Just wondering … have you tried muting and unmuting or restarting the wireplumber and/or pipewire services ?
I wonder if it is the same as here:
Which, by the way, should be fixed with pipewire 1.2.5, which is currently in Unstable branch.
Ive seen both, not my case. I can see my speakers (with go accordingly to the sound card) and it detects sound, even if I cannot hear it. Thanks tho!
I have no idea what swap is lol, ill look into it, thanks!!
Yep, just tried and the problem is still here, thank you thought!
Tried what?? Did you try modifying your grub file in the way suggested in one of my links?
ALSA is a kernel API
Install these two packages:
sof-firmware and sof-tools
sof-firmware is included in Manjaro ISOs
no-audio-and-failure-to-shutdown-on-manjaro-xfce
snd-intel-dspcfg dsp_driver=1patch to force use of snd_hda_intel driver was a very useful workaround in 2020/2021, but is no longer neededOfficial Manjaro ISOs now include package
sof-firmware.
Sound Open Firmware drivers should be installed and working on Live ISOs for most Intel laptops
andinxidata shows system is already using an SOF driver
But sof-tools is a new package
Have you tried looking at some of these suggestions…
1st suggestion is from 4 years ago
https://askubuntu.com/questions/1243369/sound-card-not-detected-ubuntu-20-04-sof-audio-pci
The accepted answer is only a temporary solution, as after implementing it, my microphone no longer worked.A more permanent solution would be to install the SOF firmware binaries from here: GitHub - thesofproject/sof-bin: Firmware and topology binaries
but inxi data shows system is using an SOF driver
2nd suggestion is to update firmware - MSI - Cyborg-15-A13VF
If PipeWire update does not work I suggest install latest stable kernel that may contain a patch for onboard audio
sudo mhwd-kernel -i linux610
Better to add modprobe options in /etc/modprobe.d/ than modifying /etc/default/grub
Related to your Alsa screenshot, you have some devices Muted (look at the MM). You can unmute/mute with m key.
You have also additional settings, press the arrow keys to the right side.
Indeed; wonder if it’s the auto-mute setting (Enabled); also it looks like the Headphones are muted. If you’re plugging the speakers in via the headphone jack, this will explain no sound.
I’m not sure if Master and Speaker are actually at 100 but the 1 is not being shown here, just the last two digits?
ALSA mixer control Auto-Mute Mode is set to Enabled, so if headphones were plugged-in the Speaker output would be muted and Headphone output unmuted
If ALSA mixer control Auto-Mute Mode is set to Disabled both Speaker and Headphone outputs can be unmuted
