No Audio Devices After Update [Pipewire]
Hi. Just updated Manjaro recently and found that it doesn’t even detect my built in laptop speakers anymore, let alone my Bluetooth earbuds. Here’s some more info for my system.
inxi -Fxz
System:    Kernel: 5.11.10-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.21.3 Distro: Manjaro Linux
           base: Arch Linux
Machine:   Type: Laptop System: Acer product: Aspire E5-573G v: V3.72 serial: <filter>
           Mobo: Acer model: ZORO_BH v: Type2 - A01 Board Version serial: <filter> UEFI: Insyde v: 1.37 date: 02/16/2016
Battery:   ID-1: BAT1 charge: 27.3 Wh (97.2%) condition: 28.1/37.0 Wh (75.9%) volts: 17.2 min: 14.8 model: SANYO AL15A32
           status: Charging
CPU:       Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell rev: 4 cache: L2: 3 MiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 17567
           Speed: 935 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 935 2: 1772 3: 1549 4: 1344
Graphics:  Device-1: Intel HD Graphics 5500 vendor: Acer Incorporated ALI driver: i915 v: kernel bus-ID: 00:02.0
           Device-2: NVIDIA GM108M [GeForce 940M] vendor: Acer Incorporated ALI driver: nvidia v: 460.67 bus-ID: 04:00.0
           Device-3: Chicony HD WebCam type: USB driver: uvcvideo bus-ID: 2-7:4
           Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nvidia unloaded: intel,nouveau
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.0.1 direct render: Yes
Audio:     Device-1: Intel Broadwell-U Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel bus-ID: 00:03.0
           Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
           v: kernel bus-ID: 00:1b.0
           Sound Server-1: ALSA v: k5.11.10-1-MANJARO running: yes
           Sound Server-2: JACK v: 1.9.17 running: no
           Sound Server-3: PulseAudio v: 14.2 running: no
           Sound Server-4: PipeWire v: 0.3.24 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8168
           v: 8.048.03-NAPI port: 4000 bus-ID: 02:00.0
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lite-On driver: ath10k_pci v: kernel
           port: 4000 bus-ID: 03:00.0
Bluetooth: Device-1: Lite-On Qualcomm Atheros QCA9377 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 2-5:3
           Report: ID: hci0 state: up address: <filter>
Drives:    Local Storage: total: 596.17 GiB used: 200.54 GiB (33.6%)
           ID-1: /dev/sda vendor: Toshiba model: MK6465GSX size: 596.17 GiB
Partition: ID-1: / size: 376.95 GiB used: 200.51 GiB (53.2%) fs: ext4 dev: /dev/sda4
           ID-2: /boot/efi size: 574.5 MiB used: 25.5 MiB (4.4%) fs: vfat dev: /dev/sda1
Swap:      ID-1: swap-1 type: partition size: 16 GiB used: 2 MiB (0.0%) dev: /dev/sda5
Sensors:   System Temperatures: cpu: 63.0 C mobo: N/A
Info:      Processes: 211 Uptime: 32m Memory: 7.69 GiB used: 4.98 GiB (64.8%) Init: systemd Compilers: gcc: 10.2.0
           clang: 11.1.0 Packages: 1989 Shell: Zsh v: 5.8 inxi: 3.3.03
Thank you.
Same here, no more audio device after upgrade
And I thought some part of my h/w had failed, but my audio has failed too after updating.
My sys info:
Machine:   Type: Desktop Mobo: MSI model: H81M-E34 (MS-7817) v: 3.0 serial: <filter> BIOS: American Megatrends v: 17.5
       date: 03/30/2015
CPU:       Info: Dual Core model: Intel Pentium G3220 bits: 64 type: MCP arch: Haswell rev: 3 cache: L2: 3 MiB
       flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12005
       Speed: 800 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 800 2: 800
Graphics:  Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics vendor: Micro-Star MSI
       Display: x11 server: X.Org 1.20.10 driver: loaded: intel unloaded: modesetting resolution: 1: 1280x1024
       2: 1280x1024~60Hz
       OpenGL: renderer: Mesa DRI Intel HD Graphics (HSW GT1) v: 4.5 Mesa 21.0.1 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Micro-Star MSI
       Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
       Sound Server-1: ALSA v: k5.4.108-1-MANJARO running: yes
       Sound Server-3: JACK v: 1.9.17 running: no
       Sound Server-4: PulseAudio v: 14.2 running: no
       Sound Server-5: PipeWire v: 0.3.24 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI driver: r8169
       v: kernel port: e000 bus-ID: 02:00.0
       IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    Local Storage: total: 931.51 GiB used: 208.54 GiB (22.4%)
       ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB
Partition: ID-1: / size: 228.17 GiB used: 208.54 GiB (91.4%) fs: ext4 dev: /dev/sda4
Swap:      ID-1: swap-1 type: partition size: 15.83 GiB used: 0 KiB (0.0%) dev: /dev/sda6
Sensors:   System Temperatures: cpu: 29.8 C mobo: 27.8 C
Info:      Processes: 189 Uptime: 2h 21m Memory: 7.66 GiB used: 1.87 GiB (24.4%) Init: systemd Compilers: gcc: 10.2.0
       clang: 11.1.0 Packages: 1973 Shell: Bash v: 5.1.0 inxi: 3.3.03
i did that:
mv /etc/pipewire /tmp
sudo pacman -S pipewire pipewire-pulse pipewire-media-session
ps aux|grep pipewire
1815 0.4 0.0 106236 10008 ? S<Lsl 19:03 0:00 /usr/bin/pipewire-pulse
2023 0.5 0.0 117944 15656 ? S<sl 19:03 0:00 /usr/bin/pipewire
2025 0.1 0.0 90116 10720 ? S<sl 19:03 0:00 /usr/bin/pipewire-media-session
kill -9 1815 2023 2025
Audio become up again, even after a reboot
Problem solved for me anyway. Solution found on After update: Audio device gone, desktop background white - #2 by sundbp
This helps me: sudo cp /etc/pipewire/media-session.d/media-session.conf.pacnew /etc/pipewire/media-session.d/media-session.conf And i also copying this: sudo cp /etc/pipewire/media-session.d/alsa-monitor.conf.pacnew /etc/pipewire/media-session.d/alsa-monitor.conf
Thanks everyone. Pasting the solution here for convenience.
Instead of reinstalling anything, just go into /etc/pipewire/media-session.d/ and move the *.conf.pacnew files to .conf files (replacing the old ones). It does the trick just like every time.
https://www.reddit.com/r/archlinux/comments/m2uiez/pipewire_no_longer_working/grr9wcf?utm_source=share&utm_medium=web2x&context=3
