-speed hub ports: 10 rev: 3.0 speed: 5 Gb/s
  Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Device-1: 4-2:2
    info: Transcend Information microSD/SD/CF UHS-II Card Reader [RDF8 RDF9]
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 3.0
    speed: 5 Gb/s power: 800mA chip-ID: 8564:4000 class-ID: 0806
    serial: <filter>
  System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 33.0 C
    mem: 32.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 291 Uptime: 7m wakeups: 0 Init: systemd v: 250 tool: systemctl
  Compilers: gcc: 11.2.0 alt: 9 clang: 13.0.1 Packages: 2374 pacman: 2366
  lib: 566 flatpak: 8 Shell: Zsh v: 5.8.1 running-in: gnome-terminal
  inxi: 3.3.14
And here the output of xrandr
~ ❯ xrandr
Screen 0: minimum 16 x 16, current 1920 x 1080, maximum 32767 x 32767
XWAYLAND0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 480mm x 270mm
   1920x1080     59.96*+
   1440x1080     59.99
   1400x1050     59.98
   1280x1024     59.89
   1280x960      59.94
   1152x864      59.96
   1024x768      59.92
   800x600       59.86
   640x480       59.38
   320x240       59.52
   1680x1050     59.95
   1440x900      59.89
   1280x800      59.81
   720x480       59.71
   640x400       59.95
   320x200       58.96
   1600x900      59.95
   1368x768      59.88
   1280x720      59.86
   1024x576      59.90
   864x486       59.92
   720x400       59.55
   640x350       59.77
And here a few lines of the dmesg logs
[  493.261964] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  493.430745] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  493.430807] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  493.631405] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  493.830901] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  493.830962] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  494.030805] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  494.230952] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  494.231014] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  494.427772] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  494.623868] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  494.623929] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  494.820170] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  494.878148] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  494.970722] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  495.020209] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  495.020270] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  495.217593] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  495.414368] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  495.414428] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  495.611400] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  495.664245] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  495.714343] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  495.726484] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  495.939108] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  495.939175] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  496.136906] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  496.200597] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  496.341054] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  496.341114] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  496.537304] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  496.736503] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  496.736564] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  496.933158] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.130347] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.130408] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  497.328594] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.395245] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  497.526836] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.526897] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  497.562245] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  497.587157] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  497.729905] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.933885] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  497.933949] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  498.132222] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  498.324069] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  498.331992] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  498.332054] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  498.529350] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  498.585303] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  498.727905] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  498.727965] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  498.924813] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.122512] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.122573] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  499.320126] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.484889] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  499.501927] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  499.523167] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.523229] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  499.724669] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.922967] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  499.923029] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  500.038760] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  500.124325] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  500.228358] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  500.326230] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  500.326300] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  500.528449] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  500.729891] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  500.729953] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  500.930621] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.042921] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  501.068874] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  501.134438] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.134503] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  501.335011] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.531216] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.531277] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  501.728410] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.924386] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  501.924448] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  502.119051] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  502.122165] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  502.320039] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  502.320098] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  502.363429] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  502.519773] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  502.721449] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  502.721511] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  502.921390] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.120610] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.120672] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  503.227864] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  503.261780] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  503.319702] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.518096] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.518180] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  503.720664] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.921219] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  503.921286] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  504.034892] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  504.120367] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  504.128261] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  504.326763] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  504.326827] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  504.527680] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  504.727968] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  504.728033] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  504.929270] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.128019] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.128080] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  505.325102] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.355676] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  505.394874] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  505.527379] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.527441] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  505.727437] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.928633] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  505.928694] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  506.103856] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  506.126778] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  506.137062] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  506.328387] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  506.328451] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  506.527393] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  506.726529] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  506.726592] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  506.927485] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.124591] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.124653] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  507.322038] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.524188] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.524248] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  507.561882] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  507.586793] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  507.727639] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.926882] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  507.926945] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  508.035886] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  508.053163] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  508.125246] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  508.321834] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  508.321900] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  508.522315] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  508.721802] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  508.721864] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  508.919565] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.054407] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  509.119183] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.119243] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  509.316169] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.515020] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.515079] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  509.713970] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.721818] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  509.911443] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  509.911504] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  510.110060] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  510.128236] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  510.152133] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  510.307918] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  510.307978] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  510.506030] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  510.709411] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  510.709472] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  510.907245] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.113701] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.113760] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  511.118215] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  511.135457] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  511.313718] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.509903] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.509965] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  511.707975] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.910482] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  511.910544] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  512.109113] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  512.306201] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  512.306260] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  512.503980] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  512.535039] i915 0000:00:02.0: cannot be used for peer-to-peer DMA as the client and provider (0000:03:00.0) do not share an upstream bridge or whitelisted host bridge
[  512.704309] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  512.704370] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  512.900414] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  513.096487] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  513.096546] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
[  513.295308] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  513.494622] [drm:dc_dmub_srv_cmd_queue [amdgpu]] *ERROR* Error waiting for DMUB idle: status=3
[  513.494682] [drm:transmitter_control_v1_6 [amdgpu]] *ERROR* Error queuing DMUB command: status=2
I don’t think the xorg log will be relevant, since i am using Wayland. Please tell me if i can do anything else.
I could really need some help, since I would like to use my system tomorrow in home office.
If somebody has an idea, i would be happy to try it out.
I “fixed” this by backing everything up and manually reinstalling Manjaro…
Not a very nice solution and involved a lot of work, but during that i could finally do the switch to KDE.
The driver is not activated. there are a lot of how-to’s to activate the system. reason is that you also have a integrated intel graphics. search for “optimus/prime amd” and “amd gpu gnome”
That information came a bit too late, but thank you anyway. Didn’t notice it in the logs.
