No AUR package anymore in pamac
after latest updates i can’t find any aur package in pamacgui.
it was enabled and working.
Update the database manually.
Peek 2020-10-12 22-16
unfortunately it does’t works on any of my pc.
all of them are behind a transparent proxy.
pamac from cli is working correctly.
could be related with this:
Then, how did you setup your proxy variables?
https://wiki.archlinux.org/index.php/Proxy_server#Environment_variables
Your IP may have been rate limited.
Either way, what’s the result of:
pamac build <AUR program>
well, it was working till some days ago… in my knowledge, transparent proxy doesn’t need to be setted up in clients pc (that’s why called trasparent)
pamac from cli it’s working fine
