Needing reinstall pBp on eMMC,
I am having a pinebookpro with Manjaro Linux 5.14.8.1.-Manjaro-Arm
I do not remember anymore what happen as it was already for some time back, but I think I have tried to install HP printer (or even installed some other app) and the official driver did not worked, and searched for some workaround and did not realised that It has asked to install a lot of other theme apps. I
I ended up that I am stacked on login screen to GUI, which does not continue further after I put in a user password.
I can put Ctrl +alt F2, (if I understand it correctly it is console mode) and get log into root mode, after putting password. I wished to update the pacman by:
sudo pacman-mirrors -f5
sudo pacman -Syyuu
but I do not have network active. I tried nmtui, but it does recognise a wifi network there, but cannot activate it( because it does not shows up in active networks lists)
in first step: I wish to update my network card settings is not connected to wireless, network.
I would like to connect to network in terminal .
Then:I wish to figure out what actually hapend, and repair it. May I get some instructions please?
edit:
much easier than nmcli is using:
nmtui
it’s a simple graphical user interface for use in a terminal/TTY
I do not know whether it is present by default - just try …
/edit
nmcli is what you can use
nmcli --help
or
man nmcli
could help - or ask google for how to use it
If you use the title to describe what you want to do next, you may get some good help :wink:
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots … below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
