This is somewhat similar to No Audio After Suspend? - #5, but after the last update, no there isn’t any audio at boot.
Pipewire is started:
sarah@MidnightStarSign:~$ systemctl --user status pipewire
● pipewire.service - Multimedia Service
Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; vendor preset: e>
Active: active (running) since Wed 2021-08-18 12:04:44 EDT; 10min ago
TriggeredBy: ● pipewire.socket
Main PID: 2966 (pipewire)
Tasks: 2 (limit: 77043)
Memory: 29.8M
CPU: 2.583s
CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.servi>
└─2966 /usr/bin/pipewire
Aug 18 12:04:44 MidnightStarSign systemd[2530]: Started Multimedia Service.
And ALSA and Pipewire are running:
sarah@MidnightStarSign:~$ inxi -A
Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Schiit Audio Schiit Modi 3+ type: USB driver: snd-usb-audio
Device-5: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
Device-6: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
Sound Server-1: ALSA v: k5.10.59-1-MANJARO running: yes
Sound Server-2: PipeWire v: 0.3.33 running: yes
Yet no audio plays over the headset (to avoid amplifier / speaker issues):
Killing Clementine and restarting Clementine does not help.
How can I restore audio?
EDIT 1:
I just noticed as well that applications don’t switch to a new audio source selected (like if I switched to the ASUS AI Noise Cancelling source, Clementine doesn’t migrate over, neither does pavucontrol. I can see this when I try and adjust the volume using the keyboard shortcut for volume up, it raises the previous audio source’s volume level instead of the current source’s volume level (The Schiit is currently changed to 95%, despite ASUS being selected).
