Hello, I have recently had to update my laptop to an MSI Prestige Evo 14 (w/ latest BIOS), which has an Intel Tiger Lake CPU, and using the latest KDE installation ISO, there is no audio output. The hardware is detected (i.e. no “Dummy Output”), but there is no sound. I have tried installing manjaro-pipewire as I’ve seen recommended, but that did not fix anything. I have looked at other posts in this forum but haven’t yet seen a solution. I am using the refind bootloader as well.
Here is the output if inxi -Fza
Kernel: 5.18.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: root=UUID=8d913465-a22b-4383-aefe-d3ccbc2ff054 rw quiet
apparmor=1 security=apparmor udev.log_priority=3 quiet
initrd=boot\initramfs-5.18-x86_64.img
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Micro-Star product: Prestige 14Evo A11M v: REV:1.0
Mobo: Micro-Star model: MS-14C4 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E14C4IMS.31B date: 04/25/2022
ID-1: BAT1 charge: 21.3 Wh (41.2%) condition: 51.7/52.4 Wh (98.5%)
volts: 11.2 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A
status: discharging
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 672 high: 1086 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 457 2: 1086 3: 421 4: 520
5: 478 6: 779 7: 906 8: 734 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x623d built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel Xe Graphics (TGL GT2) v: 4.6 Mesa 22.1.1
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.18.3-1-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.0 running: no
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF-ID-1: vpn0 state: down mac: N/A
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 118.19 GiB (24.8%)
model: MZVL2512HCJQ-00B00 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: GXA7301Q temp: 35.9 C scheme: GPT
ID-1: / raw-size: 195.57 GiB size: 191.44 GiB (97.89%)
used: 20.34 GiB (10.6%) fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%)
used: 33.8 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 238 Uptime: 48m wakeups: 8449 Memory: 15.34 GiB
used: 3.43 GiB (22.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1341
lib: 355 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.17
I have also tried making sure nothing is muted in alsamixer.
Perhaps someone is familiar with that is going on?
Here is some interesting output from journalctl -p3 -xb
░░ Subject: A start job for unit UNIT has failed
░░ Defined-By: systemd
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 24 and the job result is failed.
Jun 12 13:51:26 Gemini-L kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jun 12 13:51:30 Gemini-L bluetoothd[506]: Failed to set mode: Failed (0x03)
Jun 12 13:53:15 Gemini-L pipewire[935]: spa.alsa: 'hw:0,10': playback open failed: Device or resource busy
Jun 12 13:53:15 Gemini-L pipewire[935]: spa.audioadapter: params Spa:Enum:ParamId:EnumFormat: 0:0 (follower format) Device or resource busy
Jun 12 13:53:15 Gemini-L pipewire[935]: pw.node: (alsa_output.pci-0000_00_1f.3.pro-output-10-43) suspended -> error (Start error: Device or resource busy)
Jun 12 13:53:15 Gemini-L pipewire[935]: spa.alsa: 'hw:0,11': playback open failed: Device or resource busy
Jun 12 13:53:15 Gemini-L pipewire[935]: pw.node: (alsa_output.pci-0000_00_1f.3.pro-output-11-54) suspended -> error (Start error: Device or resource busy)
Jun 12 13:53:15 Gemini-L pipewire[935]: spa.alsa: 'hw:0,12': playback open failed: Device or resource busy
Jun 12 13:53:15 Gemini-L pipewire[935]: pw.node: (alsa_output.pci-0000_00_1f.3.pro-output-12-33) suspended -> error (Start error: Device or resource busy)
Jun 12 13:53:15 Gemini-L pipewire[935]: spa.alsa: 'hw:0,13': playback open failed: Device or resource busy
Jun 12 13:53:15 Gemini-L pipewire[935]: pw.node: (alsa_output.pci-0000_00_1f.3.pro-output-13-53) suspended -> error (Start error: Device or resource busy)
and for lspci -v | grep -i audio -A7
➜ lspci -v | grep -i audio -A7
00:1f.3 Multimedia audio controller: Intel Corporation Tiger Lake-LP Smart Sound Technology Audio Controller (rev 20)
DeviceName: Onboard - Sound
Subsystem: Micro-Star International Co., Ltd. [MSI] Device 12c5
Flags: bus master, fast devsel, latency 32, IRQ 171, IOMMU group 15
Memory at 603d188000 (64-bit, non-prefetchable) [size=16K]
Memory at 603d000000 (64-bit, non-prefetchable) [size=1M]
Capabilities: <access denied>
Kernel driver in use: snd_hda_intel
install sof firmware:
sudo pacman -S sof-firmware
reboot and test
Thank you for writing back. sof-firmware has been installed by default. I should also mention I’m using the 5.18 kernel (but the behavior was the same for 5.15 and 5.17)
so try with the 5.19 kernel… also try different profiles in system settings/audio
There is no difference in using the 5.19 rc1 kernel. The only audio profile available is Play HiFi quality music
post output from:
journalctl --boot=0 --priority=3 --no-pager
Jun 12 19:05:18 Gemini-L kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jun 12 19:05:18 Gemini-L kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
Jun 12 19:05:20 Gemini-L systemd[953]: Failed to start Update XDG user dir configuration.
Jun 12 19:05:22 Gemini-L kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jun 12 19:05:27 Gemini-L bluetoothd[943]: Failed to set mode: Failed (0x03)
nothing there
and output from:
systemctl --user status pipewire-pulse.service
systemctl --user status pipewire.service
● pipewire-pulse.service - PipeWire PulseAudio
Loaded: loaded (/usr/lib/systemd/user/pipewire-pulse.service; disabled; vendor preset: enabled)
Active: active (running) since Sun 2022-06-12 19:05:27 EDT; 13h ago
TriggeredBy: ● pipewire-pulse.socket
Main PID: 1342 (pipewire-pulse)
Tasks: 2 (limit: 18824)
Memory: 9.6M
CPU: 3.133s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire-pulse.service
└─1342 /usr/bin/pipewire-pulse
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:30 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:32 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:34 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:36 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:38 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:40 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:42 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:44 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:46 error:25 (Input/output error)
Jun 12 19:05:36 Gemini-L pipewire-pulse[1342]: mod.protocol-pulse: client 0x5587535dec50 [libcanberra]: ERROR command:18 (PLAY_SAMPLE) tag:48 error:25 (Input/output error)
● pipewire.service - PipeWire Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
TriggeredBy: ● pipewire.socket
Main PID: 1340 (pipewire)
Memory: 16.3M
CPU: 2.011s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
└─1340 /usr/bin/pipewire
Jun 12 19:05:27 Gemini-L systemd[1029]: Started PipeWire Multimedia Service.
Jun 12 19:05:27 Gemini-L pipewire[1340]: ALSA lib parser.c:1194:(parse_sequence) error: sequence command 'devdisall' is ignored
Olli
13 June 2022 13:09
11
please post the output of
pactl list sources
Olli:
pactl list sources
Source #42
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
Driver: PipeWire
Sample Specification: s24-32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,5:playback"
api.alsa.path = "hw:sofhdadsp,5"
api.alsa.open.ucm = "true"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "monitor"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = ""
alsa.id = "HDMI3 (*)"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "5"
alsa.card = "0"
alsa.card_name = "sof-hda-dsp"
alsa.long_card_name = "Micro_StarInternationalCo.Ltd.-Prestige14EvoA11M-REV1.0-MS_14C4"
alsa.driver_name = "snd_soc_skl_hda_dsp"
device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
device.profile.description = "HDMI / DisplayPort 3 Output"
card.profile.device = "0"
device.id = "39"
factory.name = "api.alsa.pcm.sink"
priority.driver = "664"
priority.session = "664"
media.class = "Audio/Sink"
node.nick = "sof-hda-dsp"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
device.icon_name = "audio-card"
device.bus = "pci"
device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "32"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "41"
object.serial = "42"
node.max-latency = "4096/48000"
Formats:
pcm
Source #43
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,4:playback"
api.alsa.path = "hw:sofhdadsp,4"
device.routes = "1"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI2 (*)"
alsa.device = "4"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
device.profile.description = "HDMI / DisplayPort 2 Output"
card.profile.device = "1"
device.id = "39"
priority.driver = "680"
priority.session = "680"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "42"
object.serial = "43"
Formats:
pcm
Source #44
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
Driver: PipeWire
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,3:playback"
api.alsa.path = "hw:sofhdadsp,3"
device.routes = "1"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDMI1 (*)"
alsa.device = "3"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
device.profile.description = "HDMI / DisplayPort 1 Output"
card.profile.device = "2"
device.id = "39"
priority.driver = "696"
priority.session = "696"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "43"
object.serial = "44"
Formats:
pcm
Source #45
State: SUSPENDED
Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp:playback"
api.alsa.path = "hw:sofhdadsp"
device.routes = "2"
device.api = "alsa"
alsa.name = ""
alsa.id = "HDA Analog (*)"
alsa.device = "0"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp: sink"
device.profile.description = "Speaker + Headphones"
card.profile.device = "3"
device.id = "39"
priority.driver = "744"
priority.session = "744"
node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "44"
object.serial = "45"
Formats:
pcm
Source #46
State: SUSPENDED
Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source
Description: Tiger Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone
Driver: PipeWire
Mute: no
balance 0.00
Monitor of Sink: n/a
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp:capture"
api.alsa.pcm.stream = "capture"
device.routes = "1"
device.api = "alsa"
device.class = "sound"
alsa.name = ""
alsa.device = "0"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp: source"
device.profile.description = "Headphones Stereo Microphone"
card.profile.device = "4"
device.id = "39"
factory.name = "api.alsa.pcm.source"
priority.driver = "1744"
priority.session = "1744"
media.class = "Audio/Source"
node.name = "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone"
device.bus = "pci"
factory.id = "18"
client.id = "32"
factory.mode = "split"
object.id = "45"
object.serial = "46"
Ports:
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, availability group: Mic, not available)
Active Port: [In] Mic2
Formats:
pcm
Source #47
State: SUSPENDED
Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
Description: Tiger Lake-LP Smart Sound Technology Audio Controller Digital Microphone
Driver: PipeWire
Mute: no
Volume: front-left: 48287 / 74% / -7.96 dB, front-right: 48287 / 74% / -7.96 dB
balance 0.00
Base Volume: 30419 / 46% / -20.00 dB
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:hw:sofhdadsp,6:capture"
api.alsa.path = "hw:sofhdadsp,6"
device.routes = "1"
device.api = "alsa"
alsa.name = ""
alsa.id = "DMIC (*)"
alsa.device = "6"
alsa.card = "0"
device.profile.name = "HiFi: hw:sofhdadsp,6: source"
device.profile.description = "Digital Microphone"
card.profile.device = "5"
device.id = "39"
priority.driver = "1648"
priority.session = "1648"
node.name = "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source"
device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Digital Microphone"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "46"
object.serial = "47"
Ports:
[In] Mic1: Digital Microphone (type: Mic, priority: 100, availability unknown)
Active Port: [In] Mic1
Formats:
pcm
Olli
13 June 2022 13:39
13
you can try to switch back to alsa instead of pipewire and check again
sudo pacman -Rdd pipewire-pulse
sudo pacman -S manjaro-pulse
you need to reboot after this
➜ systemctl --user status pulseaudio
● pulseaudio.service - Sound Service
Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
Active: active (running) since Mon 2022-06-13 09:40:59 EDT; 2min 38s ago
TriggeredBy: ● pulseaudio.socket
Main PID: 1170 (pulseaudio)
Tasks: 11 (limit: 18824)
Memory: 39.0M
CPU: 2.100s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
├─1170 /usr/bin/pulseaudio --daemonize=no --log-target=journal
└─1374 /usr/lib/pulse/gsettings-helper
Jun 13 09:40:57 Gemini-L systemd[1009]: Starting Sound Service...
Jun 13 09:40:59 Gemini-L pulseaudio[1170]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 13 09:40:59 Gemini-L systemd[1009]: Started Sound Service.
Jun 13 09:40:59 Gemini-L pulseaudio[1170]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Here is pactl list sources
Source #0
State: SUSPENDED
Driver: module-alsa-card.c
Sample Specification: s16le 2ch 48000Hz
Owner Module: 6
Mute: no
balance 0.00
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
alsa.card = "0"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a0c8"
device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
device.string = "0"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Formats:
pcm
Source #1
State: SUSPENDED
Owner Module: 6
Mute: no
balance 0.00
Properties:
device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Source #2
State: SUSPENDED
Owner Module: 6
Mute: no
balance 0.00
Properties:
device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Source #3
State: SUSPENDED
Owner Module: 6
Mute: no
balance 0.00
Properties:
device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Source #4
State: SUSPENDED
Owner Module: 6
Mute: no
Volume: front-left: 7789 / 12% / -55.50 dB, front-right: 7789 / 12% / -55.50 dB
balance 0.00
Base Volume: 6554 / 10% / -60.00 dB
Properties:
device.api = "alsa"
alsa.name = ""
alsa.device = "0"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:sofhdadsp"
device.buffering.buffer_size = "65536"
device.buffering.fragment_size = "16384"
device.access_mode = "mmap+timer"
Ports:
[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, not available)
Formats:
pcm
Source #5
State: SUSPENDED
Owner Module: 6
Mute: no
Volume: front-left: 48211 / 74% / -8.00 dB, front-right: 48211 / 74% / -8.00 dB
balance 0.00
Properties:
device.api = "alsa"
alsa.name = ""
alsa.device = "6"
alsa.card = "0"
device.bus = "pci"
device.string = "_ucm0001.hw:sofhdadsp,6"
Ports:
Formats:
pcm
and journalctl
➜ journalctl --boot=0 --priority=3 --no-pager
Jun 13 09:40:49 Gemini-L kernel: pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
Jun 13 09:40:49 Gemini-L kernel: pci 0000:00:07.1: DPC: RP PIO log size 0 is invalid
Jun 13 09:40:49 Gemini-L systemd-udevd[305]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Jun 13 09:40:51 Gemini-L systemd[944]: Failed to start Update XDG user dir configuration.
Jun 13 09:40:53 Gemini-L kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Jun 13 09:40:58 Gemini-L bluetoothd[927]: Failed to set mode: Failed (0x03)
Olli
13 June 2022 13:49
15
can you check alsamixer ? open a terminal and start
alsamixer
it’s a basic tool but you can check the mutings etc… and change it.
Nothing seems out of the ordinary in alsamixer
Olli
13 June 2022 14:02
17
yes, everything seems okay. maybe it’s (again) something with these weird idle/suspend/hibernation BS.
please post
cat /etc/pulse/default.pa
“load-module module-suspend-on-idle” active ?
it seems active, yes. Would it be wise to try this? [HowTo] set up the audio card in Samsung Galaxy Book as it uses the same realtek audio card?
➜ cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
### Allow including a default.pa.d directory, which if present, can be used
### for additional configuration snippets.
### Note that those snippet files must have a .pa file extension, not .conf
.nofail
.include /etc/pulse/default.pa.d
Olli
13 June 2022 14:13
19
let’s give it a simple try, replace
with
###load-module module-suspend-on-idle
it’s pssible you need sudo to edit, please reboot and see if there’s a change. if not you can always undo this step.
unfortunately there was no change =/
