I installed manjaro linux on my hp envy x360 laptop but no wifi are showing up. I managed to update my system though bluetooth tethering but nothing changed.
I found someone who had to reset his bios settings (https://forum.manjaro.org/t/i-cant-connect-to-wifi/119330) before being able to connect to his wifi and I think I have the same issue because when I type the following commands, I get the exact same results:
> sudo rmmod b43
rmmod: ERROR: Module b43 is not currently loaded
> sudo rmmod ssb
mmod: ERROR: Module ssb is not currently loaded
> sudo rmmod bcma
rmmod: ERROR: Module bcma is not currently loaded
> sudo modprobe -r wl
> sudo modprobe wl
I reset my bios settings twice but I still get the same outputs. I also couldn’t find the option to enable uefi or ahci.
Does someone have an idea what I could do?
Sorry, here is my inxi output:
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=16d5ae98-ac98-413e-8071-6f9bb1acc02f rw quiet
cryptdevice=UUID=061f4376-ca0f-4d1f-a90e-f40883e44068:luks-061f4376-ca0f-4d1f-a90e-f40883e44068
root=/dev/mapper/luks-061f4376-ca0f-4d1f-a90e-f40883e44068
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Convertible System: HP product: HP ENVY x360 Convertible 15-eu0xxx
v: N/A serial: <superuser required> Chassis: type: 31
Mobo: HP model: 888A v: 63.49 serial: <superuser required> UEFI: AMI
v: F.06 date: 07/28/2021
ID-1: BAT0 charge: 51.1 Wh (100.0%) condition: 51.1/51.1 Wh (100.0%)
volts: 12.9 min: 11.6 model: 333-27-3A-A BN03051XL type: Li-ion
serial: <filter> status: full cycles: 54
Device-1: hid-0018:04F3:2CFF.000A-battery model: ELAN2514:00 04F3:2CFF
serial: N/A charge: N/A status: N/A
RAM: total: 14.98 GiB used: 3.12 GiB (20.9%)
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1684 high: 3693 min/max: 1400/4056 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3693 2: 2201
3: 1485 4: 1532 5: 1455 6: 1473 7: 1394 8: 1393 9: 1397 10: 1397 11: 1397
12: 1397 bogomips: 50322
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 48.0 C
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 5360x1440 s-dpi: 96 s-size: 1418x381mm (55.83x15.00")
s-diag: 1468mm (57.81")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-left
model: Gigabyte M34WQ serial: <filter> built: 2022 res: 3440x1440 hz: 144
dpi: 109 gamma: 1.2 size: 800x335mm (31.5x13.19") diag: 867mm (34.1")
modes: max: 3440x1440 min: 720x400
Monitor-2: eDP-1 mapped: eDP pos: bottom-r model: LG Display 0x069b
built: 2019 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 Mesa 22.3.1 renderer: AMD Radeon Graphics (renoir LLVM
14.0.6 DRM 3.42 5.15.85-1-MANJARO) direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x,snd_pci_acp5x
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
bus-ID: 04:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: N/A modules: wl pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF-ID-1: bnep0 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-3:2 chip-ID: 0bda:2852 class-ID: e001 serial: <filter>
Device-1: luks-061f4376-ca0f-4d1f-a90e-f40883e44068 maj-min: 254:0
type: LUKS dm: dm-0 size: 244.14 GiB
Components:
p-1: nvme0n1p5 maj-min: 259:5 size: 244.14 GiB
Local Storage: total: 476.94 GiB used: 13.01 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM512GD3JX013N size: 476.94 GiB block-size: physical: 512 B
rev: HPS1 temp: 31.9 C scheme: GPT
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%) used: 12.95 GiB (5.4%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-061f4376-ca0f-4d1f-a90e-f40883e44068 label: N/A
uuid: 16d5ae98-ac98-413e-8071-6f9bb1acc02f
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 65.5 MiB (25.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 6645-7B97
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 231.92 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 616 MiB fs: ntfs
label: Windows RE tools uuid: FEC4FBB5C4FB6DF1
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-1:2 info: Realtek RTS5411 Hub ports: 6 rev: 2.1 speed: 480 Mb/s
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-1.1:4 info: ROCCAT Kain 120 Aimo type: Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s power: 500mA
chip-ID: 1e7d:2d5c class-ID: 0300
Device-2: 1-1.2:5 info: ROCCAT Vulcan AIMO type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1e7d:3098 class-ID: 0300
Device-3: 1-1.6:6 info: Realtek HID Device type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 0bda:1100 class-ID: 0300
Device-4: 1-4:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c4c class-ID: 0000
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-3:2 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:2852
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 47.0 C
Processes: 296 Uptime: 1h 52m wakeups: 9 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1252 libs: 322 tools: pamac pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.24
It looks like you do not have the driver installed. It requires the following driver and you will also need the appropriate linux headers for your kernel as well as dkms installed.
https://aur.archlinux.org/packages/rtw89-dkms-git
In terminal:
pamac build rtw89-dkms-git
or install via pamac GUI and reboot
Also you don’t have a swapfile or swap partition. It would be a good idea to create one or the other.
