Hello, since 1 or maybe even 2 weeks everytime I shutdown or reboot message “A stop job is running for User Manager for UID 1000” appers and I need to wait 2 minutes. I already know that i can change that timeout but i want to fix program that causes it. I viewed logs and I saw something incomprehensible for me:
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: State 'stop-sigterm' timed out. Killing.
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Killing process 1005 (systemd) with signal S>
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Killing process 2813 (dbus-daemon) with sign>
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Main process exited, code=killed, status=9/K>
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Failed with result 'timeout'.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped User Manager for UID 1000.
It seams like systemd fails to stop systemd and/or dbus-daemon?
Full reboot log is here: https://pastebin.com/raw/ZEyUEsXR
I just want normal shutdown and reboot without workarounds if possible
Try this then reboot, on next reboots it should be gone (i hope ):
# /etc/systemd/logind.conf.d/KillUserProcesses.conf
# See logind.conf(5) for details.
[Login]
KillUserProcesses=yes
Assuming your problem is related to:
This is first time im using Manjaro Linux and i noticed some strange stuff after logout of the GUI.
This is a repeat login after logout of same user (me the only one on system)
The first time is no problem but after that the system has problems to let me login again in the GUI (KDE Plasma).
It gets stuck and the bar does not fill-up completely.
I have to switch to an VT and do CTRL+ALT+DEL to reboot, which also takes some time due to a systemd unit waiting (Session 2 of user)
Is this hapeni…
Unfortunately it did not help. I also tried adding the entry to /etc/systemd/logind.conf
Then i’m unable to give anyother advice, because i can’t open the link with your logs.
(I get an Secure Connection Failed on my side)
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.624:127): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Network Manager...
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6283] caught SIGTERM, shutting down normally.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Network Service...
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6304] device (wlp4s0): state change: activated -> deactivating (reason 'unmanaged', sys-iface-state: 'managed')
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6308] manager: NetworkManager state is now DISCONNECTING
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping WPA supplicant...
gru 18 21:49:52 BxOxSxS dbus-daemon[608]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.5' (uid=0 pid=609 comm="/usr/bin/NetworkManager --no-daemon ")
gru 18 21:49:52 BxOxSxS dbus-daemon[608]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <warn> [1608324592.6339] dispatcher: (7) failed: Refusing activation, D-Bus is shutting down.
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6340] device (wlp4s0): state change: deactivating -> unmanaged (reason 'removed', sys-iface-state: 'managed')
gru 18 21:49:52 BxOxSxS kernel: wlp4s0: deauthenticating from 70:4f:57:eb:02:b4 by local choice (Reason: 3=DEAUTH_LEAVING)
gru 18 21:49:52 BxOxSxS wpa_supplicant[736]: wlp4s0: CTRL-EVENT-DISCONNECTED bssid=70:4f:57:eb:02:b4 reason=3 locally_generated=1
gru 18 21:49:52 BxOxSxS systemd-networkd[276]: wlp4s0: DHCPv6 lease lost
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=17 op=UNLOAD
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6555] manager: NetworkManager state is now DISCONNECTED
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-networkd.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Network Service.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1334 audit(1608324592.654:128): prog-id=17 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6583] device (p2p-dev-wlp4s0): state change: disconnected -> unmanaged (reason 'removed', sys-iface-state: 'removed')
gru 18 21:49:52 BxOxSxS systemd[1]: Requested transaction contradicts existing jobs: Transaction for systemd-networkd.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-networkd.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-networkd.service/start is destructive (reboot.target has 'start' job queued, but 'stop' is included in transaction).
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-networkd.socket: Failed with result 'resources'.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.657:129): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-networkd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS wpa_supplicant[736]: nl80211: deinit ifname=wlp4s0 disabled_11b_rates=0
gru 18 21:49:52 BxOxSxS NetworkManager[609]: <info> [1608324592.6764] exiting (success)
gru 18 21:49:52 BxOxSxS systemd[1]: NetworkManager.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Network Manager.
I copied the part with the errors so maybe you can help him out now.
Looks like a problem with NetworkManager, maybe it needs an update?
(Or WPA supplicant)
You can disable watchdog altogether so you don’t get this
gru 18 21:49:52 BxOxSxS systemd[1]: Using hardware watchdog 'iTCO_wdt', version 0, device /dev/watchdog
gru 18 21:49:52 BxOxSxS systemd[1]: Set hardware watchdog to 10min.
gru 18 21:49:52 BxOxSxS kernel: watchdog: watchdog0: watchdog did not stop!
anymore.
Just add nowatchdog to your kernel parameters and blacklist iTCO_wdt in /etc/modprobe.d/blacklist.conf
see Improving performance - ArchWiki
Here is my full reboot log
gru 18 21:47:52 BxOxSxS systemd-logind[616]: System is rebooting.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Session 3 of user boss.
gru 18 21:47:52 BxOxSxS systemd[1]: Removed slice system-getty.slice.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Wayland Session (session: gnome).
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target Current graphical user session.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Session.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Wayland Session.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME session X11 services.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Session (session: gnome).
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME accessibility target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME color management target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME date & time target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME maintenance of expirable data target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME keyboard configuration target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME keyboard shortcuts target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME power management target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME printer notifications target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME RFKill support target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME FreeDesktop screensaver target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME file sharing target.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME smartcard target.
gru 18 21:47:52 BxOxSxS kernel: audit: type=1130 audit(1608324472.190:102): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bumblebeed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS kernel: audit: type=1131 audit(1608324472.190:103): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bumblebeed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bumblebeed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bumblebeed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME sound sample caching target.
gru 18 21:47:52 BxOxSxS dnscrypt-proxy[610]: [2020-12-18 21:47:52] [NOTICE] Stopped.
gru 18 21:47:52 BxOxSxS ModemManager[674]: <info> caught signal, shutting down...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME USB protection target.
gru 18 21:47:52 BxOxSxS ntfs-3g[340]: Unmounting /dev/sda4 (Part5)
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Wacom tablet support target.
gru 18 21:47:52 BxOxSxS crond[607]: (CRON) INFO (Shutting down)
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME XSettings target.
gru 18 21:47:52 BxOxSxS kernel: rfkill: input handler enabled
gru 18 21:47:52 BxOxSxS ntfs-3g[335]: Unmounting /dev/sda3 (Windows)
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME Terminal Server...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME accessibility service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME color management service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME date & time service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME maintenance of expirable data service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME keyboard configuration service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME keyboard shortcuts service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME power management service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME printer notifications service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME RFKill support service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME FreeDesktop screensaver service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME file sharing service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME smartcard service...
gru 18 21:47:52 BxOxSxS nordvpnd[642]: 2020/12/18 21:47:52 releasing /etc/resolv.conf
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME sound sample caching service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME USB protection service...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME Wacom tablet support service...
gru 18 21:47:52 BxOxSxS ModemManager[674]: <info> ModemManager is shut down
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME XSettings service...
gru 18 21:47:52 BxOxSxS systemd[1]: Removed slice system-modprobe.slice.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Bluetooth.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Graphical Interface.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Multi-User System.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Login Prompts.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Host and Network Name Lookups.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Sound Card.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Timers.
gru 18 21:47:52 BxOxSxS systemd[1]: fstrim.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Discard unused blocks once a week.
gru 18 21:47:52 BxOxSxS systemd[1]: logrotate.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Daily rotation of log files.
gru 18 21:47:52 BxOxSxS systemd[1]: man-db.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Daily man-db regeneration.
gru 18 21:47:52 BxOxSxS systemd[1]: pamac-cleancache.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Monthly clean packages cache.
gru 18 21:47:52 BxOxSxS systemd[1]: pamac-mirrorlist.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Generate mirrorlist weekly.
gru 18 21:47:52 BxOxSxS systemd[1]: shadow.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Daily verification of password and group files.
gru 18 21:47:52 BxOxSxS systemd[1]: systemd-tmpfiles-clean.timer: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Daily Cleanup of Temporary Directories.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target System Time Synchronized.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target System Time Set.
gru 18 21:47:52 BxOxSxS systemd[1]: lvm2-lvmpolld.socket: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Closed LVM2 poll daemon socket.
gru 18 21:47:52 BxOxSxS systemd[1]: systemd-rfkill.socket: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
gru 18 21:47:52 BxOxSxS systemd[1]: Unmounting /mnt/Part5...
gru 18 21:47:52 BxOxSxS systemd[1]: Unmounting /mnt/Windows...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Modem Manager...
gru 18 21:47:52 BxOxSxS snapd[615]: main.go:155: Exiting on terminated signal.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Accounts Service...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Bumblebee C Daemon.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Manage, Install and Generate Color Profiles...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Periodic Command Scheduler...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping DNSCrypt-proxy client...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping GNOME Display Manager...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Location Lookup Service...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Initialize hardware monitoring sensors...
gru 18 21:47:52 BxOxSxS systemd[1005]: mnt-Part5.mount: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: mnt-Windows.mount: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Starting Generate shutdown-ramfs...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping NordVPN Daemon...
gru 18 21:47:52 BxOxSxS NetworkManager[609]: <info> [1608324472.2247] modem-manager: ModemManager no longer available
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Snap Daemon...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Forward Password Requests to Wall...
gru 18 21:47:52 BxOxSxS systemd[1005]: gnome-terminal-server.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME Terminal Server.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Datetime.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Load/Save Random Seed...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Disk Manager...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Daemon for power management...
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME date & time service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.A11ySettings.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME accessibility service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Housekeeping.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME maintenance of expirable data service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.PrintNotifications.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME printer notifications service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Rfkill.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME RFKill support service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Sharing.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME file sharing service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.ScreensaverProxy.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME FreeDesktop screensaver service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Smartcard.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME smartcard service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Sound.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME sound sample caching service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.UsbProtection.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME USB protection service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.XSettings.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME XSettings service.
gru 18 21:47:52 BxOxSxS systemd[1005]: vte-spawn-228fc73d-32dd-4d20-a0ff-fd74f3e80de8.scope: Succeeded.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: cronie.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Periodic Command Scheduler.
gru 18 21:47:52 BxOxSxS systemd[1]: dnscrypt-proxy.service: Succeeded.
gru 18 21:47:52 BxOxSxS kernel: audit: type=1131 audit(1608324472.336:104): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnscrypt-proxy comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped DNSCrypt-proxy client.
gru 18 21:47:52 BxOxSxS kernel: audit: type=1131 audit(1608324472.340:105): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dnscrypt-proxy comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1005]: gnome-session-monitor.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped Monitor Session leader for GNOME Session.
gru 18 21:47:52 BxOxSxS systemd[1]: snapd.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Snap Daemon.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: nordvpnd.service: Succeeded.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=nordvpnd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped NordVPN Daemon.
gru 18 21:47:52 BxOxSxS systemd[1]: systemd-ask-password-wall.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Forward Password Requests to Wall.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-ask-password-wall comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: accounts-daemon.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Accounts Service.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=accounts-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: ModemManager.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Modem Manager.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: upower.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Daemon for power management.
gru 18 21:47:52 BxOxSxS mkinitcpio[2628]: ==> Starting build: none
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=geoclue comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: geoclue.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Location Lookup Service.
gru 18 21:47:52 BxOxSxS systemd[1]: rtkit-daemon.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: colord.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Manage, Install and Generate Color Profiles.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=colord comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS mkinitcpio[2628]: -> Running build hook: [sd-shutdown]
gru 18 21:47:52 BxOxSxS systemd[1]: mnt-Part5.mount: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Unmounted /mnt/Part5.
gru 18 21:47:52 BxOxSxS systemd[1]: mnt-Windows.mount: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Unmounted /mnt/Windows.
gru 18 21:47:52 BxOxSxS systemd[1]: lm_sensors.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Initialize hardware monitoring sensors.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lm_sensors comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: systemd-random-seed.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Load/Save Random Seed.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-random-seed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: session-3.scope: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Session 3 of user boss.
gru 18 21:47:52 BxOxSxS udisksd[1151]: udisks daemon version 2.9.1 exiting
gru 18 21:47:52 BxOxSxS systemd-logind[616]: Session 3 logged out. Waiting for processes to exit.
gru 18 21:47:52 BxOxSxS audit: BPF prog-id=16 op=UNLOAD
gru 18 21:47:52 BxOxSxS audit: BPF prog-id=15 op=UNLOAD
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped target Network is Online.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping Authorization Manager...
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping User Login Management...
gru 18 21:47:52 BxOxSxS systemd[1005]: Requested transaction contradicts existing jobs: Transaction for exit.target/start is destructive (gnome-session-restart-dbus.service has 'start' job queued, but 'stop' is included in transaction).
gru 18 21:47:52 BxOxSxS systemd[1005]: Failed to enqueue exit.target job: Transaction for exit.target/start is destructive (gnome-session-restart-dbus.service has 'start' job queued, but 'stop' is included in transaction).
gru 18 21:47:52 BxOxSxS systemd[1]: Stopping User Manager for UID 1000...
gru 18 21:47:52 BxOxSxS systemd[1]: udisks2.service: Succeeded.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Disk Manager.
gru 18 21:47:52 BxOxSxS systemd[1]: polkit.service: Succeeded.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped Authorization Manager.
gru 18 21:47:52 BxOxSxS systemd-logind[616]: Removed session 3.
gru 18 21:47:52 BxOxSxS gnome-shell[1085]: Error checking authorization for action id org.freedesktop.bolt.enroll: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name :1.3 was not provided by any .service files
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Keyboard.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME keyboard configuration service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Color.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME color management service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Power.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME power management service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.MediaKeys.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME keyboard shortcuts service.
gru 18 21:47:52 BxOxSxS systemd[1005]: org.gnome.SettingsDaemon.Wacom.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped GNOME Wacom tablet support service.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Session is initialized.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopped target GNOME Shell.
gru 18 21:47:52 BxOxSxS systemd[1005]: Stopping GNOME Shell on Wayland...
gru 18 21:47:52 BxOxSxS mntray[1431]: The X11 connection broke (error 1). Did the X11 server die?
gru 18 21:47:52 BxOxSxS discord-canary.desktop[1652]: X connection to :0 broken (explicit kill or server shutdown).
gru 18 21:47:52 BxOxSxS gdm[653]: Gdm: GdmLocalDisplayFactory: Failed to issue method call: GDBus.Error:org.freedesktop.DBus.Error.NoReply: Message recipient disconnected from message bus without replying
gru 18 21:47:52 BxOxSxS gdm[653]: Gdm: Freeing conversation 'gdm-password' with active job
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=gdm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: gdm.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped GNOME Display Manager.
gru 18 21:47:52 BxOxSxS gnome-shell[1085]: Connection to xwayland lost
gru 18 21:47:52 BxOxSxS systemd[1005]: app-gnome-mntray-1431.scope: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: app-gnome-copyq\x2d1-1436.scope: Succeeded.
gru 18 21:47:52 BxOxSxS xdg-desktop-por[1554]: Error reading events from display: Przerwany potok
gru 18 21:47:52 BxOxSxS evolution-alarm[1426]: Error reading events from display: Przerwany potok
gru 18 21:47:52 BxOxSxS gjs[1352]: Error reading events from display: Przerwany potok
gru 18 21:47:52 BxOxSxS systemd[1005]: app-gnome-discord\x2dcanary-1424.scope: Succeeded.
gru 18 21:47:52 BxOxSxS dbus-daemon[1025]: [session uid=1000 pid=1025] Monitoring connection :1.61 closed.
gru 18 21:47:52 BxOxSxS systemd[1005]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
gru 18 21:47:52 BxOxSxS systemd[1005]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
gru 18 21:47:52 BxOxSxS systemd[1005]: app-gnome-org.gnome.Evolution\x2dalarm\x2dnotify-1426.scope: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1005]: pulseaudio.service: Succeeded.
gru 18 21:47:52 BxOxSxS mkinitcpio[2628]: ==> Build complete.
gru 18 21:47:52 BxOxSxS systemd[1]: mkinitcpio-generate-shutdown-ramfs.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Finished Generate shutdown-ramfs.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=mkinitcpio-generate-shutdown-ramfs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:52 BxOxSxS systemd[1]: systemd-logind.service: Succeeded.
gru 18 21:47:52 BxOxSxS systemd[1]: Stopped User Login Management.
gru 18 21:47:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:47:53 BxOxSxS systemd[1005]: org.gnome.Shell@wayland.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped GNOME Shell on Wayland.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped target GNOME Session Manager is ready.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopping GNOME Session Manager (session: gnome)...
gru 18 21:47:53 BxOxSxS gnome-session[1069]: gnome-session-binary[1069]: WARNING: Could not get session class: Nie ma takiego urządzenia ani adresu
gru 18 21:47:53 BxOxSxS gnome-session-binary[1069]: WARNING: Could not get session class: Nie ma takiego urządzenia ani adresu
gru 18 21:47:53 BxOxSxS systemd[1005]: at-spi-dbus-bus.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gnome-session-manager@gnome.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped GNOME Session Manager (session: gnome).
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped target Tasks to be run before GNOME Session starts.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped target Session services which should run early before the graphical session is brought up.
gru 18 21:47:53 BxOxSxS systemd[1005]: Reached target Shutdown running GNOME Session.
gru 18 21:47:53 BxOxSxS systemd[1005]: Starting Restart DBus after GNOME Session shutdown...
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped target Shutdown running GNOME Session.
gru 18 21:47:53 BxOxSxS systemd[1005]: Started Restart DBus after GNOME Session shutdown.
gru 18 21:47:53 BxOxSxS gvfsd[1040]: A connection to the bus can't be made
gru 18 21:47:53 BxOxSxS systemd[1]: run-user-1000-gvfs.mount: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1]: Unmounted /run/user/1000/gvfs.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopping D-Bus User Message Bus...
gru 18 21:47:53 BxOxSxS evolution-calen[1160]: Error setting property 'ConnectionStatus' on interface org.gnome.evolution.dataserver.Source: Połączenie jest zamknięte (g-io-error-quark, 18)
gru 18 21:47:53 BxOxSxS evolution-addre[1190]: Error setting property 'ConnectionStatus' on interface org.gnome.evolution.dataserver.Source: Połączenie jest zamknięte (g-io-error-quark, 18)
gru 18 21:47:53 BxOxSxS systemd[1005]: run-user-1000-gvfs.mount: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
gru 18 21:47:53 BxOxSxS systemd[1005]: xdg-permission-store.service: Failed with result 'exit-code'.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-metadata.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-mtp-volume-monitor.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-goa-volume-monitor.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gnome-session-restart-dbus.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: app-gnome-ignore\x2dlid\x2dswitch\x2dtweak-1417.scope: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: run-user-1000-doc.mount: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: app-gnome-org.gnome.SettingsDaemon.DiskUtilityNotify-1425.scope: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1]: run-user-1000-doc.mount: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1]: Unmounted /run/user/1000/doc.
gru 18 21:47:53 BxOxSxS systemd[1005]: xdg-document-portal.service: Main process exited, code=exited, status=20/n/a
gru 18 21:47:53 BxOxSxS systemd[1005]: xdg-document-portal.service: Failed with result 'exit-code'.
gru 18 21:47:53 BxOxSxS systemd[1005]: dbus.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: Stopped D-Bus User Message Bus.
gru 18 21:47:53 BxOxSxS systemd[1005]: evolution-source-registry.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-udisks2-volume-monitor.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: evolution-addressbook-factory.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-afc-volume-monitor.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: xdg-desktop-portal.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: gvfs-daemon.service: Succeeded.
gru 18 21:47:53 BxOxSxS systemd[1005]: Started D-Bus User Message Bus.
gru 18 21:47:53 BxOxSxS systemd[1005]: evolution-calendar-factory.service: Succeeded.
gru 18 21:48:04 BxOxSxS wpa_supplicant[736]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-84 noise=-95 txrate=90000
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Killing process 1005 (systemd) with signal SIGKILL.
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Killing process 2813 (dbus-daemon) with signal SIGKILL.
gru 18 21:49:52 BxOxSxS systemd[1]: user@1000.service: Main process exited, code=killed, status=9/KILL
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
gru 18 21:49:52 BxOxSxS kernel: kauditd_printk_skb: 19 callbacks suppressed
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.594:125): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping User Runtime Directory /run/user/1000...
gru 18 21:49:52 BxOxSxS systemd[1]: run-user-1000.mount: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounted /run/user/1000.
gru 18 21:49:52 BxOxSxS systemd[1]: user-runtime-dir@1000.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped User Runtime Directory /run/user/1000.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Removed slice User Slice of UID 1000.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.611:126): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Permit User Sessions...
gru 18 21:49:52 BxOxSxS wpa_supplicant[736]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-69 noise=-95 txrate=1000
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-user-sessions.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Permit User Sessions.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Network.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target User and Group Name Lookups.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Remote File Systems.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS wpa_supplicant[736]: wlp4s0: CTRL-EVENT-TERMINATING
gru 18 21:49:52 BxOxSxS systemd[1]: wpa_supplicant.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped WPA supplicant.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.687:130): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.691:131): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping D-Bus System Message Bus...
gru 18 21:49:52 BxOxSxS systemd[1]: dbus.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped D-Bus System Message Bus.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Basic System.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Paths.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Slices.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.714:132): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Removed slice User and Session Slice.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Sockets.
gru 18 21:49:52 BxOxSxS systemd[1]: dbus.socket: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Closed D-Bus System Message Bus Socket.
gru 18 21:49:52 BxOxSxS systemd[1]: nordvpnd.socket: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Closed NordVPN Daemon Socket.
gru 18 21:49:52 BxOxSxS systemd[1]: snapd.socket: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Closed Socket activation for snappy daemon.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target System Initialization.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Local Encrypted Volumes.
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-ask-password-wall.path: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-sysctl.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Apply Kernel Variables.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-modules-load.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Load Kernel Modules.
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.744:133): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Network Time Synchronization...
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
gru 18 21:49:52 BxOxSxS kernel: audit: type=1131 audit(1608324592.747:134): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-backlight@backlight:intel_backlight.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
gru 18 21:49:52 BxOxSxS audit[2819]: SYSTEM_SHUTDOWN pid=2819 uid=0 auid=4294967295 ses=4294967295 msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-timesyncd.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Network Time Synchronization.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-update-utmp.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-tmpfiles-setup.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Create Volatile Files and Directories.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Local File Systems.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounting /boot/efi...
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounting /home...
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounting /tmp...
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounting Mount unit for core, revision 10444...
gru 18 21:49:52 BxOxSxS systemd[1]: boot-efi.mount: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounted /boot/efi.
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-fsck@dev-disk-by\x2duuid-D27B\x2dC3CF.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped File System Check on /dev/disk/by-uuid/D27B-C3CF.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-disk-by\x2duuid-D27B\x2dC3CF comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: tmp.mount: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounted /tmp.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Swap.
gru 18 21:49:52 BxOxSxS systemd[1]: home.mount: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounted /home.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Block Device Preparation for /dev/mapper/home.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Cryptography Setup for home...
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-fsck@dev-mapper-home.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped File System Check on /dev/mapper/home.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-fsck@dev-mapper-home comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Removed slice system-systemd\x2dfsck.slice.
gru 18 21:49:52 BxOxSxS systemd[1]: var-lib-snapd-snap-core-10444.mount: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Unmounted Mount unit for core, revision 10444.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped target Local File Systems (Pre).
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-remount-fs.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Remount Root and Kernel File Systems.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-remount-fs comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-tmpfiles-setup-dev.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Create Static Device Nodes in /dev.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-cryptsetup@home.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Cryptography Setup for home.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-cryptsetup@home comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Reached target Unmount All Filesystems.
gru 18 21:49:52 BxOxSxS systemd[1]: lvm2-monitor.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Stopping LVM2 metadata daemon...
gru 18 21:49:52 BxOxSxS systemd[1]: lvm2-lvmetad.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Stopped LVM2 metadata daemon.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Reached target Shutdown.
gru 18 21:49:52 BxOxSxS systemd[1]: Reached target Final Step.
gru 18 21:49:52 BxOxSxS systemd[1]: lvm2-lvmetad.socket: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Closed LVM2 metadata daemon socket.
gru 18 21:49:52 BxOxSxS systemd[1]: systemd-reboot.service: Succeeded.
gru 18 21:49:52 BxOxSxS systemd[1]: Finished Reboot.
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
gru 18 21:49:52 BxOxSxS systemd[1]: Reached target Reboot.
gru 18 21:49:52 BxOxSxS systemd[1]: Shutting down.
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=9 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=8 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=7 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=6 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=5 op=UNLOAD
gru 18 21:49:52 BxOxSxS audit: BPF prog-id=4 op=UNLOAD
gru 18 21:49:52 BxOxSxS systemd-shutdown[1]: Syncing filesystems and block devices.
gru 18 21:49:52 BxOxSxS systemd-shutdown[1]: Sending SIGTERM to remaining processes...
gru 18 21:49:52 BxOxSxS haveged[243]: haveged: Stopping due to signal 15
gru 18 21:49:52 BxOxSxS haveged[243]: haveged starting up
gru 18 21:49:52 BxOxSxS systemd-journald[244]: Journal stopped
My system is completely updated
Is this a default install of Manjaro-GNOME, because tbh i don’t use Gnome…
Does it happen without your DNSCrypt-proxy and NordVPN services?
(They might interfere with the shutdown)
Plus i see another unfamiliar line:
Something is trying to restart gnome…
I installed manjaro something like a year ago and changed a lot of stuff so I cannot say it’s latest and default gnome-shell
I also did sudo systemctl stop NetworkManager.service nordvpnd.service nordvpnd.socket dnscrypt-proxy.service and then shutdown and still same issue
Without knowing what exactly you changed, it’s hard to say what is causing this problem right
I also just noticed you’re on testing branch which by nature is a very instable road to walk.
The above combined, i pass the problem to others if you don’t mind
Problem disappeared after latest update. Thanks all for help
system
Closed
16 January 2021 22:10
15
