AUR Helper not working with proxy
Hey there!
I’m using manjaro with a proxy. When enabling the aur helper in Add/Remove Software, the AUR tab always just shows “No packages”. I set the http_proxy variables.
Thanks for your help,
felixoi
Pamac uses the system network - if your system works - e.g. internet browser using the proxy - then Pamac will work as well as it requires no special settings.
Try commandline
pamac search xyz
when found
pamac build xyz
I’m getting this error
  • (pamac:2786): WARNING **: 17:35:54.684: aur.vala:60: Error resolving “http”: Name or service not known
but I can use my browser and everything and also installing AUR packages using yay works…
Pinging @guinux as the main pamac developer.
