Need Help With Two Issues On Boot Of Manjaro KDE
Hi,
When I boot my Manjaro KDE I have two issues:
(1) I see a prompt to enter encrypted hard drive password?
(2) I see a prompt for Manjaro News update 2022-05-04?
See attached screenshot.
Any ideas?
Jesse
Hi @JeZxLee,
  1. Is probably from kwallet. I don’t use it so I’m not sure. If you don’t want it, try disabling it. On second thought, it actually looks like a permissions problem/misconfiguration on a hard drive. Quite possibly an external hard drive. How and where is it mounted? See [Tutorial] Working with additional 'drives', [root tip] Use systemd to mount ANY device, and [root tip] systemd mount unit samples.
  2. The notification is from matray. You can remove it or mute the notifications in System Settings.
Hope this helps!
