New pending updates break my system
Whenever updates are available and I go to click on the package manager in system tray, it doesn’t open. Nothing will open. I have to hard restart. Apply updates. Then restart again.
Why would the operating system fail at this similar point almost every time, all but one update this past year has caused this.
No programs will run. Not konsole, not settings, not system utilities, not even system activity monitor will launch.
Most the time I get an error about system bus lost connection. Apologies for not having the verbatim error, it didn’t flash that this time. >> this is the error “Message recipient disconnected from message bus without replying”
Its so odd.
EDIT:: Ive always ran into this bug when I go to launch a “system Utility” such as night color control, add/remove programs, and sometimes task manager or system settings. I have no idea how long the issue sits just fine for, until I finally notice system tray indicator on updates or go to open task manager or other system tool.
Its likely no more than 24hrs before I notice and have to hard reset due to opening up night color control everyday, except maybe a day or two every few months.
Everything else works just fine or at least Ive not noticed anything else.
EDIT 2:: Logs based on the command given in the first reply. This log is NOT from before or after the bug occurs. Unless someone has some ideas, I wont be able to get logs at the time of noticing the bug; none of the terminal/cmd line programs will launch…altho, Yakuake might still function properly but I cannot explicitly recall trying to use that for restarting
 sudo inxi --admin --verbosity=7 --filter --no-host --width         ✔
[sudo] password for [username redacted]:
  Kernel: 6.1.66-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet available: acpi_pm
    root=UUID=ca7fd84c-5967-473c-a2d8-bb37fb208f2e rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASRock model: B450M Pro4 serial: <filter>
    UEFI: American Megatrends v: P5.00 date: 03/08/2021
  Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
    serial: <filter> charge: 100% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 30.74 GiB used: 15.12 GiB (49.2%)
  Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 8 GiB speed: 2667 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK32GX4M4Z2933C16
    serial: N/A
  Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2Z2933C16
    serial: N/A
  Device-3: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
    serial: N/A
  Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
    serial: N/A
  Info: model: AMD Ryzen 5 5600G with Radeon Graphics socket: AM4 bits: 64
    type: MT MCP arch: Zen 3 gen: 4 level: v3 note: check built: 2021-22
    microcode: 0xA50000B
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 16 MiB
    desc: 1x16 MiB
  Speed (MHz): avg: 1400 min/max: 1400/3900 boost: enabled
    base/boost: 3900/4450 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.4 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
    5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    bogomips: 93646
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
  Type: spec_rstack_overflow mitigation: safe RET, no microcode
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Micro-Star MSI
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: DP-1,HDMI-A-1 empty: DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:73ff
    class-ID: 0300
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    driver: N/A alternate: amdgpu arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 0a:00.0 chip-ID: 1002:1638 class-ID: 0300
  Display: server: X.Org v: 21.1.9 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1185x381mm (46.65x15.00")
    s-diag: 1245mm (49.01")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-right
    model: LG (GoldStar) ULTRAGEAR serial: <filter> built: 2022 res: 2560x1440
    hz: 120 dpi: 93 gamma: 1.2 size: 697x392mm (27.44x15.43")
    diag: 800mm (31.5") ratio: 16:9 modes: max: 2560x1440 min: 640x350
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-l model: BenQ GL2480
    serial: <filter> built: 2020 res: 1920x1080 dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
    16.0.6 DRM 3.49 6.1.66-2-MANJARO) device-ID: 1002:73ff memory: 7.81 GiB
    unified: no
  API: Vulkan v: 1.3.269 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.1.9-manjaro1.1
    device-ID: 1002:73ff surfaces: xcb,xlib
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s bus-ID: 0a:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    speed: 16 GT/s bus-ID: 0a:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.66-2-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.0 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-2:2
    chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
  Local Storage: total: 3.24 TiB used: 1.75 TiB (54.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 28.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 92d 21h cycles: 243
    read-units: 39,504,203 [20.2 TB] written-units: 260,576,451 [133 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Smart Modular Tech.
    model: SHGS31-1000GS-2 family: SATA SSDs size: 931.51 GiB block-size:
    physical: 4096 B logical: 512 B sata: 3.2 speed: 6.0 Gb/s tech: SSD
    serial: <filter> fw-rev: 0Q00 temp: 29 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 336d 20h cycles: 131
    Old-Age: threshold: 1
  ID-3: /dev/sdb maj-min: 8:16 vendor: Smart Modular Tech.
    serial: <filter> fw-rev: 0Q00 temp: 27 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 2y 326d 12h cycles: 131
  ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT1000MX500SSD4
    family: Micron Client SSDs size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 023 temp: 54 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 3y 74d 15h cycles: 123
    written: 1.57 TiB
  ID-5: /dev/sdd maj-min: 8:48 vendor: Transcend model: N/A size: 59.62 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s
    lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: TS3A
    scheme: MBR
  ID-1: / raw-size: 465.46 GiB size: 457.09 GiB (98.20%)
    used: 208.31 GiB (45.6%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p2
    maj-min: 259:2 label: N/A uuid: ca7fd84c-5967-473c-a2d8-bb37fb208f2e
    used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: NO_LABEL uuid: 4D0D-8D3C
  ID-3: /run/media/ziward/btc raw-size: 931.51 GiB size: 915.82 GiB (98.31%)
    used: 603.06 GiB (65.8%) fs: ext4 block-size: 4096 B dev: /dev/sdb1
    maj-min: 8:17 label: btc uuid: 06fcec6d-12b0-43c3-a429-875af300ad78
  ID-4: /run/media/ziward/data raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 736.94 GiB (80.5%) fs: ext4 block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: data uuid: 075c599c-8985-4f56-aed0-6955f7a5f131
  ID-5: /run/media/ziward/ilmwlod raw-size: 931.51 GiB
    size: 915.82 GiB (98.31%) used: 248.34 GiB (27.1%) fs: ext4
    block-size: 4096 B dev: /dev/sdc1 maj-min: 8:33 label: ilmwlod
    uuid: bbcc533f-8082-4922-b434-00d26ee5dd65
  ID-1: /dev/sdd1 maj-min: 8:49 size: 59.61 GiB fs: exfat label: N/A uuid: N/A
  Device-1: 1-2:2 info: ASUSTek Broadcom BCM20702A0 Bluetooth type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
  Device-2: 1-5:3 info: Logitech Nano Receiver type: mouse,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c526 class-ID: 0300
  Device-3: 1-6:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-1: 2-3:2 info: Transcend Information microSD/SD/CF UHS-II Card
    Reader [RDF8 RDF9] type: mass storage driver: usb-storage interfaces: 1
    rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1
    power: 896mA chip-ID: 8564:4000 class-ID: 0806 serial: <filter>
  Device-1: 3-1:2 info: DragonRise GameCube Controller Adapter type: HID
    driver: hid_mf,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 0079:1846 class-ID: 0300
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-1:4 info: Usb KeyBoard type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: c0f4:04d0 class-ID: 0300
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 35.6 C mobo: N/A gpu: amdgpu temp: 54.0 C
    mem: 66.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 2053
  Processes: 411 Uptime: 21h 7m wakeups: 0 Init: systemd v: 254
  Packages: 1655 pm: pacman pkgs: 1624 libs: 467 tools: pamac pm: flatpak
  pkgs: 31 Shell: Sudo (sudo) v: 1.9.15p2 default: Bash v: 5.2.21
  running-in: yakuake inxi: 3.3.31
Did you forget, to include some error-logs ?
Please try the update in a terminal and provide logs :wink:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
Gentle shut down a suddenly hanged PC to minimize a chance of getting a broken filesystem and data loss:
I feel like we saw a few ‘pamac (tray) crashes’ threads …
There is this one that is unresolved …
For now I might suggest 2 things;
Mirrors and update using pacman:
sudo pacman-mirrors -f && sudo pacman -Syu
Backup pamac config:
mv ~/.config/pamac/config ~/.config/pamac/config.bak
Didnt have email notifications on. Thanks for the leads. Ill get around to posting logs within a day or two.
I was frustrated, flustered, and lacking time on the date of my og post to go look up what logs to post and what commands are needed to do so.
Starting the thread as I did has now provided me the log info commands as well as a few others things I look into first. I think thats a better result than if I woulda pulled my hair out trying to include all the log info. I just wanted to get a solution moving forward. I appreciate the input so far.
