To do this. wrap the text in triple backtics (```) to get the correct formatting.
Alternatively, select all the test and click thee </> button in the editor toolbar.
That means you are using zsh, and not bash…
if you use bash, you will get :
bash: neofetch: command not found
# ~/.bashrc
[[ $- != *i* ]] && return
colors() {
local fgc bgc vals seq0
printf "Color escapes are %s\n" '\e[${value};...;${value}m'
printf "Values 30..37 are \e[33mforeground colors\e[m\n"
printf "Values 40..47 are \e[43mbackground colors\e[m\n"
printf "Value 1 gives a \e[1mbold-faced look\e[m\n\n"
# foreground colors
for fgc in {30..37}; do
# background colors
for bgc in {40..47}; do
fgc=${fgc#37} # white
bgc=${bgc#40} # black
vals="${fgc:+$fgc;}${bgc}"
vals=${vals%%;}
seq0="${vals:+\e[${vals}m}"
printf " %-9s" "${seq0:-(default)}"
printf " ${seq0}TEXT\e[m"
printf " \e[${vals:+${vals+$vals;}}1mBOLD\e[m"
done
echo; echo
done
[ -r /usr/share/bash-completion/bash_completion ] && . /usr/share/bash-completion/bash_completion
# Change the window title of X terminals
case ${TERM} in
xterm*|rxvt*|Eterm*|aterm|kterm|gnome*|interix|konsole*)
PROMPT_COMMAND='echo -ne "\033]0;${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\007"'
screen*)
PROMPT_COMMAND='echo -ne "\033_${USER}@${HOSTNAME%%.*}:${PWD/#$HOME/\~}\033\\"'
esac
use_color=true
# Set colorful PS1 only on colorful terminals.
# dircolors --print-database uses its own built-in database
# instead of using /etc/DIR_COLORS. Try to use the external file
# first to take advantage of user additions. Use internal bash
# globbing instead of external grep binary.
safe_term=${TERM//[^[:alnum:]]/?} # sanitize TERM
match_lhs=""
[[ -f ~/.dir_colors ]] && match_lhs="${match_lhs}$(<~/.dir_colors)"
[[ -f /etc/DIR_COLORS ]] && match_lhs="${match_lhs}$(</etc/DIR_COLORS)"
[[ -z ${match_lhs} ]] \
&& type -P dircolors >/dev/null \
&& match_lhs=$(dircolors --print-database)
[[ $'\n'${match_lhs} == *$'\n'"TERM "${safe_term}* ]] && use_color=true
if ${use_color} ; then
# Enable colors for ls, etc. Prefer ~/.dir_colors #64489
if type -P dircolors >/dev/null ; then
if [[ -f ~/.dir_colors ]] ; then
eval $(dircolors -b ~/.dir_colors)
elif [[ -f /etc/DIR_COLORS ]] ; then
eval $(dircolors -b /etc/DIR_COLORS)
fi
fi
if [[ ${EUID} == 0 ]] ; then
PS1='\[\033[01;31m\][\h\[\033[01;36m\] \W\[\033[01;31m\]]\$\[\033[00m\] '
else
PS1='\[\033[01;32m\][\u@\h\[\033[01;37m\] \W\[\033[01;32m\]]\$\[\033[00m\] '
fi
alias ls='ls --color=auto'
alias grep='grep --colour=auto'
alias egrep='egrep --colour=auto'
alias fgrep='fgrep --colour=auto'
else
# show root@ when we don't have colors
PS1='\u@\h \W \$ '
else
PS1='\u@\h \w \$ '
fi
fi
unset use_color safe_term match_lhs sh
alias cp="cp -i" # confirm before overwriting something
alias df='df -h' # human-readable sizes
alias free='free -m' # show sizes in MB
alias np='nano -w PKGBUILD'
alias more=less
xhost +local:root > /dev/null 2>&1
# Bash won't get SIGWINCH if another process is in the foreground.
# Enable checkwinsize so that bash will check the terminal size when
# it regains control. #65623
# http://cnswww.cns.cwru.edu/~chet/bash/FAQ (E11)
shopt -s checkwinsize
shopt -s expand_aliases
# export QT_SELECT=4
# Enable history appending instead of overwriting. #139609
shopt -s histappend
# # ex - archive extractor
# # usage: ex <file>
ex ()
if [ -f $1 ] ; then
case $1 in
*.tar.bz2) tar xjf $1 ;;
*.tar.gz) tar xzf $1 ;;
*.bz2) bunzip2 $1 ;;
*.rar) unrar x $1 ;;
*.gz) gunzip $1 ;;
*.tar) tar xf $1 ;;
*.tbz2) tar xjf $1 ;;
*.tgz) tar xzf $1 ;;
*.zip) unzip $1 ;;
*.Z) uncompress $1;;
*.7z) 7z x $1 ;;
*) echo "'$1' cannot be extracted via ex()" ;;
esac
else
echo "'$1' is not a valid file"
fi
when i ran echo $SHELL it came up as bash though
While the </> (code) button should work …
A useful thing could be …
cat ~/.bashrc | curl -F 'f:1=<-' ix.io
EDIT - ah nevermind you fixed it now @Cryptos70928.
Well, that end pipe above can still be useful in the future
it is fixed?
Your formatting, yes.
ok. Just to be sure.
run as below:
$ bash
now you are 100% sure that you are using bash. Then:
$ source ~/.bashrc
of course after adding neofetch at the end of .bashrc
i ran it and neofetch came up
whenever i do bash, neofetch comes up but i have to manually type bash
no… you are using zsh. That’s why
you have to set bash as your default.
use chsh
$ which bash
(example) /usr/bin/bash
$ chsh -s /usr/bin/bash username
/usr/bin/bash, or whatever you get up
username is ur username
to check your current sh, you can type this…
$ grep `whoami` /etc/passwd
the /usr/bin/bash doesnt exist for me
I was an example… type
$ which bash
and if you want to keep using zsh, you could also add neofetch to .zshrc instead of .bashrc
All is up to you
i did which bash it came up as /usr/bin/bash but it says it doesnt exist in etc shells
should i add /usr/bin/bash in /etc/shells ?
let’s see the content of /etc/shells
$ less /etc/shells
there are:
/bin/sh
/bin/bash
/bin/zsh
/usr/bin/zsh
/usr/bin/git–shell
just use /bin/bash
$ chsh -s /bin/bash [username]
you need to logout, and login I think for changes to take effect.
Oh thanks!! it works !!thank you guys for helping a noob like me
