Those packages are all in the Arch repos, they will be installed as dependencies after you follow my instructions.
ok, i installed it, now how can i enable it?
Scroll back up and follow the instructions already provided.
i was following guides from here and no luck, can you please tell me how i can enable it?
i installed the font and:
git clone https://gitlab.manjaro.org/packages/community/manjaro-zsh-config.git
cd manjaro-zsh-config
makepkg -srif
and after that i tried to apply configs from this post and no luck.
By doing what?
Include this in ~/.zshrc
# Use powerline
USE_POWERLINE="true"
# Source manjaro-zsh-configuration
if [[ -e /usr/share/zsh/manjaro-zsh-config ]]; then
source /usr/share/zsh/manjaro-zsh-config
fi
# Use manjaro zsh prompt
if [[ -e /usr/share/zsh/manjaro-zsh-prompt ]]; then
source /usr/share/zsh/manjaro-zsh-prompt
fi
Have you sourced your ~/.zshrc
or restarted your shell yet? Whenever you make changes to any shell config files, you need to source it for the current active terminal:
source ~/.zshrc
…and just to be sure, you have made ZSH your default shell?
thank you so much guys, you’re the best!
Last question: how can i track for a changes on: Packages / Community / manjaro-zsh-config · GitLab
for a new versions so that i can upgrade it?
Updates to this package - if you have it installed - come automatically with the regular updates.
I know of only one way to track changes: watch what gets updated
But, as already said, you’d have to apply any changes to files in /etc/skel
manually whenever they change.
… why would you want to track any minor change to the default configuration
when you have a configuration that you are happy with? …rhetorical question
All the setup documents you really want and which are introduced by these bundles end up in the registry:
/and so forth/skel
where all the default design documents dwell.
They get utilized and applied consequently just when another client account is made.
To utilize these in an all-around existing record
you want to duplicate the (significant) documents to the client account you need them to be applied in.
