No audio output in fresh install (Intel Tiger Lake, MSI Evo laptop)
okay, please check the following, but take care:
" No HDMI 5/7.1 Selection for Device
If you are unable to select 5/7.1 channel output for a working HDMI device, then turning off “stream device reading” in /etc/pulse/default.pa might help.
See #Fallback device is not respected.
Failed to create sink input: sink is suspended
If you do not have any output sound and receive dozens of error messages related to a suspended sink from running journalctl -b as root, then backup first and then delete your user-specific pulse folders:
$ rm -r ~/.pulse ~/.pulse-cookie ~/.config/pulse"
Neither of these solutions seemed to change anything, unfortunately. I did notice this in journalctl, if it has any relevance:
Jun 13 10:39:04 Gemini-L kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
meanwhile i don’t think that it is a driver-problem.
please post the output of
aplay -L
➜ aplay -L
null
    Discard all samples (playback) or generate zero samples (capture)
lavrate
    Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
    Rate Converter Plugin Using Samplerate Library
speexrate
    Rate Converter Plugin Using Speex Resampler
jack
    JACK Audio Connection Kit
oss
    Open Sound System
pipewire
    PipeWire Sound Server
pulse
    PulseAudio Sound Server
speex
    Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
    Plugin for channel upmix (4,6,8)
vdownmix
    Plugin for channel downmix (stereo) with a simple spacialization
default
    Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=sofhdadsp
    sof-hda-dsp,
    Default Audio Device
usbstream:CARD=sofhdadsp
    sof-hda-dsp
    USB Stream Output
jack ? why ? is there something you also installed and didn’t told ?
I haven’t installed anything beyond manjaro-pipewire and then, per this threads instructions, replaced it with manjaro-pulseaudio
this is confusing, i have no idea.
I can try another fresh install, though I dont know how much that would help
before you could simply use a live-iso and check if this works. that’s less work. but yes it’s a good idea.
Would you be interested in any outputs while I use a live-iso?
yes if audio is workig. in this case you can analyze the difference and you’ll see what driver and what settings are used.
Currently booted into the most recent live-iso for KDE and the audio does not output.
possibly relevant journalctl output:
Jun 13 17:35:38 manjaro systemsettings[2735]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:151:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to b>
Jun 13 17:35:38 manjaro systemsettings[2735]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ApplicationItem.qml:147:9: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to b>
Jun 13 17:35:38 manjaro systemsettings[2735]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PageRow.qml:674:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 14. Use 'sequences: [ <key> ]' to bind to a>
Jun 13 17:35:38 manjaro systemsettings[2735]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PageRow.qml:670:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 13. Use 'sequences: [ <key> ]' to bind to a>
Jun 13 17:35:38 manjaro systemsettings[2735]: kf.coreaddons: "Could not load plugin from kcm_pulseaudio: The shared library was not found."
Jun 13 17:35:38 manjaro systemsettings[2735]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Jun 13 17:35:44 manjaro xdg-desktop-portal-kde[1768]: xdp-kde-background: GetAppState called: no parameters
Jun 13 17:35:44 manjaro kernel: msi_wmi: Unknown event received
Jun 13 17:35:51 manjaro systemsettings[2735]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink"
Jun 13 17:35:51 manjaro systemsettings[2735]: org.kde.plasma.pulseaudio: No object for name "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source"
Jun 13 17:35:51 manjaro kwin_x11[1340]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36099, resource id: 67109028, major code: 18 (ChangeProperty), minor code: 0
Jun 13 17:35:51 manjaro kwin_x11[1340]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36117, resource id: 27263249, major code: 18 (ChangeProperty), minor code: 0
Jun 13 17:36:09 manjaro rtkit-daemon[1482]: Supervising 11 threads of 4 processes of 1 users.
Jun 13 17:36:12 manjaro rtkit-daemon[1482]: Supervising 11 threads of 4 processes of 1 users.
Jun 13 17:36:12 manjaro rtkit-daemon[1482]: Successfully made thread 2822 of process 2506 owned by '1000' RT at priority 10.
Jun 13 17:36:12 manjaro rtkit-daemon[1482]: Supervising 12 threads of 5 processes of 1 users.
Jun 13 17:37:02 manjaro plasmashell[1418]: trying to show an empty dialog
Jun 13 17:37:04 manjaro plasmashell[1418]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_aspell.so: (libaspell.so.15: c>
Jun 13 17:37:04 manjaro plasmashell[1418]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_hspell.so: (libhspell.so.0: ca>
Jun 13 17:37:04 manjaro plasmashell[1418]: kf.sonnet.core: Sonnet: Unable to load plugin "/usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so" Error: "Cannot load library /usr/lib/qt/plugins/kf5/sonnet/sonnet_voikko.so: (libvoikko.so.1: ca>
Jun 13 17:37:04 manjaro plasmashell[1418]: kf.sonnet.core: No language dictionaries for the language: "en_US" trying to load en_US as default
Jun 13 17:37:04 manjaro plasmashell[1418]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
aplay -L
lavrate
samplerate
speexrate
jack
oss
    Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
    sof-hda-dsp,
    sof-hda-dsp
    USB Stream Output
audio from inxi
  Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Micro-Star MSI
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
    chip-ID: 8086:a0c8 class-ID: 0401
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
pulseaudio status
> systemctl --user status pulseaudio
● pulseaudio.service - Sound Service
     Loaded: loaded (/usr/lib/systemd/user/pulseaudio.service; disabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-06-13 17:34:44 UTC; 7min ago
TriggeredBy: ● pulseaudio.socket
   Main PID: 1460 (pulseaudio)
      Tasks: 11 (limit: 18782)
     Memory: 58.5M
        CPU: 1.024s
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pulseaudio.service
             ├─1460 /usr/bin/pulseaudio --daemonize=no --log-target=journal
             └─1803 /usr/lib/pulse/gsettings-helper
Jun 13 17:34:42 manjaro systemd[1261]: Starting Sound Service...
Jun 13 17:34:44 manjaro gst-plugin-scan[1694]: type name '-a-png-encoder-pred' contains invalid characters
Jun 13 17:34:44 manjaro gst-plugin-scan[1694]: g_type_set_qdata: assertion 'node != NULL' failed
Jun 13 17:34:44 manjaro pulseaudio[1460]: stat('/etc/pulse/default.pa.d'): No such file or directory
Jun 13 17:34:44 manjaro systemd[1261]: Started Sound Service.
pactl list sources
Source #0
        State: SUSPENDED
        Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
        Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
        Driver: module-alsa-card.c
        Sample Specification: s16le 2ch 48000Hz
        Channel Map: front-left,front-right
        Owner Module: 6
        Mute: no
        Volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
                balance 0.00
        Base Volume: 65536 / 100% / 0.00 dB
        Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink
        Latency: 0 usec, configured 0 usec
        Flags: DECIBEL_VOLUME LATENCY
        Properties:
                device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
                device.class = "monitor"
                alsa.card = "0"
                alsa.card_name = "sof-hda-dsp"
                alsa.long_card_name = "Micro_StarInternationalCo.Ltd.-Prestige14EvoA11M-REV1.0-MS_14C4"
                alsa.driver_name = "snd_soc_skl_hda_dsp"
                device.bus_path = "pci-0000:00:1f.3-platform-skl_hda_dsp_generic"
                sysfs.path = "/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
                device.bus = "pci"
                device.vendor.id = "8086"
                device.product.id = "a0c8"
                device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
                device.string = "0"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-card-pci"
        Formats:
                pcm
Source #1
        State: SUSPENDED
        Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
        Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
        Owner Module: 6
        Mute: no
                balance 0.00
        Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink
        Properties:
                device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formats:
                pcm
Source #2
        State: SUSPENDED
        Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
        Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
        Owner Module: 6
        Mute: no
                balance 0.00
        Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink
        Properties:
                device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formats:
                pcm
Source #3
        State: SUSPENDED
        Name: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
        Description: Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones
        Owner Module: 6
        Mute: no
                balance 0.00
        Monitor of Sink: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink
        Properties:
                device.description = "Monitor of Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "0"
        Formats:
                pcm
Source #4
        State: SUSPENDED
        Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source
        Description: Tiger Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone
        Owner Module: 6
        Mute: no
        Volume: front-left: 7789 /  12% / -55.50 dB,   front-right: 7789 /  12% / -55.50 dB
                balance 0.00
        Base Volume: 6554 /  10% / -60.00 dB
        Monitor of Sink: n/a
        Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
        Properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = ""
                alsa.id = "HDA Analog (*)"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "_ucm0001.hw:sofhdadsp"
                device.buffering.buffer_size = "65536"
                device.buffering.fragment_size = "16384"
                device.access_mode = "mmap+timer"
                device.profile.name = "HiFi: hw:sofhdadsp: source"
                device.profile.description = "Headphones Stereo Microphone"
                alsa.mixer_device = "_ucm0001.hw:sofhdadsp"
                device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Headphones Stereo Microphone"
        Ports:
                [In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, not available)
        Active Port: [In] Mic2
        Formats:
                pcm
Source #5
        State: SUSPENDED
        Name: alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source
        Description: Tiger Lake-LP Smart Sound Technology Audio Controller Digital Microphone
        Owner Module: 6
        Mute: no
        Volume: front-left: 30419 /  46% / -20.00 dB,   front-right: 30419 /  46% / -20.00 dB
                balance 0.00
        Base Volume: 30419 /  46% / -20.00 dB
        Properties:
                device.api = "alsa"
                alsa.name = ""
                alsa.id = "DMIC (*)"
                alsa.device = "6"
                alsa.card = "0"
                device.bus = "pci"
                device.string = "_ucm0001.hw:sofhdadsp,6"
                device.profile.name = "HiFi: hw:sofhdadsp,6: source"
                device.profile.description = "Digital Microphone"
                device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Digital Microphone"
        Ports:
                [In] Mic1: Digital Microphone (type: Mic, priority: 100, availability unknown)
        Active Port: [In] Mic1
        Formats:
                pcm
pipewire services
> systemctl --user status pipewire-pulse.service
Unit pipewire-pulse.service could not be found.
> systemctl --user status pipewire.service
● pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-06-13 17:34:44 UTC; 10min ago
TriggeredBy: ● pipewire.socket
   Main PID: 1785 (pipewire)
      Tasks: 2 (limit: 18782)
     Memory: 1.9M
        CPU: 17ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─1785 /usr/bin/pipewire
Jun 13 17:34:44 manjaro systemd[1261]: Started PipeWire Multimedia Service.
well you can try 2 different things now. first, boot to your existing system and check the software-manager if a packet called “sof-firmware” is installed. if not please install. a 2nd test, you could use a different live-iso (linux-mint or similar) and test if audio works in their live-iso. if so you could check what drivers are installed and this would give you a hint what to install. i googled a little bit so i would recommend to check first if “sof-firmware” is installed.
sof-firmware is definitely installed, so I’ll try the other option after a bit more digging
Linux mint was no dice. However, when I rebooted after the linux mint live-iso and booted into Manjaro again… the sound started to work. I genuinely dont understand how. I will provide any and all logs to further understand this unusual behavior.
the aplay and pactl command-output would be interesting to me. what is the difference now ?
EDIT/UPDATE: The problem was solved by disabling fast boot in Windows.
aplay
➜ aplay -L
null
lavrate
samplerate
speexrate
jack
oss
    Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
    sof-hda-dsp,
    sof-hda-dsp
    USB Stream Output
pactl list
Module #1
	Argument: {
            nice.level    = -11
            #rt.prio      = 88
            #rt.time.soft = -1
            #rt.time.hard = -1
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-rt"
		object.id = "1"
		object.serial = "1"
		module.author = "Wim Taymans <wim.taymans@gmail.com>"
		module.description = "Use realtime thread scheduling, falling back to RTKit"
		module.usage = "[nice.level=<priority: default 20(don't change)>] [rt.prio=<priority: default 88>] [rt.time.soft=<in usec: default -1] [rt.time.hard=<in usec: default -1] "
		module.version = "0.3.52"
		nice.level = "-11"
Module #2
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-protocol-native"
		object.id = "2"
		object.serial = "2"
		module.description = "Native protocol using unix sockets"
Module #3
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-profiler"
		object.id = "3"
		object.serial = "3"
		module.description = "Generate Profiling data"
Module #5
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-metadata"
		object.id = "5"
		object.serial = "5"
		module.description = "Allow clients to create metadata store"
Module #7
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-device-factory"
		object.id = "7"
		object.serial = "7"
		module.description = "Provide a factory to make SPA devices"
Module #9
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-spa-node-factory"
		object.id = "9"
		object.serial = "9"
		module.description = "Provide a factory to make SPA nodes"
Module #11
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-node"
		object.id = "11"
		object.serial = "11"
		module.description = "Allow clients to create and control remote nodes"
Module #13
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-client-device"
		object.id = "13"
		object.serial = "13"
		module.description = "Allow clients to create and control remote devices"
Module #15
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-portal"
		object.id = "15"
		object.serial = "15"
Module #16
	Argument: {
            # access.allowed to list an array of paths of allowed
            # apps.
            #access.allowed = [
            #    /usr/bin/pipewire-media-session
            # An array of rejected paths.
            #access.rejected = [ ]
            # An array of paths with restricted access.
            #access.restricted = [ ]
            # Anything not in the above lists gets assigned the
            # access.force permission.
            #access.force = flatpak
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-access"
		object.id = "16"
		object.serial = "16"
		module.description = "Perform access check"
		module.usage = "[ access.force=flatpak ] [ access.allowed=<cmd-line> ] [ access.rejected=<cmd-line> ] [ access.restricted=<cmd-line> ] "
Module #17
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-adapter"
		object.id = "17"
		object.serial = "17"
		module.description = "Manage adapter nodes"
Module #19
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-link-factory"
		object.id = "19"
		object.serial = "19"
		module.description = "Allow clients to create links"
Module #21
	Argument:
	Usage counter: n/a
	Properties:
		module.name = "libpipewire-module-session-manager"
		object.id = "21"
		object.serial = "21"
		module.author = "George Kiagiadakis <george.kiagiadakis@collabora.com>"
		module.description = "Implements objects for session management"
Module #536870912
	Argument:
	Usage counter: n/a
	Properties:
		module.author = "Pauli Virtanen <pav@iki.fi>"
		module.description = "Always keeps at least one sink loaded even if it's a null one"
		module.usage = "sink_name=<name of sink>"
Sink #42
	State: SUSPENDED
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output
	Driver: PipeWire
	Sample Specification: s24-32le 2ch 48000Hz
	Owner Module: 4294967295
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink.monitor
	Flags: HARDWARE DECIBEL_VOLUME LATENCY
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp,5:playback"
		api.alsa.path = "hw:sofhdadsp,5"
		api.alsa.open.ucm = "true"
		api.alsa.pcm.card = "0"
		api.alsa.pcm.stream = "playback"
		audio.channels = "2"
		audio.position = "FL,FR"
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI3 (*)"
		alsa.device = "5"
		alsa.card = "0"
		device.profile.name = "HiFi: hw:sofhdadsp,5: sink"
		device.profile.description = "HDMI / DisplayPort 3 Output"
		card.profile.device = "0"
		device.id = "40"
		factory.name = "api.alsa.pcm.sink"
		priority.driver = "664"
		priority.session = "664"
		media.class = "Audio/Sink"
		node.nick = "sof-hda-dsp"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_5__sink"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 3 Output"
		device.icon_name = "audio-card"
		device.bus = "pci"
		node.pause-on-idle = "false"
		factory.id = "18"
		clock.quantum-limit = "8192"
		client.id = "32"
		node.driver = "true"
		factory.mode = "merge"
		audio.adapt.follower = ""
		library.name = "audioconvert/libspa-audioconvert"
		object.id = "41"
		object.serial = "42"
	Ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, availability group: HDMI/DP,pcm=5, not available)
	Active Port: [Out] HDMI3
	Formats:
		pcm
Sink #43
	State: SUSPENDED
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink.monitor
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp,4:playback"
		api.alsa.path = "hw:sofhdadsp,4"
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI2 (*)"
		alsa.device = "4"
		alsa.card = "0"
		device.profile.name = "HiFi: hw:sofhdadsp,4: sink"
		device.profile.description = "HDMI / DisplayPort 2 Output"
		card.profile.device = "1"
		device.id = "40"
		priority.driver = "680"
		priority.session = "680"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_4__sink"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 2 Output"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "42"
		object.serial = "43"
	Ports:
		[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, availability group: HDMI/DP,pcm=4, not available)
	Active Port: [Out] HDMI2
	Formats:
		pcm
Sink #44
	State: SUSPENDED
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink.monitor
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp,3:playback"
		api.alsa.path = "hw:sofhdadsp,3"
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.id = "HDMI1 (*)"
		alsa.device = "3"
		alsa.card = "0"
		device.profile.name = "HiFi: hw:sofhdadsp,3: sink"
		device.profile.description = "HDMI / DisplayPort 1 Output"
		card.profile.device = "2"
		device.id = "40"
		priority.driver = "696"
		priority.session = "696"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_3__sink"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller HDMI / DisplayPort 1 Output"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "43"
		object.serial = "44"
	Ports:
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, availability group: HDMI/DP,pcm=3, not available)
	Active Port: [Out] HDMI1
	Formats:
		pcm
Sink #45
	State: SUSPENDED
	Description: Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones
	Driver: PipeWire
	Sample Specification: s32le 2ch 48000Hz
	Mute: no
	Volume: front-left: 42598 /  65% / -11.23 dB,   front-right: 42598 /  65% / -11.23 dB
	        balance 0.00
	Monitor Source: alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink.monitor
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp:playback"
		api.alsa.path = "hw:sofhdadsp"
		device.routes = "2"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "0"
		alsa.card = "0"
		device.profile.name = "HiFi: hw:sofhdadsp: sink"
		device.profile.description = "Speaker + Headphones"
		card.profile.device = "3"
		device.id = "40"
		priority.driver = "744"
		priority.session = "744"
		node.name = "alsa_output.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__sink"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller Speaker + Headphones"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "44"
		object.serial = "45"
		node.max-latency = "4096/48000"
	Ports:
		[Out] Speaker: Speaker (type: Speaker, priority: 100, availability unknown)
		[Out] Headphones: Headphones (type: Headphones, priority: 200, availability group: Headphone, not available)
	Active Port: [Out] Speaker
	Formats:
		pcm
Source #42
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "5"
		alsa.card = "0"
		device.id = "40"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "41"
	Formats:
		pcm
Source #43
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "4"
		alsa.card = "0"
		device.id = "40"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "42"
	Formats:
		pcm
Source #44
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "3"
		alsa.card = "0"
		device.id = "40"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "43"
	Formats:
		pcm
Source #45
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		device.routes = "2"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "0"
		alsa.card = "0"
		device.id = "40"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "44"
	Formats:
		pcm
Source #46
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	        balance 0.00
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp:capture"
		api.alsa.pcm.stream = "capture"
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "0"
		alsa.card = "0"
		card.profile.device = "4"
		device.id = "40"
		factory.name = "api.alsa.pcm.source"
		priority.driver = "1744"
		priority.session = "1744"
		media.class = "Audio/Source"
		node.name = "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp__source"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		factory.mode = "split"
		object.id = "45"
		object.serial = "46"
	Ports:
		[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, availability group: Mic, not available)
	Formats:
		pcm
Source #47
	State: SUSPENDED
	Driver: PipeWire
	Mute: no
	Volume: front-left: 48287 /  74% / -7.96 dB,   front-right: 48287 /  74% / -7.96 dB
	        balance 0.00
	Properties:
		object.path = "alsa:pcm:0:hw:sofhdadsp,6:capture"
		api.alsa.path = "hw:sofhdadsp,6"
		device.routes = "1"
		device.api = "alsa"
		alsa.name = ""
		alsa.device = "6"
		alsa.card = "0"
		card.profile.device = "5"
		device.id = "40"
		priority.driver = "1648"
		priority.session = "1648"
		node.name = "alsa_input.pci-0000_00_1f.3-platform-skl_hda_dsp_generic.HiFi__hw_sofhdadsp_6__source"
		device.bus = "pci"
		factory.id = "18"
		client.id = "32"
		object.id = "46"
		object.serial = "47"
	Ports:
	Formats:
		pcm
Client #34
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.protocol = "protocol-native"
		pipewire.sec.pid = "1363"
		pipewire.sec.uid = "1000"
		pipewire.sec.gid = "1000"
		module.id = "2"
		object.id = "34"
		object.serial = "34"
		config.name = "pipewire-pulse.conf"
		cpu.max-align = "64"
		default.clock.rate = "48000"
		default.clock.quantum = "1024"
		default.clock.min-quantum = "32"
		default.clock.max-quantum = "2048"
		default.clock.quantum-limit = "8192"
		default.video.width = "640"
		default.video.height = "480"
		default.video.rate.num = "25"
		default.video.rate.denom = "1"
		log.level = "2"
		clock.power-of-two-quantum = "true"
		link.max-buffers = "64"
		mem.warn-mlock = "false"
		mem.allow-mlock = "true"
		settings.check-quantum = "false"
		settings.check-rate = "false"
		application.name = "pipewire-pulse"
		application.process.binary = "pipewire-pulse"
		application.language = "en_US.UTF-8"
		application.process.id = "1363"
		application.process.user = "pdimens"
		application.process.host = "Gemini-L"
		application.process.session_id = "2"
		window.x11.display = ":0"
		core.version = "0.3.52"
		core.name = "pipewire-pdimens-1363"
		pipewire.access = "unrestricted"
Client #31
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.pid = "1362"
		module.id = "2"
		object.id = "31"
		object.serial = "31"
		config.prefix = "media-session.d"
		config.name = "media-session.conf"
		log.level = "2"
		application.name = "pipewire-media-session"
		application.process.binary = "pipewire-media-session"
		application.process.id = "1362"
		core.name = "pipewire-pdimens-1362"
Client #32
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "32"
		object.serial = "32"
		log.level = "2"
Client #68
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "66"
		object.serial = "68"
		client.api = "pipewire-pulse"
		pulse.server.type = "unix"
		application.name = "Plasma PA"
		application.id = "org.kde.plasma-pa"
		application.icon_name = "audio-card"
		application.process.id = "1232"
		application.process.binary = "latte-dock"
		application.process.machine_id = "eac5b4bfa73a4449940a4aed21383188"
		log.level = "2"
Client #97
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "68"
		object.serial = "97"
		application.name = "libcanberra"
		application.version = "0.30"
		application.id = "org.freedesktop.libcanberra"
		log.level = "2"
Client #138
	Driver: PipeWire
	Owner Module: 2
	Properties:
		pipewire.sec.pid = "1596"
		module.id = "2"
		object.id = "70"
		object.serial = "138"
		pipewire.access.portal.is_portal = "true"
		portal.monitor = "Camera"
		log.level = "0"
		application.name = "xdg-desktop-portal"
		application.process.binary = "xdg-desktop-portal"
		application.process.id = "1596"
		core.name = "pipewire-pdimens-1596"
Client #262
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "92"
		object.serial = "262"
		application.name = "Chrome input"
		application.process.id = "3538"
		application.process.binary = "rstudio"
		log.level = "2"
Client #308
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "91"
		object.serial = "308"
		window.x11.screen = "0"
		application.name = "Firefox"
		application.process.id = "3869"
		application.process.binary = "firefox"
		log.level = "2"
Client #309
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "83"
		object.serial = "309"
		log.level = "2"
Client #311
	Driver: PipeWire
	Owner Module: 2
	Properties:
		module.id = "2"
		object.id = "88"
		object.serial = "311"
		application.process.id = "4439"
		application.process.binary = "pactl"
		application.name = "pactl"
		log.level = "2"
Sample #0
	Sample Specification: s16le 2ch 44100Hz
	        balance 0.00
	Duration: 0.1s
	Lazy: no
	Filename: n/a
	Properties:
		event.id = "audio-volume-change"
		event.description = "Volume Control Feedback Sound"
		media.role = "event"
		media.name = "audio-volume-change"
		media.filename = "/usr/share/sounds/freedesktop/stereo/audio-volume-change.oga"
Card #41
	Driver: alsa
	Owner Module: n/a
	Properties:
		device.enum.api = "udev"
		device.api = "alsa"
		media.class = "Audio/Device"
		api.alsa.path = "hw:0"
		api.alsa.card = "0"
		api.alsa.card.name = "sof-hda-dsp"
		api.alsa.card.longname = "Micro_StarInternationalCo.Ltd.-Prestige14EvoA11M-REV1.0-MS_14C4"
		device.plugged.usec = "3680639"
		device.sysfs.path = "/sys/devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0"
		device.bus = "pci"
		device.subsystem = "sound"
		device.vendor.id = "32902"
		device.product.id = "41160"
		device.name = "alsa_card.pci-0000_00_1f.3-platform-skl_hda_dsp_generic"
		device.description = "Tiger Lake-LP Smart Sound Technology Audio Controller"
		device.nick = "sof-hda-dsp"
		api.alsa.use-acp = "true"
		api.acp.auto-port = "false"
		factory.id = "14"
		client.id = "31"
		object.id = "40"
		object.serial = "41"
		object.path = "alsa:pcm:0"
		alsa.card = "0"
		device.string = "0"
	Profiles:
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
		HiFi: Play HiFi quality Music (sinks: 4, sources: 2, priority: 8000, available: yes)
	Active Profile: HiFi
	Ports:
		[Out] HDMI3: HDMI / DisplayPort 3 Output (type: HDMI, priority: 700, latency offset: 0 usec, availability group: HDMI/DP,pcm=5, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=5"
				card.profile.port = "0"
			Part of profile(s): HiFi
		[Out] HDMI2: HDMI / DisplayPort 2 Output (type: HDMI, priority: 600, latency offset: 0 usec, availability group: HDMI/DP,pcm=4, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=4"
				card.profile.port = "1"
		[Out] HDMI1: HDMI / DisplayPort 1 Output (type: HDMI, priority: 500, latency offset: 0 usec, availability group: HDMI/DP,pcm=3, not available)
			Properties:
				port.type = "hdmi"
				port.availability-group = "HDMI/DP,pcm=3"
				card.profile.port = "2"
		[Out] Speaker: Speaker (type: Speaker, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "speaker"
				card.profile.port = "3"
		[Out] Headphones: Headphones (type: Headphones, priority: 200, latency offset: 0 usec, availability group: Headphone, not available)
			Properties:
				port.type = "headphones"
				port.availability-group = "Headphone"
				card.profile.port = "4"
		[In] Mic2: Headphones Stereo Microphone (type: Mic, priority: 200, latency offset: 0 usec, availability group: Mic, not available)
			Properties:
				port.type = "mic"
				port.availability-group = "Mic"
				card.profile.port = "5"
		[In] Mic1: Digital Microphone (type: Mic, priority: 100, latency offset: 0 usec, availability unknown)
			Properties:
				port.type = "mic"
				card.profile.port = "6"
