Need help with Live Buildiso
Greetings everyone,
I am still having issues with building the latest version of DeLinuxCo (Manjaro Cinnamon)
The issue has to do with Live ISO , the system boots right into a gui but does not login automatically and entering “manjaro” as password will not work. But, dropping to a terminal (Ctr+Alt+F3), and reinstalling lightdm using sudo pacman -Sy lightdm and then restarting lightdm using sudo systemctl restart lightdm will automatically login and continue as normal.
Installing the OS onto the machine works fine and boots normally. This only occurs on LIVE ISO.
I have tried this on x.org and Xlibre, makes no difference from what I can tell.
Here is the test ISO if anyone has time to to look into it: https://delinuxco.nyc3.cdn.digitaloceanspaces.com/iso/delinuxco-testing-26.1.0-pre-260615-linux70.iso
I am just stumped…
Greetings everyone…
Well, I still have not been able to get Cinnamon to boot properly on live ISO. Just got done starting from scratch building a stock version of Manjaro Cinnamon and when booting in a VM (Virt-Manager) it boots just fine, but on an AMD Mini PC takes you to the login promp and password “manajaro” does not work.
Have to go through the same procedure as before…
I am trying to build with Kernel 6.18 instead of 7.0, but at this point it is a matter of just throwing something at the wall to see if it stick.
Any help would be greatly appreciated.
-João
I hear you - I have been at the point of giving in - throwing the towel - more times than I care to remember…
When you have the live environment where this doesn’t work, look at the file /var/log/mhwd-live.log - not sure if the filename is correct - but you get the idea.
What is interesting is what happens when the hardware detection run - apparently it does not load the correct driver on bare-metal.
If you wait 4-5 minutes after entering the password (manjaro) and then press enter, does it still not accept the password?
@growler that actually did work, I rebooted the stock ISO again, and when it got to the login screen, I just left it there for 5 minutes, came back and entered the password and it logged in right away!
@ManjaroDevOps Sunday in the USA is Fathers Day, so I do not have time today to dig deeper, but tomorrow I will hunt down the logs and see what I can find.
In all honesty, I am feeling a little uneasy about my efforts in this project. I have spent much time and money in doing this project hoping that it will benefit someone out there, but Manjaro’s direction is still unknown, will the community efforts just go away, is the future locked down to KDE, Gnome and Wayland and everything else be dammed? I have enjoyed my time here on Manjaro, I still believe it is one of the best distros around and wish to continue to support it. I know that with all of the issues with Manjaro structure right now, a lowly spin is irrelevant in grand scheme of things but it is what it is.
Thank you both for your help, I will report back soon with what I find.
-João
Not at all. As far as we’re concerned, there is still a place for all of the different versions currently on offer, including the various spins. :wink:
So something has just not started in time, and the fix is probably a simple systemd dependency?
Experimenting with buildiso was on my list of to-dos. :confused:
Unfortunately I have no idea what is causing this login anomaly.
But I also encountered this while launching another - community-based release.
https://download.manjaro.org/cinnamon/26.1-pre1/manjaro-cinnamon-26.1-pre1-260610-linux618.iso
I booted your ISO on my hardware using Ventoy and got the same result. It doesn’t work right away, but it does after a few minutes.
mhwd-live.log:
Summary
Running MHWD...
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/r8168/MHWDCONFIG' is invalid!
e[1me[31mWarning: e[mconfig '/var/lib/mhwd/db/pci/network_drivers/rt3562sta/MHWDCONFIG' is invalid!
e[1me[31m> e[mUsing config 'video-linux' for device: 0000:03:00.0 (0300:1002:731f) Display controller ATI Technologies Inc Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
e[1me[31m> e[mInstalling video-linux...
e[0;32mwarning: database file for 'core' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'extra' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'multilib' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'delinuxco' does not exist (use '-Sy' to download)
e[me[0;32mwarning: database file for 'xlibre' does not exist (use '-Sy' to download)
e[me[0;32mSourcing /etc/mhwd-x86_64.conf
e[me[0;32mHas lib32 support: true
e[me[0;32mSourcing /var/lib/mhwd/db/pci/graphic_drivers/video-linux/MHWDCONFIG
e[me[0;32mProcessing classid: 0300
e[me[0;32mSourcing /var/lib/mhwd/scripts/include/0300
e[me[0;32mProcessing classid: 0380
e[me[0;32mProcessing classid: 0302
e[me[0;32m:: Synchronizing package databases...
e[me[0;32m mhwd downloading...
e[me[0;32mresolving dependencies...
e[me[0;32mlooking for conflicting packages...
e[me[0;32m:: xf86-video-ati-1:22.0.0-3 and xlibre-xserver-25.0.0.22-2 are in conflict (X-ABI-VIDEODRV_VERSION). Remove xlibre-xserver? [y/N] error: unresolvable package conflicts detected
e[me[0;32merror: failed to prepare transaction (conflicting dependencies)
e[me[0;32m
e[me[0;32m:: xf86-video-ati-1:22.0.0-3 and xlibre-xserver-25.0.0.22-2 are in conflict (X-ABI-VIDEODRV_VERSION>=26)
e[me[0;32mError: pacman failed!
e[me[1me[31mError: e[mscript failed!
MHWD DONE
Probably irrelevant, but here’s my inxi:
Summary
  Kernel: 7.0.10-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1 clocksource: tsc
    avail: hpet,acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
    tz=Europe/Berlin misobasedir=manjaro misolabel=DELINUXCO_CINNAMON_2610PRE quiet
    systemd.show_status=1 apparmor=1 security=apparmor driver=free nouveau.modeset=1
    i915.modeset=1 radeon.modeset=1
  Console: tty 3 DM: LightDM v: 1.32.0 Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: ASRock model: B650M PG Lightning serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends LLC. v: 4.20
    date: 04/16/2026
  System RAM: total: 32 GiB available: 30.92 GiB used: 1.34 GiB (4.3%)
  Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: spec: 4800 MT/s actual: 5200 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: N/A part-no: F5-5200J3636C16G serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 5 7600X bits: 64 type: MT MCP arch: Zen 4 gen: 4 level: v4 note: check
    built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x61 (97) stepping: 2
    microcode: 0xA60120C
  Topology: cpus: 1x dies: 1 clusters: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 6 MiB desc: 6x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2998 min/max: 409/5655 boost: enabled scaling: driver: amd-pstate-epp
    governor: powersave cores: 1: 2998 2: 2998 3: 2998 4: 2998 5: 2998 6: 2998 7: 2998 8: 2998
    9: 2998 10: 2998 11: 2998 12: 2998 bogomips: 112593
  Flags: 3dnowprefetch abm adx aes amd_lbr_pmc_freeze amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc
    cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate
    ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext
    monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae
    pat pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2 pfthreshold
    pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
    xtopology
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional; STIBP: always-on;
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT]
    vendor: ASRock driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
    built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1
    empty: DP-1,DP-2,DP-3 bus-ID: 03:00.0 chip-ID: 1002:731f class-ID: 0300
  Device-2: Microdia USB Live camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:10 chip-ID: 0c45:636b class-ID: 0102
    serial: <filter>
  Display: unspecified server: X.org with: Xwayland v: 24.1.11 driver: gpu: amdgpu tty: 240x67
  Monitor-1: HDMI-A-1 model: HISENSE serial: <filter> built: 2019 res: 3840x2160 dpi: 85
    gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green: x: 0.298 y: 0.690 blue: x: 0.137 y: 0.035
    white: x: 0.282 y: 0.298 size: 698x392mm (27.48x15.43") diag: 1321mm (52") ratio: 16:9
    modes: 3840x2160, 4096x2160, 1920x1080, 1280x1024, 1280x960, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 97 2: parse_edid: unhandled CEA mode 94
    3: parse_edid: unhandled CEA mode 95 4: parse_edid: unhandled CEA mode 96 5: parse_edid:
    unhandled CEA mode 93 6: parse_edid: unhandled CEA mode 106 7: parse_edid: unhandled CEA mode
    107 8: parse_edid: unhandled CEA mode 101 9: parse_edid: unhandled CEA mode 102 10: parse_edid:
    unhandled CEA mode 98 11: parse_edid: unhandled CEA mode 99 12: parse_edid: unhandled CEA
    mode 100
  API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    gbm: drv: radeonsi surfaceless: drv: radeonsi inactive: wayland,x11
  API: OpenGL v: 4.6 vendor: mesa v: 26.1.1-arch1.2 note: console (EGL sourced) renderer: AMD
    Radeon RX 5600 XT (radeonsi navi10 ACO DRM 3.64 7.0.10-1-MANJARO), llvmpipe (LLVM 22.1.5 256
    bits)
  Info: Tools: api: eglinfo, glxinfo, vulkaninfo x11: xprop,xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 10 HDMI Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38 class-ID: 0403
  Device-2: Plantronics Blackwire C3220 Headset driver: plantronics,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.4.3:12 chip-ID: 047f:c056
    class-ID: 0300 serial: <filter>
  Device-3: Microdia USB Live camera driver: snd-usb-audio,uvcvideo type: USB rev: 2.0
    serial: <filter>
  API: ALSA v: k7.0.10-1-MANJARO status: kernel-api with: aoss type: oss-emulator
  Server-2: PipeWire v: 1.6.5 status: off with: 1: pipewire-pulse status: off 2: wireplumber
    status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Broadcom NetXtreme II BCM5709 Gigabit Ethernet driver: bnx2 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 port: N/A bus-ID: 04:00.0 chip-ID: 14e4:1639 class-ID: 0200
  IF: enp4s0f0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
  Device-2: Broadcom NetXtreme II BCM5709 Gigabit Ethernet driver: bnx2 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 4 port: N/A bus-ID: 04:00.1 chip-ID: 14e4:1639 class-ID: 0200
  IF: enp4s0f1 state: down mac: <filter>
  Device-3: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0 chip-ID: 10ec:8125 class-ID: 0200
  IF: enp8s0 state: down mac: <filter>
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s lanes: 1
    mode: 1.1 bus-ID: 1-11.3:11 chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Local Storage: total: 3.91 TiB used: 3 KiB (0.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000S1024G size: 953.87 GiB
    block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter>
    fw-rev: EIFK51.2 temp: 47.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CX400-512-G2 size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 3A0 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
    block-size: physical: 4096 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1
    mode: 3.2 gen-1x1 tech: SSD serial: <filter> fw-rev: 0209 scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: GOODRAM model: SSDPR-CX400-512-G2 size: 476.94 GiB
  ID-5: /dev/sdd maj-min: 8:48 vendor: Toshiba model: MQ01UBB200 size: 1.82 TiB block-size:
    physical: 512 B logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
    tech: HDD rpm: 5400 serial: <filter> scheme: GPT
  ID-1: /mnt raw-size: 256 MiB size: 252 MiB (98.46%) used: 3 KiB (0.0%) fs: vfat dev: /dev/sdd3
    maj-min: 8:51 label: BIOS uuid: 829E-E8C1
  ID-1: /dev/dm-0 maj-min: 253:0 mapped: ventoy size: 7 GiB fs: iso9660
  ID-2: /dev/dm-1 maj-min: 8:49 mapped: sdd1 size: 838.98 GiB fs: exfat label: Ventoy
    uuid: 7AA1-2C2B
  ID-3: /dev/nvme0n1p1 maj-min: 259:1 size: 50 MiB fs: vfat label: EFI uuid: 4217-942E
  ID-4: /dev/nvme0n1p2 maj-min: 259:2 size: 2 GiB fs: ext4 label: GRUB
    uuid: b0a3e1e1-562b-4e33-a11d-db05cbd5040d
  ID-5: /dev/nvme0n1p3 maj-min: 259:3 size: 951.82 GiB fs: btrfs label: LFS
    uuid: a1f6fc58-6656-430d-9ab4-ee85d87424c9
  ID-6: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A uuid: 5CB4-DAF5
  ID-7: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A uuid: N/A
  ID-8: /dev/sda3 maj-min: 8:3 size: 109.17 GiB fs: ntfs label: N/A uuid: 96BCB6B6BCB6906B
  ID-9: /dev/sda4 maj-min: 8:4 size: 890 MiB fs: ntfs label: N/A uuid: B650539750535D65
  ID-10: /dev/sda5 maj-min: 8:5 size: 331.78 GiB fs: btrfs label: Daten-lokal
    uuid: d7fb122e-e7fb-407f-8aac-8331cabae503
  ID-11: /dev/sda6 maj-min: 8:6 size: 35 GiB fs: swap label: swap
    uuid: 0e740132-0b83-48cc-a49c-ca70a1c410b9
  ID-12: /dev/sdb1 maj-min: 8:17 size: 976 MiB fs: vfat label: N/A uuid: 9040-F597
  ID-13: /dev/sdb2 maj-min: 8:18 size: 219.92 GiB fs: ext4 label: N/A
    uuid: 04cd1dea-756d-411f-9c1d-70c1cda85df1
  ID-14: /dev/sdb3 maj-min: 8:19 size: 12.01 GiB fs: swap label: N/A
    uuid: 3f337ce7-7a82-4951-8c2b-d42f3a523d6a
  ID-15: /dev/sdd1 maj-min: 8:49 size: 838.98 GiB fs: exfat label: Ventoy uuid: 7AA1-2C2B
  ID-16: /dev/sdd2 maj-min: 8:50 size: 32 MiB fs: vfat label: VTOYEFI uuid: EA6C-95B2
  ID-17: /dev/sdd4 maj-min: 8:52 size: 1023.75 GiB fs: ext4 label: Daten-USB
    uuid: db4580cc-fbf4-46f9-8033-091c9da4ca09
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 chip-ID: 1d6b:0002 class-ID: 0900
  Hub-2: 1-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 chip-ID: 05e3:0610 class-ID: 0900
  Hub-3: 1-1.4:4 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Hub-4: 1-1.4.1:6 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: 05e3:0610 class-ID: 0900
  Device-1: 1-1.4.1.1:9 info: Yubicom Yubikey 4/5 U2F type: HID driver: hid-generic,usbhid
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 1050:0402 class-ID: 0300
  Device-2: 1-1.4.1.4:13 info: Acer & Multimedia LCKEY type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 1189:8890 class-ID: 0301 serial: <filter>
  Device-3: 1-1.4.2:8 info: Elan Micro Gaming KB type: keyboard driver: hid-generic,usbhid
    interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
    chip-ID: 04f3:152e class-ID: 0301
  Device-4: 1-1.4.3:12 info: Plantronics Blackwire C3220 Headset type: audio,HID
    driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 047f:c056 class-ID: 0300 serial: <filter>
  Hub-5: 1-7:3 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
  Device-1: 1-10:5 info: SDRplay type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 400mA chip-ID: 1df7:3060 class-ID: ff00
    serial: <filter>
  Hub-6: 1-11:7 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
  Device-1: 1-11.3:11 info: TP-Link UB500 Adapter type: bluetooth driver: btusb interfaces: 2
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA chip-ID: 2357:0604
  Device-2: 1-11.4:14 info: Maxxter ACER Mouse 2.4G type: mouse,keyboard
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 248a:8173 class-ID: 0301
  Device-3: 1-12:10 info: Microdia USB Live camera type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0c45:636b class-ID: 0102 serial: <filter>
  Hub-7: 2-0:1 info: super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
    mode: 3.2 gen-2x1 chip-ID: 1d6b:0003 class-ID: 0900
  Hub-8: 2-1:2 info: Genesys Logic USB3.2 Hub ports: 4 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0625 class-ID: 0900
  Device-1: 2-1.3:4 info: Toshiba America External USB 3.0 type: mass storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 896mA chip-ID: 0480:a200 class-ID: 0806 serial: <filter>
  Hub-9: 2-1.4:5 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 chip-ID: 05e3:0626 class-ID: 0900
  Hub-10: 2-1.4.1:6 info: Genesys Logic Hub ports: 4 rev: 3.2 speed: 5 Gb/s (596.0 MiB/s)
    lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626 class-ID: 0900
  Device-1: 2-2:3 info: JMicron / USA JMS578 SATA 6Gb/s type: mass storage driver: uas
    interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
    chip-ID: 152d:0578 class-ID: 0806 serial: <filter>
  Hub-11: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-12: 4-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  Hub-13: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Hub-14: 6-0:1 info: super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1
  Device-1: 6-2:2 info: JMicron / USA JMS578 SATA 6Gb/s type: mass storage driver: uas
  Hub-15: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
  Device-1: 7-1:2 info: ASRock LED Controller type: HID driver: hid-generic,usbhid interfaces: 1
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2
  System Temperatures: cpu: 51.0 C mobo: 43.5 C gpu: amdgpu temp: 47.0 C mem: 48.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1010
  Packages: pm: pacman pkgs: 1599 libs: 395 tools: pamac,yay pm: flatpak pkgs: 0
  Active pacman repo servers in: /etc/pacman.conf
    1: https://delinuxco.nyc3.digitaloceanspaces.com/x86_64/
    2: https://x11libre.net/repo/arch_based/x86_64/
    1: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://manjaro.mirror.ac.za/stable/$repo/$arch
    3: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    5: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    6: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    7: https://mirror.init7.net/manjaro/stable/$repo/$arch
    8: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    9: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    10: https://manjaro.syxpi.fr/manjaro/stable/$repo/$arch
    11: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    12: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    13: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    14: https://manjaro.ynh.ovh/stable/$repo/$arch
    15: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    16: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    17: https://mirror.meowsmp.net/manjaro/stable/$repo/$arch
    18: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
    19: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    20: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    21: https://manjaro.grena.ge/stable/$repo/$arch
    22: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    23: https://manjaro.nic.cz/stable/$repo/$arch
    24: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    26: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    27: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    28: https://mirror.mobinhost.com/manjaro/stable/$repo/$arch
    29: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    30: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    31: https://mirrors2.manjaro.org/stable/$repo/$arch
    32: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    33: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    34: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    35: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    36: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    37: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    38: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    39: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    40: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    41: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    42: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    43: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    44: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    45: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    46: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
    47: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    48: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    49: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    50: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    52: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    53: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    54: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    55: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    56: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    57: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    58: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    59: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    60: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    61: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    62: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    64: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    65: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    66: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    67: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    68: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    69: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    70: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    71: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    72: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    73: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    74: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    75: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    76: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    78: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    79: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    80: https://linorg.usp.br/manjaro/stable/$repo/$arch
    81: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    82: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    83: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    84: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    85: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    86: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    87: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    88: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    89: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    91: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    92: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    93: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    94: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    95: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    96: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    97: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    98: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    99: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    100: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    101: https://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    102: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    103: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
    104: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    105: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    106: https://mirror.23m.com/manjaro/stable/$repo/$arch
    107: https://manjaro.kurdy.org/stable/$repo/$arch
    108: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    109: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    110: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    111: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    112: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    113: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    114: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    115: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    116: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    117: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    118: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    119: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    120: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    121: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    122: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    123: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    124: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    125: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 279
  1: cpu: 0.5% command: lightdm-gtk-greeter pid: 2882 mem: 150.6 MiB (0.4%)
  2: cpu: 0.4% command: init pid: 1 mem: 15.3 MiB (0.0%)
  3: cpu: 0.3% command: gpg-agent pid: 1673 mem: 4.46 MiB (0.0%)
  4: cpu: 0.1% command: Xorg pid: 2862 mem: 141.6 MiB (0.4%)
  5: cpu: 0.0% command: [kthreadd] pid: 2 mem: 0.00 MiB (0.0%)
  Memory top: 5 of 279
  1: mem: 150.6 MiB (0.4%) command: lightdm-gtk-greeter pid: 2882 cpu: 0.5%
  2: mem: 141.6 MiB (0.4%) command: Xorg pid: 2862 cpu: 0.1%
  3: mem: 25.6 MiB (0.0%) command: NetworkManager pid: 1482 cpu: 0.0%
  4: mem: 18.6 MiB (0.0%) command: touchegg pid: 1500 cpu: 0.0%
  5: mem: 17.9 MiB (0.0%) command: systemd-journald pid: 1035 cpu: 0.0%
  Processes: 279 Power: uptime: 4m states: freeze,mem,disk suspend: deep avail: s2idle wakeups: 0
    hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 12.2 GiB Init: systemd
    v: 260 default: graphical tool: systemctl
  Compilers: gcc: 16.1.1 Shell: Bash (login) v: 5.3.9 running-in: tty 3 inxi: 3.3.40
What’s the output of:
systemd-analyze critical-chain
graphical.target reached with no blockers?
And you can drill further to see what’s taking so long to come up…
systemd-analyze blame
@pwx Thank you for testing the ISO, yes even though that is an issue with Xlibre, the default manjaro-cinnamon ISO still does the same thing and it is running Xorg.
And here is one that is really weird… I had let my MiniPC (beelink SER), 8core AMD unit sitting idling from the last test, where I waited for 5 minutes and then logged in. I restarted the device from the main menu, and when it rebooted, it auto logged in right away! @!&#$%^(!@&^#%(!? :slight_smile: I then shut it down completely and restarted, again failed to auto login and had to wait the full 5 minutes.
Keep in mind, in a VM it does autologin every time…
wow, what a mystery!
I still don’t know what the issue might be … I built a local Manjaro Cinnamon ISO using linux70 (stable) - which will not load the desktop upon boot - prompt for password instead of autologin.
  • ThinkPad x13 AMD Ryzen 7 Pro w/ Radeon 780 Graphics
The pacman.log list the gpu packages installed - nothing intimidating there.
I am not good at interpreting the logs - looking into /var/log/lightdm
The seat0-greeter.log shows a message about an error spawning a command line
  • dbus-launch --autolaunch .... bla
I am having a lot thoughts
  • pam
  • systemd
  • could be interaction between kernel, pam and systemd
But I cannot make head or tails … nothing useful I’m afraid
I am going to test a similar ISO but with linux618
EDIT:
Using a process of elimination - throwing something at the ceiling to see if it stick…
After building a linux618(stable) ISO I can boot the same ThinkPad with no issues.
The LIVE desktop open as expected.
As I can reproduce your issue in it’s full using linux70, I am guessing that we are looking at the interaction between the kernel, pam and system - which one is
I don’t know what it is - I am utterly clueless… sorry…
I have now switched to another test laptop
  • ThinkPad T495 with AMD Ryzen 5 PRO w/ Radeon Vega Mobile Gfx
There is no issue booting the linux618 ISO - straight to desktop.
Restarting the second laptop - this time booting the linux70 ISO - no issues - straight to desktop.
Retesting the x13 - same mysterious issue using linux70.
EDIT:
Next step - new ISO using linux71(unstable) - no issues booting on ThinkPad x13 and the same goes for ThinkPad T495.
 $ uname -r
7.1.1-3-MANJARO
I cannot be conclusive but it do point to the aforementioned interaction between kernel, systemd and pam security or a kernel regression or it could be something entirely different.
EDIT: 2026-06-22T22:00:00Z
I wanted to make a note of this yesterday but forgot.
With the aforementioned ThinkPad x13 which exhibit the strange live boot issue using linux70 a little twist can be added.
The system is my primary working laptop - it was only booted with the ISO for the test.
The twist is, when normally the laptop uses linux70 so there is no reason why booting an ISO with Cinnamon and Linux 7.0 should fail - it simply makes no sense - no sense at all…
Well, i am almost done with the latest IOS of DeLinuxCo and I still have not been able to understand why this happens.
In my VM, testing the ISO, it goes right the login promp, have to wait at least 90 seconds and then I can login using “manjaro” as the password. That was last night, I shut down the VM ISO, this morning, booted the same ISO, logged right in automatically, no issue at all.
I just hate to push out a release of the ISO with this issue, but maybe I can swing it as a feature :slight_smile:
I even tried Ai, nothing…
Wait Longer: The most reliable but least elegant solution is to simply wait for the full 90 seconds (or a bit more, until you see the login prompt appear). This gives the integration process time to complete so that your real password entry works immediately after.
Wait patiently… then log in.
It would be worth trying to compare the contents of the files in /etc/pam.d from a working ISO with those in the current one to see if there are any changes and, if so, what they are.
Logic suggests that the delay would be caused by a systemd service that waits for another service to complete. Usually this would be something network-related.
And yet, why would it change?
Because of the unpredictability of the service it waits for. One time it could succeed right away — e.g. polling for a network connection — and other times it will hang for a while.
The solution is to look over the list of services your ISO is starting at boot, and to see whether they are all strictly necessary.
by the way; is your ISO profile public?
Not yet, that is on my list of things to do.
Can you try a different DM? I’ve had so many problems with lightdm, including what you’re suffering (Cinnamon, Xfce, Sway, etc.), that I always remove it and install ly instead.
It may not be pretty, but it always works.
