Tengo una inquietud, mira instalé manjaro en mi maquina una lenovo v110-14iap por cierto y todo anduvo bien borrando el disco completo con la partición por defecto.
Pero luego quise ir por lo recomendado e instalar nuevamente (en la misma maquina) pero con la partición manual y al reiniciar hace algo no sé qué con dhcp ( sale dhcp…) y luego de un tiempo de busqueda creo lanza un error PXE-E53:No boot filename received.
¿a qué se debe?
I moved this topic from Support to the language specific category, so native speakers can be of help.
Translation of his OP:
Hello everyone
I'm new to this world of forums.
I have a concern, look I installed manjaro on my machine a lenovo v110-14iap by the way and everything went well deleting the entire disk with the default partition.
But then I wanted to go for what was recommended and install again (on the same machine) but with the manual partition and when restarting it does something I don’t know what with dhcp (dhcp comes out…) and after a while of searching I think it throws an error PXE-E53 :No boot filename received.
for what is this?
Help others to help you better by:
Providing system info about your hardware by posting program output instead of describing your hardware.
Use new lines when a sentence ends, so it is better readable and followable by others.
If english is not your native language please see:
If you are unable to boot into your system to provide the needed info, then use a Live-ISO image to boot from a USB-Stick…
Some commands as mentioned in the articles above are:
The PXE error indicates that you are trying to boot via PXE over the network instead of your drive.
Please check the bootloader you use via the UEFI-Boot-menu.
El error de PXE indica que está intentando iniciar a través de PXE a través de la red en lugar de su unidad.
Verifique el cargador de arranque que usa a través del menú de arranque UEFI.
Cómo configuro bien?
Ayuda!
No puedo subir una foto de mi bios en la pestaña boot pero, el PXE aparece activado y si lo desactivo y arranco la pantalla se va a negro y luego me muestra el boot menú.
tengo el arranque configurado con manjaro de los primeros pero igual hace eso.
¿qué hago?
