Hello there. I uninstalled Dolphin and replaced it with Nemo from the Add/Remove Software app (Dolphin was freezing Plasma frequently even going black screen, so getting rid of it was a relief). Nemo works fine, except that it won’t let me paste anything from the desktop directly using the right-click menu (the paste option appears greyed out). Instead I have to minimize Nemo and then drag and drop anything from the desktop or do it from inside Nemo. Any clues to why this is happening?
I saw a bug report on bugs.kde.org that indicates that QT and KDE apps use 2 different stacks for copy/paste functionality. So they might have trouble “communicating”.
Hmmm. Looks like I will have to get used to this bug, or explore other file managers.
Just as an FYI, I haven’t had any issues with Dolphin, so it might be worth looking into why it causes issues on your end.
Do I have to start another topic or do I keep posting here?
Yes, provide some information about your system as explained here
Thank you for your reply, here it is.
Kernel: 5.13.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=aabf2c26-693a-45ad-9a9a-2cdc64635713 rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Micro-Star model: A320M-A PRO MAX (MS-7C52) v: 1.0
serial: <filter> UEFI: American Megatrends v: 2.80 date: 12/07/2020
RAM: total: 5.74 GiB used: 2.9 GiB (50.4%)
Info: Quad Core model: AMD Ryzen 3 3200G with Radeon Vega Graphics bits: 64
type: MCP arch: Zen family: 17 (23) model-id: 18 (24) stepping: 1
microcode: 8108109 cache: L2: 2 MiB bogomips: 28813
Speed: 1260 MHz min/max: N/A Core speeds (MHz): 1: 1260 2: 3600 3: 3600
4: 3600
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca
mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl
npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36
rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap smca sme
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce
topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt
disabled, RSB filling
Device-1: AMD Picasso vendor: Micro-Star MSI driver: amdgpu v: kernel
bus-ID: 29:00.0 chip-ID: 1002:15d8 class-ID: 0300
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: DVI-D-0 res: 1600x900 hz: 60 dpi: 92 size: 443x249mm (17.4x9.8")
diag: 508mm (20")
OpenGL: renderer: AMD Radeon Vega 8 Graphics (RAVEN DRM 3.41.0
5.13.11-1-MANJARO LLVM 12.0.1)
v: 4.6 Mesa 21.1.6 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel bus-ID: 29:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 29:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.11-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel port: f000 bus-ID: 25:00.0
IF: enp37s0 state: down mac: <filter>
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter driver: ath9k
v: kernel port: f000 bus-ID: 26:00.0 chip-ID: 168c:0032 class-ID: 0280
IF: wlp38s0 state: up mac: <filter>
Local Storage: total: 931.51 GiB used: 19.32 GiB (2.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000DM003-1CH162
type: HDD rpm: 7200 serial: <filter> rev: CC47 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSB0 rev: LM00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 238.15 GiB size: 233.36 GiB (97.99%)
used: 19.29 GiB (8.3%) fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: aabf2c26-693a-45ad-9a9a-2cdc64635713
used: 36.9 MiB (38.5%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 4C30-C8B5
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 9040dcbd-0e40-43c3-aebe-317ea1356c19
ID-1: /dev/sda1 maj-min: 8:1 size: 499 MiB fs: ntfs label: Recovery
uuid: 42282E95282E884D
ID-2: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/sda4 maj-min: 8:4 size: 427.13 GiB fs: ntfs label: N/A
uuid: 40B05D17B05D14AE
ID-4: /dev/sda6 maj-min: 8:6 size: 234.38 GiB fs: ext4 label: rootMX19
uuid: d1f1abc0-c53f-4e23-a2c3-d2928587eaa9
ID-5: /dev/sda7 maj-min: 8:7 size: 15.62 GiB fs: swap label: N/A
uuid: dfa03ad5-936d-4ab0-9b83-3d2ba48e669b
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 9 rev: 2.0
Device-1: 1-4:2 info: Microsoft Wired Keyboard 400 type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 045e:0752 class-ID: 0301
Device-2: 1-5:3 info: Microsoft Basic Optical Mouse v2.0 type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 045e:00cb class-ID: 0301
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 3 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 26.0 C
Processes: 212 Uptime: 1h 10m wakeups: 0 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: pacman: 1312 lib: 366
flatpak: 0 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
All seems in order with your system, so that leads to this
Also, in Settings you can set the Compositor like this:
I’ve just purged baloo as in the link you posted and set the compositor parameters as in the image. Let’s see if from now on my system stops going all black when Dolphin is working. I’ll let you know how it goes these days. Thank you.
It’s been a couple of months and since the baloo purging and applying the compositor parameters, the black screen problem seems to be gone for good.
