Need help with Live Buildiso
@Lolix
I just pushed the iso-profile to GitHub.
Greetings all, here is probably my final Beta ISO sans this issue.
https://delinuxco.nyc3.cdn.digitaloceanspaces.com/x86_64/delinuxco-workstation-26.1.0-pre-260709-x86_64-beta.iso
A couple of caveats here, the 90 second wait time is not fixed, it is completely arbitrary, sometimes it is only 10 seconds, other times it is 30 seconds etc.
I my testing VM, on the same ISO, within minutes, of boots, it may login it automatically or it may not. On my Beelink Ser, it will almost always take over a minute before it will login. Disconnecting the network seems to have no change.
If anyone would like to download the ISO and take a gander, sometimes just a new pair of eyes is all it takes.
Aside from the Live ISO issue, everything is working perfect, probably the best ISO release to date.
So my brother and I were chatting about this issue over coffee, and he came up with a great idea, “is there a way to delay the starting of LightDM during the boot process, just for testing?”
As it turns out, you can do this by adding ExecStartPre=/usr/bin/sleep 30 using sudo systemctl edit lightdm.service . This will delay lightdm by 30 seconds for testing.
The problem is how would one go about adding this to an ISO?
Just an idea!
You can use the “isomaster” application to edit the .iso image file.
And including the editing, it creates a new .iso
Unfortunately it will not build…
Anyone know why Manjaro buildiso will not build with the latest packages? The host system is fully updated, the caches cleared, mirrors refreshed and even changed, but continues to build with outdates packages?
It could be the build mirror configured in your manjaro-tools.conf
In your ~/.config/manjaro-tools/manjaro-tools.config change the build_mirror environment variable.
The example is using my personal mirror (you can use it for building - but don’t rely on it)
# build_mirror=https://manjaro.moson.eu/
build_mirror=https://manjaro.dk/repo
Since it works fine when installed, this feels like a live environment config issue rather than a lightdm bug—maybe the auto-login settings or session initialization are getting overridden somewhere on boot. Worth checking if the lightdm config in the live ISO matches what gets set up during the install process.
