Magacu
30 September 2024 17:36
1
Hey, Im pretty much a complete noob (this is my first time trying something else than windows) and decided to try using Manjaro on my new laptop since im studying software.
However, Ive found myself in a quite lot of problems, and this is one of them.
My sound doesnt work, at least from speakers (i have not been able to try it on headphones) even though, according to the computer and alsamixer, there is sound playing. Some help?
Some specifications:
Kernel: 6.9.12-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro base: Arch Linux
Device-1: Intel Raptor Lake-P/U/H cAVS vendor: Micro-Star MSI
driver: sof-audio-pci-intel-tgl bus-ID: 0000:00:1f.3
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 0000:01:00.1
API: ALSA v: k6.9.12-3-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 1.2.3 status: active
Edit: show terminal response with preformatted text – nikgnomic
Wollie
30 September 2024 20:49
2
First thing to do after installing is to update the system, e.g. via
sudo pacman -Syu
and to reboot afterwards.
This kernel is “End Of Life” and should be replaced by another kernel. This can be done by the Manjaro Settings Manager (GUI) for example. After installing another kernel, reboot and delete kernel 6.9.
Further details:
Okay, so Ive installed 6.6.52-1-MANJARO and updated the system just as you said, and audio isnt working yet
Kernel: 6.6.52-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
Desktop: KDE Plasma v: 6.1.5 Distro: Manjaro base: Arch Linux
API: ALSA v: k6.6.52-1-MANJARO status: kernel-api
Server-2: PipeWire v: 1.2.3 status: active ````
The kernel and the audio are mutually exclusive.
You have an audio issue (it… doesn’t work)
You also had a kernel issue (it needed to be replaced)
Replacing the kernel wasn’t expected to magically fix your audio.
I hope that clears it up.
Cheers.
Alright, thank you! I just wasnt sure if changing the kernel it would help with it.
Still, I hope to find a way because Im not yet sure of why it isnt working, in case someone is able to help
And neither is anyone else (yet).
There’s no mention of anything audio related in today’s round of updates. However, there’s this pipewire-pulse conflicts with pulseaudio-ctl dating back to 2024-08-08. Maybe that’s related, maybe not.
If you provide the output from:
inxi --admin --verbosity=8 --filter --no-host --width
this might give others a better perspective.
Install these two packages:
sof-firmware and sof-tools by
sudo pacman -Syu sof-firmware sof-tools
and reboot.
Ill try diving into that in a bit, meanwhile, heres what ive got:
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:51ca class-ID: 0401
bus-ID: 0000:01:00.1 chip-ID: 10de:22be class-ID: 0403
API: ALSA v: k6.6.52-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
Welcome to Manjaro and our Forum
Magacu:
So you just fresh installed your system and used a older ISO?
I hope not, because its important to use the newest ISO on a Rolling Release Distro.
Wollie
1 October 2024 18:19
10
As long as you are able to update them, older ISO are no general problem to be used.
Kobold
1 October 2024 18:22
11
But what about regression? Isn’t Kernel 6.9 EOL since 2 month now?
Doesn’t that mean the ISO could be older than 3 month at least?
Kobold
1 October 2024 18:27
13
Magacu:
heres what ive got:
There is no need to cut your system info’s… this terminal System Info’s respect your privacy and hide your IP/MAC adress.
Don’t worries, we aren’t a Microsoft Forum and spying in your privacy
Btw. Alsamixer (terminal menue) gives you also access and adjustments around your Sound Device.
Wollie
1 October 2024 19:07
14
If you can update from the installed system, the ISO was fine. In case of an EOL kernel you need to switch to another kernel soon, yes, but this is required from time to time anyway as long you are not using an LTS-kernel.
For a Raptor Lake this could be smart amplifiers not working for audio to speakers
Please post more information about audio devices detected in ALSA
sudo alsa-info.sh --upload
Magacu
2 October 2024 16:13
16
Magacu
2 October 2024 16:14
17
Also heres what I see on alsamixer:
Magacu
4 October 2024 12:10
18
Still trying but haven´t found a solution.
I posted my alsa and here are some more information:
root=UUID=4c75799c-d4a2-4718-b0e3-dd118a43cce6 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Laptop System: Micro-Star product: Cyborg 15 A13VF v: REV:1.0
Mobo: Micro-Star model: MS-15K1 v: REV:1.0 serial: <superuser required>
part-nu: 15K1.1 uuid: <superuser required> UEFI: American Megatrends LLC.
v: E15K1IMS.112 date: 07/09/2024
ID-1: BAT1 charge: 50.7 Wh (100.0%) condition: 50.7/52.0 Wh (97.4%)
volts: 12.9 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A status: full
System RAM: total: 32 GiB available: 31.06 GiB used: 4.43 GiB (14.3%)
Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s volts: note: check
curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M425R2GA3BB0-CWMOD serial: <filter>
Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
Info: model: 13th Gen Intel Core i7-13620H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4122
Topology: cpus: 1x dies: 1 clusters: 7 cores: 10 threads: 16 mt: 6 tpc: 2
st: 4 smt: enabled cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32
KiB, 4x64 KiB L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 24 MiB
desc: 1x24 MiB
Speed (MHz): avg: 400 min/max: 400/4700:4900:3600 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 93424
de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb
pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp
rep_good sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
xtopology xtpr
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-13 process: Intel 7 (10nm) built: 2022+
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:a7a8 class-ID: 0300
Device-2: NVIDIA AD107M [GeForce RTX 4060 Max-Q / Mobile]
vendor: Micro-Star MSI driver: N/A alternate: nouveau non-free: 550.xx+
status: current (as of 2024-09) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ bus-ID: 0000:01:00.0 chip-ID: 10de:28a0
class-ID: 0300
Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 30c9:0042
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green: x: 0.329
y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a8 memory: 15.16 GiB unified: yes
API: Vulkan v: 1.3.295 layers: 4 device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.2.2-arch1.1
device-ID: 8086:a7a8 surfaces: xcb,xlib
Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 0000:00:14.3 chip-ID: 8086:51f1 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000
bus-ID: 0000:04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0033
class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller Intel
driver: vmd v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:a77f rev:
class-ID: 0104
Local Storage: total: 953.87 GiB used: 124.37 GiB (13.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA1T0QFM
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: V3MA002 temp: 39.9 C
scheme: GPT
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%)
used: 124.37 GiB (13.3%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 4c75799c-d4a2-4718-b0e3-dd118a43cce6
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: CC43-3FA8
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-4:2 info: Wacom CTH-490 [Intuos Art/Photo/Comic (S)]
type: HID,mouse driver: usbhid,wacom interfaces: 3 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 498mA
chip-ID: 056a:033c class-ID: 0301
Device-2: 1-6:3 info: Luxvisions Innotech Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 30c9:0042 class-ID: 0e02 serial: <filter>
Device-3: 1-10:4 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0033 class-ID: e001
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1418 libs: 454 tools: pamac pm: flatpak pkgs: 0
1: https://mirror.23m.com/manjaro/stable/$repo/$arch
2: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
3: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
4: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
5: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 321
1: cpu: 29.5% command: firefox pid: 1400 mem: 527.9 MiB (1.6%)
2: cpu: 9.4% command: firefox pid: 5112 mem: 225.8 MiB (0.7%)
3: cpu: 6.1% command: kwin_x11 pid: 926 mem: 178.3 MiB (0.5%)
4: cpu: 4.8% command: Xorg pid: 766 mem: 79.9 MiB (0.2%)
5: cpu: 4.7% command: firefox pid: 1655 mem: 385.3 MiB (1.2%)
Memory top: 5 of 321
1: mem: 527.9 MiB (1.6%) command: firefox pid: 1400 cpu: 29.5%
2: mem: 411.7 MiB (1.2%) command: plasmashell pid: 991 cpu: 2.1%
3: mem: 410.0 MiB (1.2%) command: firefox pid: 2661 cpu: 1.0%
4: mem: 385.3 MiB (1.2%) command: firefox pid: 1655 cpu: 4.7%
5: mem: 267.8 MiB (0.8%) command: firefox pid: 1648 cpu: 3.2%
Processes: 321 Power: uptime: 35m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend,
test_resume image: 12.41 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.32
running-in: konsole inxi: 3.3.36
Have you tried looking at some of these suggestions here and here ?
Likely unrelated to this issue, but you should probably configure swap sooner rather than later. You have none, which may be detrimental for any applications that require it.
Cheers.
