Recently, my bios stopped reading one of my 2 NVMe SSD’s. It had Manjaro on it. I reset my bios, and now it’s reading that drive, but not the other one with windows11 on it. When booted into Manjaro, I can still see all the files and applications on the windows SSD from inside dolphin in Manjaro. How do I fix this issue? When I go to boot menu during startup it gives me both NVMe SSD’s as an option but when I click the one that now has the “UEFI” attached to it (that happened after running command below) it gives me a black screen and says input boot drive like it’s not seeing it there. The SSD I boot Manjaro on says Manjaro on it in boot menu. How do I get the windows SSD to boot again?
I ran this:
sudo pacman -S os-prober
sudo os-prober
sudo grub-mkconfig -o /boot/grub/grub.cfg
and got this output:
Found theme: /usr/share/grub/themes/Manjaro/theme.txt
Found linux image: /boot/vmlinuz-5.15-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.15-x86_64.img
Found initrd fallback image: /boot/initramfs-5.15-x86_64-fallback.img
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
this is my Inxi -F output:
Host: raivyn Kernel: 5.15.49-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.24.5 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X570 AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570 AORUS MASTER serial: <superuser required>
UEFI: American Megatrends LLC. v: F35e date: 10/13/2021
Info: 12-core model: AMD Ryzen 9 5900X bits: 64 type: MT MCP cache:
L2: 6 MiB
Speed (MHz): avg: 3039 min/max: 2200/4950 cores: 1: 3596 2: 2876 3: 2462
4: 3314 5: 2874 6: 2873 7: 2879 8: 3597 9: 2879 10: 2880 11: 2879 12: 2880
13: 3600 14: 2880 15: 2880 16: 3570 17: 3164 18: 2867 19: 2878 20: 3600
21: 2879 22: 2880 23: 2880 24: 2878
Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] driver: nvidia
v: 470.129.06
Device-2: Sunplus Innovation Depstech webcam MIC type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X. Org v: 21.1.3 with: Xwayland v: 22.1.2 driver: X:
loaded: nvidia gpu: nvidia resolution: 3840x2160~60Hz
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06
Device-1: NVIDIA driver: snd_hda_intel
Device-2: AMD Starship/Matisse HD Audio driver: snd_hda_intel
Device-3: Sunplus Innovation Depstech webcam MIC type: USB
Sound Server-1: ALSA v: k5.15.49-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.52 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi
IF: wlp5s0 state: down mac: ea:98:ac:33:10:c9
Device-2: Intel I211 Gigabit Network driver: igb
IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: 18:c0:4d:04:dd:f6
Device-3: Realtek RTL8125 2.5GbE driver: r8169
IF: enp7s0 state: down mac: 18:c0:4d:04:dd:f7
Device-1: Intel AX200 Bluetooth type: USB driver: btusb
Local Storage: total: 1.88 TiB used: 867.68 GiB (45.2%)
ID-1: /dev/nvme0n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB
ID-2: /dev/nvme1n1 vendor: Sabrent model: Rocket 4.0 1TB size: 931.51 GiB
ID-3: /dev/sda type: USB vendor: SanDisk model: USB 3.2Gen1
ID-1: / size: 915.53 GiB used: 206.09 GiB (22.5%) fs: ext4
dev: /dev/nvme0n1p2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 52 C
Processes: 474 Uptime: 2d 7h 23m Memory: 31.27 GiB used: 4.21 GiB (13.5%)
Shell: Zsh inxi: 3.3.19
