Need a little btrfs subvolumes advice
I have subvolumes:
@home
@cache
Before major system changes, I do snapshot of @ to bak_@
but…
To do this I need to boot into live environment, mount drive with btrfs file system and then do the snapshot.
Similar way with snapshot recovery
I don’t believe that there is no better way (for this case I don’t want to use tools like timeshift)
I think that sometime ago I tried to do this under running system (restore snapshot) but something went wrong and I had to repair everything my way.
If I have @ subvolume
Can I do its snapshot backup in current running system?
Can I restore this backup during the same session ?
Why? :face_with_raised_eyebrow:
Yes. Timeshift and Snapper also do that.
I don’t think so. But you can boot using a snapshot.
I have encrypted drive. After restoring, something went wronk and I couldn’t boot the system. I had to chroot into installation and install bootloader (systemd boot)
I thought that timeshift do this. Isn’t it? It recover snapshots after reboot?
I never restored a system backup with Timeshift, but i think it would have the same impact than updating. Meaning, you’d need to reboot afterwards in order to use the restored system.
Ok
SO one more question
To do proper backup I use btrfs send recieve but I have to do readonly snapshot first.
Is there a way to pipe this somehow?
Something like
btrfs snapshot @ -r | btrfs send | btrfs recieve ??
In a single line, using & may be more relevant.
btrfs snapshot @ -r & btrfs send | btrfs recieve
https://wiki.archlinux.org/title/Btrfs#Send/receive
Is it necessary though? From what i read, you already need to specify the snapshot destination when taking it. Do you need to backup it twice?
https://wiki.archlinux.org/title/Btrfs#Snapshots
But snapshot is not a backup.
I use send receive when for example I need to transfer system to another drive
I do snaps and rollbacks in live system.
To do a snap, mount the root file system and then make the snap. Like:
sudo mount -t btrfs /dev/sda1 /mnt
sudo btrfs sub snap /mnt/@ /mnt/@-210902-preUpdate
sudo umount /mnt
Do what you need.
You can undo with:
sudo mv /mnt/@ /mnt/@-failed
sudo mv /mnt/@-210902-preUpdate /mnt/@
sudo umount /mnt
and when you reboot you are in the previous state. The reboot it’s a must.
May be you can work with different snaps in “live mode” using firejail --chroot. I’ll try someday.
You should delete the failed snap eventually, to free disk space.
As you probably know:
sudo btrfs sub del /mnt/@-failed
sudo umount /mnt
It’s important to do the two “mv’s”.
That can work :slight_smile:
I believe that I tried sometime ago, something like:
mounting
creating snapshots
and to rollback:
btrfs subvolume delete @ which was my root subvolume
btrfs subvolume snapshot @bak @
Don’t remember but this destroyed my system I believe :slight_smile:
So with subvolumes @ and @bak I should do
mv @ @trash
mv @bak @
My directory tree lokks like this:
nvme0n1       259:0    0 931,5G  0 disk
├─nvme0n1p1   259:1    0   500M  0 part  /boot
├─nvme0n1p2   259:2    0   431G  0 part  /Windows
└─nvme0n1p3   259:3    0   500G  0 part
  └─cryptroot 254:0    0   500G  0 crypt /var/cache
                                         /home
My subvolumes are on nvme on nvme0n1p3, and this partition is encrypted so I should mount /dev/mapper/cryptroot it directly in /mnt
And when I ls mnt I’ll see @, @bak subvolumes
Right?
Do you
For a roll back you may also look at
There are some limits in moving snapshots. You can’t move a ro-snapshot, but only rw-snapshots. So you can’t move @backup when it is readonly (what a backup should be). But you may make a rw-snapshot of the backup to @
Using snapshots, understand that you have to explicitly mount your root filesystem (subvolid=5).
Whether you do your snapshots manually (that is what i do) or in an app, it has to be done.
All my snapshot are in /.snapshots folder (folder created manually) and i have added this in fstab :
UUID=xxxx-xxxx /.snapshots btrfs subvolid=5,defaults,noatime,space_cache,ssd,compress=zstd,commit=120 0 1
Where UUID=xxxx-xxxx is your root partition
In that case, you can list your snapshots in command line, add or delete them, no need to boot into a live cd. You see them all in the /.snapshots folder too.
When i want to add a snapshot of @, i do :
sudo btrfs subvolume snapshot / /.snapshots/<name of your snapshot>
Then i advice you to install grub-btrfs, so that your snapshots are available in grub menu. So each time you add a snapshot there is a new entry in grub. I do not use Timeshift either.
So, i manually add snapshots in a running system and when i want to restore the previous snapshot (or an older one), i reboot and i choose it in grub menu.
Good advice but I use systemd boot :slight_smile:
I’ve got one more question
Let’s say that I have root subvolume like
And I do a snapshot of it like
@backup
If something goes wrong and I would like to use backup subvolume then should I do
and
btrfs subvolume snapshot @backup @
btrfs subvolume delete @backup
Or should I just do
and
mv @backup @
I would like to bump my previous question and ask one more
@snap
In fstab should I mount @ or @snap?
Can I use both snapshots (change fstab entry when I want) or just use @ and if something goes wrong delete @ and use @snap?
There is a difference between a snapshot and a subvolume. A snapshot is meant to be readonly, so you can´t work on it.
https://wiki.manjaro.org/index.php/Btrfs
If you create a second subvolume (rw) this will be a separate subvolume with inital the same files. But when using it it will beginn to differ from ist anchestor. Also if you use the anchestor again (rw) this subvolume will also beginn to differ from its first state. While this is possible, you may get confused, where your newest files may be :wink:
