TL;DR - how can I delete all network connection data from the system(not from the “System Settings Module” - I already tried that)? UPDATE - Tried wiping all the data. Didn’t work.
I have recently replaced my router with one that has both 5Ghz WiFi and 2.4Ghz (both “working” at the same time). Apart from the SSID and frequency, both connections have the same configuration - despite that, Manjaro can only connect to the 5Ghz connection - when I attempt to connect to the 2.4Ghz one, it’s always stuck at “configuring interface” and asks me for the password every minute or so (I triple checked to see if it was the correct password, and it was). I can guarantee that it’s not a hardware problem, and that it’s also not a problem from the way that the WiFi is configured - as both connections are nearly identical in terms of how they’re configured. After the 3rd time it asks for a password or so, it stops and says “wireless interface - no secrets were provided”. I looked in the logs and it just says association timed out reason=conn failed.
Now to the important part - I think I know what’s going on, I did use absolutely the same WiFi SSID with the other router as the SSID I’m using for the 2.4Ghz connection right now - maybe, with no better way of saying this coming to mind, there is some left-over data from the old connection and that’s what’s causing the errors. I tried deleting the connection from the System Settings Module, several times, but it didn’t fix anything. Maybe deleting absolutely all network connection data with a terminal command or just simply deleting a file might fix the issue. Perhaps my googling skills just failed me but I haven’t found anything of the sort when I searched for it. Any other recommendations are of course welcome.
System information
Kernel: 5.8.18-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
root=UUID=49267eb0-b637-4c0d-8186-3b4f1567a55b rw quiet apparmor=1
security=apparmor resume=UUID=77cc4b1c-18f1-4758-9ca5-2c7558bd6e1e
udev.log_priority=3
Desktop: KDE Plasma 5.20.3 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Convertible System: ASUSTeK product: ZenBook UX463FL_UX463FL v: 1.0
serial: <filter>
Mobo: ASUSTeK model: UX463FL v: 1.0 serial: <filter>
UEFI: American Megatrends v: UX463FL.304 date: 12/17/2019
ID-1: BAT0 charge: 29.5 Wh condition: 45.9/50.0 Wh (92%) volts: 11.9/11.9
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Discharging
cycles: 55
Device-1: hid-0018:04F3:29B9.0001-battery model: ELAN9008:00 04F3:29B9
serial: N/A charge: N/A status: N/A
Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 8E (142) stepping: C (12) microcode: DE
L2 cache: 8192 KiB
bogomips: 36812
Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: NVIDIA GP108BM [GeForce MX250] vendor: ASUSTeK driver: nvidia
v: 450.80.02 alternate: nouveau,nvidia_drm bus ID: 02:00.0
chip ID: 10de:1d52
Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
bus ID: 1-5:4 chip ID: 13d3:56cb serial: <filter>
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11
driver: modesetting,nvidia unloaded: intel,nouveau alternate: fbdev,nv,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.2.2
direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.8.18-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 4000
bus ID: 00:14.3 chip ID: 8086:02f0
Local Storage: total: 953.87 GiB used: 15.02 GiB (1.6%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB1T0HALR-00000
size: 953.87 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: EXA7301Q scheme: GPT
ID-1: / raw size: 200.00 GiB size: 195.86 GiB (97.93%)
used: 14.38 GiB (7.3%) fs: ext4 dev: /dev/nvme0n1p6
ID-2: /home raw size: 150.00 GiB size: 146.64 GiB (97.76%)
used: 654.0 MiB (0.4%) fs: ext4 dev: /dev/nvme0n1p5
ID-1: swap-1 type: partition size: 8.00 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7
System Temperatures: cpu: 40.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 226 Uptime: 8m Memory: 15.42 GiB used: 1.65 GiB (10.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 clang: 11.0.0 Packages: 1277
pacman: 1271 lib: 366 flatpak: 6 Shell: Bash v: 5.0.18 running in: yakuake
inxi: 3.1.08
System log when trying to connect to the network
2 2/11/2020 12:41 wpa_supplicant wlo1: Trying to associate with 40:9b:cd:a5:0e:b4 (SSID='007' freq=2432 MHz)
22/11/2020 12:41 NetworkManager <info> [1606041702.2397] device (wlo1): supplicant interface state: authenticating -> associating
22/11/2020 12:41 NetworkManager <info> [1606041702.2397] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
22/11/2020 12:41 kernel wlo1: authenticated
22/11/2020 12:41 kernel wlo1: associate with 40:9b:cd:a5:0e:b4 (try 1/3)
22/11/2020 12:41 kernel wlo1: associate with 40:9b:cd:a5:0e:b4 (try 2/3)
22/11/2020 12:41 kernel wlo1: associate with 40:9b:cd:a5:0e:b4 (try 3/3)
22/11/2020 12:41 kernel wlo1: association with 40:9b:cd:a5:0e:b4 timed out
22/11/2020 12:41 wpa_supplicant wlo1: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="007" auth_failures=1 duration=10 reason=CONN_FAILED
22/11/2020 12:41 NetworkManager <info> [1606041702.5824] device (wlo1): supplicant interface state: associating -> disconnected
22/11/2020 12:41 NetworkManager <info> [1606041702.5825] device (p2p-dev-wlo1): supplicant management interface state: associating -> disconnected
22/11/2020 12:41 NetworkManager <info> [1606041712.5834] device (wlo1): supplicant interface state: disconnected -> scanning
22/11/2020 12:41 NetworkManager <info> [1606041712.5835] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
22/11/2020 12:41 wpa_supplicant wlo1: CTRL-EVENT-SSID-REENABLED id=0 ssid="007"
22/11/2020 12:41 wpa_supplicant wlo1: SME: Trying to authenticate with 40:9b:cd:a5:0e:b4 (SSID='007' freq=2432 MHz)
22/11/2020 12:41 kernel wlo1: authenticate with 40:9b:cd:a5:0e:b4
22/11/2020 12:41 kernel wlo1: send auth to 40:9b:cd:a5:0e:b4 (try 1/3)
22/11/2020 12:41 NetworkManager <info> [1606041713.5980] device (wlo1): supplicant interface state: scanning -> authenticating
22/11/2020 12:41 NetworkManager <info> [1606041713.5981] device (p2p-dev-wlo1): supplicant management interface state: scanning -> authenticating
22/11/2020 12:41 wpa_supplicant wlo1: Trying to associate with 40:9b:cd:a5:0e:b4 (SSID='007' freq=2432 MHz)
22/11/2020 12:41 NetworkManager <info> [1606041713.6606] device (wlo1): supplicant interface state: authenticating -> associating
22/11/2020 12:41 NetworkManager <info> [1606041713.6607] device (p2p-dev-wlo1): supplicant management interface state: authenticating -> associating
22/11/2020 12:41 wpa_supplicant wlo1: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="007" auth_failures=2 duration=20 reason=CONN_FAILED
22/11/2020 12:41 NetworkManager <info> [1606041714.0253] device (wlo1): supplicant interface state: associating -> disconnected
22/11/2020 12:41 NetworkManager <info> [1606041714.0254] device (p2p-dev-wlo1): supplicant management interface state: associating -> disconnected
22/11/2020 12:42 NetworkManager <info> [1606041724.0273] device (wlo1): supplicant interface state: disconnected -> scanning
22/11/2020 12:42 NetworkManager <info> [1606041724.0274] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> scanning
22/11/2020 12:42 NetworkManager <warn> [1606041727.0387] device (wlo1): Activation: (wifi) association took too long
22/11/2020 12:42 NetworkManager <info> [1606041727.0388] device (wlo1): state change: config -> failed (reason 'no-secrets', sys-iface-state: 'managed')
22/11/2020 12:42 NetworkManager <info> [1606041727.0398] manager: NetworkManager state is now DISCONNECTED
22/11/2020 12:42 NetworkManager <info> [1606041727.0431] device (wlo1): set-hw-addr: set MAC address to 82:02:29:D7:5E:56 (scanning)
22/11/2020 12:42 NetworkManager <warn> [1606041727.0474] device (wlo1): Activation: failed for connection '007'
22/11/2020 12:42 NetworkManager <info> [1606041727.0484] device (wlo1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
22/11/2020 12:42 kded5 "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/9"
22/11/2020 12:42 kdeconnectd "No such interface “org.freedesktop.DBus.Properties” on object at path /org/freedesktop/NetworkManager/ActiveConnection/9"
22/11/2020 12:42 NetworkManager <info> [1606041727.0906] device (wlo1): supplicant interface state: scanning -> disconnected
22/11/2020 12:42 NetworkManager <info> [1606041727.0907] device (p2p-dev-wlo1): supplicant management interface state: scanning -> disconnected
22/11/2020 12:42 NetworkManager <info> [1606041727.0953] device (wlo1): supplicant interface state: disconnected -> inactive
22/11/2020 12:42 NetworkManager <info> [1606041727.0954] device (p2p-dev-wlo1): supplicant management interface state: disconnected -> inactive
can you add kernel version 5.9
reboot and press Esc to select new kernel in advanced section
sudo mhwd-kernel -i linux59
sudo pacman -S linux59-headers
Well ok, I did plan to update to 5.9 sooner or later anyway. I did update, and unsurprisingly it still doesn’t connect.
There aren’t any issues when trying to connect to any other WiFi connection other than this one which is why I don’t understand what the issue could be - other than the network manager confusing the new connection with the old connection that used the same name I don’t see what else could go wrong. And the only way I could fix that is by deleting all the data associated with that connection. I tried doing even that, listed all the files from /etc/NetworkManager/system-connections and then deleted the file with the SSID name of the network that’s causing the issues, and that didn’t help either.
