No brightness control on NVIDIA (HP-Omen)
I’m running Manjaro KDE Plasma on an HP Omen notebook.
I did a fresh install and brightness control doesn’t work. Tried the other thread that offered a workaround, but couldn’t get it to work. I’m stuck at i think 50% brightness, which make my notebook screen really hard to use.
sudo mhwd -li
> Installed PCI configs:
    video-nvidia-470xx            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
  Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=ad930e0c-7e47-47e7-b8b0-b8a5c486e77e rw quiet splash
    video.use_native_backlight=1
    nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: HP product: OMEN by HP Laptop 15-ce0xx v: N/A
  Mobo: HP model: 8390 v: 40.28 serial: <superuser required>
    UEFI: American Megatrends v: F.19 date: 04/18/2019
  ID-1: BAT0 charge: 58.2 Wh (100.0%) condition: 58.2/58.2 Wh (100.0%)
    volts: 17.4 min: 15.4 model: HP Primary type: Li-ion serial: N/A
    status: Full
  RAM: total: 11.64 GiB used: 2.2 GiB (18.9%)
  RAM Report:
  Info: model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake
    family: 6 model-id: 0x9E (158) stepping: 9 microcode: 0xEA
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 3100 min/max: 800/3500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3100 2: 3100 3: 3100 4: 3100 bogomips: 20004
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
    cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c
    flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify
    ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear
    mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme x2apic
  Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: NVIDIA GP106BM [GeForce GTX 1060 Mobile 6GB]
    vendor: Hewlett-Packard driver: nvidia v: 470.86
    alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1c60
    class-ID: 0300
  Device-2: Realtek HP Wide Vision FHD Camera type: USB driver: uvcvideo
    bus-ID: 1-6:4 chip-ID: 0bda:58e6 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: nvidia resolution: <missing: xdpyinfo>
  Device-1: Intel CM238 HD Audio vendor: Hewlett-Packard driver: snd_hda_intel
    v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GP106 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f1
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
  Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
    vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
    port: d000 bus-ID: 3b:00.0 chip-ID: 10ec:b822 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  IF-ID-1: enp0s20f0u1 state: unknown speed: -1 duplex: half mac: <filter>
  Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
    v: 0.8 bus-ID: 1-7:5 chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 465.76 GiB used: 13.26 GiB (2.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
    type: SSD serial: <filter> rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 452.66 GiB size: 444.48 GiB (98.19%)
    used: 13.26 GiB (3.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: ad930e0c-7e47-47e7-b8b0-b8a5c486e77e
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 6C77-FC1D
  ID-1: swap-1 type: partition size: 12.8 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: b0f639fc-f313-45c5-88df-e023b81cc40a
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-1:6 info: Xiaomi Mi/Redmi series (RNDIS) type: CDC-Data
    driver: rndis_host interfaces: 2 rev: 2.1 speed: 480 Mb/s power: 500mA
    chip-ID: 2717:ff80 class-ID: 0a00 serial: <filter>
  Device-2: 1-3:3 info: Logitech G403 Prodigy Gaming Mouse type: Mouse,HID
    power: 300mA chip-ID: 046d:c083 class-ID: 0300 serial: <filter>
  Device-3: 1-6:4 info: Realtek HP Wide Vision FHD Camera type: Video
    driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-4: 1-7:5 info: Realtek Realtek Bluetooth 4.2 Adapter
    type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s
    power: 500mA chip-ID: 0bda:b00b class-ID: e001 serial: <filter>
  Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 70.0 C pch: 54.0 C mobo: N/A gpu: nvidia
    temp: 63 C
  Processes: 245 Uptime: 8m wakeups: 1 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: N/A Packages: pacman: 1094 lib: 318 Shell: Zsh v: 5.8
  default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
lspci -v
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
        DeviceName: Onboard - Other
        Subsystem: Hewlett-Packard Company Device 8390
        Flags: bus master, fast devsel, latency 0
        Capabilities: <access denied>
        Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 121
        Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
        I/O behind bridge: 0000e000-0000efff [size=4K]
        Memory behind bridge: db000000-dc0fffff [size=17M]
        Prefetchable memory behind bridge: 00000000b0000000-00000000c1ffffff [size=288M]
        Kernel driver in use: pcieport
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 05)
        Flags: fast devsel, IRQ 16
        Memory at dc320000 (64-bit, non-prefetchable) [size=32K]
        Kernel driver in use: proc_thermal
        Kernel modules: processor_thermal_device_pci_legacy
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31) (prog-if 30 [XHCI])
        Flags: bus master, medium devsel, latency 0, IRQ 127
        Memory at dc310000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: xhci_hcd
        Kernel modules: xhci_pci
00:14.2 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Thermal Subsystem (rev 31)
        Flags: fast devsel, IRQ 18
        Memory at dc337000 (64-bit, non-prefetchable) [size=4K]
        Kernel driver in use: intel_pch_thermal
        Kernel modules: intel_pch_thermal
00:15.0 Signal processing controller: Intel Corporation 100 Series/C230 Series Chipset Family Serial IO I2C Controller #0 (rev 31)
        Flags: bus master, fast devsel, latency 0, IRQ 16
        Memory at dc336000 (64-bit, non-prefetchable) [size=4K]
        Kernel driver in use: intel-lpss
        Kernel modules: intel_lpss_pci
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
        Flags: bus master, fast devsel, latency 0, IRQ 128
        Memory at dc335000 (64-bit, non-prefetchable) [size=4K]
        Kernel driver in use: mei_me
        Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation HM170/QM170 Chipset SATA Controller [AHCI Mode] (rev 31) (prog-if 01 [AHCI 1.0])
        DeviceName: Onboard - SATA
        Flags: bus master, 66MHz, medium devsel, latency 0, IRQ 125
        Memory at dc330000 (32-bit, non-prefetchable) [size=8K]
        Memory at dc334000 (32-bit, non-prefetchable) [size=256]
        I/O ports at f050 [size=8]
        I/O ports at f040 [size=4]
        I/O ports at f020 [size=32]
        Memory at dc333000 (32-bit, non-prefetchable) [size=2K]
        Kernel driver in use: ahci
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (rev f1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 122
        Bus: primary=00, secondary=02, subordinate=3a, sec-latency=0
        I/O behind bridge: 00002000-00002fff [size=4K]
        Memory behind bridge: c4000000-da0fffff [size=353M]
        Prefetchable memory behind bridge: 0000000080000000-00000000a1ffffff [size=544M]
00:1c.5 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #6 (rev f1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 123
        Bus: primary=00, secondary=3b, subordinate=3b, sec-latency=0
        I/O behind bridge: 0000d000-0000dfff [size=4K]
        Memory behind bridge: dc200000-dc2fffff [size=1M]
        Prefetchable memory behind bridge: [disabled]
00:1c.6 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #7 (rev f1) (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 124
        Bus: primary=00, secondary=3c, subordinate=3c, sec-latency=0
        I/O behind bridge: [disabled]
        Memory behind bridge: dc100000-dc1fffff [size=1M]
00:1f.0 ISA bridge: Intel Corporation HM175 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
        Flags: fast devsel
        Memory at dc32c000 (32-bit, non-prefetchable) [disabled] [size=16K]
00:1f.3 Audio device: Intel Corporation CM238 HD Audio Controller (rev 31) (prog-if 80)
        DeviceName: Onboard - Sound
        Flags: bus master, fast devsel, latency 32, IRQ 129
        Memory at dc328000 (64-bit, non-prefetchable) [size=16K]
        Memory at dc300000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
        Flags: medium devsel, IRQ 16
        Memory at dc332000 (64-bit, non-prefetchable) [size=256]
        I/O ports at f000 [size=32]
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GP106BM [GeForce GTX 1060 Mobile 6GB] (rev a1) (prog-if 00 [VGA controller])
        DeviceName: NVIDIA GeForce GTX 1060
        Subsystem: Hewlett-Packard Company GeForce GTX 1060 Max-Q 6GB
        Flags: bus master, fast devsel, latency 0, IRQ 131
        Memory at db000000 (32-bit, non-prefetchable) [size=16M]
        Memory at b0000000 (64-bit, prefetchable) [size=256M]
        Memory at c0000000 (64-bit, prefetchable) [size=32M]
        I/O ports at e000 [size=128]
        Expansion ROM at dc000000 [virtual] [disabled] [size=512K]
        Kernel driver in use: nvidia
        Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1)
        Flags: bus master, fast devsel, latency 0, IRQ 17
        Memory at dc080000 (32-bit, non-prefetchable) [size=16K]
3b:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822BE 802.11a/b/g/n/ac WiFi adapter
        DeviceName: Realtek RTL8822BE 802.11 ac 2x2 WiFi + BT 4.2 Combo Adapter (MU-MIMO supported)
        Subsystem: Hewlett-Packard Company Realtek RTL8822BE 802.11ac 2 × 2 Wi-Fi + Bluetooth 4.2 Combo Adapter (MU-MIMO supported)
        Flags: bus master, fast devsel, latency 0, IRQ 130
        I/O ports at d000 [size=256]
        Memory at dc200000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: rtw_8822be
        Kernel modules: rtw88_8822be
3c:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS522A PCI Express Card Reader (rev 01)
        DeviceName: Realtek PCIE CardReader
        Flags: bus master, fast devsel, latency 0, IRQ 126
        Memory at dc100000 (32-bit, non-prefetchable) [size=4K]
        Kernel driver in use: rtsx_pci
        Kernel modules: rtsx_pci
sudo nvim /usr/share/X11/xorg.conf.d/10-amdgpu-nvidia-drm-outputclass.conf
Have this:
Section "OutputClass"
    Identifier "nvidia"
    MatchDriver "nvidia-drm"
    Driver "nvidia"
    Option "RegistryDwords" "EnableBrightnessControl=1"
    ModulePath "/usr/lib/nvidia/xorg"
    ModulePath "/usr/lib/xorg/modules"
sudo nvim /etc/default/grub
Have this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video.use_native_backlight=1"
GRUB_CMDLINE_LINUX="nvidia.NVreg_RegistryDwords=EnableBrightnessControl=1"
Tried following different guides showed in here https://forum.manjaro.org/t/cant-adjust-screen-brightness-lenovo-laptop-nvidia-xfce/28771/17
I am finding a similar issue after an update. My screen brightness control doesn’t function either. For me it is quite dim, and severely bothering my eyes. In the interests of comparision, I’ll post my version of the same specs. (Much of it is greek to me).
sudo mhwd -li
video-hybrid-amd-nvidia-prime            2021.12.18               false            PCI
  Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=68377ab6-3b49-48e8-95e6-b73d9d553f8f rw quiet acpi_osi=Linux
    acpi_backlight=vendor quiet acpi_osi=Linux acpi_backlight=vendor
  Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IU_TUF506IU
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: FA506IU v: 1.0 serial: <superuser required>
    UEFI: American Megatrends v: FA506IU.315 date: 01/29/2021
  ID-1: BAT1 charge: 39.1 Wh (100.0%) condition: 39.1/48.1 Wh (81.4%)
    volts: 12.7 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: Full
  Device-1: sony_controller_battery_dc:0c:2d:4c:b2:ba model: N/A serial: N/A
    charge: N/A status: Charging
  RAM: total: 15.06 GiB used: 4.26 GiB (28.3%)
  RAM Report:
  Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600104
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1396 high: 1397 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
    3: 1397 4: 1397 5: 1397 6: 1397 7: 1397 8: 1397 9: 1397 10: 1397 11: 1397
    12: 1397 13: 1397 14: 1396 15: 1397 16: 1397 bogomips: 92666
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
    pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse
    sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
  Device-1: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
    driver: nvidia v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
    chip-ID: 10de:2191 class-ID: 0300
  Device-2: AMD Renoir vendor: ASUSTeK driver: amdgpu v: kernel
    bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
  Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
    bus-ID: 3-4:3 chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau
    alternate: fbdev,nv,vesa display-ID: :0 screens: 1
    s-diag: 582mm (22.9")
  Monitor-1: eDP res: 1920x1080 hz: 144 dpi: 142 size: 344x194mm (13.5x7.6")
    diag: 395mm (15.5")
  OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.19-2-MANJARO LLVM 13.0.0)
    v: 4.6 Mesa 21.2.5 direct render: Yes
  Device-1: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
    class-ID: 0403
  Device-2: AMD vendor: ASUSTeK driver: snd_hda_intel v: kernel
    bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
    chip-ID: 1022:15e2 class-ID: 0480
  Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-5: Sony DualShock 4 [CUH-ZCT2x] type: USB
    driver: snd-usb-audio,sony,usbhid bus-ID: 3-2:2 chip-ID: 054c:09cc
    class-ID: 0300
  Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
    vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:c822 class-ID: 0280
  Device-1: Lite-On Bluetooth Radio type: USB driver: btusb v: 0.8
    bus-ID: 5-1:2 chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
  Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
  Local Storage: total: 476.94 GiB used: 282.67 GiB (59.3%)
    model: PC SN530 SDBPNPZ-512G-1002 size: 476.94 GiB block-size:
    physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
    serial: <filter> rev: 21106000 temp: 33.9 C scheme: GPT
  ID-1: / raw-size: 97.66 GiB size: 95.56 GiB (97.86%) used: 26.14 GiB (27.4%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: System
    uuid: 68377ab6-3b49-48e8-95e6-b73d9d553f8f
    used: 7.6 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
    uuid: 8AE0-BDE8
  ID-3: /home raw-size: 375.81 GiB size: 368.85 GiB (98.15%)
    used: 256.53 GiB (69.5%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
    label: Home uuid: 6545cb97-2b18-4366-8f77-2008234740f9
  ID-1: swap-1 type: partition size: 2.97 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 0523bc22-709a-4a79-a561-aa3e62dc2a3b
  Hub-1: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Sony DualShock 4 [CUH-ZCT2x] type: Audio,HID
    driver: snd-usb-audio,sony,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 054c:09cc class-ID: 0300
  Device-2: 3-4:3 info: IMC Networks USB2.0 HD UVC WebCam type: Video
  Hub-2: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  Hub-3: 5-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:2 info: Lite-On Bluetooth Radio type: Bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA
  Device-2: 5-2:3 info: Microsoft Nano Transceiver v1.0 for Bluetooth
    type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
  Hub-4: 6-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 41.4 C mobo: 41.0 C gpu: amdgpu temp: 36.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 390 Uptime: 18m wakeups: 2 Init: systemd v: 249 tool: systemctl
  Compilers: gcc: 11.1.0 Packages: apt: 0 pacman: 1966 lib: 478 flatpak: 0
  Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
tim@asus:~$ sudo mhwd -li
[sudo] password for tim:
tim@asus:~$ inxi --admin --verbosity=7 --filter --no-host --width
    status: Full
  RAM: total: 15.06 GiB used: 4.46 GiB (29.6%)
  RAM Report:
    desc: 2x4 MiB
  Speed (MHz): avg: 1473 high: 2617 min/max: 1400/2900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2617 2: 1397
    12: 1397 13: 1396 14: 1397 15: 1397 16: 1397 bogomips: 92666
    diag: 395mm (15.5")
    class-ID: 0403
    class-ID: 0300
  Local Storage: total: 476.94 GiB used: 282.68 GiB (59.3%)
    uuid: 8AE0-BDE8
  System Temperatures: cpu: 38.4 C mobo: 38.0 C gpu: amdgpu temp: 33.0 C
  Fan Speeds (RPM): cpu: 2100
  Processes: 389 Uptime: 28m wakeups: 2 Init: systemd v: 249 tool: systemctl
lspci -v
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
        Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir Root Complex
        Flags: fast devsel
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
        Subsystem: Advanced Micro Devices, Inc. [AMD] Renoir IOMMU
        Flags: bus master, fast devsel, latency 0, IRQ -2147483648
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
        Flags: fast devsel, IOMMU group 0
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 26, IOMMU group 1
        I/O behind bridge: 0000f000-0000ffff [size=4K]
        Memory behind bridge: fb000000-fc0fffff [size=17M]
        Prefetchable memory behind bridge: 00000000b0000000-00000000c20fffff [size=289M]
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
        Flags: fast devsel, IOMMU group 2
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 27, IOMMU group 3
        Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
        Memory behind bridge: fc900000-fc9fffff [size=1M]
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 28, IOMMU group 4
        Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
        Memory behind bridge: fc800000-fc8fffff [size=1M]
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 29, IOMMU group 5
        Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
        Memory behind bridge: fc700000-fc7fffff [size=1M]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
        Flags: fast devsel, IOMMU group 6
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 30, IOMMU group 6
        Bus: primary=00, secondary=05, subordinate=05, sec-latency=0
        I/O behind bridge: 0000c000-0000cfff [size=4K]
        Memory behind bridge: fc200000-fc5fffff [size=4M]
        Prefetchable memory behind bridge: 00000000d0000000-00000000e01fffff [size=258M]
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus (prog-if 00 [Normal decode])
        Flags: bus master, fast devsel, latency 0, IRQ 31, IOMMU group 6
        Bus: primary=00, secondary=06, subordinate=06, sec-latency=0
        Memory behind bridge: fc600000-fc6fffff [size=1M]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
        Subsystem: ASUSTeK Computer Inc. Device 1e21
        Flags: 66MHz, medium devsel, IOMMU group 7
        Kernel driver in use: piix4_smbus
        Kernel modules: i2c_piix4, sp5100_tco
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
        Flags: bus master, 66MHz, medium devsel, latency 0, IOMMU group 7
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
        Flags: fast devsel, IOMMU group 8
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
        Kernel driver in use: k10temp
        Kernel modules: k10temp
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
01:00.0 VGA compatible controller: NVIDIA Corporation TU116M [GeForce GTX 1660 Ti Mobile] (rev a1) (prog-if 00 [VGA controller])
        Subsystem: ASUSTeK Computer Inc. Device 16cf
        Flags: bus master, fast devsel, latency 0, IRQ 85, IOMMU group 9
        Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
        I/O ports at f000 [size=128]
        Expansion ROM at fc000000 [virtual] [disabled] [size=512K]
01:00.1 Audio device: NVIDIA Corporation TU116 High Definition Audio Controller (rev a1)
        Flags: bus master, fast devsel, latency 0, IRQ 78, IOMMU group 9
        Memory at fc080000 (32-bit, non-prefetchable) [size=16K]
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
        Subsystem: ASUSTeK Computer Inc. Device 208f
        Flags: bus master, fast devsel, latency 0, IRQ 75, IOMMU group 10
        I/O ports at e000 [size=256]
        Memory at fc904000 (64-bit, non-prefetchable) [size=4K]
        Memory at fc900000 (64-bit, non-prefetchable) [size=16K]
        Kernel driver in use: r8169
        Kernel modules: r8169
03:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8822CE 802.11ac PCIe Wireless Network Adapter
        Subsystem: Lite-On Communications Inc Device 0810
        Flags: bus master, fast devsel, latency 0, IRQ 55, IOMMU group 11
        Memory at fc800000 (64-bit, non-prefetchable) [size=64K]
        Kernel driver in use: rtw_8822ce
        Kernel modules: rtw88_8822ce
04:00.0 Non-Volatile memory controller: Sandisk Corp WD Blue SN550 NVMe SSD (rev 01) (prog-if 02 [NVM Express])
        Subsystem: Sandisk Corp WD Blue SN550 NVMe SSD
        Flags: bus master, fast devsel, latency 0, IRQ 33, NUMA node 0, IOMMU group 12
        Memory at fc700000 (64-bit, non-prefetchable) [size=16K]
        Memory at fc704000 (64-bit, non-prefetchable) [size=256]
        Kernel driver in use: nvme
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c6) (prog-if 00 [VGA controller])
        Flags: bus master, fast devsel, latency 0, IRQ 65, IOMMU group 6
        Memory at d0000000 (64-bit, prefetchable) [size=256M]
        Memory at e0000000 (64-bit, prefetchable) [size=2M]
        I/O ports at c000 [size=256]
        Memory at fc500000 (32-bit, non-prefetchable) [size=512K]
        Kernel driver in use: amdgpu
        Kernel modules: amdgpu
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device 1637
        Flags: bus master, fast devsel, latency 0, IRQ 81, IOMMU group 6
        Memory at fc5c8000 (32-bit, non-prefetchable) [size=16K]
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
        Subsystem: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
        Flags: bus master, fast devsel, latency 0, IRQ 75, IOMMU group 6
        Memory at fc400000 (32-bit, non-prefetchable) [size=1M]
        Memory at fc5cc000 (32-bit, non-prefetchable) [size=8K]
        Kernel driver in use: ccp
        Kernel modules: ccp
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
        Subsystem: ASUSTeK Computer Inc. Device 201f
        Flags: bus master, fast devsel, latency 0, IRQ 56, IOMMU group 6
        Memory at fc300000 (64-bit, non-prefetchable) [size=1M]
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir USB 3.1 (prog-if 30 [XHCI])
        Memory at fc200000 (64-bit, non-prefetchable) [size=1M]
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor (rev 01)
        Subsystem: Device 1e21:1043
        Flags: fast devsel, IRQ 76, IOMMU group 6
        Memory at fc580000 (32-bit, non-prefetchable) [size=256K]
        Kernel modules: snd_pci_acp3x, snd_rn_pci_acp3x
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) HD Audio Controller
        DeviceName: HD Audio Controller
        Flags: bus master, fast devsel, latency 0, IRQ 82, IOMMU group 6
        Memory at fc5c0000 (32-bit, non-prefetchable) [size=32K]
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
        Flags: bus master, fast devsel, latency 0, IRQ 35, IOMMU group 6
        Memory at fc601000 (32-bit, non-prefetchable) [size=2K]
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81) (prog-if 01 [AHCI 1.0])
        Flags: bus master, fast devsel, latency 0, IRQ 37, IOMMU group 6
        Memory at fc600000 (32-bit, non-prefetchable) [size=2K]
Mine does not have the “ENABLEBrightnessControl=1”. So at least we know that setting isn’t directly determinant (despite it’s seeming relevance).
Section "ServerLayout"
    Identifier "layout"
    Option "AllowNVIDIAGPUScreens"
EndSection
    Identifier "AMDgpu"
    MatchDriver "amdgpu"
    Driver "amdgpu"
EndSection
    Identifier "nvidia"
    Driver "nvidia"
    Option "AllowEmptyInitialConfiguration"
EndSection
/etc/default/grub
Here, my entries were different. So to to start with, I tried commenting them out, with no effect. Here they are, disabled.
#GRUB_CMDLINE_LINUX_DEFAULT="quiet acpi_osi=Linux acpi_backlight=vendor"
#GRUB_CMDLINE_LINUX="quiet acpi_osi=Linux acpi_backlight=vendor"
I am now going to copy and paste the other Grub commands into my grub file and reboot.
Changing my grub config file to include the following lines had no effect after reboot:
I don’t have the solution to getting brightness control working for you, but I too am unable to change my screen brightness. On occasion, my screen is less bright than I would like, too. When that happens, I have discovered that simply putting the laptop to sleep and then waking it back up will restore it to full brightness. A reboot does not change the brightness level when this happens, just the suspend.
Just posting this to see if it helps you if you are still stuck in “dim” mode.
Maybe you can refer to this article:
It was fine when I used the 5.15.2-2 kernel, but since the upgrade last week……
Dont know whether any of what is here might help but thought I would share it…
https://wiki.archlinux.org/title/Backlight
https://bbs.archlinux.org/viewtopic.php?id=230932
Regards
Yes. Thanks. That does restore some (or all) brightness. I can’t tell what level it is because the brightness slider isn’t effecting a change in light level. But it is brighter.
Hello, as someone who has dealt with a similar issue on an HP Omen myself, I may be able to help a bit.
You haven’t stated your issue quite clearly, but if you have the same one I used to have, then I can be of help. My brightness keys work and brightness change bar shows on screen, it just didn’t do anything to the actual backlight of the screen. This seems to be a problem with nvidia drivers. The proprietary driver version up to 465.24.02 used to work well, but after that on some laptops the brightess controls just stopped working. Luckily there was a version 495.44 around a month or two ago that fixed this for most laptops: NVIDIA DRIVERS Linux x64 (AMD64/EM64T) Display Driver
Here’s some useful info:
  1. An active nvidia forum on this issue:
    Laptop backlight control regression with 465.24.02 - #34 by danito8905 - Linux - NVIDIA Developer Forums
  2. A guide on how to manually install nvidia drivers from their website
    https://linuxconfig.org/how-to-install-the-nvidia-drivers-on-manjaro-linux
P.S. I know that manual driver installation may look a bit scary as you won’t have access to a desktop environment and may be frowned upon by some people who love their drivers managed by mhwd or pacman, but it did fix the issue for me and some people on that forum.
Feel free to contact me if you need more info. I hope I was of help!
