Desktop profile: kde.
I tried to connect an Android phone via mtp, but it failed. The error message is as follows:
$ mtpfs
Listing raw device(s)
Device 0 (VID=12d1 and PID=107e) is a Huawei P9 Plus.
Found 1 device(s):
Huawei: P9 Plus (12d1:107e) @ bus 1, dev 14
Attempting to connect device
libusb_claim_interface() reports device is busy, likely in use by GVFS or KDE MTP device handling alreadyLIBMTP PANIC: Unable to initialize device
Unable to open raw device 0
It shows that my device is busy and may be occupied by GVFS or KDE MTP. I tried to kill them, but it didn’t work.
I have the following questions:
- I cannot see any device mount points under the /run/user/1000/gvfs folder. This is an empty folder. How to deal with this?
- How to solve the problem of GVFS or KDE MTP occupying my device?
- How can I directly use GVFS or KDE MTP to access my device? The operation of the command line environment is required, and the operation of the GUI environment is not required.
Make sure the gvfs-mtp package is installed. It adds and activates the service gvfs-mtp-volume-monitor.service and that should have to give you access to Dolphin to mount it, or trough the System Tray notifications and disk & devices actions to mount and open.
Usually the mtp should happen in mtp:/device_name/*storage once the path
mtp:udi=/org/kde/solid/udev/sys/devices/pciXXXX:XX/YYYY:ZZ:Xa.Z/usbX/Y-Z/
is activated …
Make sure your mobile is set for USB storage when connected to PC.
Dolphin can access my phone normally, and the gvfs-mtp package has been installed, but gvfs-mtp-volume-monitor.service does not exist.
$ sudo systemctl start gvfs-mtp-volume-monitor
Failed to start gvfs-mtp-volume-monitor.service: Unit gvfs-mtp-volume-monitor.service not found.
gvfs is still an empty folder.
Is a user unit, and usually should not be loaded, but unloaded … i think because is using dbus org.gtk.vfs.MTPVolumeMonitor
Once you connect the device trough USB there should be a notification and the option to mount it.
Do you have the same issue trough KDE Connect ?
There is no problem with the KDE Connect link. It can accurately detect the SD card and internal memory in my Android device.
