After the last major update, I seem to have lost sound, but only after suspending. I can sometimes get it back, and it comes back after a system reset, but not before.
pulseaudio -k
is ineffective, and plasma-pa
is already installed. I tried to do sudo alsa force-reload
, but it says that the alsa
command cannot be found. alsamixer
appears to work, but I can’t get it to display the Schiit Modi 3 in a way where I can control its volume:
How can I get back audio after suspending like this? Is there some kind of package conflict?
System Specs:
Host: MidnightStarSign Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc
v: 11.1.0 Desktop: KDE Plasma 5.22.4 Distro: Manjaro Linux base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 3001 date: 12/04/2020
Info: 16-Core model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 rev: 0
cache: L2: 8 MiB
bogomips: 217719
Speed: 4587 MHz min/max: 2200/3400 MHz boost: enabled Core speeds (MHz): 1: 4587
2: 4423 3: 2611 4: 2589 5: 2610 6: 2632 7: 2614 8: 2609 9: 4764 10: 4220 11: 3830
12: 4370 13: 3837 14: 3859 15: 3819 16: 3861 17: 3786 18: 3217 19: 2590 20: 2636
21: 2600 22: 2592 23: 2594 24: 4414 25: 2626 26: 2913 27: 3858 28: 3802 29: 3807
30: 3632 31: 3213 32: 2627
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 470.57.02 bus-ID: 0b:00.0
Device-2: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Display: x11 server: X.Org 1.20.13 driver: loaded: nvidia resolution:
1: 1920x1080~60Hz 2: 1920x1080 3: 1920x1080
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0b:00.1
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 0e:00.4
Device-3: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2
Device-4: Schiit Audio Schiit Modi 3+ type: USB driver: snd-usb-audio
bus-ID: 3-2:3
Device-5: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-5:3
Device-6: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 7-1:2
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
Device-1: Realtek RTL8125 2.5GbE driver: r8169 v: kernel port: d000
bus-ID: 05:00.0
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: 3c:7c:3f:a6:c3:22
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
port: c000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: 24:4b:fe:5b:08:2a
IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
driver: btusb v: 0.8 bus-ID: 3-5.3:6
Local Storage: total: 4.01 TiB used: 2.11 TiB (52.7%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS100T3X0C-00SJG0
size: 931.51 GiB temp: 51.9 C
ID-2: /dev/nvme1n1 vendor: Western Digital model: WDS100T2B0C-00PXH0
size: 931.51 GiB temp: 46.9 C
ID-3: /dev/sda vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
ID-4: /dev/sdb type: USB vendor: Generic model: USB3.0 CRW -SD size: 238.3 GiB
ID-5: /dev/sdd type: USB vendor: Samsung model: Flash Drive FIT size: 119.51 GiB
ID-6: /dev/sde type: USB vendor: Toshiba model: TransMemory size: 14.92 GiB
ID-7: /dev/sdf type: USB vendor: SanDisk model: Gaming Xbox 360 size: 7.48 GiB
ID-1: / size: 767 GiB used: 640.9 GiB (83.6%) fs: btrfs dev: /dev/dm-0
mapped: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450
ID-2: /boot/efi size: 511 MiB used: 26.1 MiB (5.1%) fs: vfat dev: /dev/nvme0n1p1
ID-3: /home size: 767 GiB used: 640.9 GiB (83.6%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 64 GiB used: 437.8 MiB (0.7%) dev: /dev/dm-1
mapped: luks-81b2dc57-06f5-4471-b484-77c3a516f307
System Temperatures: cpu: 54.4 C mobo: N/A gpu: nvidia temp: 44 C
Processes: 818 Uptime: 3d 1h 55m Memory: 62.78 GiB used: 15.3 GiB (24.4%)
Init: systemd Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 2040 Shell: Bash
v: 5.1.8 inxi: 3.3.06
