So, i try the kernel 6.2 but it was not able to wake up from sleep, i’ve to do REISUB.
Now i’m using the kernel 6.1.12-1,
uname -r output:
6.1.12-1-MANJARO
but it is given me the same problem, network not working after sleep mode.
Fast startup and hibernation already disable in windows disk.
Fast boot already disable in bios.
rfkill list output:
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: yes
journalctl -b0 -p4 --no-pager output:
mar 12 14:55:44 facundo-msip65 kernel: x86/cpu: SGX disabled by BIOS.
mar 12 14:55:44 facundo-msip65 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
mar 12 14:55:44 facundo-msip65 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
mar 12 14:55:44 facundo-msip65 kernel: #7 #8 #9 #10 #11
mar 12 14:55:44 facundo-msip65 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
mar 12 14:55:44 facundo-msip65 kernel: pci 0000:3d:00.0: [Firmware Bug]: disabling VPD access (can't determine size of non-standard VPD format)
mar 12 14:55:44 facundo-msip65 kernel: usb: port power management may be unreliable
mar 12 14:55:44 facundo-msip65 kernel: acpi_call: loading out-of-tree module taints kernel.
mar 12 14:55:44 facundo-msip65 kernel: VBoxNetAdp: Successfully started.
mar 12 14:55:44 facundo-msip65 kernel: VBoxNetFlt: Successfully started.
mar 12 14:55:45 facundo-msip65 kernel: soc_button_array ACPI0011:00: Unknown button index 0 upage 01 usage c6, ignoring
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
mar 12 14:55:45 facundo-msip65 kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
mar 12 14:55:46 facundo-msip65 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
mar 12 14:55:46 facundo-msip65 kernel: nvidia: module license 'NVIDIA' taints kernel.
mar 12 14:55:46 facundo-msip65 kernel: Disabling lock debugging due to kernel taint
mar 12 14:55:46 facundo-msip65 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.89.02 Wed Feb 1 23:23:25 UTC 2023
mar 12 14:55:47 facundo-msip65 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
mar 12 14:55:47 facundo-msip65 systemd[1032]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: src/plugin.c:plugin_init() Failed to init vcp plugin
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: src/plugin.c:plugin_init() Failed to init mcp plugin
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
mar 12 14:55:47 facundo-msip65 bluetoothd[1032]: src/plugin.c:plugin_init() Failed to init bap plugin
mar 12 14:55:49 facundo-msip65 kernel: psmouse serio1: Failed to deactivate mouse on isa0060/serio1: -71
mar 12 14:55:49 facundo-msip65 kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
mar 12 14:55:50 facundo-msip65 kernel: psmouse serio1: Failed to enable mouse on isa0060/serio1
mar 12 14:55:51 facundo-msip65 kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
mar 12 14:55:53 facundo-msip65 kernel: kauditd_printk_skb: 91 callbacks suppressed
mar 12 14:55:53 facundo-msip65 systemd[1289]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
mar 12 14:55:53 facundo-msip65 systemd[1289]: Failed to start Update XDG user dir configuration.
mar 12 14:55:54 facundo-msip65 sddm-greeter[1298]: QFont::fromString: Invalid description '(empty)'
mar 12 14:55:54 facundo-msip65 sddm-greeter[1298]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fffe64a0110), parent's thread is QThread(0x555c91ced4b0), current thread is QThread(0x555c91e48b20)
mar 12 14:55:54 facundo-msip65 sddm-greeter[1298]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
mar 12 14:55:56 facundo-msip65 sddm-greeter[1298]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
mar 12 14:55:56 facundo-msip65 sddm-greeter[1298]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
mar 12 14:55:56 facundo-msip65 sddm-greeter[1298]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
mar 12 14:55:56 facundo-msip65 sddm-greeter[1298]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
mar 12 14:55:56 facundo-msip65 sddm-greeter[1298]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
mar 12 14:56:02 facundo-msip65 kernel: kauditd_printk_skb: 7 callbacks suppressed
mar 12 14:56:02 facundo-msip65 NetworkManager[1052]: <warn> [1678629362.3046] device (wlo1): no secrets: No agents were available for this request.
mar 12 14:56:02 facundo-msip65 NetworkManager[1052]: <warn> [1678629362.3051] device (wlo1): Activation: failed for connection 'MiFibra-4G-Flash'
mar 12 14:56:02 facundo-msip65 systemd-xdg-autostart-generator[1351]: /home/facundo/.config/autostart/org.kde.latte-dock.desktop:9: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
mar 12 14:56:03 facundo-msip65 systemd-xdg-autostart-generator[1395]: /home/facundo/.config/autostart/org.kde.latte-dock.desktop:9: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
mar 12 14:56:04 facundo-msip65 ksmserver[1436]: Qt: Session management error: networkIdsList argument is NULL
mar 12 14:56:04 facundo-msip65 kwin_x11[1439]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
mar 12 14:56:04 facundo-msip65 kwin_x11[1439]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
mar 12 14:56:04 facundo-msip65 ksmserver[1436]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.14'
mar 12 14:56:04 facundo-msip65 plasmashell[1519]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
mar 12 14:56:04 facundo-msip65 plasmashell[1519]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
mar 12 14:56:04 facundo-msip65 org_kde_powerdevil[1569]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 12 14:56:05 facundo-msip65 pipewire-media-session[1644]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
mar 12 14:56:05 facundo-msip65 pipewire-media-session[1644]: mod.rt: found session bus but no portal
mar 12 14:56:05 facundo-msip65 pipewire[1641]: mod.rt: Can't find org.freedesktop.portal.Desktop. Is xdg-desktop-portal running?
mar 12 14:56:05 facundo-msip65 pipewire[1641]: mod.rt: found session bus but no portal
mar 12 14:56:05 facundo-msip65 kded5[1438]: kscreen.kded: PowerDevil SuspendSession action not available!
mar 12 14:56:05 facundo-msip65 org_kde_powerdevil[1569]: org.kde.powerdevil: Handle button events action could not check for screen configuration
mar 12 14:56:05 facundo-msip65 org_kde_powerdevil[1569]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
mar 12 14:56:05 facundo-msip65 plasmashell[1519]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
mar 12 14:56:05 facundo-msip65 kwin_x11[1439]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
mar 12 14:56:05 facundo-msip65 plasmashell[1519]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
mar 12 14:56:06 facundo-msip65 bluetoothd[1032]: Failed to set mode: Failed (0x03)
mar 12 14:56:06 facundo-msip65 kded5[1438]: kf.bluezqt: PendingCall Error: "Failed"
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:243:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:217:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:207:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:187:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/Logic.qml:159:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/UpcomingEvents.qml:228:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/UpcomingEvents.qml:212:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/PlasmaCalendarManager.qml:107:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:06 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/PlasmaCalendarManager.qml:16: Error: Qt.createQmlObject(): failed to create object:
file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/inline:1:1: module "org.kde.plasma.PimCalendars" is not installed
mar 12 14:56:06 facundo-msip65 pulseaudio[1962]: stat('/etc/pulse/default.pa.d'): No existe el fichero o el directorio
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 10. Use 'sequences: [ <key> ]' to bind to all of them.
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 9. Use 'sequences: [ <key> ]' to bind to all of them.
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/ShortcutMenuItem.qml:17:5: QML Shortcut: Shortcut: Only binding to one of multiple key bindings associated with 8. Use 'sequences: [ <key> ]' to bind to all of them.
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notes/contents/ui/main.qml:153:13: QML TextArea: Binding loop detected for property "implicitWidth"
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/TimeFormatSizeHelper.qml:84:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/TimeFormatSizeHelper.qml:79:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/TimeFormatSizeHelper.qml:74:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.klaunch/contents/ui/CompactRepresentation.qml:43: TypeError: Cannot read property 'height' of null
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.volumewin7mixer/contents/ui/MediaController.qml:202:4: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.volumewin7mixer/contents/ui/InputManager.qml:6:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.volumewin7mixer/contents/ui/DynamicFilterModel.qml:30:34: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.volumewin7mixer/contents/ui/Mpris2DataSource.qml:159:31: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
mar 12 14:56:07 facundo-msip65 plasmashell[1519]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
mar 12 14:56:08 facundo-msip65 kwin_x11[1439]: kwin_core: XCB error: 152 (BadDamage), sequence: 5433, resource id: 16777259, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:18:1: QML MouseArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth"
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/calendars/PlasmaCalendarManager.qml:16: Error: Qt.createQmlObject(): failed to create object:
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/main.qml:165:3: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/AgendaListItem.qml:33:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/AgendaListItem.qml:23:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/AgendaView.qml:23:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/DaysCalendar.qml:300:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/TimerView.qml:213:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/MeteogramView.qml:36:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.plasma.eventcalendar/contents/ui/PopupView.qml:85:2: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: qt.svg: link #fcitx-kbd is undefined!
mar 12 14:56:08 facundo-msip65 plasmashell[1519]: file:///home/facundo/.local/share/plasma/plasmoids/org.kde.thermalMonitor/contents/ui/main.qml:312: TypeError: Cannot insert into a readonly container
mar 12 14:56:09 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.milou/contents/ui/main.qml:47:17: Unable to assign double to QQuickAnchorLine
mar 12 14:56:09 facundo-msip65 plasmashell[1519]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5586889902c0) QQmlContext(0x5586868a7250) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
mar 12 14:56:09 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
mar 12 14:56:09 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:222:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
mar 12 14:56:10 facundo-msip65 plasmashell[1519]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
mar 12 14:56:12 facundo-msip65 kernel: kauditd_printk_skb: 9 callbacks suppressed
mar 12 14:56:12 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.printmanager/contents/ui/PrinterItem.qml:22:5: Unable to assign [undefined] to bool
mar 12 14:56:12 facundo-msip65 kwin_x11[1439]: kwin_core: XCB error: 152 (BadDamage), sequence: 12029, resource id: 16777439, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 12 14:56:13 facundo-msip65 kwin_x11[1439]: kwin_core: XCB error: 152 (BadDamage), sequence: 13460, resource id: 16777749, major code: 143 (DAMAGE), minor code: 3 (Subtract)
mar 12 14:56:19 facundo-msip65 kstart5[2241]: Omitting both --window and --windowclass arguments is not recommended
mar 12 14:56:26 facundo-msip65 systemsettings[2293]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:200:9: QML MouseArea: Binding loop detected for property "width"
mar 12 14:56:27 facundo-msip65 systemsettings[2293]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
mar 12 14:56:44 facundo-msip65 kernel: [UFW BLOCK] IN=wlo1 OUT= MAC=18:56:80:f3:98:d2:d4:86:60:ed:a1:6a:08:00 SRC=192.168.1.1 DST=224.0.0.1 LEN=32 TOS=0x00 PREC=0x00 TTL=1 ID=22186 DF PROTO=2
mar 12 14:57:00 facundo-msip65 kded5[1438]: org.kde.plasma.nm.kded: Unhandled active connection state change: 3
mar 12 14:57:00 facundo-msip65 kscreenlocker_greet[2474]: Qt: Session management error: networkIdsList argument is NULL
mar 12 14:57:01 facundo-msip65 kscreenlocker_greet[2474]: kf.kirigami: Failed to find a Kirigami platform plugin
mar 12 14:57:01 facundo-msip65 kscreenlocker_greet[2474]: qt.svg: link #fcitx-kbd is undefined!
mar 12 14:57:02 facundo-msip65 kscreenlocker_greet[2474]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_GB" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
mar 12 14:57:18 facundo-msip65 kernel: psmouse serio1: Failed to disable mouse on isa0060/serio1
mar 12 14:57:18 facundo-msip65 kernel: iwlwifi 0000:00:14.3: reporting RF_KILL (radio disabled)
mar 12 14:57:18 facundo-msip65 kernel: done.
mar 12 14:57:18 facundo-msip65 kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
mar 12 14:57:19 facundo-msip65 plasmashell[1519]: qt.qpa.clipboard: QXcbClipboard::setMimeData: Cannot set X11 selection owner
mar 12 14:57:29 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:162: TypeError: Cannot read property 'text' of null
mar 12 14:57:29 facundo-msip65 plasmashell[1519]: trying to show an empty dialog
mar 12 14:57:29 facundo-msip65 plasmashell[1519]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
mar 12 14:57:34 facundo-msip65 kstart5[2891]: Omitting both --window and --windowclass arguments is not recommended
mar 12 14:58:01 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:325:17: QML Label: Binding loop detected for property "verticalAlignment"
mar 12 14:58:01 facundo-msip65 plasmashell[1519]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/FolderItemDelegate.qml:387:21: Unable to assign [undefined] to bool
mar 12 14:58:03 facundo-msip65 plasmashell[1519]: trying to show an empty dialog
mar 12 14:58:05 facundo-msip65 notepadqq-bin[2973]: js: Uncaught Error: Script error for "../../mathjax2/MathJax"
http://requirejs.org/docs/errors.html#scripterror
mar 12 14:58:07 facundo-msip65 notepadqq-bin[2973]: js: Uncaught Error: Script error for "../../mathjax2/MathJax"
