No available connections
I’m having issues with getting any sort of wireless connection on my manjaro linux, I have realtek 802.11n wireless wifi adapter
Hello! Welcome to Manjaro!
Please see this so we can help you easier: How to provide good information
My bad for not giving good info, I am using an evoo laptop and I have linux510 kernel as the kernel for manjaro I also have windows 10 on the same laptop as I dual boot the operating systems, when I type, “inxi -Nazy” the wifi driver pops up but I cant use it without an ethernet connection
Please share what pops up
Device-1: Realtek 802.11n WLAN Adapter type: USB driver: btusb bus-ID: 1-4:3
(and the the chip id)
Please share THE FULL output of this command:
Please use code blocks for things you copy/paste from the terminal - it’s easy. Three back-tick marks ``` (shift plus the ~ button ) before and after what you paste.
root=UUID=9b7c831a-0770-48b4-be6d-15468503d5da rw quiet apparmor=1
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1
Type: Laptop System: EVOO Products LLC. product: EV-C-116-7 v: N/A
serial:
Mobo: EVOO model: EVOO serial: UEFI: EVOO Products LLC.
v: 0.5.0_P6S43M2E0F0L2B0T0P2G00A0U0D217_ENE date: 12/23/2020
ID-1: BAT0 charge: 37.0 Wh (100.0%) condition: 37.0/37.0 Wh (100.0%)
volts: 7.4 min: N/A model: Emdoor Li-ion Battery type: Li-ion
serial: status: Charging
RAM: total: 3.67 GiB used: 1.91 GiB (52.1%)
Info: Dual Core model: Intel Celeron N4000 bits: 64 type: MCP
arch: Goldmont Plus family: 6 model-id: 7A (122) stepping: 1 microcode: 36
cache: L2: 4 MiB bogomips: 4378
Speed: 838 MHz min/max: 800/2600 MHz Core speeds (MHz): 1: 838 2: 839
Flags: 3dnowprefetch acpi aes aperfmperf apic arat arch_capabilities
arch_perfmon art bts cat_l2 cdp_l2 clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est
flexpriority fpu fsgsbase fxsr ht ibpb ibrs ibrs_enhanced ida intel_pt
lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl
nx pae pat pbe pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti
pts rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep sha_ni smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vme vmx vnmi vpid x2apic
Device-1: Intel GeminiLake [UHD Graphics 600] vendor: nCipher Security
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0300
Device-2: Microdia Sonix USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-6:4 chip-ID: 0c45:6310 class-ID: 0e02 serial:
Display: x11 server: [X.Org](http://x.org/) 1.20.13 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 136 size: 256x144mm (10.1x5.7")
diag: 294mm (11.6")
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 21.2.3
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0403
Sound Server-1: ALSA v: k5.10.70-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Message: No device data found.
IF-ID-1: enp0s21f0u2 state: unknown speed: N/A duplex: N/A mac:
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 1-2:5 chip-ID: 04e8:6864
class-ID: 0a00 serial:
Device-2: Realtek 802.11n WLAN Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-4:3 chip-ID: 0bda:d723 class-ID: e001 serial:
Report: ID: hci0 rfk-id: 0 state: up address: bt-v: 2.1 lmp-v: 4.2
sub-v: 96f1 hci-v: 4.2 rev: 828a
Info: acl-mtu: 1021:8 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: slave accept
service-classes: rendering, capturing, object transfer, audio, telephony
Local Storage: total: 57.62 GiB used: 20.44 GiB (35.5%)
ID-1: /dev/mmcblk0 maj-min: 179:0 model: 58K721 size: 57.62 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: rev: 0x8
scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 33.77 GiB size: 32.94 GiB (97.55%) used: 20.41 GiB (62.0%)
fs: ext4 dev: /dev/mmcblk0p4 maj-min: 179:4 label: N/A
uuid: 9b7c831a-0770-48b4-be6d-15468503d5da
used: 25.6 MiB (8.5%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
label: NO_LABEL uuid: A8B2-64EA
ID-1: /dev/mmcblk0p2 maj-min: 179:2 size: 16 MiB fs: ext4 label: N/A
uuid: e3cb3baf-8011-49e4-9987-c727ed0a3621
ID-2: /dev/mmcblk0p3 maj-min: 179:3 size: 23.54 GiB fs: ntfs label: N/A
uuid: 54E88771E8874FE2
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-2:5
info: Samsung GT-I9070 (network tethering USB debugging enabled)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 04e8:6864 class-ID: 0a00
serial:
Device-2: 1-4:3 info: Realtek 802.11n WLAN Adapter type: Bluetooth
