On my Asus laptop (Strix G712LW) I have not sound from the internal speakers. Bluetooth and headphones (3.5mil aux) both work.
It may be a dumb misconfiguration of my part but I cannot figure it out.
This is the output of inxi -Fxzc0:
Kernel: 6.6.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.10 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G712LW_G712LW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G712LW v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G712LW.314 date: 04/27/2021
ID-1: BAT0 charge: 39.7 Wh (83.4%) condition: 47.6/66.0 Wh (72.2%)
volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery status: not charging
Info: 6-core model: Intel Core i7-10750H bits: 64 type: MT MCP
arch: Comet Lake rev: 2 cache: L1: 384 KiB L2: 1.5 MiB L3: 12 MiB
Speed (MHz): avg: 880 high: 901 min/max: 800/5000 cores: 1: 800 2: 901
3: 800 4: 900 5: 900 6: 870 7: 899 8: 901 9: 900 10: 898 11: 897 12: 900
bogomips: 62431
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen-9.5 bus-ID: 00:02.0
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile / Max-Q Refresh]
vendor: ASUSTeK driver: nvidia v: 545.29.06 arch: Turing bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.10 driver: X:
loaded: modesetting,nvidia dri: iris gpu: i915 s-res: 1920x1080
resolution: 1920x1080
API: EGL v: 1.5 drivers: iris,kms_swrast,nvidia,swrast platforms:
active: gbm,x11,surfaceless,device inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
API: Vulkan v: 1.3.274 drivers: nvidia surfaces: xcb,xlib devices: 1
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA TU106 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 01:00.1
API: ALSA v: k6.6.10-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.0.0 status: active
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3
vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 05:00.0
IF: eno2 state: down mac: <filter>
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB
bus-ID: 1-14:4
Local Storage: total: 1.38 TiB used: 33.42 GiB (2.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB temp: 32.9 C
ID-2: /dev/nvme1n1 vendor: Intel model: SSDPEKNW512G8 size: 476.94 GiB
temp: 28.9 C
ID-1: / size: 475.44 GiB used: 33.11 GiB (7.0%) fs: btrfs dev: /dev/dm-0
mapped: luks-b413853b-82ef-4724-9e91-3d4ad4c0fa23
ID-2: /boot size: 973.4 MiB used: 313.9 MiB (32.2%) fs: ext4
dev: /dev/nvme1n1p3
ID-3: /boot/efi size: 511 MiB used: 6.3 MiB (1.2%) fs: vfat
dev: /dev/nvme1n1p1
ID-4: /home size: 475.44 GiB used: 33.11 GiB (7.0%) fs: btrfs
dev: /dev/dm-0 mapped: luks-b413853b-82ef-4724-9e91-3d4ad4c0fa23
ID-5: /var/log size: 475.44 GiB used: 33.11 GiB (7.0%) fs: btrfs
ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) file: /swap/swapfile
System Temperatures: cpu: 43.0 C pch: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3100
Processes: 358 Uptime: 16m Memory: total: 16 GiB available: 15.41 GiB
used: 5.16 GiB (33.5%) Init: systemd Compilers: gcc: 13.2.1 clang: 16.0.6
Packages: 1167 Shell: Zsh v: 5.9 inxi: 3.3.31
I don’t know what other info I need to include.
Thanks in advance
