How can i make my Arch Konsole look like the same like it’s in Manjaro KDE?
Any terminal commands?
With the Powerlevel10k ZSH theme, mainly:
thanks, and how can i make it to look just like in Manjaro KDE Konsole?
The Manjaro zsh configuration is at:
https://github.com/Chrysostomus/manjaro-zsh-config
You can source these to get a similar look.
All the packages Manjaro uses for zsh -
zsh
zsh-autosuggestions
zsh-syntax-highlighting
zsh-completions
zsh-history-substring-search
zsh-theme-powerlevel10k
manjaro-zsh-config
Except the last one (the source link is given above), all are available in Arch repos.
thank you, i installed all of these packages except manjaro-zsh-config, can you tell me how i can set it up and make it work?
All the configuration files you need and which are installed by these packages end up in the directory:
/etc/skel
where all the default configuration files reside.
They get used and applied automatically only when a new user account is created.
If you want to make use of these in an already existing account
you need to copy the (relevant) files to the user account you want them to be applied in.
Considering @Edward1 is not using Manjaro,
For the most basic yet effective usage, you can just create two files with the contents manjaro-zsh-config and manjaro-zsh-prompt and source those in your ~/.zshrc
On the first run, you’ll be greeted with p10k configuration prompt. Configure it & bingo!
For example, in my Arch install, I have ~/.zsh-config
and ~/.zsh-prompt
and in my ~/.zshrc
, I have,
source ~/.zsh-config
source ~/.zsh-prompt
does anybody here has a guide how to install and configure zsh to act EXACTLY how is done in Manjaro?
@Edward1, here you go, create the following 4 files as with the given path and your prompt should be exactly as Manjaro zsh prompt (appearance and behaviour):
~/.zshrc
# Use powerline
USE_POWERLINE="true"
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
## Options section
setopt correct # Auto correct mistakes
setopt extendedglob # Extended globbing. Allows using regular expressions with *
setopt nocaseglob # Case insensitive globbing
setopt rcexpandparam # Array expension with parameters
setopt nocheckjobs # Don't warn about running processes when exiting
setopt numericglobsort # Sort filenames numerically when it makes sense
setopt nobeep # No beep
setopt appendhistory # Immediately append history instead of overwriting
setopt histignorealldups # If a new command is a duplicate, remove the older one
setopt autocd # if only directory path is entered, cd there.
setopt inc_append_history # save commands are added to the history immediately, otherwise only when shell exits.
setopt histignorespace # Don't save commands that start with space
zstyle ':completion:*' matcher-list 'm:{a-zA-Z}={A-Za-z}' # Case insensitive tab completion
zstyle ':completion:*' list-colors "${(s.:.)LS_COLORS}" # Colored completion (different colors for dirs/files/etc)
zstyle ':completion:*' rehash true # automatically find new executables in path
# Speed up completions
zstyle ':completion:*' accept-exact '*(N)'
zstyle ':completion:*' use-cache on
zstyle ':completion:*' cache-path ~/.zsh/cache
HISTFILE=~/.zhistory
HISTSIZE=10000
SAVEHIST=10000
#export EDITOR=/usr/bin/nano
#export VISUAL=/usr/bin/nano
WORDCHARS=${WORDCHARS//\/[&.;]} # Don't consider certain characters part of the word
## Keybindings section
bindkey -e
bindkey '^[[7~' beginning-of-line # Home key
bindkey '^[[H' beginning-of-line # Home key
if [[ "${terminfo[khome]}" != "" ]]; then
bindkey "${terminfo[khome]}" beginning-of-line # [Home] - Go to beginning of line
fi
bindkey '^[[8~' end-of-line # End key
bindkey '^[[F' end-of-line # End key
if [[ "${terminfo[kend]}" != "" ]]; then
bindkey "${terminfo[kend]}" end-of-line # [End] - Go to end of line
fi
bindkey '^[[2~' overwrite-mode # Insert key
bindkey '^[[3~' delete-char # Delete key
bindkey '^[[C' forward-char # Right key
bindkey '^[[D' backward-char # Left key
bindkey '^[[5~' history-beginning-search-backward # Page up key
bindkey '^[[6~' history-beginning-search-forward # Page down key
# Navigate words with ctrl+arrow keys
bindkey '^[Oc' forward-word #
bindkey '^[Od' backward-word #
bindkey '^[[1;5D' backward-word #
bindkey '^[[1;5C' forward-word #
bindkey '^H' backward-kill-word # delete previous word with ctrl+backspace
bindkey '^[[Z' undo # Shift+tab undo last action
## Alias section
alias cp="cp -i" # Confirm before overwriting something
alias df='df -h' # Human-readable sizes
alias free='free -m' # Show sizes in MB
alias gitu='git add . && git commit && git push'
# Theming section
autoload -U compinit colors zcalc
compinit -d
colors
# Color man pages
export LESS_TERMCAP_mb=$'\E[01;32m'
export LESS_TERMCAP_md=$'\E[01;32m'
export LESS_TERMCAP_me=$'\E[0m'
export LESS_TERMCAP_se=$'\E[0m'
export LESS_TERMCAP_so=$'\E[01;47;34m'
export LESS_TERMCAP_ue=$'\E[0m'
export LESS_TERMCAP_us=$'\E[01;36m'
export LESS=-R
## Plugins section: Enable fish style features
# Use syntax highlighting
source /usr/share/zsh/plugins/zsh-syntax-highlighting/zsh-syntax-highlighting.zsh
# Use history substring search
source /usr/share/zsh/plugins/zsh-history-substring-search/zsh-history-substring-search.zsh
# bind UP and DOWN arrow keys to history substring search
zmodload zsh/terminfo
bindkey "$terminfo[kcuu1]" history-substring-search-up
bindkey "$terminfo[kcud1]" history-substring-search-down
bindkey '^[[A' history-substring-search-up
bindkey '^[[B' history-substring-search-down
# Offer to install missing package if command is not found
if [[ -r /usr/share/zsh/functions/command-not-found.zsh ]]; then
source /usr/share/zsh/functions/command-not-found.zsh
export PKGFILE_PROMPT_INSTALL_MISSING=1
fi
# Set terminal window and tab/icon title
# usage: title short_tab_title [long_window_title]
# See: http://www.faqs.org/docs/Linux-mini/Xterm-Title.html#ss3.1
# Fully supports screen and probably most modern xterm and rxvt
# (In screen, only short_tab_title is used)
function title {
emulate -L zsh
setopt prompt_subst
[[ "$EMACS" == *term* ]] && return
# if $2 is unset use $1 as default
# if it is set and empty, leave it as is
: ${2=$1}
case "$TERM" in
xterm*|putty*|rxvt*|konsole*|ansi|mlterm*|alacritty|st*)
print -Pn "\e]2;${2:q}\a" # set window name
print -Pn "\e]1;${1:q}\a" # set tab name
screen*|tmux*)
print -Pn "\ek${1:q}\e\\" # set screen hardstatus
# Try to use terminfo to set the title
# If the feature is available set title
if [[ -n "$terminfo[fsl]" ]] && [[ -n "$terminfo[tsl]" ]]; then
echoti tsl
print -Pn "$1"
echoti fsl
fi
esac
ZSH_THEME_TERM_TAB_TITLE_IDLE="%15<..<%~%<<" #15 char left truncated PWD
ZSH_THEME_TERM_TITLE_IDLE="%n@%m:%~"
# Runs before showing the prompt
function mzc_termsupport_precmd {
[[ "${DISABLE_AUTO_TITLE:-}" == true ]] && return
title $ZSH_THEME_TERM_TAB_TITLE_IDLE $ZSH_THEME_TERM_TITLE_IDLE
# Runs before executing the command
function mzc_termsupport_preexec {
emulate -L zsh
# split command into array of arguments
local -a cmdargs
cmdargs=("${(z)2}")
# if running fg, extract the command from the job description
if [[ "${cmdargs[1]}" = fg ]]; then
# get the job id from the first argument passed to the fg command
local job_id jobspec="${cmdargs[2]#%}"
# logic based on jobs arguments:
# http://zsh.sourceforge.net/Doc/Release/Jobs-_0026-Signals.html#Jobs
# https://www.zsh.org/mla/users/2007/msg00704.html
case "$jobspec" in
<->) # %number argument:
# use the same <number> passed as an argument
job_id=${jobspec} ;;
""|%|+) # empty, %% or %+ argument:
# use the current job, which appears with a + in $jobstates:
# suspended:+:5071=suspended (tty output)
job_id=${(k)jobstates[(r)*:+:*]} ;;
-) # %- argument:
# use the previous job, which appears with a - in $jobstates:
# suspended:-:6493=suspended (signal)
job_id=${(k)jobstates[(r)*:-:*]} ;;
[?]*) # %?string argument:
# use $jobtexts to match for a job whose command *contains* <string>
job_id=${(k)jobtexts[(r)*${(Q)jobspec}*]} ;;
*) # %string argument:
# use $jobtexts to match for a job whose command *starts with* <string>
job_id=${(k)jobtexts[(r)${(Q)jobspec}*]} ;;
esac
# override preexec function arguments with job command
if [[ -n "${jobtexts[$job_id]}" ]]; then
1="${jobtexts[$job_id]}"
2="${jobtexts[$job_id]}"
fi
fi
# cmd name only, or if this is sudo or ssh, the next cmd
local CMD=${1[(wr)^(*=*|sudo|ssh|mosh|rake|-*)]:gs/%/%%}
local LINE="${2:gs/%/%%}"
title '$CMD' '%100>...>$LINE%<<'
autoload -U add-zsh-hook
add-zsh-hook precmd mzc_termsupport_precmd
add-zsh-hook preexec mzc_termsupport_preexec
# File and Dir colors for ls and other outputs
export LS_OPTIONS='--color=auto'
eval "$(dircolors -b)"
alias ls='ls $LS_OPTIONS'
emulate -L zsh
source /usr/share/zsh-theme-powerlevel10k/powerlevel10k.zsh-theme
source /usr/share/zsh/plugins/zsh-autosuggestions/zsh-autosuggestions.zsh
# Determine terminal capabilities.
if ! zmodload zsh/langinfo zsh/terminfo ||
[[ $langinfo[CODESET] != (utf|UTF)(-|)8 || $TERM == (dumb|linux) ]] ||
(( terminfo[colors] < 256 )); then
# Don't use the powerline config. It won't work on this terminal.
local USE_POWERLINE=false
# Define alias `x` if our parent process is `login`.
local parent
if { parent=$(</proc/$PPID/comm) } && [[ ${parent:t} == login ]]; then
alias x='startx ~/.xinitrc'
fi
fi
} 2>/dev/null
if [[ $USE_POWERLINE == false ]]; then
# Use 8 colors and ASCII.
source /usr/share/zsh/p10k-portable.zsh
ZSH_AUTOSUGGEST_HIGHLIGHT_STYLE='fg=black,bold'
else
# Use 256 colors and UNICODE.
source /usr/share/zsh/p10k.zsh
ZSH_AUTOSUGGEST_HIGHLIGHT_STYLE='fg=244'
fi
# Generated by Powerlevel10k configuration wizard on 2021-11-14 at 16:02 CET.
# Based on romkatv/powerlevel10k/config/p10k-rainbow.zsh, checksum 19497.
# Wizard options: nerdfont-complete + powerline, small icons, rainbow, unicode,
# angled separators, sharp heads, flat tails, 1 line, compact, many icons, concise,
# instant_prompt=quiet.
# Type `p10k configure` to generate another config.
# Config for Powerlevel10k with powerline prompt style with colorful background.
# Type `p10k configure` to generate your own config based on it.
# Tip: Looking for a nice color? Here's a one-liner to print colormap.
# for i in {0..255}; do print -Pn "%K{$i} %k%F{$i}${(l:3::0:)i}%f " ${${(M)$((i%6)):#3}:+$'\n'}; done
# Temporarily change options.
'builtin' 'local' '-a' 'p10k_config_opts'
[[ ! -o 'aliases' ]] || p10k_config_opts+=('aliases')
[[ ! -o 'sh_glob' ]] || p10k_config_opts+=('sh_glob')
[[ ! -o 'no_brace_expand' ]] || p10k_config_opts+=('no_brace_expand')
'builtin' 'setopt' 'no_aliases' 'no_sh_glob' 'brace_expand'
emulate -L zsh -o extended_glob
# Unset all configuration options. This allows you to apply configuration changes without
# restarting zsh. Edit ~/.p10k.zsh and type `source ~/.p10k.zsh`.
unset -m '(POWERLEVEL9K_*|DEFAULT_USER)~POWERLEVEL9K_GITSTATUS_DIR'
# Zsh >= 5.1 is required.
autoload -Uz is-at-least && is-at-least 5.1 || return
# The list of segments shown on the left. Fill it with the most important segments.
typeset -g POWERLEVEL9K_LEFT_PROMPT_ELEMENTS=(
os_icon # os identifier
dir # current directory
vcs # git status
# prompt_char # prompt symbol
# The list of segments shown on the right. Fill it with less important segments.
# Right prompt on the last prompt line (where you are typing your commands) gets
# automatically hidden when the input line reaches it. Right prompt above the
# last prompt line gets hidden if it would overlap with left prompt.
typeset -g POWERLEVEL9K_RIGHT_PROMPT_ELEMENTS=(
status # exit code of the last command
command_execution_time # duration of the last command
background_jobs # presence of background jobs
direnv # direnv status (https://direnv.net/)
asdf # asdf version manager (https://github.com/asdf-vm/asdf)
virtualenv # python virtual environment (https://docs.python.org/3/library/venv.html)
anaconda # conda environment (https://conda.io/)
pyenv # python environment (https://github.com/pyenv/pyenv)
goenv # go environment (https://github.com/syndbg/goenv)
nodenv # node.js version from nodenv (https://github.com/nodenv/nodenv)
nvm # node.js version from nvm (https://github.com/nvm-sh/nvm)
nodeenv # node.js environment (https://github.com/ekalinin/nodeenv)
# node_version # node.js version
# go_version # go version (https://golang.org)
# rust_version # rustc version (https://www.rust-lang.org)
# dotnet_version # .NET version (https://dotnet.microsoft.com)
# php_version # php version (https://www.php.net/)
# laravel_version # laravel php framework version (https://laravel.com/)
# java_version # java version (https://www.java.com/)
# package # name@version from package.json (https://docs.npmjs.com/files/package.json)
rbenv # ruby version from rbenv (https://github.com/rbenv/rbenv)
rvm # ruby version from rvm (https://rvm.io)
fvm # flutter version management (https://github.com/leoafarias/fvm)
luaenv # lua version from luaenv (https://github.com/cehoffman/luaenv)
jenv # java version from jenv (https://github.com/jenv/jenv)
plenv # perl version from plenv (https://github.com/tokuhirom/plenv)
phpenv # php version from phpenv (https://github.com/phpenv/phpenv)
scalaenv # scala version from scalaenv (https://github.com/scalaenv/scalaenv)
haskell_stack # haskell version from stack (https://haskellstack.org/)
kubecontext # current kubernetes context (https://kubernetes.io/)
terraform # terraform workspace (https://www.terraform.io)
# terraform_version # terraform version (https://www.terraform.io)
aws # aws profile (https://docs.aws.amazon.com/cli/latest/userguide/cli-configure-profiles.html)
aws_eb_env # aws elastic beanstalk environment (https://aws.amazon.com/elasticbeanstalk/)
azure # azure account name (https://docs.microsoft.com/en-us/cli/azure)
gcloud # google cloud cli account and project (https://cloud.google.com/)
google_app_cred # google application credentials (https://cloud.google.com/docs/authentication/production)
toolbox # toolbox name (https://github.com/containers/toolbox)
context # user@hostname
nordvpn # nordvpn connection status, linux only (https://nordvpn.com/)
ranger # ranger shell (https://github.com/ranger/ranger)
nnn # nnn shell (https://github.com/jarun/nnn)
xplr # xplr shell (https://github.com/sayanarijit/xplr)
vim_shell # vim shell indicator (:sh)
midnight_commander # midnight commander shell (https://midnight-commander.org/)
nix_shell # nix shell (https://nixos.org/nixos/nix-pills/developing-with-nix-shell.html)
vi_mode # vi mode (you don't need this if you've enabled prompt_char)
# vpn_ip # virtual private network indicator
# load # CPU load
# disk_usage # disk usage
# ram # free RAM
# swap # used swap
todo # todo items (https://github.com/todotxt/todo.txt-cli)
timewarrior # timewarrior tracking status (https://timewarrior.net/)
taskwarrior # taskwarrior task count (https://taskwarrior.org/)
# time # current time
# ip # ip address and bandwidth usage for a specified network interface
# public_ip # public IP address
# proxy # system-wide http/https/ftp proxy
# battery # internal battery
# wifi # wifi speed
# example # example user-defined segment (see prompt_example function below)
# Defines character set used by powerlevel10k. It's best to let `p10k configure` set it for you.
typeset -g POWERLEVEL9K_MODE=nerdfont-complete
# When set to `moderate`, some icons will have an extra space after them. This is meant to avoid
# icon overlap when using non-monospace fonts. When set to `none`, spaces are not added.
typeset -g POWERLEVEL9K_ICON_PADDING=none
# When set to true, icons appear before content on both sides of the prompt. When set
# to false, icons go after content. If empty or not set, icons go before content in the left
# prompt and after content in the right prompt.
# You can also override it for a specific segment:
# POWERLEVEL9K_STATUS_ICON_BEFORE_CONTENT=false
# Or for a specific segment in specific state:
# POWERLEVEL9K_DIR_NOT_WRITABLE_ICON_BEFORE_CONTENT=false
typeset -g POWERLEVEL9K_ICON_BEFORE_CONTENT=
# Add an empty line before each prompt.
typeset -g POWERLEVEL9K_PROMPT_ADD_NEWLINE=false
# Connect left prompt lines with these symbols. You'll probably want to use the same color
# as POWERLEVEL9K_MULTILINE_FIRST_PROMPT_GAP_FOREGROUND below.
typeset -g POWERLEVEL9K_MULTILINE_FIRST_PROMPT_PREFIX='%242F╭─'
typeset -g POWERLEVEL9K_MULTILINE_NEWLINE_PROMPT_PREFIX='%242F├─'
typeset -g POWERLEVEL9K_MULTILINE_LAST_PROMPT_PREFIX='%242F╰─'
# Connect right prompt lines with these symbols.
typeset -g POWERLEVEL9K_MULTILINE_FIRST_PROMPT_SUFFIX='%242F─╮'
typeset -g POWERLEVEL9K_MULTILINE_NEWLINE_PROMPT_SUFFIX='%242F─┤'
typeset -g POWERLEVEL9K_MULTILINE_LAST_PROMPT_SUFFIX='%242F─╯'
# Filler between left and right prompt on the first prompt line. You can set it to ' ', '·' or
# '─'. The last two make it easier to see the alignment between left and right prompt and to
# separate prompt from command output. You might want to set POWERLEVEL9K_PROMPT_ADD_NEWLINE=false
# for more compact prompt if using using this option.
typeset -g POWERLEVEL9K_MULTILINE_FIRST_PROMPT_GAP_CHAR=' '
typeset -g POWERLEVEL9K_MULTILINE_FIRST_PROMPT_GAP_BACKGROUND=
typeset -g POWERLEVEL9K_MULTILINE_NEWLINE_PROMPT_GAP_BACKGROUND=
if [[ $POWERLEVEL9K_MULTILINE_FIRST_PROMPT_GAP_CHAR != ' ' ]]; then
# The color of the filler. You'll probably want to match the color of POWERLEVEL9K_MULTILINE
# ornaments defined above.
typeset -g POWERLEVEL9K_MULTILINE_FIRST_PROMPT_GAP_FOREGROUND=242
# Start filler from the edge of the screen if there are no left segments on the first line.
typeset -g POWERLEVEL9K_EMPTY_LINE_LEFT_PROMPT_FIRST_SEGMENT_END_SYMBOL='%{%}'
# End filler on the edge of the screen if there are no right segments on the first line.
typeset -g POWERLEVEL9K_EMPTY_LINE_RIGHT_PROMPT_FIRST_SEGMENT_START_SYMBOL='%{%}'
fi
# Separator between same-color segments on the left.
typeset -g POWERLEVEL9K_LEFT_SUBSEGMENT_SEPARATOR='\uE0B1'
# Separator between same-color segments on the right.
typeset -g POWERLEVEL9K_RIGHT_SUBSEGMENT_SEPARATOR='\uE0B3'
# Separator between different-color segments on the left.
typeset -g POWERLEVEL9K_LEFT_SEGMENT_SEPARATOR='\uE0B0'
# Separator between different-color segments on the right.
typeset -g POWERLEVEL9K_RIGHT_SEGMENT_SEPARATOR='\uE0B2'
# The right end of left prompt.
typeset -g POWERLEVEL9K_LEFT_PROMPT_LAST_SEGMENT_END_SYMBOL='\uE0B0'
# The left end of right prompt.
typeset -g POWERLEVEL9K_RIGHT_PROMPT_FIRST_SEGMENT_START_SYMBOL='\uE0B2'
# The left end of left prompt.
typeset -g POWERLEVEL9K_LEFT_PROMPT_FIRST_SEGMENT_START_SYMBOL=''
# The right end of right prompt.
typeset -g POWERLEVEL9K_RIGHT_PROMPT_LAST_SEGMENT_END_SYMBOL=''
# Left prompt terminator for lines without any segments.
typeset -g POWERLEVEL9K_EMPTY_LINE_LEFT_PROMPT_LAST_SEGMENT_END_SYMBOL=
#################################[ os_icon: os identifier ]##################################
# OS identifier color.
typeset -g POWERLEVEL9K_OS_ICON_FOREGROUND=30
typeset -g POWERLEVEL9K_OS_ICON_BACKGROUND=7
# Custom icon.
# typeset -g POWERLEVEL9K_OS_ICON_CONTENT_EXPANSION='⭐'
################################[ prompt_char: prompt symbol ]################################
# Transparent background.
typeset -g POWERLEVEL9K_PROMPT_CHAR_BACKGROUND=
# Green prompt symbol if the last command succeeded.
typeset -g POWERLEVEL9K_PROMPT_CHAR_OK_{VIINS,VICMD,VIVIS,VIOWR}_FOREGROUND=76
# Red prompt symbol if the last command failed.
typeset -g POWERLEVEL9K_PROMPT_CHAR_ERROR_{VIINS,VICMD,VIVIS,VIOWR}_FOREGROUND=196
# Default prompt symbol.
typeset -g POWERLEVEL9K_PROMPT_CHAR_{OK,ERROR}_VIINS_CONTENT_EXPANSION='❯'
# Prompt symbol in command vi mode.
typeset -g POWERLEVEL9K_PROMPT_CHAR_{OK,ERROR}_VICMD_CONTENT_EXPANSION='❮'
# Prompt symbol in visual vi mode.
typeset -g POWERLEVEL9K_PROMPT_CHAR_{OK,ERROR}_VIVIS_CONTENT_EXPANSION='V'
# Prompt symbol in overwrite vi mode.
typeset -g POWERLEVEL9K_PROMPT_CHAR_{OK,ERROR}_VIOWR_CONTENT_EXPANSION='▶'
typeset -g POWERLEVEL9K_PROMPT_CHAR_OVERWRITE_STATE=true
# No line terminator if prompt_char is the last segment.
typeset -g POWERLEVEL9K_PROMPT_CHAR_LEFT_PROMPT_LAST_SEGMENT_END_SYMBOL=
# No line introducer if prompt_char is the first segment.
typeset -g POWERLEVEL9K_PROMPT_CHAR_LEFT_PROMPT_FIRST_SEGMENT_START_SYMBOL=
# No surrounding whitespace.
typeset -g POWERLEVEL9K_PROMPT_CHAR_LEFT_{LEFT,RIGHT}_WHITESPACE=
##################################[ dir: current directory ]##################################
# Current directory background color.
typeset -g POWERLEVEL9K_DIR_BACKGROUND=30
# Default current directory foreground color.
typeset -g POWERLEVEL9K_DIR_FOREGROUND=254
# If directory is too long, shorten some of its segments to the shortest possible unique
# prefix. The shortened directory can be tab-completed to the original.
typeset -g POWERLEVEL9K_SHORTEN_STRATEGY=truncate_to_unique
# Replace removed segment suffixes with this symbol.
typeset -g POWERLEVEL9K_SHORTEN_DELIMITER=
# Color of the shortened directory segments.
typeset -g POWERLEVEL9K_DIR_SHORTENED_FOREGROUND=250
# Color of the anchor directory segments. Anchor segments are never shortened. The first
# segment is always an anchor.
typeset -g POWERLEVEL9K_DIR_ANCHOR_FOREGROUND=255
# Display anchor directory segments in bold.
typeset -g POWERLEVEL9K_DIR_ANCHOR_BOLD=true
# Don't shorten directories that contain any of these files. They are anchors.
local anchor_files=(
.bzr
.citc
.git
.hg
.node-version
.python-version
.go-version
.ruby-version
.lua-version
.java-version
.perl-version
.php-version
.tool-version
.shorten_folder_marker
.svn
.terraform
CVS
Cargo.toml
composer.json
go.mod
package.json
stack.yaml
typeset -g POWERLEVEL9K_SHORTEN_FOLDER_MARKER="(${(j:|:)anchor_files})"
# If set to "first" ("last"), remove everything before the first (last) subdirectory that contains
# files matching $POWERLEVEL9K_SHORTEN_FOLDER_MARKER. For example, when the current directory is
# /foo/bar/git_repo/nested_git_repo/baz, prompt will display git_repo/nested_git_repo/baz (first)
# or nested_git_repo/baz (last). This assumes that git_repo and nested_git_repo contain markers
# and other directories don't.
# Optionally, "first" and "last" can be followed by ":<offset>" where <offset> is an integer.
# This moves the truncation point to the right (positive offset) or to the left (negative offset)
# relative to the marker. Plain "first" and "last" are equivalent to "first:0" and "last:0"
# respectively.
typeset -g POWERLEVEL9K_DIR_TRUNCATE_BEFORE_MARKER=false
# Don't shorten this many last directory segments. They are anchors.
typeset -g POWERLEVEL9K_SHORTEN_DIR_LENGTH=1
# Shorten directory if it's longer than this even if there is space for it. The value can
# be either absolute (e.g., '80') or a percentage of terminal width (e.g, '50%'). If empty,
# directory will be shortened only when prompt doesn't fit or when other parameters demand it
# (see POWERLEVEL9K_DIR_MIN_COMMAND_COLUMNS and POWERLEVEL9K_DIR_MIN_COMMAND_COLUMNS_PCT below).
# If set to `0`, directory will always be shortened to its minimum length.
typeset -g POWERLEVEL9K_DIR_MAX_LENGTH=80
# When `dir` segment is on the last prompt line, try to shorten it enough to leave at least this
# many columns for typing commands.
typeset -g POWERLEVEL9K_DIR_MIN_COMMAND_COLUMNS=40
# COLUMNS * POWERLEVEL9K_DIR_MIN_COMMAND_COLUMNS_PCT * 0.01 columns for typing commands.
typeset -g POWERLEVEL9K_DIR_MIN_COMMAND_COLUMNS_PCT=50
# If set to true, embed a hyperlink into the directory. Useful for quickly
# opening a directory in the file manager simply by clicking the link.
# Can also be handy when the directory is shortened, as it allows you to see
# the full directory that was used in previous commands.
typeset -g POWERLEVEL9K_DIR_HYPERLINK=false
# Enable special styling for non-writable and non-existent directories. See POWERLEVEL9K_LOCK_ICON
# and POWERLEVEL9K_DIR_CLASSES below.
typeset -g POWERLEVEL9K_DIR_SHOW_WRITABLE=v3
# The default icon shown next to non-writable and non-existent directories when
# POWERLEVEL9K_DIR_SHOW_WRITABLE is set to v3.
# typeset -g POWERLEVEL9K_LOCK_ICON='⭐'
# POWERLEVEL9K_DIR_CLASSES allows you to specify custom icons and colors for different
# directories. It must be an array with 3 * N elements. Each triplet consists of:
# 1. A pattern against which the current directory ($PWD) is matched. Matching is done with
# extended_glob option enabled.
# 2. Directory class for the purpose of styling.
# 3. An empty string.
# Triplets are tried in order. The first triplet whose pattern matches $PWD wins.
# If POWERLEVEL9K_DIR_SHOW_WRITABLE is set to v3, non-writable and non-existent directories
# acquire class suffix _NOT_WRITABLE and NON_EXISTENT respectively.
# For example, given these settings:
# typeset -g POWERLEVEL9K_DIR_CLASSES=(
# '~/work(|/*)' WORK ''
# '~(|/*)' HOME ''
# '*' DEFAULT '')
# Whenever the current directory is ~/work or a subdirectory of ~/work, it gets styled with one
# of the following classes depending on its writability and existence: WORK, WORK_NOT_WRITABLE or
# WORK_NON_EXISTENT.
# Simply assigning classes to directories doesn't have any visible effects. It merely gives you an
# option to define custom colors and icons for different directory classes.
# # Styling for WORK.
# typeset -g POWERLEVEL9K_DIR_WORK_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_DIR_WORK_BACKGROUND=4
# typeset -g POWERLEVEL9K_DIR_WORK_FOREGROUND=254
# typeset -g POWERLEVEL9K_DIR_WORK_SHORTENED_FOREGROUND=250
# typeset -g POWERLEVEL9K_DIR_WORK_ANCHOR_FOREGROUND=255
# # Styling for WORK_NOT_WRITABLE.
# typeset -g POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_BACKGROUND=4
# typeset -g POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_FOREGROUND=254
# typeset -g POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_SHORTENED_FOREGROUND=250
# typeset -g POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_ANCHOR_FOREGROUND=255
# # Styling for WORK_NON_EXISTENT.
# typeset -g POWERLEVEL9K_DIR_WORK_NON_EXISTENT_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_DIR_WORK_NON_EXISTENT_BACKGROUND=4
# typeset -g POWERLEVEL9K_DIR_WORK_NON_EXISTENT_FOREGROUND=254
# typeset -g POWERLEVEL9K_DIR_WORK_NON_EXISTENT_SHORTENED_FOREGROUND=250
# typeset -g POWERLEVEL9K_DIR_WORK_NON_EXISTENT_ANCHOR_FOREGROUND=255
# If a styling parameter isn't explicitly defined for some class, it falls back to the classless
# parameter. For example, if POWERLEVEL9K_DIR_WORK_NOT_WRITABLE_FOREGROUND is not set, it falls
# back to POWERLEVEL9K_DIR_FOREGROUND.
# typeset -g POWERLEVEL9K_DIR_CLASSES=()
# Custom prefix.
# typeset -g POWERLEVEL9K_DIR_PREFIX='in '
#####################################[ vcs: git status ]######################################
# Version control system colors.
typeset -g POWERLEVEL9K_VCS_CLEAN_BACKGROUND=2
typeset -g POWERLEVEL9K_VCS_MODIFIED_BACKGROUND=3
typeset -g POWERLEVEL9K_VCS_UNTRACKED_BACKGROUND=2
typeset -g POWERLEVEL9K_VCS_CONFLICTED_BACKGROUND=3
typeset -g POWERLEVEL9K_VCS_LOADING_BACKGROUND=8
# Branch icon. Set this parameter to '\uF126 ' for the popular Powerline branch icon.
typeset -g POWERLEVEL9K_VCS_BRANCH_ICON='\uF126 '
# Untracked files icon. It's really a question mark, your font isn't broken.
# Change the value of this parameter to show a different icon.
typeset -g POWERLEVEL9K_VCS_UNTRACKED_ICON='?'
# Formatter for Git status.
# Example output: master wip ⇣42⇡42 *42 merge ~42 +42 !42 ?42.
# You can edit the function to customize how Git status looks.
# VCS_STATUS_* parameters are set by gitstatus plugin. See reference:
# https://github.com/romkatv/gitstatus/blob/master/gitstatus.plugin.zsh.
function my_git_formatter() {
emulate -L zsh
if [[ -n $P9K_CONTENT ]]; then
# If P9K_CONTENT is not empty, use it. It's either "loading" or from vcs_info (not from
# gitstatus plugin). VCS_STATUS_* parameters are not available in this case.
typeset -g my_git_format=$P9K_CONTENT
return
fi
# Styling for different parts of Git status.
local meta='%7F' # white foreground
local clean='%0F' # black foreground
local modified='%0F' # black foreground
local untracked='%0F' # black foreground
local conflicted='%1F' # red foreground
local res
if [[ -n $VCS_STATUS_LOCAL_BRANCH ]]; then
local branch=${(V)VCS_STATUS_LOCAL_BRANCH}
# If local branch name is at most 32 characters long, show it in full.
# Otherwise show the first 12 … the last 12.
# Tip: To always show local branch name in full without truncation, delete the next line.
(( $#branch > 32 )) && branch[13,-13]="…" # <-- this line
res+="${clean}${(g::)POWERLEVEL9K_VCS_BRANCH_ICON}${branch//\%/%%}"
fi
if [[ -n $VCS_STATUS_TAG
# Show tag only if not on a branch.
# Tip: To always show tag, delete the next line.
&& -z $VCS_STATUS_LOCAL_BRANCH # <-- this line
]]; then
local tag=${(V)VCS_STATUS_TAG}
# If tag name is at most 32 characters long, show it in full.
# Tip: To always show tag name in full without truncation, delete the next line.
(( $#tag > 32 )) && tag[13,-13]="…" # <-- this line
res+="${meta}#${clean}${tag//\%/%%}"
fi
# Display the current Git commit if there is no branch and no tag.
# Tip: To always display the current Git commit, delete the next line.
[[ -z $VCS_STATUS_LOCAL_BRANCH && -z $VCS_STATUS_TAG ]] && # <-- this line
res+="${meta}@${clean}${VCS_STATUS_COMMIT[1,8]}"
# Show tracking branch name if it differs from local branch.
if [[ -n ${VCS_STATUS_REMOTE_BRANCH:#$VCS_STATUS_LOCAL_BRANCH} ]]; then
res+="${meta}:${clean}${(V)VCS_STATUS_REMOTE_BRANCH//\%/%%}"
fi
# Display "wip" if the latest commit's summary contains "wip" or "WIP".
if [[ $VCS_STATUS_COMMIT_SUMMARY == (|*[^[:alnum:]])(wip|WIP)(|[^[:alnum:]]*) ]]; then
res+=" ${modified}wip"
fi
# ⇣42 if behind the remote.
(( VCS_STATUS_COMMITS_BEHIND )) && res+=" ${clean}⇣${VCS_STATUS_COMMITS_BEHIND}"
# ⇡42 if ahead of the remote; no leading space if also behind the remote: ⇣42⇡42.
(( VCS_STATUS_COMMITS_AHEAD && !VCS_STATUS_COMMITS_BEHIND )) && res+=" "
(( VCS_STATUS_COMMITS_AHEAD )) && res+="${clean}⇡${VCS_STATUS_COMMITS_AHEAD}"
# ⇠42 if behind the push remote.
(( VCS_STATUS_PUSH_COMMITS_BEHIND )) && res+=" ${clean}⇠${VCS_STATUS_PUSH_COMMITS_BEHIND}"
(( VCS_STATUS_PUSH_COMMITS_AHEAD && !VCS_STATUS_PUSH_COMMITS_BEHIND )) && res+=" "
# ⇢42 if ahead of the push remote; no leading space if also behind: ⇠42⇢42.
(( VCS_STATUS_PUSH_COMMITS_AHEAD )) && res+="${clean}⇢${VCS_STATUS_PUSH_COMMITS_AHEAD}"
# *42 if have stashes.
(( VCS_STATUS_STASHES )) && res+=" ${clean}*${VCS_STATUS_STASHES}"
# 'merge' if the repo is in an unusual state.
[[ -n $VCS_STATUS_ACTION ]] && res+=" ${conflicted}${VCS_STATUS_ACTION}"
# ~42 if have merge conflicts.
(( VCS_STATUS_NUM_CONFLICTED )) && res+=" ${conflicted}~${VCS_STATUS_NUM_CONFLICTED}"
# +42 if have staged changes.
(( VCS_STATUS_NUM_STAGED )) && res+=" ${modified}+${VCS_STATUS_NUM_STAGED}"
# !42 if have unstaged changes.
(( VCS_STATUS_NUM_UNSTAGED )) && res+=" ${modified}!${VCS_STATUS_NUM_UNSTAGED}"
# ?42 if have untracked files. It's really a question mark, your font isn't broken.
# See POWERLEVEL9K_VCS_UNTRACKED_ICON above if you want to use a different icon.
# Remove the next line if you don't want to see untracked files at all.
(( VCS_STATUS_NUM_UNTRACKED )) && res+=" ${untracked}${(g::)POWERLEVEL9K_VCS_UNTRACKED_ICON}${VCS_STATUS_NUM_UNTRACKED}"
# "─" if the number of unstaged files is unknown. This can happen due to
# POWERLEVEL9K_VCS_MAX_INDEX_SIZE_DIRTY (see below) being set to a non-negative number lower
# than the number of files in the Git index, or due to bash.showDirtyState being set to false
# in the repository config. The number of staged and untracked files may also be unknown
# in this case.
(( VCS_STATUS_HAS_UNSTAGED == -1 )) && res+=" ${modified}─"
typeset -g my_git_format=$res
functions -M my_git_formatter 2>/dev/null
# Don't count the number of unstaged, untracked and conflicted files in Git repositories with
# more than this many files in the index. Negative value means infinity.
# If you are working in Git repositories with tens of millions of files and seeing performance
# sagging, try setting POWERLEVEL9K_VCS_MAX_INDEX_SIZE_DIRTY to a number lower than the output
# of `git ls-files | wc -l`. Alternatively, add `bash.showDirtyState = false` to the repository's
# config: `git config bash.showDirtyState false`.
typeset -g POWERLEVEL9K_VCS_MAX_INDEX_SIZE_DIRTY=-1
# Don't show Git status in prompt for repositories whose workdir matches this pattern.
# For example, if set to '~', the Git repository at $HOME/.git will be ignored.
# Multiple patterns can be combined with '|': '~(|/foo)|/bar/baz/*'.
typeset -g POWERLEVEL9K_VCS_DISABLED_WORKDIR_PATTERN='~'
# Disable the default Git status formatting.
typeset -g POWERLEVEL9K_VCS_DISABLE_GITSTATUS_FORMATTING=true
# Install our own Git status formatter.
typeset -g POWERLEVEL9K_VCS_CONTENT_EXPANSION='${$((my_git_formatter()))+${my_git_format}}'
# Enable counters for staged, unstaged, etc.
typeset -g POWERLEVEL9K_VCS_{STAGED,UNSTAGED,UNTRACKED,CONFLICTED,COMMITS_AHEAD,COMMITS_BEHIND}_MAX_NUM=-1
# Custom icon.
# typeset -g POWERLEVEL9K_VCS_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Custom prefix.
# typeset -g POWERLEVEL9K_VCS_PREFIX='on '
# Show status of repositories of these types. You can add svn and/or hg if you are
# using them. If you do, your prompt may become slow even when your current directory
# isn't in an svn or hg reposotiry.
typeset -g POWERLEVEL9K_VCS_BACKENDS=(git)
##########################[ status: exit code of the last command ]###########################
# Enable OK_PIPE, ERROR_PIPE and ERROR_SIGNAL status states to allow us to enable, disable and
# style them independently from the regular OK and ERROR state.
typeset -g POWERLEVEL9K_STATUS_EXTENDED_STATES=true
# Status on success. No content, just an icon. No need to show it if prompt_char is enabled as
# it will signify success by turning green.
typeset -g POWERLEVEL9K_STATUS_OK=true
typeset -g POWERLEVEL9K_STATUS_OK_VISUAL_IDENTIFIER_EXPANSION='✔'
typeset -g POWERLEVEL9K_STATUS_OK_FOREGROUND=2
typeset -g POWERLEVEL9K_STATUS_OK_BACKGROUND=0
# Status when some part of a pipe command fails but the overall exit status is zero. It may look
# like this: 1|0.
typeset -g POWERLEVEL9K_STATUS_OK_PIPE=true
typeset -g POWERLEVEL9K_STATUS_OK_PIPE_VISUAL_IDENTIFIER_EXPANSION='✔'
typeset -g POWERLEVEL9K_STATUS_OK_PIPE_FOREGROUND=2
typeset -g POWERLEVEL9K_STATUS_OK_PIPE_BACKGROUND=0
# Status when it's just an error code (e.g., '1'). No need to show it if prompt_char is enabled as
# it will signify error by turning red.
typeset -g POWERLEVEL9K_STATUS_ERROR=true
typeset -g POWERLEVEL9K_STATUS_ERROR_VISUAL_IDENTIFIER_EXPANSION='✘'
typeset -g POWERLEVEL9K_STATUS_ERROR_FOREGROUND=3
typeset -g POWERLEVEL9K_STATUS_ERROR_BACKGROUND=1
# Status when the last command was terminated by a signal.
typeset -g POWERLEVEL9K_STATUS_ERROR_SIGNAL=true
# Use terse signal names: "INT" instead of "SIGINT(2)".
typeset -g POWERLEVEL9K_STATUS_VERBOSE_SIGNAME=false
typeset -g POWERLEVEL9K_STATUS_ERROR_SIGNAL_VISUAL_IDENTIFIER_EXPANSION='✘'
typeset -g POWERLEVEL9K_STATUS_ERROR_SIGNAL_FOREGROUND=3
typeset -g POWERLEVEL9K_STATUS_ERROR_SIGNAL_BACKGROUND=1
# Status when some part of a pipe command fails and the overall exit status is also non-zero.
# It may look like this: 1|0.
typeset -g POWERLEVEL9K_STATUS_ERROR_PIPE=true
typeset -g POWERLEVEL9K_STATUS_ERROR_PIPE_VISUAL_IDENTIFIER_EXPANSION='✘'
typeset -g POWERLEVEL9K_STATUS_ERROR_PIPE_FOREGROUND=3
typeset -g POWERLEVEL9K_STATUS_ERROR_PIPE_BACKGROUND=1
###################[ command_execution_time: duration of the last command ]###################
# Execution time color.
typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_FOREGROUND=0
typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_BACKGROUND=3
# Show duration of the last command if takes at least this many seconds.
typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_THRESHOLD=3
# Show this many fractional digits. Zero means round to seconds.
typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_PRECISION=0
# Duration format: 1d 2h 3m 4s.
typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_FORMAT='d h m s'
# Custom icon.
# typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Custom prefix.
# typeset -g POWERLEVEL9K_COMMAND_EXECUTION_TIME_PREFIX='took '
#######################[ background_jobs: presence of background jobs ]#######################
# Background jobs color.
typeset -g POWERLEVEL9K_BACKGROUND_JOBS_FOREGROUND=6
typeset -g POWERLEVEL9K_BACKGROUND_JOBS_BACKGROUND=0
# Don't show the number of background jobs.
typeset -g POWERLEVEL9K_BACKGROUND_JOBS_VERBOSE=false
# Custom icon.
# typeset -g POWERLEVEL9K_BACKGROUND_JOBS_VISUAL_IDENTIFIER_EXPANSION='⭐'
#######################[ direnv: direnv status (https://direnv.net/) ]########################
# Direnv color.
typeset -g POWERLEVEL9K_DIRENV_FOREGROUND=3
typeset -g POWERLEVEL9K_DIRENV_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_DIRENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
###############[ asdf: asdf version manager (https://github.com/asdf-vm/asdf) ]###############
# Default asdf color. Only used to display tools for which there is no color override (see below).
# Tip: Override these parameters for ${TOOL} with POWERLEVEL9K_ASDF_${TOOL}_FOREGROUND and
# POWERLEVEL9K_ASDF_${TOOL}_BACKGROUND.
typeset -g POWERLEVEL9K_ASDF_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_BACKGROUND=7
# There are four parameters that can be used to hide asdf tools. Each parameter describes
# conditions under which a tool gets hidden. Parameters can hide tools but not unhide them. If at
# least one parameter decides to hide a tool, that tool gets hidden. If no parameter decides to
# hide a tool, it gets shown.
# Special note on the difference between POWERLEVEL9K_ASDF_SOURCES and
# POWERLEVEL9K_ASDF_PROMPT_ALWAYS_SHOW. Consider the effect of the following commands:
# asdf local python 3.8.1
# asdf global python 3.8.1
# After running both commands the current python version is 3.8.1 and its source is "local" as
# it takes precedence over "global". If POWERLEVEL9K_ASDF_PROMPT_ALWAYS_SHOW is set to false,
# it'll hide python version in this case because 3.8.1 is the same as the global version.
# POWERLEVEL9K_ASDF_SOURCES will hide python version only if the value of this parameter doesn't
# contain "local".
# Hide tool versions that don't come from one of these sources.
# Available sources:
# - shell `asdf current` says "set by ASDF_${TOOL}_VERSION environment variable"
# - local `asdf current` says "set by /some/not/home/directory/file"
# - global `asdf current` says "set by /home/username/file"
# Note: If this parameter is set to (shell local global), it won't hide tools.
# Tip: Override this parameter for ${TOOL} with POWERLEVEL9K_ASDF_${TOOL}_SOURCES.
typeset -g POWERLEVEL9K_ASDF_SOURCES=(shell local global)
# If set to false, hide tool versions that are the same as global.
# Note: The name of this parameter doesn't reflect its meaning at all.
# Note: If this parameter is set to true, it won't hide tools.
# Tip: Override this parameter for ${TOOL} with POWERLEVEL9K_ASDF_${TOOL}_PROMPT_ALWAYS_SHOW.
typeset -g POWERLEVEL9K_ASDF_PROMPT_ALWAYS_SHOW=false
# If set to false, hide tool versions that are equal to "system".
# Tip: Override this parameter for ${TOOL} with POWERLEVEL9K_ASDF_${TOOL}_SHOW_SYSTEM.
typeset -g POWERLEVEL9K_ASDF_SHOW_SYSTEM=true
# If set to non-empty value, hide tools unless there is a file matching the specified file pattern
# in the current directory, or its parent directory, or its grandparent directory, and so on.
# Note: If this parameter is set to empty value, it won't hide tools.
# Note: SHOW_ON_UPGLOB isn't specific to asdf. It works with all prompt segments.
# Tip: Override this parameter for ${TOOL} with POWERLEVEL9K_ASDF_${TOOL}_SHOW_ON_UPGLOB.
# Example: Hide nodejs version when there is no package.json and no *.js files in the current
# directory, in `..`, in `../..` and so on.
# typeset -g POWERLEVEL9K_ASDF_NODEJS_SHOW_ON_UPGLOB='*.js|package.json'
typeset -g POWERLEVEL9K_ASDF_SHOW_ON_UPGLOB=
# Ruby version from asdf.
typeset -g POWERLEVEL9K_ASDF_RUBY_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_RUBY_BACKGROUND=1
# typeset -g POWERLEVEL9K_ASDF_RUBY_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_RUBY_SHOW_ON_UPGLOB='*.foo|*.bar'
# Python version from asdf.
typeset -g POWERLEVEL9K_ASDF_PYTHON_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_PYTHON_BACKGROUND=4
# typeset -g POWERLEVEL9K_ASDF_PYTHON_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_PYTHON_SHOW_ON_UPGLOB='*.foo|*.bar'
# Go version from asdf.
typeset -g POWERLEVEL9K_ASDF_GOLANG_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_GOLANG_BACKGROUND=4
# typeset -g POWERLEVEL9K_ASDF_GOLANG_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_GOLANG_SHOW_ON_UPGLOB='*.foo|*.bar'
# Node.js version from asdf.
typeset -g POWERLEVEL9K_ASDF_NODEJS_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_NODEJS_BACKGROUND=2
# typeset -g POWERLEVEL9K_ASDF_NODEJS_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_NODEJS_SHOW_ON_UPGLOB='*.foo|*.bar'
# Rust version from asdf.
typeset -g POWERLEVEL9K_ASDF_RUST_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_RUST_BACKGROUND=208
# typeset -g POWERLEVEL9K_ASDF_RUST_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_RUST_SHOW_ON_UPGLOB='*.foo|*.bar'
# .NET Core version from asdf.
typeset -g POWERLEVEL9K_ASDF_DOTNET_CORE_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_DOTNET_CORE_BACKGROUND=5
# typeset -g POWERLEVEL9K_ASDF_DOTNET_CORE_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_DOTNET_CORE_SHOW_ON_UPGLOB='*.foo|*.bar'
# Flutter version from asdf.
typeset -g POWERLEVEL9K_ASDF_FLUTTER_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_FLUTTER_BACKGROUND=4
# typeset -g POWERLEVEL9K_ASDF_FLUTTER_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_FLUTTER_SHOW_ON_UPGLOB='*.foo|*.bar'
# Lua version from asdf.
typeset -g POWERLEVEL9K_ASDF_LUA_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_LUA_BACKGROUND=4
# typeset -g POWERLEVEL9K_ASDF_LUA_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_LUA_SHOW_ON_UPGLOB='*.foo|*.bar'
# Java version from asdf.
typeset -g POWERLEVEL9K_ASDF_JAVA_FOREGROUND=1
typeset -g POWERLEVEL9K_ASDF_JAVA_BACKGROUND=7
# typeset -g POWERLEVEL9K_ASDF_JAVA_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_JAVA_SHOW_ON_UPGLOB='*.foo|*.bar'
# Perl version from asdf.
typeset -g POWERLEVEL9K_ASDF_PERL_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_PERL_BACKGROUND=4
# typeset -g POWERLEVEL9K_ASDF_PERL_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_PERL_SHOW_ON_UPGLOB='*.foo|*.bar'
# Erlang version from asdf.
typeset -g POWERLEVEL9K_ASDF_ERLANG_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_ERLANG_BACKGROUND=1
# typeset -g POWERLEVEL9K_ASDF_ERLANG_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_ERLANG_SHOW_ON_UPGLOB='*.foo|*.bar'
# Elixir version from asdf.
typeset -g POWERLEVEL9K_ASDF_ELIXIR_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_ELIXIR_BACKGROUND=5
# typeset -g POWERLEVEL9K_ASDF_ELIXIR_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_ELIXIR_SHOW_ON_UPGLOB='*.foo|*.bar'
# Postgres version from asdf.
typeset -g POWERLEVEL9K_ASDF_POSTGRES_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_POSTGRES_BACKGROUND=6
# typeset -g POWERLEVEL9K_ASDF_POSTGRES_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_POSTGRES_SHOW_ON_UPGLOB='*.foo|*.bar'
# PHP version from asdf.
typeset -g POWERLEVEL9K_ASDF_PHP_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_PHP_BACKGROUND=5
# typeset -g POWERLEVEL9K_ASDF_PHP_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_PHP_SHOW_ON_UPGLOB='*.foo|*.bar'
# Haskell version from asdf.
typeset -g POWERLEVEL9K_ASDF_HASKELL_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_HASKELL_BACKGROUND=3
# typeset -g POWERLEVEL9K_ASDF_HASKELL_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_HASKELL_SHOW_ON_UPGLOB='*.foo|*.bar'
# Julia version from asdf.
typeset -g POWERLEVEL9K_ASDF_JULIA_FOREGROUND=0
typeset -g POWERLEVEL9K_ASDF_JULIA_BACKGROUND=2
# typeset -g POWERLEVEL9K_ASDF_JULIA_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_ASDF_JULIA_SHOW_ON_UPGLOB='*.foo|*.bar'
##########[ nordvpn: nordvpn connection status, linux only (https://nordvpn.com/) ]###########
# NordVPN connection indicator color.
typeset -g POWERLEVEL9K_NORDVPN_FOREGROUND=7
typeset -g POWERLEVEL9K_NORDVPN_BACKGROUND=4
# Hide NordVPN connection indicator when not connected.
typeset -g POWERLEVEL9K_NORDVPN_{DISCONNECTED,CONNECTING,DISCONNECTING}_CONTENT_EXPANSION=
typeset -g POWERLEVEL9K_NORDVPN_{DISCONNECTED,CONNECTING,DISCONNECTING}_VISUAL_IDENTIFIER_EXPANSION=
# Custom icon.
# typeset -g POWERLEVEL9K_NORDVPN_VISUAL_IDENTIFIER_EXPANSION='⭐'
#################[ ranger: ranger shell (https://github.com/ranger/ranger) ]##################
# Ranger shell color.
typeset -g POWERLEVEL9K_RANGER_FOREGROUND=3
typeset -g POWERLEVEL9K_RANGER_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_RANGER_VISUAL_IDENTIFIER_EXPANSION='⭐'
######################[ nnn: nnn shell (https://github.com/jarun/nnn) ]#######################
# Nnn shell color.
typeset -g POWERLEVEL9K_NNN_FOREGROUND=0
typeset -g POWERLEVEL9K_NNN_BACKGROUND=6
# Custom icon.
# typeset -g POWERLEVEL9K_NNN_VISUAL_IDENTIFIER_EXPANSION='⭐'
##################[ xplr: xplr shell (https://github.com/sayanarijit/xplr) ]##################
# xplr shell color.
typeset -g POWERLEVEL9K_XPLR_FOREGROUND=0
typeset -g POWERLEVEL9K_XPLR_BACKGROUND=6
# Custom icon.
# typeset -g POWERLEVEL9K_XPLR_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########################[ vim_shell: vim shell indicator (:sh) ]###########################
# Vim shell indicator color.
typeset -g POWERLEVEL9K_VIM_SHELL_FOREGROUND=0
typeset -g POWERLEVEL9K_VIM_SHELL_BACKGROUND=2
# Custom icon.
# typeset -g POWERLEVEL9K_VIM_SHELL_VISUAL_IDENTIFIER_EXPANSION='⭐'
######[ midnight_commander: midnight commander shell (https://midnight-commander.org/) ]######
# Midnight Commander shell color.
typeset -g POWERLEVEL9K_MIDNIGHT_COMMANDER_FOREGROUND=3
typeset -g POWERLEVEL9K_MIDNIGHT_COMMANDER_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_MIDNIGHT_COMMANDER_VISUAL_IDENTIFIER_EXPANSION='⭐'
#[ nix_shell: nix shell (https://nixos.org/nixos/nix-pills/developing-with-nix-shell.html) ]##
# Nix shell color.
typeset -g POWERLEVEL9K_NIX_SHELL_FOREGROUND=0
typeset -g POWERLEVEL9K_NIX_SHELL_BACKGROUND=4
# Tip: If you want to see just the icon without "pure" and "impure", uncomment the next line.
# typeset -g POWERLEVEL9K_NIX_SHELL_CONTENT_EXPANSION=
# Custom icon.
# typeset -g POWERLEVEL9K_NIX_SHELL_VISUAL_IDENTIFIER_EXPANSION='⭐'
##################################[ disk_usage: disk usage ]##################################
# Colors for different levels of disk usage.
typeset -g POWERLEVEL9K_DISK_USAGE_NORMAL_FOREGROUND=3
typeset -g POWERLEVEL9K_DISK_USAGE_NORMAL_BACKGROUND=0
typeset -g POWERLEVEL9K_DISK_USAGE_WARNING_FOREGROUND=0
typeset -g POWERLEVEL9K_DISK_USAGE_WARNING_BACKGROUND=3
typeset -g POWERLEVEL9K_DISK_USAGE_CRITICAL_FOREGROUND=7
typeset -g POWERLEVEL9K_DISK_USAGE_CRITICAL_BACKGROUND=1
# Thresholds for different levels of disk usage (percentage points).
typeset -g POWERLEVEL9K_DISK_USAGE_WARNING_LEVEL=90
typeset -g POWERLEVEL9K_DISK_USAGE_CRITICAL_LEVEL=95
# If set to true, hide disk usage when below $POWERLEVEL9K_DISK_USAGE_WARNING_LEVEL percent.
typeset -g POWERLEVEL9K_DISK_USAGE_ONLY_WARNING=false
# Custom icon.
# typeset -g POWERLEVEL9K_DISK_USAGE_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########[ vi_mode: vi mode (you don't need this if you've enabled prompt_char) ]###########
# Foreground color.
typeset -g POWERLEVEL9K_VI_MODE_FOREGROUND=0
# Text and color for normal (a.k.a. command) vi mode.
typeset -g POWERLEVEL9K_VI_COMMAND_MODE_STRING=NORMAL
typeset -g POWERLEVEL9K_VI_MODE_NORMAL_BACKGROUND=2
# Text and color for visual vi mode.
typeset -g POWERLEVEL9K_VI_VISUAL_MODE_STRING=VISUAL
typeset -g POWERLEVEL9K_VI_MODE_VISUAL_BACKGROUND=4
# Text and color for overtype (a.k.a. overwrite and replace) vi mode.
typeset -g POWERLEVEL9K_VI_OVERWRITE_MODE_STRING=OVERTYPE
typeset -g POWERLEVEL9K_VI_MODE_OVERWRITE_BACKGROUND=3
# Text and color for insert vi mode.
typeset -g POWERLEVEL9K_VI_INSERT_MODE_STRING=
typeset -g POWERLEVEL9K_VI_MODE_INSERT_FOREGROUND=8
######################################[ ram: free RAM ]#######################################
# RAM color.
typeset -g POWERLEVEL9K_RAM_FOREGROUND=0
typeset -g POWERLEVEL9K_RAM_BACKGROUND=3
# Custom icon.
# typeset -g POWERLEVEL9K_RAM_VISUAL_IDENTIFIER_EXPANSION='⭐'
#####################################[ swap: used swap ]######################################
# Swap color.
typeset -g POWERLEVEL9K_SWAP_FOREGROUND=0
typeset -g POWERLEVEL9K_SWAP_BACKGROUND=3
# Custom icon.
# typeset -g POWERLEVEL9K_SWAP_VISUAL_IDENTIFIER_EXPANSION='⭐'
######################################[ load: CPU load ]######################################
# Show average CPU load over this many last minutes. Valid values are 1, 5 and 15.
typeset -g POWERLEVEL9K_LOAD_WHICH=5
# Load color when load is under 50%.
typeset -g POWERLEVEL9K_LOAD_NORMAL_FOREGROUND=0
typeset -g POWERLEVEL9K_LOAD_NORMAL_BACKGROUND=2
# Load color when load is between 50% and 70%.
typeset -g POWERLEVEL9K_LOAD_WARNING_FOREGROUND=0
typeset -g POWERLEVEL9K_LOAD_WARNING_BACKGROUND=3
# Load color when load is over 70%.
typeset -g POWERLEVEL9K_LOAD_CRITICAL_FOREGROUND=0
typeset -g POWERLEVEL9K_LOAD_CRITICAL_BACKGROUND=1
# Custom icon.
# typeset -g POWERLEVEL9K_LOAD_VISUAL_IDENTIFIER_EXPANSION='⭐'
################[ todo: todo items (https://github.com/todotxt/todo.txt-cli) ]################
# Todo color.
typeset -g POWERLEVEL9K_TODO_FOREGROUND=0
typeset -g POWERLEVEL9K_TODO_BACKGROUND=8
# Hide todo when the total number of tasks is zero.
typeset -g POWERLEVEL9K_TODO_HIDE_ZERO_TOTAL=true
# Hide todo when the number of tasks after filtering is zero.
typeset -g POWERLEVEL9K_TODO_HIDE_ZERO_FILTERED=false
# Todo format. The following parameters are available within the expansion.
# - P9K_TODO_TOTAL_TASK_COUNT The total number of tasks.
# - P9K_TODO_FILTERED_TASK_COUNT The number of tasks after filtering.
# These variables correspond to the last line of the output of `todo.sh -p ls`:
# TODO: 24 of 42 tasks shown
# Here 24 is P9K_TODO_FILTERED_TASK_COUNT and 42 is P9K_TODO_TOTAL_TASK_COUNT.
# typeset -g POWERLEVEL9K_TODO_CONTENT_EXPANSION='$P9K_TODO_FILTERED_TASK_COUNT'
# Custom icon.
# typeset -g POWERLEVEL9K_TODO_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########[ timewarrior: timewarrior tracking status (https://timewarrior.net/) ]############
# Timewarrior color.
typeset -g POWERLEVEL9K_TIMEWARRIOR_FOREGROUND=255
typeset -g POWERLEVEL9K_TIMEWARRIOR_BACKGROUND=8
# If the tracked task is longer than 24 characters, truncate and append "…".
# Tip: To always display tasks without truncation, delete the following parameter.
# Tip: To hide task names and display just the icon when time tracking is enabled, set the
# value of the following parameter to "".
typeset -g POWERLEVEL9K_TIMEWARRIOR_CONTENT_EXPANSION='${P9K_CONTENT:0:24}${${P9K_CONTENT:24}:+…}'
# Custom icon.
# typeset -g POWERLEVEL9K_TIMEWARRIOR_VISUAL_IDENTIFIER_EXPANSION='⭐'
##############[ taskwarrior: taskwarrior task count (https://taskwarrior.org/) ]##############
# Taskwarrior color.
typeset -g POWERLEVEL9K_TASKWARRIOR_FOREGROUND=0
typeset -g POWERLEVEL9K_TASKWARRIOR_BACKGROUND=6
# Taskwarrior segment format. The following parameters are available within the expansion.
# - P9K_TASKWARRIOR_PENDING_COUNT The number of pending tasks: `task +PENDING count`.
# - P9K_TASKWARRIOR_OVERDUE_COUNT The number of overdue tasks: `task +OVERDUE count`.
# Zero values are represented as empty parameters.
# The default format:
# '${P9K_TASKWARRIOR_OVERDUE_COUNT:+"!$P9K_TASKWARRIOR_OVERDUE_COUNT/"}$P9K_TASKWARRIOR_PENDING_COUNT'
# typeset -g POWERLEVEL9K_TASKWARRIOR_CONTENT_EXPANSION='$P9K_TASKWARRIOR_PENDING_COUNT'
# Custom icon.
# typeset -g POWERLEVEL9K_TASKWARRIOR_VISUAL_IDENTIFIER_EXPANSION='⭐'
##################################[ context: user@hostname ]##################################
# Context color when running with privileges.
typeset -g POWERLEVEL9K_CONTEXT_ROOT_FOREGROUND=1
typeset -g POWERLEVEL9K_CONTEXT_ROOT_BACKGROUND=0
# Context color in SSH without privileges.
typeset -g POWERLEVEL9K_CONTEXT_{REMOTE,REMOTE_SUDO}_FOREGROUND=3
typeset -g POWERLEVEL9K_CONTEXT_{REMOTE,REMOTE_SUDO}_BACKGROUND=0
# Default context color (no privileges, no SSH).
typeset -g POWERLEVEL9K_CONTEXT_FOREGROUND=3
typeset -g POWERLEVEL9K_CONTEXT_BACKGROUND=0
# Context format when running with privileges: user@hostname.
typeset -g POWERLEVEL9K_CONTEXT_ROOT_TEMPLATE='%n@%m'
# Context format when in SSH without privileges: user@hostname.
typeset -g POWERLEVEL9K_CONTEXT_{REMOTE,REMOTE_SUDO}_TEMPLATE='%n@%m'
# Default context format (no privileges, no SSH): user@hostname.
typeset -g POWERLEVEL9K_CONTEXT_TEMPLATE='%n@%m'
# Don't show context unless running with privileges or in SSH.
# Tip: Remove the next line to always show context.
typeset -g POWERLEVEL9K_CONTEXT_{DEFAULT,SUDO}_{CONTENT,VISUAL_IDENTIFIER}_EXPANSION=
# Custom icon.
# typeset -g POWERLEVEL9K_CONTEXT_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Custom prefix.
# typeset -g POWERLEVEL9K_CONTEXT_PREFIX='with '
###[ virtualenv: python virtual environment (https://docs.python.org/3/library/venv.html) ]###
# Python virtual environment color.
typeset -g POWERLEVEL9K_VIRTUALENV_FOREGROUND=0
typeset -g POWERLEVEL9K_VIRTUALENV_BACKGROUND=4
# Don't show Python version next to the virtual environment name.
typeset -g POWERLEVEL9K_VIRTUALENV_SHOW_PYTHON_VERSION=false
# If set to "false", won't show virtualenv if pyenv is already shown.
# If set to "if-different", won't show virtualenv if it's the same as pyenv.
typeset -g POWERLEVEL9K_VIRTUALENV_SHOW_WITH_PYENV=false
# Separate environment name from Python version only with a space.
typeset -g POWERLEVEL9K_VIRTUALENV_{LEFT,RIGHT}_DELIMITER=
# Custom icon.
# typeset -g POWERLEVEL9K_VIRTUALENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
#####################[ anaconda: conda environment (https://conda.io/) ]######################
# Anaconda environment color.
typeset -g POWERLEVEL9K_ANACONDA_FOREGROUND=0
typeset -g POWERLEVEL9K_ANACONDA_BACKGROUND=4
# Anaconda segment format. The following parameters are available within the expansion.
# - CONDA_PREFIX Absolute path to the active Anaconda/Miniconda environment.
# - CONDA_DEFAULT_ENV Name of the active Anaconda/Miniconda environment.
# - CONDA_PROMPT_MODIFIER Configurable prompt modifier (see below).
# - P9K_ANACONDA_PYTHON_VERSION Current python version (python --version).
# CONDA_PROMPT_MODIFIER can be configured with the following command:
# conda config --set env_prompt '({default_env}) '
# The last argument is a Python format string that can use the following variables:
# - prefix The same as CONDA_PREFIX.
# - default_env The same as CONDA_DEFAULT_ENV.
# - name The last segment of CONDA_PREFIX.
# - stacked_env Comma-separated list of names in the environment stack. The first element is
# always the same as default_env.
# Note: '({default_env}) ' is the default value of env_prompt.
# The default value of POWERLEVEL9K_ANACONDA_CONTENT_EXPANSION expands to $CONDA_PROMPT_MODIFIER
# without the surrounding parentheses, or to the last path component of CONDA_PREFIX if the former
# is empty.
typeset -g POWERLEVEL9K_ANACONDA_CONTENT_EXPANSION='${${${${CONDA_PROMPT_MODIFIER#\(}% }%\)}:-${CONDA_PREFIX:t}}'
# Custom icon.
# typeset -g POWERLEVEL9K_ANACONDA_VISUAL_IDENTIFIER_EXPANSION='⭐'
################[ pyenv: python environment (https://github.com/pyenv/pyenv) ]################
# Pyenv color.
typeset -g POWERLEVEL9K_PYENV_FOREGROUND=0
typeset -g POWERLEVEL9K_PYENV_BACKGROUND=4
# Hide python version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_PYENV_SOURCES=(shell local global)
# If set to false, hide python version if it's the same as global:
# $(pyenv version-name) == $(pyenv global).
typeset -g POWERLEVEL9K_PYENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide python version if it's equal to "system".
typeset -g POWERLEVEL9K_PYENV_SHOW_SYSTEM=true
# Pyenv segment format. The following parameters are available within the expansion.
# - P9K_CONTENT Current pyenv environment (pyenv version-name).
# - P9K_PYENV_PYTHON_VERSION Current python version (python --version).
# The default format has the following logic:
# 1. Display just "$P9K_CONTENT" if it's equal to "$P9K_PYENV_PYTHON_VERSION" or
# starts with "$P9K_PYENV_PYTHON_VERSION/".
# 2. Otherwise display "$P9K_CONTENT $P9K_PYENV_PYTHON_VERSION".
typeset -g POWERLEVEL9K_PYENV_CONTENT_EXPANSION='${P9K_CONTENT}${${P9K_CONTENT:#$P9K_PYENV_PYTHON_VERSION(|/*)}:+ $P9K_PYENV_PYTHON_VERSION}'
# Custom icon.
# typeset -g POWERLEVEL9K_PYENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
################[ goenv: go environment (https://github.com/syndbg/goenv) ]################
# Goenv color.
typeset -g POWERLEVEL9K_GOENV_FOREGROUND=0
typeset -g POWERLEVEL9K_GOENV_BACKGROUND=4
# Hide go version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_GOENV_SOURCES=(shell local global)
# If set to false, hide go version if it's the same as global:
# $(goenv version-name) == $(goenv global).
typeset -g POWERLEVEL9K_GOENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide go version if it's equal to "system".
typeset -g POWERLEVEL9K_GOENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_GOENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ nodenv: node.js version from nodenv (https://github.com/nodenv/nodenv) ]##########
# Nodenv color.
typeset -g POWERLEVEL9K_NODENV_FOREGROUND=2
typeset -g POWERLEVEL9K_NODENV_BACKGROUND=0
# Hide node version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_NODENV_SOURCES=(shell local global)
# If set to false, hide node version if it's the same as global:
# $(nodenv version-name) == $(nodenv global).
typeset -g POWERLEVEL9K_NODENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide node version if it's equal to "system".
typeset -g POWERLEVEL9K_NODENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_NODENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
##############[ nvm: node.js version from nvm (https://github.com/nvm-sh/nvm) ]###############
# Nvm color.
typeset -g POWERLEVEL9K_NVM_FOREGROUND=0
typeset -g POWERLEVEL9K_NVM_BACKGROUND=5
# Custom icon.
# typeset -g POWERLEVEL9K_NVM_VISUAL_IDENTIFIER_EXPANSION='⭐'
############[ nodeenv: node.js environment (https://github.com/ekalinin/nodeenv) ]############
# Nodeenv color.
typeset -g POWERLEVEL9K_NODEENV_FOREGROUND=2
typeset -g POWERLEVEL9K_NODEENV_BACKGROUND=0
# Don't show Node version next to the environment name.
typeset -g POWERLEVEL9K_NODEENV_SHOW_NODE_VERSION=false
# Separate environment name from Node version only with a space.
typeset -g POWERLEVEL9K_NODEENV_{LEFT,RIGHT}_DELIMITER=
# Custom icon.
# typeset -g POWERLEVEL9K_NODEENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
##############################[ node_version: node.js version ]###############################
# Node version color.
typeset -g POWERLEVEL9K_NODE_VERSION_FOREGROUND=7
typeset -g POWERLEVEL9K_NODE_VERSION_BACKGROUND=2
# Show node version only when in a directory tree containing package.json.
typeset -g POWERLEVEL9K_NODE_VERSION_PROJECT_ONLY=true
# Custom icon.
# typeset -g POWERLEVEL9K_NODE_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
#######################[ go_version: go version (https://golang.org) ]########################
# Go version color.
typeset -g POWERLEVEL9K_GO_VERSION_FOREGROUND=255
typeset -g POWERLEVEL9K_GO_VERSION_BACKGROUND=2
# Show go version only when in a go project subdirectory.
typeset -g POWERLEVEL9K_GO_VERSION_PROJECT_ONLY=true
# Custom icon.
# typeset -g POWERLEVEL9K_GO_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
#################[ rust_version: rustc version (https://www.rust-lang.org) ]##################
# Rust version color.
typeset -g POWERLEVEL9K_RUST_VERSION_FOREGROUND=0
typeset -g POWERLEVEL9K_RUST_VERSION_BACKGROUND=208
# Show rust version only when in a rust project subdirectory.
typeset -g POWERLEVEL9K_RUST_VERSION_PROJECT_ONLY=true
# Custom icon.
# typeset -g POWERLEVEL9K_RUST_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
###############[ dotnet_version: .NET version (https://dotnet.microsoft.com) ]################
# .NET version color.
typeset -g POWERLEVEL9K_DOTNET_VERSION_FOREGROUND=7
typeset -g POWERLEVEL9K_DOTNET_VERSION_BACKGROUND=5
# Show .NET version only when in a .NET project subdirectory.
typeset -g POWERLEVEL9K_DOTNET_VERSION_PROJECT_ONLY=true
# Custom icon.
# typeset -g POWERLEVEL9K_DOTNET_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
#####################[ php_version: php version (https://www.php.net/) ]######################
# PHP version color.
typeset -g POWERLEVEL9K_PHP_VERSION_FOREGROUND=0
typeset -g POWERLEVEL9K_PHP_VERSION_BACKGROUND=5
# Show PHP version only when in a PHP project subdirectory.
typeset -g POWERLEVEL9K_PHP_VERSION_PROJECT_ONLY=true
# Custom icon.
# typeset -g POWERLEVEL9K_PHP_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ laravel_version: laravel php framework version (https://laravel.com/) ]###########
# Laravel version color.
typeset -g POWERLEVEL9K_LARAVEL_VERSION_FOREGROUND=1
typeset -g POWERLEVEL9K_LARAVEL_VERSION_BACKGROUND=7
# Custom icon.
# typeset -g POWERLEVEL9K_LARAVEL_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
#############[ rbenv: ruby version from rbenv (https://github.com/rbenv/rbenv) ]##############
# Rbenv color.
typeset -g POWERLEVEL9K_RBENV_FOREGROUND=0
typeset -g POWERLEVEL9K_RBENV_BACKGROUND=1
# Hide ruby version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_RBENV_SOURCES=(shell local global)
# If set to false, hide ruby version if it's the same as global:
# $(rbenv version-name) == $(rbenv global).
typeset -g POWERLEVEL9K_RBENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide ruby version if it's equal to "system".
typeset -g POWERLEVEL9K_RBENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_RBENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
####################[ java_version: java version (https://www.java.com/) ]####################
# Java version color.
typeset -g POWERLEVEL9K_JAVA_VERSION_FOREGROUND=1
typeset -g POWERLEVEL9K_JAVA_VERSION_BACKGROUND=7
# Show java version only when in a java project subdirectory.
typeset -g POWERLEVEL9K_JAVA_VERSION_PROJECT_ONLY=true
# Show brief version.
typeset -g POWERLEVEL9K_JAVA_VERSION_FULL=false
# Custom icon.
# typeset -g POWERLEVEL9K_JAVA_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
###[ package: name@version from package.json (https://docs.npmjs.com/files/package.json) ]####
# Package color.
typeset -g POWERLEVEL9K_PACKAGE_FOREGROUND=0
typeset -g POWERLEVEL9K_PACKAGE_BACKGROUND=6
# Package format. The following parameters are available within the expansion.
# - P9K_PACKAGE_NAME The value of `name` field in package.json.
# - P9K_PACKAGE_VERSION The value of `version` field in package.json.
# typeset -g POWERLEVEL9K_PACKAGE_CONTENT_EXPANSION='${P9K_PACKAGE_NAME//\%/%%}@${P9K_PACKAGE_VERSION//\%/%%}'
# Custom icon.
# typeset -g POWERLEVEL9K_PACKAGE_VISUAL_IDENTIFIER_EXPANSION='⭐'
#######################[ rvm: ruby version from rvm (https://rvm.io) ]########################
# Rvm color.
typeset -g POWERLEVEL9K_RVM_FOREGROUND=0
typeset -g POWERLEVEL9K_RVM_BACKGROUND=240
# Don't show @gemset at the end.
typeset -g POWERLEVEL9K_RVM_SHOW_GEMSET=false
# Don't show ruby- at the front.
typeset -g POWERLEVEL9K_RVM_SHOW_PREFIX=false
# Custom icon.
# typeset -g POWERLEVEL9K_RVM_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########[ fvm: flutter version management (https://github.com/leoafarias/fvm) ]############
# Fvm color.
typeset -g POWERLEVEL9K_FVM_FOREGROUND=0
typeset -g POWERLEVEL9K_FVM_BACKGROUND=4
# Custom icon.
# typeset -g POWERLEVEL9K_FVM_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ luaenv: lua version from luaenv (https://github.com/cehoffman/luaenv) ]###########
# Lua color.
typeset -g POWERLEVEL9K_LUAENV_FOREGROUND=0
typeset -g POWERLEVEL9K_LUAENV_BACKGROUND=4
# Hide lua version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_LUAENV_SOURCES=(shell local global)
# If set to false, hide lua version if it's the same as global:
# $(luaenv version-name) == $(luaenv global).
typeset -g POWERLEVEL9K_LUAENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide lua version if it's equal to "system".
typeset -g POWERLEVEL9K_LUAENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_LUAENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
###############[ jenv: java version from jenv (https://github.com/jenv/jenv) ]################
# Java color.
typeset -g POWERLEVEL9K_JENV_FOREGROUND=1
typeset -g POWERLEVEL9K_JENV_BACKGROUND=7
# Hide java version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_JENV_SOURCES=(shell local global)
# If set to false, hide java version if it's the same as global:
# $(jenv version-name) == $(jenv global).
typeset -g POWERLEVEL9K_JENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide java version if it's equal to "system".
typeset -g POWERLEVEL9K_JENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_JENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########[ plenv: perl version from plenv (https://github.com/tokuhirom/plenv) ]############
# Perl color.
typeset -g POWERLEVEL9K_PLENV_FOREGROUND=0
typeset -g POWERLEVEL9K_PLENV_BACKGROUND=4
# Hide perl version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_PLENV_SOURCES=(shell local global)
# If set to false, hide perl version if it's the same as global:
# $(plenv version-name) == $(plenv global).
typeset -g POWERLEVEL9K_PLENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide perl version if it's equal to "system".
typeset -g POWERLEVEL9K_PLENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_PLENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
############[ phpenv: php version from phpenv (https://github.com/phpenv/phpenv) ]############
# PHP color.
typeset -g POWERLEVEL9K_PHPENV_FOREGROUND=0
typeset -g POWERLEVEL9K_PHPENV_BACKGROUND=5
# Hide php version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_PHPENV_SOURCES=(shell local global)
# If set to false, hide php version if it's the same as global:
# $(phpenv version-name) == $(phpenv global).
typeset -g POWERLEVEL9K_PHPENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide PHP version if it's equal to "system".
typeset -g POWERLEVEL9K_PHPENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_PHPENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
#######[ scalaenv: scala version from scalaenv (https://github.com/scalaenv/scalaenv) ]#######
# Scala color.
typeset -g POWERLEVEL9K_SCALAENV_FOREGROUND=0
typeset -g POWERLEVEL9K_SCALAENV_BACKGROUND=1
# Hide scala version if it doesn't come from one of these sources.
typeset -g POWERLEVEL9K_SCALAENV_SOURCES=(shell local global)
# If set to false, hide scala version if it's the same as global:
# $(scalaenv version-name) == $(scalaenv global).
typeset -g POWERLEVEL9K_SCALAENV_PROMPT_ALWAYS_SHOW=false
# If set to false, hide scala version if it's equal to "system".
typeset -g POWERLEVEL9K_SCALAENV_SHOW_SYSTEM=true
# Custom icon.
# typeset -g POWERLEVEL9K_SCALAENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ haskell_stack: haskell version from stack (https://haskellstack.org/) ]###########
# Haskell color.
typeset -g POWERLEVEL9K_HASKELL_STACK_FOREGROUND=0
typeset -g POWERLEVEL9K_HASKELL_STACK_BACKGROUND=3
# Hide haskell version if it doesn't come from one of these sources.
# shell: version is set by STACK_YAML
# local: version is set by stack.yaml up the directory tree
# global: version is set by the implicit global project (~/.stack/global-project/stack.yaml)
typeset -g POWERLEVEL9K_HASKELL_STACK_SOURCES=(shell local)
# If set to false, hide haskell version if it's the same as in the implicit global project.
typeset -g POWERLEVEL9K_HASKELL_STACK_ALWAYS_SHOW=true
# Custom icon.
# typeset -g POWERLEVEL9K_HASKELL_STACK_VISUAL_IDENTIFIER_EXPANSION='⭐'
################[ terraform: terraform workspace (https://www.terraform.io) ]#################
# Don't show terraform workspace if it's literally "default".
typeset -g POWERLEVEL9K_TERRAFORM_SHOW_DEFAULT=false
# POWERLEVEL9K_TERRAFORM_CLASSES is an array with even number of elements. The first element
# in each pair defines a pattern against which the current terraform workspace gets matched.
# More specifically, it's P9K_CONTENT prior to the application of context expansion (see below)
# that gets matched. If you unset all POWERLEVEL9K_TERRAFORM_*CONTENT_EXPANSION parameters,
# you'll see this value in your prompt. The second element of each pair in
# POWERLEVEL9K_TERRAFORM_CLASSES defines the workspace class. Patterns are tried in order. The
# first match wins.
# typeset -g POWERLEVEL9K_TERRAFORM_CLASSES=(
# '*prod*' PROD
# '*test*' TEST
# '*' OTHER)
# If your current terraform workspace is "project_test", its class is TEST because "project_test"
# doesn't match the pattern '*prod*' but does match '*test*'.
# You can define different colors, icons and content expansions for different classes:
# typeset -g POWERLEVEL9K_TERRAFORM_TEST_FOREGROUND=2
# typeset -g POWERLEVEL9K_TERRAFORM_TEST_BACKGROUND=0
# typeset -g POWERLEVEL9K_TERRAFORM_TEST_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_TERRAFORM_TEST_CONTENT_EXPANSION='> ${P9K_CONTENT} <'
# '*prod*' PROD # These values are examples that are unlikely
# '*test*' TEST # to match your needs. Customize them as needed.
'*' OTHER)
typeset -g POWERLEVEL9K_TERRAFORM_OTHER_FOREGROUND=4
typeset -g POWERLEVEL9K_TERRAFORM_OTHER_BACKGROUND=0
# typeset -g POWERLEVEL9K_TERRAFORM_OTHER_VISUAL_IDENTIFIER_EXPANSION='⭐'
#############[ terraform_version: terraform version (https://www.terraform.io) ]##############
# Terraform version color.
typeset -g POWERLEVEL9K_TERRAFORM_VERSION_FOREGROUND=4
typeset -g POWERLEVEL9K_TERRAFORM_VERSION_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_TERRAFORM_VERSION_VISUAL_IDENTIFIER_EXPANSION='⭐'
################[ terraform_version: It shows active terraform version (https://www.terraform.io) ]#################
typeset -g POWERLEVEL9K_TERRAFORM_VERSION_SHOW_ON_COMMAND='terraform|tf'
#############[ kubecontext: current kubernetes context (https://kubernetes.io/) ]#############
# Show kubecontext only when the the command you are typing invokes one of these tools.
# Tip: Remove the next line to always show kubecontext.
typeset -g POWERLEVEL9K_KUBECONTEXT_SHOW_ON_COMMAND='kubectl|helm|kubens|kubectx|oc|istioctl|kogito|k9s|helmfile|flux|fluxctl|stern'
# Kubernetes context classes for the purpose of using different colors, icons and expansions with
# different contexts.
# POWERLEVEL9K_KUBECONTEXT_CLASSES is an array with even number of elements. The first element
# in each pair defines a pattern against which the current kubernetes context gets matched.
# that gets matched. If you unset all POWERLEVEL9K_KUBECONTEXT_*CONTENT_EXPANSION parameters,
# POWERLEVEL9K_KUBECONTEXT_CLASSES defines the context class. Patterns are tried in order. The
# first match wins.
# typeset -g POWERLEVEL9K_KUBECONTEXT_CLASSES=(
# '*prod*' PROD
# '*test*' TEST
# '*' DEFAULT)
# If your current kubernetes context is "deathray-testing/default", its class is TEST
# because "deathray-testing/default" doesn't match the pattern '*prod*' but does match '*test*'.
# typeset -g POWERLEVEL9K_KUBECONTEXT_TEST_FOREGROUND=0
# typeset -g POWERLEVEL9K_KUBECONTEXT_TEST_BACKGROUND=2
# typeset -g POWERLEVEL9K_KUBECONTEXT_TEST_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_KUBECONTEXT_TEST_CONTENT_EXPANSION='> ${P9K_CONTENT} <'
'*' DEFAULT)
typeset -g POWERLEVEL9K_KUBECONTEXT_DEFAULT_FOREGROUND=7
typeset -g POWERLEVEL9K_KUBECONTEXT_DEFAULT_BACKGROUND=5
# typeset -g POWERLEVEL9K_KUBECONTEXT_DEFAULT_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Use POWERLEVEL9K_KUBECONTEXT_CONTENT_EXPANSION to specify the content displayed by kubecontext
# segment. Parameter expansions are very flexible and fast, too. See reference:
# http://zsh.sourceforge.net/Doc/Release/Expansion.html#Parameter-Expansion.
# Within the expansion the following parameters are always available:
# - P9K_CONTENT The content that would've been displayed if there was no content
# expansion defined.
# - P9K_KUBECONTEXT_NAME The current context's name. Corresponds to column NAME in the
# output of `kubectl config get-contexts`.
# - P9K_KUBECONTEXT_CLUSTER The current context's cluster. Corresponds to column CLUSTER in the
# - P9K_KUBECONTEXT_NAMESPACE The current context's namespace. Corresponds to column NAMESPACE
# in the output of `kubectl config get-contexts`. If there is no
# namespace, the parameter is set to "default".
# - P9K_KUBECONTEXT_USER The current context's user. Corresponds to column AUTHINFO in the
# If the context points to Google Kubernetes Engine (GKE) or Elastic Kubernetes Service (EKS),
# the following extra parameters are available:
# - P9K_KUBECONTEXT_CLOUD_NAME Either "gke" or "eks".
# - P9K_KUBECONTEXT_CLOUD_ACCOUNT Account/project ID.
# - P9K_KUBECONTEXT_CLOUD_ZONE Availability zone.
# - P9K_KUBECONTEXT_CLOUD_CLUSTER Cluster.
# P9K_KUBECONTEXT_CLOUD_* parameters are derived from P9K_KUBECONTEXT_CLUSTER. For example,
# if P9K_KUBECONTEXT_CLUSTER is "gke_my-account_us-east1-a_my-cluster-01":
# - P9K_KUBECONTEXT_CLOUD_NAME=gke
# - P9K_KUBECONTEXT_CLOUD_ACCOUNT=my-account
# - P9K_KUBECONTEXT_CLOUD_ZONE=us-east1-a
# - P9K_KUBECONTEXT_CLOUD_CLUSTER=my-cluster-01
# If P9K_KUBECONTEXT_CLUSTER is "arn:aws:eks:us-east-1:123456789012:cluster/my-cluster-01":
# - P9K_KUBECONTEXT_CLOUD_NAME=eks
# - P9K_KUBECONTEXT_CLOUD_ACCOUNT=123456789012
# - P9K_KUBECONTEXT_CLOUD_ZONE=us-east-1
typeset -g POWERLEVEL9K_KUBECONTEXT_DEFAULT_CONTENT_EXPANSION=
# Show P9K_KUBECONTEXT_CLOUD_CLUSTER if it's not empty and fall back to P9K_KUBECONTEXT_NAME.
POWERLEVEL9K_KUBECONTEXT_DEFAULT_CONTENT_EXPANSION+='${P9K_KUBECONTEXT_CLOUD_CLUSTER:-${P9K_KUBECONTEXT_NAME}}'
# Append the current context's namespace if it's not "default".
POWERLEVEL9K_KUBECONTEXT_DEFAULT_CONTENT_EXPANSION+='${${:-/$P9K_KUBECONTEXT_NAMESPACE}:#/default}'
# Custom prefix.
# typeset -g POWERLEVEL9K_KUBECONTEXT_PREFIX='at '
#[ aws: aws profile (https://docs.aws.amazon.com/cli/latest/userguide/cli-configure-profiles.html) ]#
# Show aws only when the the command you are typing invokes one of these tools.
# Tip: Remove the next line to always show aws.
typeset -g POWERLEVEL9K_AWS_SHOW_ON_COMMAND='aws|awless|terraform|pulumi|terragrunt'
# POWERLEVEL9K_AWS_CLASSES is an array with even number of elements. The first element
# in each pair defines a pattern against which the current AWS profile gets matched.
# that gets matched. If you unset all POWERLEVEL9K_AWS_*CONTENT_EXPANSION parameters,
# POWERLEVEL9K_AWS_CLASSES defines the profile class. Patterns are tried in order. The
# first match wins.
# typeset -g POWERLEVEL9K_AWS_CLASSES=(
# '*prod*' PROD
# '*test*' TEST
# '*' DEFAULT)
# If your current AWS profile is "company_test", its class is TEST
# because "company_test" doesn't match the pattern '*prod*' but does match '*test*'.
# typeset -g POWERLEVEL9K_AWS_TEST_FOREGROUND=28
# typeset -g POWERLEVEL9K_AWS_TEST_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_AWS_TEST_CONTENT_EXPANSION='> ${P9K_CONTENT} <'
'*' DEFAULT)
typeset -g POWERLEVEL9K_AWS_DEFAULT_FOREGROUND=7
typeset -g POWERLEVEL9K_AWS_DEFAULT_BACKGROUND=1
# typeset -g POWERLEVEL9K_AWS_DEFAULT_VISUAL_IDENTIFIER_EXPANSION='⭐'
# AWS segment format. The following parameters are available within the expansion.
# - P9K_AWS_PROFILE The name of the current AWS profile.
# - P9K_AWS_REGION The region associated with the current AWS profile.
typeset -g POWERLEVEL9K_AWS_CONTENT_EXPANSION='${P9K_AWS_PROFILE//\%/%%}${P9K_AWS_REGION:+ ${P9K_AWS_REGION//\%/%%}}'
#[ aws_eb_env: aws elastic beanstalk environment (https://aws.amazon.com/elasticbeanstalk/) ]#
# AWS Elastic Beanstalk environment color.
typeset -g POWERLEVEL9K_AWS_EB_ENV_FOREGROUND=2
typeset -g POWERLEVEL9K_AWS_EB_ENV_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_AWS_EB_ENV_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ azure: azure account name (https://docs.microsoft.com/en-us/cli/azure) ]##########
# Show azure only when the the command you are typing invokes one of these tools.
# Tip: Remove the next line to always show azure.
typeset -g POWERLEVEL9K_AZURE_SHOW_ON_COMMAND='az|terraform|pulumi|terragrunt'
# Azure account name color.
typeset -g POWERLEVEL9K_AZURE_FOREGROUND=7
typeset -g POWERLEVEL9K_AZURE_BACKGROUND=4
# Custom icon.
# typeset -g POWERLEVEL9K_AZURE_VISUAL_IDENTIFIER_EXPANSION='⭐'
##########[ gcloud: google cloud account and project (https://cloud.google.com/) ]###########
# Show gcloud only when the the command you are typing invokes one of these tools.
# Tip: Remove the next line to always show gcloud.
typeset -g POWERLEVEL9K_GCLOUD_SHOW_ON_COMMAND='gcloud|gcs'
# Google cloud color.
typeset -g POWERLEVEL9K_GCLOUD_FOREGROUND=7
typeset -g POWERLEVEL9K_GCLOUD_BACKGROUND=4
# Google cloud format. Change the value of POWERLEVEL9K_GCLOUD_PARTIAL_CONTENT_EXPANSION and/or
# POWERLEVEL9K_GCLOUD_COMPLETE_CONTENT_EXPANSION if the default is too verbose or not informative
# enough. You can use the following parameters in the expansions. Each of them corresponds to the
# output of `gcloud` tool.
# Parameter | Source
# P9K_GCLOUD_CONFIGURATION | gcloud config configurations list --format='value(name)'
# P9K_GCLOUD_ACCOUNT | gcloud config get-value account
# P9K_GCLOUD_PROJECT_ID | gcloud config get-value project
# P9K_GCLOUD_PROJECT_NAME | gcloud projects describe $P9K_GCLOUD_PROJECT_ID --format='value(name)'
# Note: ${VARIABLE//\%/%%} expands to ${VARIABLE} with all occurrences of '%' replaced with '%%'.
# Obtaining project name requires sending a request to Google servers. This can take a long time
# and even fail. When project name is unknown, P9K_GCLOUD_PROJECT_NAME is not set and gcloud
# prompt segment is in state PARTIAL. When project name gets known, P9K_GCLOUD_PROJECT_NAME gets
# set and gcloud prompt segment transitions to state COMPLETE.
# You can customize the format, icon and colors of gcloud segment separately for states PARTIAL
# and COMPLETE. You can also hide gcloud in state PARTIAL by setting
# POWERLEVEL9K_GCLOUD_PARTIAL_VISUAL_IDENTIFIER_EXPANSION and
# POWERLEVEL9K_GCLOUD_PARTIAL_CONTENT_EXPANSION to empty.
typeset -g POWERLEVEL9K_GCLOUD_PARTIAL_CONTENT_EXPANSION='${P9K_GCLOUD_PROJECT_ID//\%/%%}'
typeset -g POWERLEVEL9K_GCLOUD_COMPLETE_CONTENT_EXPANSION='${P9K_GCLOUD_PROJECT_NAME//\%/%%}'
# Send a request to Google (by means of `gcloud projects describe ...`) to obtain project name
# this often. Negative value disables periodic polling. In this mode project name is retrieved
# only when the current configuration, account or project id changes.
typeset -g POWERLEVEL9K_GCLOUD_REFRESH_PROJECT_NAME_SECONDS=60
# Custom icon.
# typeset -g POWERLEVEL9K_GCLOUD_VISUAL_IDENTIFIER_EXPANSION='⭐'
#[ google_app_cred: google application credentials (https://cloud.google.com/docs/authentication/production) ]#
# Show google_app_cred only when the the command you are typing invokes one of these tools.
# Tip: Remove the next line to always show google_app_cred.
typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_SHOW_ON_COMMAND='terraform|pulumi|terragrunt'
# Google application credentials classes for the purpose of using different colors, icons and
# expansions with different credentials.
# POWERLEVEL9K_GOOGLE_APP_CRED_CLASSES is an array with even number of elements. The first
# element in each pair defines a pattern against which the current kubernetes context gets
# matched. More specifically, it's P9K_CONTENT prior to the application of context expansion
# (see below) that gets matched. If you unset all POWERLEVEL9K_GOOGLE_APP_CRED_*CONTENT_EXPANSION
# parameters, you'll see this value in your prompt. The second element of each pair in
# POWERLEVEL9K_GOOGLE_APP_CRED_CLASSES defines the context class. Patterns are tried in order.
# The first match wins.
# typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_CLASSES=(
# '*:*prod*:*' PROD
# '*:*test*:*' TEST
# '*' DEFAULT)
# If your current Google application credentials is "service_account deathray-testing x@y.com",
# its class is TEST because it doesn't match the pattern '* *prod* *' but does match '* *test* *'.
# typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_TEST_FOREGROUND=28
# typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_TEST_VISUAL_IDENTIFIER_EXPANSION='⭐'
# typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_TEST_CONTENT_EXPANSION='$P9K_GOOGLE_APP_CRED_PROJECT_ID'
# '*:*prod*:*' PROD # These values are examples that are unlikely
# '*:*test*:*' TEST # to match your needs. Customize them as needed.
'*' DEFAULT)
typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_DEFAULT_FOREGROUND=7
typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_DEFAULT_BACKGROUND=4
# typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_DEFAULT_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Use POWERLEVEL9K_GOOGLE_APP_CRED_CONTENT_EXPANSION to specify the content displayed by
# google_app_cred segment. Parameter expansions are very flexible and fast, too. See reference:
# You can use the following parameters in the expansion. Each of them corresponds to one of the
# fields in the JSON file pointed to by GOOGLE_APPLICATION_CREDENTIALS.
# Parameter | JSON key file field
# P9K_GOOGLE_APP_CRED_TYPE | type
# P9K_GOOGLE_APP_CRED_PROJECT_ID | project_id
# P9K_GOOGLE_APP_CRED_CLIENT_EMAIL | client_email
# Note: ${VARIABLE//\%/%%} expands to ${VARIABLE} with all occurrences of '%' replaced by '%%'.
typeset -g POWERLEVEL9K_GOOGLE_APP_CRED_DEFAULT_CONTENT_EXPANSION='${P9K_GOOGLE_APP_CRED_PROJECT_ID//\%/%%}'
##############[ toolbox: toolbox name (https://github.com/containers/toolbox) ]###############
# Toolbox color.
typeset -g POWERLEVEL9K_TOOLBOX_FOREGROUND=0
typeset -g POWERLEVEL9K_TOOLBOX_BACKGROUND=3
# Don't display the name of the toolbox if it matches fedora-toolbox-*.
typeset -g POWERLEVEL9K_TOOLBOX_CONTENT_EXPANSION='${P9K_TOOLBOX_NAME:#fedora-toolbox-*}'
# Custom icon.
# typeset -g POWERLEVEL9K_TOOLBOX_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Custom prefix.
# typeset -g POWERLEVEL9K_TOOLBOX_PREFIX='in '
###############################[ public_ip: public IP address ]###############################
# Public IP color.
typeset -g POWERLEVEL9K_PUBLIC_IP_FOREGROUND=7
typeset -g POWERLEVEL9K_PUBLIC_IP_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_PUBLIC_IP_VISUAL_IDENTIFIER_EXPANSION='⭐'
########################[ vpn_ip: virtual private network indicator ]#########################
# VPN IP color.
typeset -g POWERLEVEL9K_VPN_IP_FOREGROUND=0
typeset -g POWERLEVEL9K_VPN_IP_BACKGROUND=6
# When on VPN, show just an icon without the IP address.
# Tip: To display the private IP address when on VPN, remove the next line.
typeset -g POWERLEVEL9K_VPN_IP_CONTENT_EXPANSION=
# Regular expression for the VPN network interface. Run `ifconfig` or `ip -4 a show` while on VPN
# to see the name of the interface.
typeset -g POWERLEVEL9K_VPN_IP_INTERFACE='(gpd|wg|(.*tun)|tailscale)[0-9]*'
# If set to true, show one segment per matching network interface. If set to false, show only
# one segment corresponding to the first matching network interface.
# Tip: If you set it to true, you'll probably want to unset POWERLEVEL9K_VPN_IP_CONTENT_EXPANSION.
typeset -g POWERLEVEL9K_VPN_IP_SHOW_ALL=false
# Custom icon.
# typeset -g POWERLEVEL9K_VPN_IP_VISUAL_IDENTIFIER_EXPANSION='⭐'
###########[ ip: ip address and bandwidth usage for a specified network interface ]###########
# IP color.
typeset -g POWERLEVEL9K_IP_BACKGROUND=4
typeset -g POWERLEVEL9K_IP_FOREGROUND=0
# The following parameters are accessible within the expansion:
# Parameter | Meaning
# P9K_IP_IP | IP address
# P9K_IP_INTERFACE | network interface
# P9K_IP_RX_BYTES | total number of bytes received
# P9K_IP_TX_BYTES | total number of bytes sent
# P9K_IP_RX_BYTES_DELTA | number of bytes received since last prompt
# P9K_IP_TX_BYTES_DELTA | number of bytes sent since last prompt
# P9K_IP_RX_RATE | receive rate (since last prompt)
# P9K_IP_TX_RATE | send rate (since last prompt)
typeset -g POWERLEVEL9K_IP_CONTENT_EXPANSION='${P9K_IP_RX_RATE:+⇣$P9K_IP_RX_RATE }${P9K_IP_TX_RATE:+⇡$P9K_IP_TX_RATE }$P9K_IP_IP'
# Show information for the first network interface whose name matches this regular expression.
# Run `ifconfig` or `ip -4 a show` to see the names of all network interfaces.
typeset -g POWERLEVEL9K_IP_INTERFACE='[ew].*'
# Custom icon.
# typeset -g POWERLEVEL9K_IP_VISUAL_IDENTIFIER_EXPANSION='⭐'
#########################[ proxy: system-wide http/https/ftp proxy ]##########################
# Proxy color.
typeset -g POWERLEVEL9K_PROXY_FOREGROUND=4
typeset -g POWERLEVEL9K_PROXY_BACKGROUND=0
# Custom icon.
# typeset -g POWERLEVEL9K_PROXY_VISUAL_IDENTIFIER_EXPANSION='⭐'
################################[ battery: internal battery ]#################################
# Show battery in red when it's below this level and not connected to power supply.
typeset -g POWERLEVEL9K_BATTERY_LOW_THRESHOLD=20
typeset -g POWERLEVEL9K_BATTERY_LOW_FOREGROUND=1
# Show battery in green when it's charging or fully charged.
typeset -g POWERLEVEL9K_BATTERY_{CHARGING,CHARGED}_FOREGROUND=2
# Show battery in yellow when it's discharging.
typeset -g POWERLEVEL9K_BATTERY_DISCONNECTED_FOREGROUND=3
# Battery pictograms going from low to high level of charge.
typeset -g POWERLEVEL9K_BATTERY_STAGES='\uf58d\uf579\uf57a\uf57b\uf57c\uf57d\uf57e\uf57f\uf580\uf581\uf578'
# Don't show the remaining time to charge/discharge.
typeset -g POWERLEVEL9K_BATTERY_VERBOSE=false
typeset -g POWERLEVEL9K_BATTERY_BACKGROUND=0
#####################################[ wifi: wifi speed ]#####################################
# WiFi color.
typeset -g POWERLEVEL9K_WIFI_FOREGROUND=0
typeset -g POWERLEVEL9K_WIFI_BACKGROUND=4
# Custom icon.
# typeset -g POWERLEVEL9K_WIFI_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Use different colors and icons depending on signal strength ($P9K_WIFI_BARS).
# # Wifi colors and icons for different signal strength levels (low to high).
# typeset -g my_wifi_fg=(0 0 0 0 0) # <-- change these values
# typeset -g my_wifi_icon=('WiFi' 'WiFi' 'WiFi' 'WiFi' 'WiFi') # <-- change these values
# typeset -g POWERLEVEL9K_WIFI_CONTENT_EXPANSION='%F{${my_wifi_fg[P9K_WIFI_BARS+1]}}$P9K_WIFI_LAST_TX_RATE Mbps'
# typeset -g POWERLEVEL9K_WIFI_VISUAL_IDENTIFIER_EXPANSION='%F{${my_wifi_fg[P9K_WIFI_BARS+1]}}${my_wifi_icon[P9K_WIFI_BARS+1]}'
# The following parameters are accessible within the expansions:
# P9K_WIFI_SSID | service set identifier, a.k.a. network name
# P9K_WIFI_LINK_AUTH | authentication protocol such as "wpa2-psk" or "none"; empty if unknown
# P9K_WIFI_LAST_TX_RATE | wireless transmit rate in megabits per second
# P9K_WIFI_RSSI | signal strength in dBm, from -120 to 0
# P9K_WIFI_NOISE | noise in dBm, from -120 to 0
# P9K_WIFI_BARS | signal strength in bars, from 0 to 4 (derived from P9K_WIFI_RSSI and P9K_WIFI_NOISE)
####################################[ time: current time ]####################################
# Current time color.
typeset -g POWERLEVEL9K_TIME_FOREGROUND=0
typeset -g POWERLEVEL9K_TIME_BACKGROUND=7
# Format for the current time: 09:51:02. See `man 3 strftime`.
typeset -g POWERLEVEL9K_TIME_FORMAT='%D{%H:%M:%S}'
# If set to true, time will update when you hit enter. This way prompts for the past
# commands will contain the start times of their commands as opposed to the default
# behavior where they contain the end times of their preceding commands.
typeset -g POWERLEVEL9K_TIME_UPDATE_ON_COMMAND=false
# Custom icon.
# typeset -g POWERLEVEL9K_TIME_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Custom prefix.
# typeset -g POWERLEVEL9K_TIME_PREFIX='at '
# Example of a user-defined prompt segment. Function prompt_example will be called on every
# prompt if `example` prompt segment is added to POWERLEVEL9K_LEFT_PROMPT_ELEMENTS or
# POWERLEVEL9K_RIGHT_PROMPT_ELEMENTS. It displays an icon and yellow text on red background
# greeting the user.
# Type `p10k help segment` for documentation and a more sophisticated example.
function prompt_example() {
p10k segment -b 1 -f 3 -i '⭐' -t 'hello, %n'
# User-defined prompt segments may optionally provide an instant_prompt_* function. Its job
# is to generate the prompt segment for display in instant prompt. See
# https://github.com/romkatv/powerlevel10k/blob/master/README.md#instant-prompt.
# Powerlevel10k will call instant_prompt_* at the same time as the regular prompt_* function
# and will record all `p10k segment` calls it makes. When displaying instant prompt, Powerlevel10k
# will replay these calls without actually calling instant_prompt_*. It is imperative that
# instant_prompt_* always makes the same `p10k segment` calls regardless of environment. If this
# rule is not observed, the content of instant prompt will be incorrect.
# Usually, you should either not define instant_prompt_* or simply call prompt_* from it. If
# instant_prompt_* is not defined for a segment, the segment won't be shown in instant prompt.
function instant_prompt_example() {
# Since prompt_example always makes the same `p10k segment` calls, we can call it from
# instant_prompt_example. This will give us the same `example` prompt segment in the instant
# and regular prompts.
prompt_example
# User-defined prompt segments can be customized the same way as built-in segments.
typeset -g POWERLEVEL9K_EXAMPLE_FOREGROUND=3
typeset -g POWERLEVEL9K_EXAMPLE_BACKGROUND=1
# typeset -g POWERLEVEL9K_EXAMPLE_VISUAL_IDENTIFIER_EXPANSION='⭐'
# Transient prompt works similarly to the builtin transient_rprompt option. It trims down prompt
# when accepting a command line. Supported values:
# - off: Don't change prompt when accepting a command line.
# - always: Trim down prompt when accepting a command line.
# - same-dir: Trim down prompt when accepting a command line unless this is the first command
# typed after changing current working directory.
typeset -g POWERLEVEL9K_TRANSIENT_PROMPT=off
# Instant prompt mode.
# - off: Disable instant prompt. Choose this if you've tried instant prompt and found
# it incompatible with your zsh configuration files.
# - quiet: Enable instant prompt and don't print warnings when detecting console output
# during zsh initialization. Choose this if you've read and understood
# - verbose: Enable instant prompt and print a warning when detecting console output during
# zsh initialization. Choose this if you've never tried instant prompt, haven't
# seen the warning, or if you are unsure what this all means.
typeset -g POWERLEVEL9K_INSTANT_PROMPT=quiet
# Hot reload allows you to change POWERLEVEL9K options after Powerlevel10k has been initialized.
# For example, you can type POWERLEVEL9K_BACKGROUND=red and see your prompt turn red. Hot reload
# can slow down prompt by 1-2 milliseconds, so it's better to keep it turned off unless you
# really need it.
typeset -g POWERLEVEL9K_DISABLE_HOT_RELOAD=true
# If p10k is already loaded, reload configuration.
# This works even with POWERLEVEL9K_DISABLE_HOT_RELOAD=true.
(( ! $+functions[p10k] )) || p10k reload
# Tell `p10k configure` which file it should overwrite.
typeset -g POWERLEVEL9K_CONFIG_FILE=~/.p10k.zsh
(( ${#p10k_config_opts} )) && setopt ${p10k_config_opts[@]}
'builtin' 'unset' 'p10k_config_opts'
Source :
thank you so much for this guide!
Do you know how can i install manjaro-zsh-config from github, i cloned it and i’m in that folder but makepkg doesn’t work
That one failed for me too, maybe @Chrysostomus might help you in this regard.
On a second thought, you could just copy the files to the specific locations (for a “working” solution).
Use the current PKGBUILD instead:
Just out of curiosity, why isn’t it pushed to AUR?
According to @Yochanan’s guide, you have to,
yay -S nerd-fonts-noto-sans-mono
or,
pamac build nerd-fonts-noto-sans-mono
[Since nerd-fonts-noto-sans-mono
doesn’t seem to be in Arch repos]
Then
git clone https://gitlab.manjaro.org/packages/community/manjaro-zsh-config.git
cd manjaro-zsh-config
makepkg -si
And in your ~/.zshrc
, include the following lines,
# Use powerline
USE_POWERLINE="true"
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
No need, it’s in the Manjaro repos.
so that zsh package is in Manjaro repos?
Yes, it is. And is installed by default .
how can i install that file if i don’t have that file in my arch repos?
Make sure you have nerd-fonts-noto-sans-mono
installed from the AUR first.
makepkg -srif
do i have to first install this:
zsh
zsh-autosuggestions
zsh-syntax-highlighting
zsh-completions
zsh-history-substring-search
zsh-theme-powerlevel10k
manjaro-zsh-config
or i can just do what you said me to do?
