- When the my Manjaro Linux is started/restarted, there is no sound (internal speakers are muted totally) and there appear no sound devices in the Sound settings, only a virtual one.
- If you connect a speaker via Bluetooth, then it sounds well, however after switching it off again there is no sound.
- If you plug in a headphone via jack, it also sounds and when you unplug it, the sound remains: the internal speakers work well.
It’s a completely new behaviour, I have no idea where it came from. It can be repeated any number of times. So, when I boot Linux, I have to plug in a jack for a moment to get sound.
In more detail
Yesterday suddenly I lost the internal sound. At the sound setting there is only a virtual output device. I switched back to the previous kernel, it did not help.
The command lshw returns for audio:
Audio device
/0/100/1f.3
product: Sunrise Point-LP HD Audio [8086:9D70]
vendor: Intel Corporation [8086]
bus info: pci@0000:00:1f.3
version: 21
width: 64 bits
clock: 33MHz
capabilities:
Power Management,
Message Signalled Interrupts,
bus mastering,
PCI capabilities listing
configuration:
driver: snd_hda_intel
latency: 32
resources:
irq: 131
memory: b1320000-b1323fff
memory: b1310000-b131ffff
The command inxi returns for audio:
Device-1: Intel Sunrise Point-LP HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound API: ALSA v: k5.10.157-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.61 running: yes
My system is:
KDE Plasma Version: 5.26.4
KDE Frameworks Version: 5.100.0
Qt Version: 5.15.7
Kernel Version: 5.10.157-1-MANJARO (64-bit) (switched back)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-6200U CPU @ 2.30GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 520
Manufacturer: Acer
Product Name: Aspire V3-372
System Version: V1.12
The inner speakers do not work. However if I connect a headphone by a jack, it is well working. Even, pulling off the headphone, now the inner speakers work, too! Then I opened the sound settings and a list of audio outputs appeared. But switching to any other output immediately mutes the sound and the list disappears. I can repeat this experiment.
Thanks for any answer, jBalint
