Kernel: 5.12.9-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.12-x86_64
root=UUID=42c59f7e-f1c3-4cbc-ab70-b06186e581b5 rw quiet udev.log_priority=3
idle=nomwait
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: VivoBook_ASUS Laptop X505ZA_X505ZA
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X505ZA v: 1.0 serial: <filter>
UEFI: American Megatrends v: X505ZA.313 date: 02/25/2020
ID-1: BAT0 charge: 19.5 Wh (83.7%) condition: 23.3/42.1 Wh (55.4%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: Discharging cycles: 1002
RAM: total: 6.8 GiB used: 1.71 GiB (25.2%)
Info: Quad Core model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101007 cache: L2: 2 MiB bogomips: 31949
Speed: 1369 MHz min/max: 1600/2000 MHz boost: enabled Core speeds (MHz):
1: 1369 2: 1442 3: 1368 4: 1368 5: 1367 6: 1370 7: 1367 8: 1368
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:15dd
class-ID: 0300
Device-2: IMC Networks USB2.0 VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 3-2.1:3 chip-ID: 13d3:5a03 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.40.0
5.12.9-1-MANJARO LLVM 12.0.0)
v: 4.6 Mesa 21.1.2 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.12.9-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 14.2 running: no
Sound Server-4: PipeWire v: 0.3.30 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
IP v6: <filter> type: deprecated dynamic noprefixroute scope: global
vendor: ASUSTeK driver: r8169 v: kernel port: f000 bus-ID: 02:00.0
bus-ID: 3-2.2:4 chip-ID: 8087:0a2b class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Permissions: Unable to run lvs. Root privileges required.
Local Storage: total: 931.51 GiB used: 37.08 GiB (4.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 82.12 GiB size: 80.28 GiB (97.76%) used: 37.04 GiB (46.1%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: 42c59f7e-f1c3-4cbc-ab70-b06186e581b5
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 36.5 MiB (14.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: SYSTEM
uuid: 226E-201B
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 356.67 GiB fs: <superuser required>
label: OS uuid: DE1E71131E70E5C5
ID-3: /dev/sda5 maj-min: 8:5 size: 468.6 GiB fs: <superuser required>
label: New Volume uuid: 0402A78D02A78272
ID-4: /dev/sda7 maj-min: 8:7 size: 850 MiB fs: <superuser required>
label: RECOVERY uuid: A04AD8624AD8372E
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-4: 3-2:2 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 3-2.1:3 info: IMC Networks USB2.0 VGA UVC WebCam type: Video
Device-2: 3-2.2:4 info: Intel Bluetooth wireless interface type: Bluetooth
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 66.0 C mobo: 0 C gpu: amdgpu temp: 66.0 C
Fan Speeds (RPM): cpu: 3900
Processes: 244 Uptime: 17m wakeups: 1 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: pacman: 1097 lib: 298 Shell: Bash v: 5.1.8
running-in: konsole inxi: 3.3.04
Welcome to Manjaro!
- Please read this:
How to provide good information
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
- An
inxi --admin --verbosity=7 --filter --no-host --widthwould be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
Also, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text. - Does this also happen when you create a new user and log in there? (E.G.
Zexu_knub2)
edited…
& yes, i tried creating new user too
- You’re on an AMD GPU machine with 6GB RAM without swap
- I don’t run discord
so I can’t help you any further so let’s hope one of our users uses Discord on an AMD and is able to help you more intelligently than me!
No solution, but for reference. I run gnome stable with a nvidia gpu and proprietary drivers and can see screens to share with the client from the community repository. (Stable 89294 (f4e00f9)) There are other clients as in snaps iirc that could be old or not work correctly and probably some AUR options to. Are you up to date? Does your journal spit out any useful info journalctl --follow or throw any errors when starting from the terminal?
It might be GPU related.
Set up swap
I’ve installed from official repo & it’s always up to date. i tried XFCE recently & it was working there so idt it’s because of swap partition.
-- Journal begins at Sun 2021-06-20 16:42:25 IST. --
Jul 02 16:11:53 x505 plasmashell[1023]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Jul 02 16:11:53 x505 kwin_x11[964]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20747, resource id: 35651843, major code: 18 (ChangeProperty), minor code: 0
Jul 02 16:11:53 x505 systemd[890]: Started Konsole - Terminal.
Jul 02 16:11:54 x505 konsole[3138]: Icon theme "candy-icons" not found.
Jul 02 16:11:54 x505 konsole[3138]: Icon theme "ubuntu-mono-dark" not found.
Jul 02 16:11:54 x505 konsole[3138]: Icon theme "Mint-X" not found.
Jul 02 16:11:54 x505 konsole[3138]: Icon theme "elementary" not found.
Jul 02 16:11:54 x505 kwin_x11[964]: QPainter::begin: Paint device returned engine == 0, type: 3
Jul 02 16:11:54 x505 plasmashell[1023]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/main.qml:464: TypeError: Cannot read property 'length' of undefined
Jul 02 16:11:56 x505 konsole[3138]: qt.xkb.compose: failed to create compose table
Sorry for not being clear: swap is not related to your specific problem it’s just better for a 6GB machine…
