Hello, So i wanted Neofetch to open automatically when i open terminal, so i read some tutorials and added Neofetch in .bashrc. But it seems that it doesn’t work, i checked that i configured bash as the shell. How can i make neofetch open up in terminal automatically?t
What shell you use and what you put in ~/.bashrc
i used bash, and i manually put ‘neofetch’ inside .bashrc
Hi @Cryptos70928,
Are you sure you’re using bash
and not zsh
To check, open a terminal and run:
echo $SHELL
AFAIK the default, at least for KDE is zsh
and should output:
$ echo $SHELL
/usr/bin/zsh
yep i definetely use bash, i checked with echo $SHELL and it says bash
did you source your .bashrc?
run source ~/.bashrc
Do you use Konsole or other terminal emulator? If Konsole check what you have in Konsole’s profile.
Have you reloaded the ~/.bashrc
file?
source ~/.zshrc
Or reboot.
yep i just tried now…
when i ran it, it came up as zsh:command not found but on neofetch it says bash…
Are you sure it’s installed?
pamac install neofetch
yep its installed
What is the output for:
which neofetch
/usr/bin/neofetch
And if you run neofetch
manually?
neofetch
neofetch comes up as normal
OK. So if you’re using bash, it seems you have a typo in your ~/.bashrc
file. Please obtain it with, and provide the output of:
cat ~/.bashrc
~/.bashrc
[[ $- != i ]] && return
colors() {
local fgc bgc vals seq0
printf "Color escapes are %s\n" '\e[${value};...;${value}m'
printf "Values 30..37 are \e[33mforeground colors\e[m\n"
printf "Values 40..47 are \e[43mbackground colors\e[m\n"
printf "Value 1 gives a \e[1mbold-faced look\e[m\n\n"
# foreground colors
for fgc in {30..37}; do
# background colors
for bgc in {40..47}; do
fgc=${fgc#37} # white
bgc=${bgc#40} # black
vals="${fgc:+$fgc;}${bgc}"
vals=${vals%%;}
seq0="${vals:+\e[${vals}m}"
printf " %-9s" "${seq0:-(default)}"
printf " ${seq0}TEXT\e[m"
printf " \e[${vals:+${vals+$vals;}}1mBOLD\e[m"
done
echo; echo
done
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
Change the window title of X terminals
case ${TERM} in
xterm*|rxvt*|Eterm*|aterm|kterm|gnome*|interix|konsole*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME%%.}:${PWD/#$HOME/~}\007"’
screen)
PROMPT_COMMAND=‘echo -ne “\033_${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/~}\033\”’
esac
use_color=true
Set colorful PS1 only on colorful terminals.
dircolors --print-database uses its own built-in database
instead of using /etc/DIR_COLORS. Try to use the external file
first to take advantage of user additions. Use internal bash
globbing instead of external grep binary.
safe_term=${TERM//[^[:alnum:]]/?} # sanitize TERM
match_lhs=""
[[ -f ~/.dir_colors ]] && match_lhs="${match_lhs}$(<~/.dir_colors)"
[[ -f /etc/DIR_COLORS ]] && match_lhs="${match_lhs}$(</etc/DIR_COLORS)"
[[ -z ${match_lhs} ]]
&& type -P dircolors >/dev/null
&& match_lhs=$(dircolors --print-database)
[[ $’\n’${match_lhs} == $’\n’"TERM "${safe_term} ]] && use_color=true
if ${use_color} ; then
# Enable colors for ls, etc. Prefer ~/.dir_colors #64489
if type -P dircolors >/dev/null ; then
if [[ -f ~/.dir_colors ]] ; then
eval $(dircolors -b ~/.dir_colors)
elif [[ -f /etc/DIR_COLORS ]] ; then
eval $(dircolors -b /etc/DIR_COLORS)
fi
fi
if [[ ${EUID} == 0 ]] ; then
PS1='\[\033[01;31m\][\h\[\033[01;36m\] \W\[\033[01;31m\]]\$\[\033[00m\] '
else
PS1='\[\033[01;32m\][\u@\h\[\033[01;37m\] \W\[\033[01;32m\]]\$\[\033[00m\] '
fi
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
else
# show root@ when we don’t have colors
PS1=’\u@\h \W $ ’
else
PS1=’\u@\h \w $ ’
fi
fi
unset use_color safe_term match_lhs sh
alias cp=“cp -i” # confirm before overwriting something
alias df=‘df -h’ # human-readable sizes
alias free=‘free -m’ # show sizes in MB
alias np=‘nano -w PKGBUILD’
alias more=less
xhost +local:root > /dev/null 2>&1
Bash won’t get SIGWINCH if another process is in the foreground.
Enable checkwinsize so that bash will check the terminal size when
it regains control. #65623
http://cnswww.cns.cwru.edu/~chet/bash/FAQ (E11)
shopt -s checkwinsize
shopt -s expand_aliases
export QT_SELECT=4
Enable history appending instead of overwriting. #139609
shopt -s histappend
# ex - archive extractor
# usage: ex
ex ()
if [ -f $1 ] ; then
case $1 in
*.tar.bz2) tar xjf $1 ;;
*.tar.gz) tar xzf $1 ;;
*.bz2) bunzip2 $1 ;;
*.rar) unrar x $1 ;;
*.gz) gunzip $1 ;;
*.tar) tar xf $1 ;;
*.tbz2) tar xjf $1 ;;
*.tgz) tar xzf $1 ;;
*.zip) unzip $1 ;;
*.Z) uncompress $1;;
*.7z) 7z x $1 ;;
*) echo “’$1’ cannot be extracted via ex()” ;;
esac
else
echo “’$1’ is not a valid file”
fi
neofetch
Please paste the output somewhere else… it got changed with the topic formatting… or if you are pasting here, format it all as source-code
oh ok sorry
