Nintendo Switch: System reports device is busy
Hello
I have limpt error when I try do connect my Nintendo Switch (via DBI) to my laptop.
In Win10 it works fine and I can transfer files.
Any help on how to solve this?
[jesuslinux@A4910MJ ~]$ mtpfs
Listing raw device(s)
Device 0 (VID=057e and PID=201d) is a Nintendo Switch / Switch Lite.
   Found 1 device(s):
   Nintendo: Switch / Switch Lite (057e:201d) @ bus 1, dev 4
Attempting to connect device
libusb_claim_interface() reports device is busy, likely in use by GVFS or KDE MTP device handling alreadyLIBMTP PANIC: Unable to initialize device
Unable to open raw device 0
Have you tried rebooting? That might free up whatever is busy.
Related thread:
I read that post prior to posting myself.
System is updated.
I rebooted and the issue persists.
Cannot transfer files from PC to device.
Device shows:
Bus 001 Device 002: ID 057e:201d Nintendo Co., Ltd DBI
[jesuslinux@A4910MJ ~]$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 002 Device 002: ID 152d:0578 JMicron Technology Corp. / JMicron USA Technology Corp. JMS578 SATA 6Gb/s
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 002: ID 0438:7900 Advanced Micro Devices, Inc. Root Hub
Bus 003 Device 003: ID 1bcf:2c87 Sunplus Innovation Technology Inc. HP Wide Vision HD
Bus 003 Device 004: ID 0bda:b008 Realtek Semiconductor Corp. Bluetooth Radio
Bus 003 Device 005: ID 3938:1031 MOSART Semi. 2.4G Wireless Mouse
Does the device appear in Thunar? You might need gvfs-mtp for that functionality if you don’t already have it installed. If you do, it’s possible that GVFS is automounting it stopping MTPfs from accessing it.
What’s the output of mtp-detect?
The device appear in Thunar. It is when I try do copy files from PC to device partition that I get the error:
[jesuslinux@A4910MJ ~]$ mtp-detect
libmtp version: 1.1.22
   Found 1 device(s):
Attempting to connect device(s)
Android device detected, assigning default bug flags
USB low-level info:
   bcdUSB: 512
   bDeviceClass: 0
   bDeviceSubClass: 0
   bDeviceProtocol: 0
   idVendor: 057e
   idProduct: 201d
   IN endpoint maxpacket: 512 bytes
   OUT endpoint maxpacket: 512 bytes
   Raw device info:
      Bus location: 1
      Device number: 4
      Device entry info:
         Vendor: Nintendo
         Vendor id: 0x057e
         Product: Switch / Switch Lite
         Product id: 0x201d
         Device flags: 0x18008106
Configuration 0, interface 0, altsetting 0:
   Interface description contains the string "MTP"
   Device recognized as MTP, no further probing.
Device info:
   Manufacturer: Nintendo
   Model: Switch
   Device version: 21.2.0
   Serial number: XTJ10848261211
   Vendor extension ID: 0x00000006
   Vendor extension description: microsoft.com: 1.0; android.com: 1.0;
   Detected object size: 64 bits
   Extensions:
        microsoft.com: 1.0
        android.com: 1.0
Supported operations:
   1001: Get device info
   1002: Open session
   1003: Close session
   1004: Get storage IDs
   1005: Get storage info
   1007: Get object handles
   1008: Get object info
   1009: Get object
   100b: Delete object
   100c: Send object info
   100d: Send object
   1014: Get device property description
   1015: Get device property value
   1016: Set device property value
   1019: Move object
   101b: Get partial object
   95c1: Get Partial Object (64bit Offset)
   95c2: Send Partial Object
   95c3: Truncate Object
   95c4: Begin Edit Object
   95c5: End Edit Object
   9801: Get object properties supported
   9802: Get object property description
   9803: Get object property value
   9804: Set object property value
   9805: Get object property list
   9808: Send object property list
Events supported:
   0x4002: ObjectAdded
   0x4003: ObjectRemoved
   0x4004: StoreAdded
   0x4005: StoreRemoved
   0x400e: UnreportedStatus
   0x4007: ObjectInfoChanged
   0xc801: ObjectPropChanged
Device Properties Supported:
   0xd402: Friendly Device Name
   0xd406: Session Initiator Info
Playable File (Object) Types and Object Properties Supported:
   3000: Undefined Type
      dc41: Persistant Unique Object Identifier UINT128 data type READ ONLY GROUP 0x0
      dc01: Storage ID UINT32 data type ANY 32BIT VALUE form READ ONLY GROUP 0x0
      dc0b: Parent Object UINT32 data type ANY 32BIT VALUE form GET/SET GROUP 0x0
      dc02: Object Format UINT16 data type ANY 16BIT VALUE form READ ONLY GROUP 0x0
      dc04: Object Size UINT64 data type READ ONLY GROUP 0x0
      dc44: Name STRING data type GET/SET GROUP 0x0
   3001: Association/Directory
Storage Devices:
   StorageID: 0x00010001
      StorageType: 0x0004 removable RAM storage
      FilesystemType: 0x0002 generic hierarchical
      AccessCapability: 0x0000 read/write
      MaxCapacity: 492411289600
      FreeSpaceInBytes: 339388923904
      FreeSpaceInObjects: 1073741824
      StorageDescription: 1: SD Card
      VolumeIdentifier:
   StorageID: 0x00010002
      StorageType: 0x0001 fixed ROM storage
      AccessCapability: 0x0001 read only
      MaxCapacity: 16507699200
      FreeSpaceInBytes: 15808167936
      StorageDescription: 2: Nand USER
      VolumeIdentifier:
   StorageID: 0x00010003
      MaxCapacity: 2683027456
      FreeSpaceInBytes: 1150959616
      StorageDescription: 3: Nand SYSTEM
      VolumeIdentifier:
   StorageID: 0x00010005
      StorageDescription: 5: SD Card install
      VolumeIdentifier:
   StorageID: 0x00010006
      StorageType: 0x0003 fixed RAM storage
      StorageDescription: 6: NAND install
      VolumeIdentifier:
   StorageID: 0x00010007
      StorageDescription: 7: Saves
      VolumeIdentifier:
   StorageID: 0x00010008
      AccessCapability: 0x0002 read only + object deletion
      MaxCapacity: 0
      FreeSpaceInBytes: 0
      StorageDescription: 8: Album
      VolumeIdentifier:
Special directories:
   Default music folder: 0xffffffff
   Default playlist folder: 0xffffffff
   Default picture folder: 0xffffffff
   Default video folder: 0xffffffff
   Default organizer folder: 0xffffffff
   Default zencast folder: 0xffffffff
   Default album folder: 0xffffffff
   Default text folder: 0xffffffff
MTP-specific device properties:
   Friendly name: DBI MTP Responder
   Synchronization partner: (NULL)
libmtp supported (playable) filetypes:
   Folder
OK.
Try (at least temporarily) uninstalling gvfs-mtp, reboot then see if it makes any difference.
Please edit your topic title to be clear and concise about the actual issue. It seems neither libmtp nor thunar are related.
HI @JesusLinux,
Just another angle… :triangular_ruler:
When i have troubles with connecting with android phone, I install.
android-file-transfer
Maybe it needs a reboot after installation.
Out o curiosity:
I have MX Linux XFCE installed on dual boot with Manjaro XFCE on the same machine.
On MX Linux file transfer works as expected no libmtp error…
@JesusLinux
You have been asked to change the topic title, but either missed or ignored the request. I have taken the liberty of renaming your topic title to: “Nintendo Switch: System reports device is busy”. :eyes:
Is there a question here?
Information that might possibly be useful:
1. Which GRUB instance is being used to boot these OS instances?
  • GRUB installed by MX Linux XFCE?
  • GRUB installed by Manjaro XFCE?
  • Something else?
2. Does it make a difference if you shutdown MX Linux (instead of rebooting directly) and waiting a minute or two before then booting into Manjaro?
Sorry I didn’t know what I should rename the topic to…
1 - The GRUB Being used is the MX Linux one.
2 - The issue started at first boot into Manjaro. In Thunar it says the error above.
I boot into MX and it works with no problems…
