Hello dear Linux community, I have been new to manjaro for a few months as well as to the forum. I have been using linux systems for a few years. I went on vacation last week. coming back from vacation, seeing that my OS had updates (~ 200) I made them from the package manager. After rebooting, arriving on the login screen, no users were visible. I can connect through the other tty and launch the interface with startx command. When I lock my session, and I want to re-access it, a black screen appears, and I cannot access a graphical interface again. Since I’m new, I’m not sure what to give. If you have any resources / advice to help me, please let me know, or if not, is there a way to roll back the updates?
Hi and welcome to the forum
To get a better idea about your issue, is it possible to add some more info to the above post?
Hi. Thank you. You’ll find some logs bellow:
INXI result:
Kernel: 5.10.52-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d4178c92-5bc7-410d-b41f-bf56519ff6df rw quiet splash apparmor=1
Desktop: GNOME 40.3 tk: GTK 3.24.30 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: LENOVO product: 20RD0019MZ v: ThinkPad E15
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20RD0019MZ v: SDK0J40697 WIN serial: <filter>
UEFI: LENOVO v: R16ET27W (1.13 ) date: 07/28/2020
ID-1: BAT0 charge: 25.4 Wh (57.5%) condition: 44.2/45.7 Wh (96.7%)
volts: 11.3 min: 11.1 model: SMP 5B10W138 type: Li-poly serial: <filter>
status: Discharging cycles: 134
RAM: total: 7.46 GiB used: 2.36 GiB (31.7%)
Info: Quad Core model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: EA cache: L2: 8 MiB bogomips: 36812
Speed: 800 MHz min/max: 400/4900 MHz Core speeds (MHz): 1: 800 2: 801 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc
cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window
hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni
popcnt pse pse36 pts rdrand rdseed rdtscp rep_good sdbg sep smap smep ss
ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 13d3:5415 class-ID: 0e02
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.1.5
direct render: Yes
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.10.52-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.32 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
port: 3000 bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus-ID: 04:00.0
IF: enp4s0 state: down mac: <filter>
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 83.11 GiB (17.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZALQ512HALU-000L1
lanes: 4 type: SSD serial: <filter> rev: BL1QFXV7 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 235.15 GiB size: 230.4 GiB (97.98%)
used: 83.08 GiB (36.1%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
label: N/A uuid: d4178c92-5bc7-410d-b41f-bf56519ff6df
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 29.3 MiB (11.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM uuid: 1C10-2870
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 240.54 GiB fs: ntfs label: Windows
uuid: 8EB2129BB21287BB
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WinRE_DRV
uuid: 0896130C9612FA40
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
Device-1: 1-8:2 info: IMC Networks Integrated Camera type: Video
Device-2: 1-9:3 info: Synaptics type: <vendor specific> driver: N/A
interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 06cb:00da
class-ID: ff00 serial: <filter>
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 259 Uptime: 5m wakeups: 2 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1396 pacman: 1387 lib: 419
flatpak: 6 snap: 3 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.06
"sudo dmesg --level emerg,alert,crit,err,warn" result:
[ 0.238670] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 1.329151] usb: port power management may be unreliable
[ 1.825261] vboxdrv: loading out-of-tree module taints kernel.
[ 1.860406] VBoxNetAdp: Successfully started.
[ 1.862466] VBoxNetFlt: Successfully started.
[ 2.227979] acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.228063] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.228285] acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.228496] acpi PNP0C14:05: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
[ 2.334573] tpm tpm0: [Firmware Bug]: TPM interrupt not working, polling instead
[ 2.525187] r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 2.529020] iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
[ 2.665210] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
[ 2.665223] caller snb_uncore_imc_init_box+0x78/0xc0 [intel_uncore] mapping multiple BARs
[ 2.863923] urandom_read: 3 callbacks suppressed
[ 2.890913] thermal thermal_zone7: failed to read out thermal zone (-61)
[ 5.242164] kauditd_printk_skb: 87 callbacks suppressed
[ 10.287805] kauditd_printk_skb: 20 callbacks suppressed
Xorg logs:
[ 88.607] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 88.608]
X.Org X Server 1.20.11
[ 88.608] Build Operating System: Linux Manjaro Linux
[ 88.609] Current Operating System: Linux anarchy 5.10.49-1-MANJARO #1 SMP PREEMPT Sun Jul 11 12:59:43 UTC 2021 x86_64
[ 88.609] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=d4178c92-5bc7-410d-b41f-bf56519ff6df rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[ 88.609] Build Date: 13 April 2021 04:11:08PM
[ 88.609]
[ 88.609] Current version of pixman: 0.40.0
[ 88.609] Before reporting problems, check http://wiki.x.org
[ 88.609] Markers: (--) probed, (**) from config file, (==) default setting,
[ 88.610] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Jul 21 20:20:08 2021
[ 88.610] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 88.611] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 88.612] (==) No Layout section. Using the first Screen section.
[ 88.612] (==) No screen section available. Using defaults.
[ 88.612] (**) |-->Screen "Default Screen Section" (0)
[ 88.612] (**) | |-->Monitor "<default monitor>"
[ 88.612] (==) No monitor specified for screen "Default Screen Section".
[ 88.612] (==) Automatically adding devices
[ 88.612] (==) Automatically enabling devices
[ 88.612] (==) Automatically adding GPU devices
[ 88.612] (==) Automatically binding GPU devices
[ 88.612] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 88.612] (WW) The directory "/usr/share/fonts/misc" does not exist.
[ 88.612] Entry deleted from font path.
[ 88.612] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 88.612] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 88.612] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 88.612] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 88.612] (==) FontPath set to:
/usr/share/fonts/TTF
[ 88.612] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 88.612] (II) The server relies on udev to provide the list of input devices.
[ 88.612] (II) Module ABI versions:
[ 88.612] X.Org ANSI C Emulation: 0.4
[ 88.612] X.Org Video Driver: 24.1
[ 88.612] X.Org XInput driver : 24.1
[ 88.612] X.Org Server Extension : 10.0
[ 88.613] (++) using VT number 2
[ 88.617] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_33
[ 88.618] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 88.619] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 10 paused 0
[ 88.622] (--) PCI:*(0@0:2:0) 8086:9b41:17aa:5079 rev 2, Mem @ 0xb0000000/16777216, 0xa0000000/268435456, I/O @ 0x00003000/64, BIOS @ 0x????????/131072
[ 88.623] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 88.623] (II) LoadModule: "glx"
[ 88.623] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 88.625] (II) Module glx: vendor="X.Org Foundation"
[ 88.625] compiled for 1.20.11, module version = 1.0.0
[ 88.625] ABI class: X.Org Server Extension, version 10.0
[ 88.625] (==) Matched intel as autoconfigured driver 0
[ 88.625] (==) Matched modesetting as autoconfigured driver 1
[ 88.625] (==) Matched fbdev as autoconfigured driver 2
[ 88.625] (==) Matched vesa as autoconfigured driver 3
[ 88.625] (==) Assigned the driver to the xf86ConfigLayout
[ 88.625] (II) LoadModule: "intel"
[ 88.625] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 88.627] (II) Module intel: vendor="X.Org Foundation"
[ 88.627] compiled for 1.20.10, module version = 2.99.917
[ 88.627] Module class: X.Org Video Driver
[ 88.627] ABI class: X.Org Video Driver, version 24.1
[ 88.627] (II) LoadModule: "modesetting"
[ 88.627] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 88.627] (II) Module modesetting: vendor="X.Org Foundation"
[ 88.627] compiled for 1.20.11, module version = 1.20.11
[ 88.627] (II) LoadModule: "fbdev"
[ 88.628] (WW) Warning, couldn't open module fbdev
[ 88.628] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 88.628] (II) LoadModule: "vesa"
[ 88.628] (WW) Warning, couldn't open module vesa
[ 88.628] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 88.628] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 88.628] (II) intel: Driver for Intel(R) HD Graphics
[ 88.628] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 88.628] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 88.628] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 88.628] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20200917
[ 88.628] (II) intel(0): SNA compiled from 2.99.917-916-g31486f40
[ 88.643] (WW) Falling back to old probe method for modesetting
[ 88.643] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics
[ 88.643] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 4 threads
[ 88.643] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 88.643] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 88.643] (==) intel(0): RGB weight 888
[ 88.643] (==) intel(0): Default visual is TrueColor
[ 88.644] (II) intel(0): Output eDP1 has no monitor section
[ 88.644] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 88.644] (II) intel(0): Enabled output eDP1
[ 88.644] (II) intel(0): Output DP1 has no monitor section
[ 88.644] (II) intel(0): Enabled output DP1
[ 88.644] (II) intel(0): Output HDMI1 has no monitor section
[ 88.644] (II) intel(0): Enabled output HDMI1
[ 88.644] (II) intel(0): Output HDMI2 has no monitor section
[ 88.644] (II) intel(0): Enabled output HDMI2
[ 88.644] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 88.644] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 88.644] (II) intel(0): Enabled output VIRTUAL1
[ 88.644] (--) intel(0): Output eDP1 using initial mode 1920x1080 on pipe 0
[ 88.644] (==) intel(0): TearFree enabled
[ 88.644] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 88.644] (==) intel(0): DPI set to (96, 96)
[ 88.644] (II) Loading sub module "dri3"
[ 88.644] (II) LoadModule: "dri3"
[ 88.644] (II) Module "dri3" already built-in
[ 88.644] (II) Loading sub module "dri2"
[ 88.644] (II) LoadModule: "dri2"
[ 88.644] (II) Module "dri2" already built-in
[ 88.645] (II) Loading sub module "present"
[ 88.645] (II) LoadModule: "present"
[ 88.645] (II) Module "present" already built-in
[ 88.645] (II) UnloadModule: "modesetting"
[ 88.645] (II) Unloading modesetting
[ 88.646] (II) intel(0): SNA initialized with Coffeelake (gen9) backend
[ 88.646] (==) intel(0): Backing store enabled
[ 88.646] (==) intel(0): Silken mouse disabled
[ 88.646] (II) intel(0): HW Cursor enabled
[ 88.646] (==) intel(0): DPMS enabled
[ 88.646] (==) intel(0): Display hotplug detection enabled
[ 88.647] (II) intel(0): [DRI2] Setup complete
[ 88.647] (II) intel(0): [DRI2] DRI driver: i965
[ 88.647] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 88.647] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 88.647] (II) intel(0): hardware support for Present enabled
[ 88.647] (II) Initializing extension Generic Event Extension
[ 88.647] (II) Initializing extension SHAPE
[ 88.647] (II) Initializing extension MIT-SHM
[ 88.647] (II) Initializing extension XInputExtension
[ 88.647] (II) Initializing extension XTEST
[ 88.647] (II) Initializing extension BIG-REQUESTS
[ 88.647] (II) Initializing extension SYNC
[ 88.647] (II) Initializing extension XKEYBOARD
[ 88.647] (II) Initializing extension XC-MISC
[ 88.647] (II) Initializing extension SECURITY
[ 88.647] (II) Initializing extension XFIXES
[ 88.647] (II) Initializing extension RENDER
[ 88.647] (II) Initializing extension RANDR
[ 88.647] (II) Initializing extension COMPOSITE
[ 88.647] (II) Initializing extension DAMAGE
[ 88.647] (II) Initializing extension MIT-SCREEN-SAVER
[ 88.647] (II) Initializing extension DOUBLE-BUFFER
[ 88.647] (II) Initializing extension RECORD
[ 88.647] (II) Initializing extension DPMS
[ 88.647] (II) Initializing extension Present
[ 88.647] (II) Initializing extension DRI3
[ 88.647] (II) Initializing extension X-Resource
[ 88.647] (II) Initializing extension XVideo
[ 88.647] (II) Initializing extension XVideo-MotionCompensation
[ 88.647] (II) Initializing extension GLX
[ 88.672] (II) AIGLX: Loaded and initialized i965
[ 88.672] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 88.672] (II) Initializing extension XFree86-VidModeExtension
[ 88.672] (II) Initializing extension XFree86-DGA
[ 88.672] (II) Initializing extension XFree86-DRI
[ 88.672] (II) Initializing extension DRI2
[ 88.677] (II) intel(0): switch to mode 1920x1080@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 88.681] (II) intel(0): Setting screen physical size to 508 x 285
[ 88.726] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 88.726] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 88.726] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 88.726] (**) Power Button: Applying InputClass "system-keyboard"
[ 88.726] (II) LoadModule: "libinput"
[ 88.726] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 88.728] (II) Module libinput: vendor="X.Org Foundation"
[ 88.728] compiled for 1.20.11, module version = 1.1.0
[ 88.728] Module class: X.Org XInput Driver
[ 88.728] ABI class: X.Org XInput driver, version 24.1
[ 88.728] (II) Using input driver 'libinput' for 'Power Button'
[ 88.729] (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 19 paused 0
[ 88.729] (**) Power Button: always reports core events
[ 88.729] (**) Option "Device" "/dev/input/event2"
[ 88.729] (**) Option "_source" "server/udev"
[ 88.731] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 88.731] (II) event2 - Power Button: device is a keyboard
[ 88.731] (II) event2 - Power Button: device removed
[ 88.731] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 88.731] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 88.731] (**) Option "xkb_layout" "ch"
[ 88.731] (**) Option "xkb_variant" "fr"
[ 88.749] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 88.749] (II) event2 - Power Button: device is a keyboard
[ 88.749] (II) config/udev: Adding input device Video Bus (/dev/input/event9)
[ 88.749] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 88.749] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 88.749] (**) Video Bus: Applying InputClass "system-keyboard"
[ 88.749] (II) Using input driver 'libinput' for 'Video Bus'
[ 88.750] (II) systemd-logind: got fd for /dev/input/event9 13:73 fd 22 paused 0
[ 88.750] (**) Video Bus: always reports core events
[ 88.750] (**) Option "Device" "/dev/input/event9"
[ 88.750] (**) Option "_source" "server/udev"
[ 88.750] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 88.750] (II) event9 - Video Bus: device is a keyboard
[ 88.750] (II) event9 - Video Bus: device removed
[ 88.750] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input10/event9"
[ 88.750] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 88.750] (**) Option "xkb_layout" "ch"
[ 88.750] (**) Option "xkb_variant" "fr"
[ 88.751] (II) event9 - Video Bus: is tagged by udev as: Keyboard
[ 88.751] (II) event9 - Video Bus: device is a keyboard
[ 88.751] (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
[ 88.751] (II) No input driver specified, ignoring this device.
[ 88.751] (II) This device may have been added with another device file.
[ 88.752] (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
[ 88.752] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 88.752] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 88.752] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 88.752] (II) Using input driver 'libinput' for 'Sleep Button'
[ 88.752] (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 23 paused 0
[ 88.752] (**) Sleep Button: always reports core events
[ 88.752] (**) Option "Device" "/dev/input/event0"
[ 88.752] (**) Option "_source" "server/udev"
[ 88.753] (II) event0 - Sleep Button: is tagged by udev as: Keyboard
[ 88.753] (II) event0 - Sleep Button: device is a keyboard
[ 88.753] (II) event0 - Sleep Button: device removed
[ 88.753] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
[ 88.753] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 8)
[ 88.753] (**) Option "xkb_layout" "ch"
[ 88.753] (**) Option "xkb_variant" "fr"
[ 88.754] (II) config/udev: Adding input device Integrated Camera: Integrated C (/dev/input/event7)
[ 88.754] (**) Integrated Camera: Integrated C: Applying InputClass "evdev keyboard catchall"
[ 88.754] (**) Integrated Camera: Integrated C: Applying InputClass "libinput keyboard catchall"
[ 88.754] (**) Integrated Camera: Integrated C: Applying InputClass "system-keyboard"
[ 88.754] (II) Using input driver 'libinput' for 'Integrated Camera: Integrated C'
[ 88.754] (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 24 paused 0
[ 88.754] (**) Integrated Camera: Integrated C: always reports core events
[ 88.754] (**) Option "Device" "/dev/input/event7"
[ 88.754] (**) Option "_source" "server/udev"
[ 88.755] (II) event7 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 88.755] (II) event7 - Integrated Camera: Integrated C: device is a keyboard
[ 88.755] (II) event7 - Integrated Camera: Integrated C: device removed
[ 88.755] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-8/1-8:1.0/input/input9/event7"
[ 88.755] (II) XINPUT: Adding extended input device "Integrated Camera: Integrated C" (type: KEYBOARD, id 9)
[ 88.755] (**) Option "xkb_layout" "ch"
[ 88.755] (**) Option "xkb_variant" "fr"
[ 88.756] (II) event7 - Integrated Camera: Integrated C: is tagged by udev as: Keyboard
[ 88.756] (II) event7 - Integrated Camera: Integrated C: device is a keyboard
[ 88.756] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event10)
[ 88.756] (II) No input driver specified, ignoring this device.
[ 88.756] (II) This device may have been added with another device file.
[ 88.756] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[ 88.757] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event12)
[ 88.757] (II) No input driver specified, ignoring this device.
[ 88.757] (II) This device may have been added with another device file.
[ 88.757] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event13)
[ 88.757] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event14)
[ 88.757] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event15)
[ 88.758] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event16)
[ 88.758] (II) No input driver specified, ignoring this device.
[ 88.758] (II) This device may have been added with another device file.
[ 88.758] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 88.758] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 88.758] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 88.758] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 88.758] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 88.758] (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 25 paused 0
[ 88.758] (**) AT Translated Set 2 keyboard: always reports core events
[ 88.758] (**) Option "Device" "/dev/input/event3"
[ 88.758] (**) Option "_source" "server/udev"
[ 88.759] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 88.759] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 88.759] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 88.759] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 88.759] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 10)
[ 88.759] (**) Option "xkb_layout" "ch"
[ 88.759] (**) Option "xkb_variant" "fr"
[ 88.760] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 88.760] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 88.760] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event6)
[ 88.760] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 88.760] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 88.760] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 88.761] (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 26 paused 0
[ 88.761] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 88.761] (**) Option "Device" "/dev/input/event6"
[ 88.761] (**) Option "_source" "server/udev"
[ 88.761] (II) event6 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 88.761] (II) event6 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 88.762] (II) event6 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 88.762] (II) event6 - SynPS/2 Synaptics TouchPad: device removed
[ 88.762] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event6"
[ 88.763] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 11)
[ 88.763] (**) Option "AccelerationScheme" "none"
[ 88.763] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 88.763] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 88.763] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 88.764] (II) event6 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 88.764] (II) event6 - SynPS/2 Synaptics TouchPad: no resolution or size hints, assuming a size of 69x50mm
[ 88.765] (II) event6 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 88.765] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 88.765] (II) No input driver specified, ignoring this device.
[ 88.765] (II) This device may have been added with another device file.
[ 88.765] (II) config/udev: Adding input device TPPS/2 Elan TrackPoint (/dev/input/event8)
[ 88.766] (**) TPPS/2 Elan TrackPoint: Applying InputClass "evdev pointer catchall"
[ 88.766] (**) TPPS/2 Elan TrackPoint: Applying InputClass "libinput pointer catchall"
[ 88.766] (II) Using input driver 'libinput' for 'TPPS/2 Elan TrackPoint'
[ 88.766] (II) systemd-logind: got fd for /dev/input/event8 13:72 fd 27 paused 0
[ 88.766] (**) TPPS/2 Elan TrackPoint: always reports core events
[ 88.766] (**) Option "Device" "/dev/input/event8"
[ 88.766] (**) Option "_source" "server/udev"
[ 88.766] (II) event8 - TPPS/2 Elan TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 88.767] (II) event8 - TPPS/2 Elan TrackPoint: device is a pointer
[ 88.767] (II) event8 - TPPS/2 Elan TrackPoint: device removed
[ 88.767] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/serio2/input/input8/event8"
[ 88.767] (II) XINPUT: Adding extended input device "TPPS/2 Elan TrackPoint" (type: MOUSE, id 12)
[ 88.767] (**) Option "AccelerationScheme" "none"
[ 88.767] (**) TPPS/2 Elan TrackPoint: (accel) selected scheme none/0
[ 88.767] (**) TPPS/2 Elan TrackPoint: (accel) acceleration factor: 2.000
[ 88.767] (**) TPPS/2 Elan TrackPoint: (accel) acceleration threshold: 4
[ 88.768] (II) event8 - TPPS/2 Elan TrackPoint: is tagged by udev as: Mouse Pointingstick
[ 88.768] (II) event8 - TPPS/2 Elan TrackPoint: device is a pointer
[ 88.769] (II) config/udev: Adding input device TPPS/2 Elan TrackPoint (/dev/input/mouse1)
[ 88.769] (II) No input driver specified, ignoring this device.
[ 88.769] (II) This device may have been added with another device file.
[ 88.769] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 88.770] (II) config/udev: Adding input device ThinkPad Extra Buttons (/dev/input/event4)
[ 88.770] (**) ThinkPad Extra Buttons: Applying InputClass "evdev keyboard catchall"
[ 88.770] (**) ThinkPad Extra Buttons: Applying InputClass "libinput keyboard catchall"
[ 88.770] (**) ThinkPad Extra Buttons: Applying InputClass "system-keyboard"
[ 88.770] (II) Using input driver 'libinput' for 'ThinkPad Extra Buttons'
[ 88.771] (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 28 paused 0
[ 88.771] (**) ThinkPad Extra Buttons: always reports core events
[ 88.771] (**) Option "Device" "/dev/input/event4"
[ 88.771] (**) Option "_source" "server/udev"
[ 88.771] (II) event4 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 88.771] (II) event4 - ThinkPad Extra Buttons: device is a keyboard
[ 88.771] (II) event4 - ThinkPad Extra Buttons: device removed
[ 88.771] (**) Option "config_info" "udev:/sys/devices/platform/thinkpad_acpi/input/input5/event4"
[ 88.771] (II) XINPUT: Adding extended input device "ThinkPad Extra Buttons" (type: KEYBOARD, id 13)
[ 88.771] (**) Option "xkb_layout" "ch"
[ 88.771] (**) Option "xkb_variant" "fr"
[ 88.772] (II) event4 - ThinkPad Extra Buttons: is tagged by udev as: Keyboard Switch
[ 88.772] (II) event4 - ThinkPad Extra Buttons: device is a keyboard
[ 89.066] (II) intel(0): EDID vendor "LEN", prod id 16570
[ 89.066] (II) intel(0): Printing DDC gathered Modelines:
[ 89.066] (II) intel(0): Modeline "1920x1080"x0.0 138.70 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (66.7 kHz eP)
[ 89.066] (II) intel(0): Modeline "1920x1080"x0.0 110.96 1920 1968 2000 2080 1080 1083 1088 1111 -hsync -vsync (53.3 kHz e)
[ 106.380] (**) Option "fd" "19"
[ 106.380] (II) event2 - Power Button: device removed
[ 106.380] (**) Option "fd" "22"
[ 106.380] (II) event9 - Video Bus: device removed
[ 106.380] (**) Option "fd" "23"
[ 106.380] (II) event0 - Sleep Button: device removed
[ 106.380] (**) Option "fd" "24"
[ 106.380] (II) event7 - Integrated Camera: Integrated C: device removed
[ 106.380] (**) Option "fd" "25"
[ 106.380] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 106.380] (**) Option "fd" "26"
[ 106.380] (II) event6 - SynPS/2 Synaptic[ 88.607] (WW) Failed to open protocol names file lib/xorg/protocol.txt
[ 88.608]
[ 88.609]
[ 106.380] (II) event6 - SynPS/2 Synaptics TouchPad: device removed
[ 106.380] (**) Option "fd" "27"
[ 106.380] (II) event8 - TPPS/2 Elan TrackPoint: device removed
[ 106.380] (**) Option "fd" "28"
[ 106.380] (II) event4 - ThinkPad Extra Buttons: device removed
[ 106.381] (II) UnloadModule: "libinput"
[ 106.381] (II) systemd-logind: releasing fd for 13:68
[ 106.385] (II) UnloadModule: "libinput"
[ 106.385] (II) systemd-logind: releasing fd for 13:72
[ 106.387] (II) UnloadModule: "libinput"
[ 106.387] (II) systemd-logind: releasing fd for 13:70
[ 106.389] (II) UnloadModule: "libinput"
[ 106.389] (II) systemd-logind: releasing fd for 13:67
[ 106.390] (II) UnloadModule: "libinput"
[ 106.390] (II) systemd-logind: releasing fd for 13:71
[ 106.395] (II) UnloadModule: "libinput"
[ 106.395] (II) systemd-logind: releasing fd for 13:64
[ 106.396] (II) UnloadModule: "libinput"
[ 106.396] (II) systemd-logind: releasing fd for 13:73
[ 106.397] (II) UnloadModule: "libinput"
[ 106.397] (II) systemd-logind: releasing fd for 13:66
[ 106.430] (II) Server terminated successfully (0). Closing log file.
PACMAN Logs:
[2021-07-21T17:48:32+0200] [PAMAC] synchronizing package lists
[2021-07-21T17:48:50+0200] [ALPM] transaction started
[2021-07-21T17:48:50+0200] [ALPM] upgraded archlinux-keyring (20210110-1 -> 20210616-1)
[2021-07-21T17:48:50+0200] [ALPM-SCRIPTLET] ==> Ajout des clés depuis archlinux.gpg…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] ==> Signature locale des clés de confiance dans le trousseau de clés…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé AB19265E5D7D20687D303246BA1DFB64FFF979E7…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé DDB867B92AA789C165EEFA799B729B06A680C281…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 2AC0A42EFB0B5CBC7A0402ED4DC95B6D7BE9892E…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 0E8B644079F599DFC1DDC3973348882F6AC6A4C2…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé D8AFDDA07A5B6EDFA7D8CCDAD6D055F927843F1C…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 91FFE0700E80619CEB73235CA88E23E377514E00…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] ==> Importation des valeurs des propriétaires de confiance…
[2021-07-21T17:48:52+0200] [ALPM-SCRIPTLET] gpg: setting ownertrust to 4
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] ==> Désactivation des clés révoquées du trousseau de clés…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 4A8B17E20B88ACA61860009B5CED81B7C2E5C0D2…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 684148BB25B49E986A4944C55184252D824B18E8…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 5357F3B111688D88C1D88119FCF2CB179205AC90…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 50F33E2E5B0C3D900424ABE89BDCF497A4BBCC7F…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 39F880E50E49A4D11341E8F939E4F17F295AFBF4…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé F5A361A3A13554B85E57DDDAAF7EF7873CFD4BB6…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 40440DC037C05620984379A6761FAD69BA06C6A9…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé FB871F0131FEA4FB5A9192B4C8880A6406361833…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 487EACC08557AD082088DABA1EB2638FF56C0C53…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 76B4192E902C0A52642C63C273B8ED52F1D357C1…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 40776A5221EF5AD468A4906D42A1DB15EC133BAD…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 0B20CA1931F5DA3A70D0F8D2EA6836E1AB441196…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 07DFD3A0BC213FA12EDC217559B3122E2FA915EC…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 34C5D94FE7E7913E86DC427E7FB1A3800C84C0A5…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé B1F2C889CB2CCB2ADA36D963097D629E437520BD…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé D4DE5ABDE2A7287644EAC7E36D1A9E70E19DAA50…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 44D4A033AC140143927397D47EFD567D4C7EA887…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 8F76BEEA0289F9E1D3E229C05F946DED983D4366…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 27FFC4769E19F096D41D9265A04F9397CDFD6BB0…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 4FCF887689C41B09506BE8D5F3E1D5C5D30DB0AD…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 5A2257D19FF7E1E0E415968CE62F853100F0D0F0…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 7FA647CD89891DEDC060287BB9113D1ED21E1A55…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 5E7585ADFF106BFFBBA319DC654B877A0864983E…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé E7210A59715F6940CF9A4E36A001876699AD6E84…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 5559BC1A32B8F76B3FCCD9555FA5E5544F010D48…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé F3691687D867B81B51CE07D9BBE43771487328A9…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé BFA1ECFEF1524EE4099CDE971F0CD4921ECAA030…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 4D913AECD81726D9A6C74F0ADA6426DD215B37AD…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 8840BD07FC24CB7CE394A07CCF7037A4F27FB7DA…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé BC1FBE4D2826A0B51E47ED62E2539214C6C11350…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 9515D8A8EAB88E49BB65EDBCE6B456CAF15447D5…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 779CD2942629B7FA04AB8F172E89012331361F01…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé D921CABED130A5690EF1896E81AF739EC0711BF1…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 5696C003B0854206450C8E5BE613C09CB4440678…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 8CF934E339CAD8ABF342E822E711306E3C4F88BC…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 1A60DC44245D06FEF90623D6EEEEE2EEEE2EEEEE…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé A5CA9D5515DC2CA73DF748CA5C2E46A0F53A76ED…
[2021-07-21T17:48:53+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 81D7F8241DB38BC759C80FCE3A726C6170E80477…
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 63F395DE2D6398BBE458F281F2DBB4931985A992…
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 65EEFE022108E2B708CBFCF7F9E712E59AF5F22A…
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 66BD74A036D522F51DD70A3C7F2A16726521E06D…
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] ==> Mise à jour de la base de données de confiance…
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] gpg: la prochaine vérification de la base de confiance aura lieu le 2021-08-02
[2021-07-21T17:48:54+0200] [ALPM] upgraded manjaro-keyring (20201216-1 -> 20210622-1)
[2021-07-21T17:48:54+0200] [ALPM-SCRIPTLET] ==> Ajout des clés depuis manjaro.gpg…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] ==> Signature locale des clés de confiance dans le trousseau de clés…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 7C89F4D439B2BFACF425107B62443D89B35859F8…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 16DC688DF3EECC72323954237EC47C82A42D53A2…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 688E8F82879D0E25CE541426150C200743ED46D8…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 04BB537F5BC2D399BFA72F8F17C752B61B2F2E90…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 5A97ED6B72418199F0C22B23137C934B5DCB998E…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 76C6E477042BFE985CC220BD9C08A255442FAFF0…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 2D14560CDCE6A75BB186DB758238651DDF5E0594…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 74C2F2CC05A0AB7D859839938934292D604F8BA2…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 7A443CEE69B6B3777740E258084A7FC0035B1D49…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 2C688B52E3FC0144B7484BABE3B3F44AC45EE0AA…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 0037505D6C3F595C37F5626AFD847358FF20E35C…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 1E7908935AAB9A00D6B47503363DFFFD59152F77…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 39F0EC1AE50B37E5F3196F09DAD3B211663CA268…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé F66AD0FF0E57C561615A0901CEE477135C5872B0…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 77DC01C9971AC3C39A0626F72C089F09AC97B894…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 22C903DE964E6FE321656E318DB9F8C18DF53602…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé B4663188A692DB1E45A98EE95BD96CC4247B52CC…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 75C1B95A4D9514A57EB2DAE71817DC63CD3B5DF5…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé E4CDFE50A2DA85D58C8A8C70CAA6A59611C7F07E…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Signature locale de la clé 3B794DE6D4320FCE594F4171279E7CF5D8D56EC8…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] ==> Importation des valeurs des propriétaires de confiance…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] ==> Désactivation des clés révoquées du trousseau de clés…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 540DE7083B89314CF70EA6F0C1B1AD0DA80EBF3E…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé 35B4FF23EA9477582C2A0AF12B80869C5C0102A6…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] -> Désactivation de la clé FAA6840E8C3FC7F89BEE0DC8AC7AB10BCB6CDD17…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] ==> Mise à jour de la base de données de confiance…
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: marginals needed: 3 completes needed: 1 trust model: pgp
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: profondeur : 0 valables : 1 signées : 26
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] confiance : 0 i., 0 n.d., 0 j., 0 m., 0 t., 1 u.
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: profondeur : 1 valables : 26 signées : 82
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] confiance : 0 i., 0 n.d., 0 j., 26 m., 0 t., 0 u.
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: profondeur : 2 valables : 76 signées : 25
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] confiance : 76 i., 0 n.d., 0 j., 0 m., 0 t., 0 u.
[2021-07-21T17:48:55+0200] [ALPM-SCRIPTLET] gpg: la prochaine vérification de la base de confiance aura lieu le 2021-08-02
[2021-07-21T17:48:55+0200] [ALPM] transaction completed
[2021-07-21T17:48:55+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T17:57:21+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-07-21T17:57:21+0200] [ALPM] running 'kernel-alive-pre.hook'...
[2021-07-21T17:57:21+0200] [ALPM] transaction started
[2021-07-21T17:57:21+0200] [ALPM] removed pamac-snap-plugin (10.0.6-2)
[2021-07-21T17:57:21+0200] [ALPM] removed pamac-flatpak-plugin (10.0.6-2)
[2021-07-21T17:57:21+0200] [ALPM] removed pamac-common (10.0.6-2)
[2021-07-21T17:57:22+0200] [ALPM] removed adobe-source-sans-pro-fonts (3.028-1)
[2021-07-21T17:57:22+0200] [ALPM] installed adobe-source-sans-fonts (3.042-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded adwaita-maia (20210426-1 -> 20210426-2)
[2021-07-21T17:57:22+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.30-1 -> 1:0.3.31-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded alsa-topology-conf (1.2.5-1 -> 1.2.5.1-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded alsa-ucm-conf (1.2.5-1 -> 1.2.5.1-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded iana-etc (20210202-1 -> 20210624-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded alsa-lib (1.2.5-2 -> 1.2.5.1-3)
[2021-07-21T17:57:22+0200] [ALPM] upgraded hwids (20201207-1 -> 20210613-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded alsa-utils (1.2.5-3 -> 1.2.5.1-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded aom (3.1.0-1 -> 3.1.1-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded libldap (2.4.58-3 -> 2.4.59-1)
[2021-07-21T17:57:22+0200] [ALPM] installed nodejs-nopt (5.0.0-2)
[2021-07-21T17:57:22+0200] [ALPM] upgraded gdbm (1.19-2 -> 1.20-1)
[2021-07-21T17:57:22+0200] [ALPM] upgraded libxcrypt (4.4.22-4 -> 4.4.23-1)
[2021-07-21T17:57:23+0200] [ALPM] upgraded python (3.9.5-3 -> 3.9.6-1)
[2021-07-21T17:57:23+0200] [ALPM] upgraded node-gyp (8.1.0-1 -> 8.1.0-2)
[2021-07-21T17:57:23+0200] [ALPM] upgraded npm (7.16.0-1 -> 7.17.0-1)
[2021-07-21T17:57:23+0200] [ALPM] upgraded pcre (8.44-1 -> 8.45-1)
[2021-07-21T17:57:23+0200] [ALPM] upgraded glib2 (2.68.2-1 -> 2.68.3-1)
[2021-07-21T17:57:24+0200] [ALPM] upgraded apm (2.6.1-4 -> 2.6.4-1)
[2021-07-21T17:57:24+0200] [ALPM] upgraded harfbuzz (2.8.1-1 -> 2.8.2-1)
[2021-07-21T17:57:24+0200] [ALPM] upgraded fontconfig (2:2.13.93-4 -> 2:2.13.94-1)
[2021-07-21T17:57:24+0200] [ALPM-SCRIPTLET] Rebuilding fontconfig cache...
[2021-07-21T17:57:26+0200] [ALPM] upgraded pango (1:1.48.5-1 -> 1:1.48.7-1)
[2021-07-21T17:57:26+0200] [ALPM] upgraded libdrm (2.4.106-1 -> 2.4.107-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded llvm-libs (12.0.0-1 -> 12.0.1-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded vulkan-icd-loader (1.2.176-1 -> 1.2.182-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded libp11-kit (0.23.22-1 -> 0.24.0-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded audit (3.0.1-1 -> 3.0.2-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded libcap (2.50-1 -> 2.51-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded p11-kit (0.23.22-1 -> 0.24.0-1)
[2021-07-21T17:57:27+0200] [ALPM-SCRIPTLET] > /etc/ca-certificates/trust-source/blacklist has been renamed to
[2021-07-21T17:57:27+0200] [ALPM-SCRIPTLET] /etc/ca-certificates/trust-source/blocklist
[2021-07-21T17:57:27+0200] [ALPM] upgraded ca-certificates-utils (20210529-1 -> 20210603-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded ca-certificates-mozilla (3.66-1 -> 3.67-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded ca-certificates (20210529-1 -> 20210603-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded mesa (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded libpcap (1.10.0-1 -> 1.10.1-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded libcanberra (0.30+2+gc0620e4-4 -> 0.30+2+gc0620e4-5)
[2021-07-21T17:57:27+0200] [ALPM] upgraded at-spi2-core (2.40.2-1 -> 2.40.3-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded gnutls (3.7.2-1 -> 3.7.2-2)
[2021-07-21T17:57:27+0200] [ALPM] upgraded xkeyboard-config (2.32-1 -> 2.33-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded sqlite (3.35.5-1 -> 3.36.0-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded gtk3 (1:3.24.29-2 -> 1:3.24.30-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded libksba (1.4.0-2 -> 1.6.0-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded gnupg (2.2.27-1 -> 2.2.29-0.1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded gpgme (1.15.1-1 -> 1.16.0-1)
[2021-07-21T17:57:27+0200] [ALPM] upgraded python-urllib3 (1.26.5-1 -> 1.26.6-1)
[2021-07-21T17:57:27+0200] [ALPM] warning: /etc/pacman.conf installed as /etc/pacman.conf.pacnew
[2021-07-21T17:57:28+0200] [ALPM] upgraded pacman (5.2.2-6 -> 6.0.0-1)
[2021-07-21T17:57:28+0200] [ALPM] upgraded appstream-glib (0.7.18-2 -> 0.7.18-3)
[2021-07-21T17:57:28+0200] [ALPM] upgraded archlinux-appstream-data (20210423-1 -> 20210612-1)
[2021-07-21T17:57:28+0200] [ALPM] upgraded bind (9.16.16-1 -> 9.16.18-1)
[2021-07-21T17:57:28+0200] [ALPM] upgraded libmfx (21.1.3-2 -> 21.2.3-1)
[2021-07-21T17:57:28+0200] [ALPM] upgraded libva (2.11.0-1 -> 2.12.0-1)
[2021-07-21T17:57:28+0200] [ALPM] upgraded ffmpeg (2:4.4-3 -> 2:4.4-4)
[2021-07-21T17:57:29+0200] [ALPM] upgraded nspr (4.31-1 -> 4.32-1)
[2021-07-21T17:57:29+0200] [ALPM] upgraded nss (3.66-1 -> 3.67-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded electron11 (11.4.8-1 -> 11.4.10-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded bitwarden (1.26.5-1 -> 1.27.1-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded blas (3.9.1-1 -> 3.10.0-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded bluez (5.58-1 -> 5.60-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded bluez-libs (5.58-1 -> 5.60-1)
[2021-07-21T17:57:31+0200] [ALPM] upgraded boost-libs (1.75.0-5 -> 1.76.0-1)
[2021-07-21T17:57:32+0200] [ALPM] upgraded boost (1.75.0-5 -> 1.76.0-1)
[2021-07-21T17:57:32+0200] [ALPM] upgraded glu (9.0.1-2 -> 9.0.2-1)
[2021-07-21T17:57:33+0200] [ALPM] upgraded cgal (4.14.3-1 -> 4.14.3-2)
[2021-07-21T17:57:33+0200] [ALPM] upgraded compiler-rt (12.0.0-1 -> 12.0.1-2)
[2021-07-21T17:57:34+0200] [ALPM] upgraded clang (12.0.0-1 -> 12.0.1-1)
[2021-07-21T17:57:35+0200] [ALPM] upgraded cmake (3.20.3-1 -> 3.20.5-1)
[2021-07-21T17:57:35+0200] [ALPM] upgraded cpupower (5.12-1 -> 5.13-1)
[2021-07-21T17:57:35+0200] [ALPM] upgraded poppler (21.06.1-1 -> 21.07.0-1)
[2021-07-21T17:57:35+0200] [ALPM] upgraded imagemagick (7.0.11.14-1 -> 7.1.0.2-2)
[2021-07-21T17:57:35+0200] [ALPM] upgraded cups-filters (1.28.8-1 -> 1.28.9-1)
[2021-07-21T17:57:35+0200] [ALPM] upgraded dynamic-wallpaper-editor (2.5-1 -> 2.6-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded electron (12.0.9-1 -> 13.1.6-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded enchant (2.2.15-2 -> 2.3.0-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded poppler-glib (21.06.1-1 -> 21.07.0-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded gnome-desktop (1:40.1-2 -> 1:40.2-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded libhandy (1.2.2-1 -> 1.2.3-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded fuse-common (3.10.3-1 -> 3.10.4-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded fuse3 (3.10.3-1 -> 3.10.4-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded gptfdisk (1.0.7-1 -> 1.0.8-1)
[2021-07-21T17:57:36+0200] [ALPM] upgraded xfsprogs (5.11.0-2 -> 5.12.0-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded evince (40.1-2 -> 40.2-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded protobuf (3.16.0-1 -> 3.17.3-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded libphonenumber (8.12.23-1 -> 8.12.25-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded harfbuzz-icu (2.8.1-1 -> 2.8.2-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded libwpe (1.10.0-1 -> 1.10.1-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded wpebackend-fdo (1.9.92-1 -> 1.10.0-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded webkit2gtk (2.32.1-1 -> 2.32.2-1)
[2021-07-21T17:57:37+0200] [ALPM] upgraded evolution-data-server (3.40.2-1 -> 3.40.3-1)
[2021-07-21T17:57:38+0200] [ALPM] upgraded exiv2 (0.27.3-1 -> 0.27.4-2)
[2021-07-21T17:57:38+0200] [ALPM] upgraded expac (10-2 -> 10-3)
[2021-07-21T17:57:38+0200] [ALPM] upgraded faudio (21.06-1 -> 21.07-1)
[2021-07-21T17:57:38+0200] [ALPM] upgraded firefox (89.0.2-0.1 -> 90.0.1-0.1)
[2021-07-21T17:57:38+0200] [ALPM] upgraded firefox-gnome-theme-maia (20210214-1 -> 20210711-1)
[2021-07-21T17:57:38+0200] [ALPM] upgraded pipewire (1:0.3.30-1 -> 1:0.3.31-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded flatpak (1.11.1-2 -> 1.11.2-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded fprintd (1.90.9-1 -> 1.92.0-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded fwupd-efi (1.0-1 -> 1.1-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded fwupd (1.6.0-3 -> 1.6.1-2)
[2021-07-21T17:57:39+0200] [ALPM] upgraded libavif (0.9.0-2 -> 0.9.2-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded gd (2.3.2-2 -> 2.3.2-4)
[2021-07-21T17:57:39+0200] [ALPM] upgraded imath (3.0.4-1 -> 3.0.5-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded openexr (3.0.4-1 -> 3.0.5-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded jasper (2.0.28-1 -> 2.0.32-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded lapack (3.9.1-1 -> 3.10.0-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded gegl (0.4.30-3 -> 0.4.30-4)
[2021-07-21T17:57:39+0200] [ALPM] upgraded geoip-database (20210427-1 -> 20210622-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded netpbm (10.73.33-1 -> 10.73.34-1)
[2021-07-21T17:57:39+0200] [ALPM] upgraded graphviz (2.47.2-1 -> 2.47.3-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gimp (2.10.24-4 -> 2.10.24-5)
[2021-07-21T17:57:41+0200] [ALPM] upgraded glib2-docs (2.68.2-1 -> 2.68.3-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded glslang (11.4.0-1 -> 11.5.0-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded upower (0.99.11-3 -> 0.99.12-2)
[2021-07-21T17:57:41+0200] [ALPM] upgraded libnm (1.30.4-3 -> 1.32.2-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gnome-settings-daemon (3.38.2-1 -> 40.0.1-2)
[2021-07-21T17:57:41+0200] [ALPM] upgraded smbclient (4.14.4-1 -> 4.14.5-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gst-plugins-bad-libs (1.18.4-7 -> 1.18.4-8)
[2021-07-21T17:57:41+0200] [ALPM] upgraded openmpi (4.1.1-1 -> 4.1.1-2)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gst-plugins-bad (1.18.4-7 -> 1.18.4-8)
[2021-07-21T17:57:41+0200] [ALPM] upgraded totem-pl-parser (3.26.5-1 -> 3.26.6-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gnome-control-center (3.38.5-2 -> 40.0-1.2)
[2021-07-21T17:57:41+0200] [ALPM] upgraded gnome-disk-utility (40.1-2 -> 40.2-1)
[2021-07-21T17:57:41+0200] [ALPM] upgraded tracker3 (3.1.1-2 -> 3.1.2-1)
[2021-07-21T17:57:41+0200] [ALPM] installed vulkan-headers (1:1.2.182-1)
[2021-07-21T17:57:42+0200] [ALPM] installed gtk4 (1:4.2.1-2)
[2021-07-21T17:57:42+0200] [ALPM] upgraded xorg-xwayland (21.1.1-1 -> 21.1.2-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded mutter (3.38.4+9+g607803c4b-1 -> 40.3-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded pipewire-media-session (1:0.3.30-1 -> 1:0.3.31-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.30-1 -> 1:0.3.31-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell (1:3.38.4+13+gcf9d73ed5-1 -> 1:40.3-1)
[2021-07-21T17:57:42+0200] [ALPM] installed libpamac (11.0.1-3)
[2021-07-21T17:57:42+0200] [ALPM-SCRIPTLET] ==> An authentication agent is required
[2021-07-21T17:57:42+0200] [ALPM-SCRIPTLET] Cinnamon, Deepin, GNOME, GNOME Flashback, KDE, LXDE, LXQt, MATE and Xfce
[2021-07-21T17:57:42+0200] [ALPM-SCRIPTLET] have an authentication agent already.
[2021-07-21T17:57:42+0200] [ALPM-SCRIPTLET] See https://wiki.archlinux.org/index.php/Polkit#Authentication_agents
[2021-07-21T17:57:42+0200] [ALPM-SCRIPTLET] for other desktop environments.
[2021-07-21T17:57:42+0200] [ALPM] upgraded pamac-cli (10.0.6-2 -> 10.1.3-3)
[2021-07-21T17:57:42+0200] [ALPM] upgraded pamac-gtk (10.0.6-2 -> 10.1.3-3)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-layout-switcher (0.8.17-1 -> 0.8.21-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-maps (40.2-1 -> 40.3-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-appindicator (37-1 -> 40-0)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-arcmenu (11-2 -> 12-2)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-dash-to-dock (69+13+ga081e41-0 -> 69+14+g302c693-6)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-dash-to-panel (42-0 -> 43-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-desktop-icons-ng (0.15.0-1 -> 0.18.0-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-gamemode (4.r7.gac23266-1 -> 5.r0.g3bae4b2-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-gsconnect (45-1 -> 47-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-material-shell (12-3 -> 13-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-nightthemeswitcher (46-1 -> 50-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-pop-shell (1.2.0-2 -> 1.2.0+82+gd59e373-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extension-unite (48-1 -> 54-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-shell-extensions (3.38.2-1 -> 40.3-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded vte-notification-common (0.64.1-1 -> 0.64.2-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded vte3-notification (0.64.1-1 -> 0.64.2-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-terminal-fedora (3.38.1-5 -> 3.40.2-1)
[2021-07-21T17:57:42+0200] [ALPM] installed libadwaita (1.0.0alpha.1-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-todo (3.28.1+34+g1b5336f-1 -> 40.1-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded gnome-tweaks (3.34.1-1 -> 40.0-1)
[2021-07-21T17:57:42+0200] [ALPM] upgraded yelp (40.2-1 -> 40.3-1)
[2021-07-21T17:57:44+0200] [ALPM] upgraded gnome-user-docs (40.1-1 -> 40.3-1)
[2021-07-21T17:57:44+0200] [ALPM] upgraded groff (1.22.4-5 -> 1.22.4-6)
[2021-07-21T17:57:44+0200] [ALPM] upgraded hdparm (9.61-1 -> 9.62-1)
[2021-07-21T17:57:44+0200] [ALPM] upgraded perl-libwww (6.54-2 -> 6.55-1)
[2021-07-21T17:57:44+0200] [ALPM] upgraded hwinfo (21.74-1 -> 21.75-1)
[2021-07-21T17:57:44+0200] [ALPM] upgraded intel-ucode (20210216-1 -> 20210608-1)
[2021-07-21T17:57:45+0200] [ALPM] upgraded iproute2 (5.12.0-1 -> 5.13.0-1)
[2021-07-21T17:57:46+0200] [ALPM] upgraded jre-openjdk-headless (15.0.2.u7-1 -> 16.0.1.u9-1)
[2021-07-21T17:57:46+0200] [ALPM] upgraded jre-openjdk (15.0.2.u7-1 -> 16.0.1.u9-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded qt5-base (5.15.2+kde+r196-1 -> 5.15.2+kde+r210-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded kcoreaddons (5.82.0-1 -> 5.84.0-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded polkit-qt5 (0.113.0-2 -> 0.114.0-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded kauth (5.82.0-1 -> 5.84.0-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded kitemmodels (5.82.0-1 -> 5.84.0-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded kwindowsystem (5.82.0-1 -> 5.84.0-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-alsa-lib (1.2.5-2 -> 1.2.5.1-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-libxcrypt (4.4.22-2 -> 4.4.23-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-libldap (2.4.58-1 -> 2.4.59-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-libcap (2.50-1 -> 2.51-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-libdrm (2.4.106-1 -> 2.4.107-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-llvm-libs (12.0.0-1 -> 12.0.1-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.176-1 -> 1.2.182-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-mesa (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-faudio (21.06-1 -> 21.07-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-glib2 (2.68.2-1 -> 2.68.3-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-harfbuzz (2.8.1-1 -> 2.8.2-1)
[2021-07-21T17:57:47+0200] [ALPM] upgraded lib32-fontconfig (2:2.13.93-4 -> 2:2.13.94-1)
[2021-07-21T17:57:47+0200] [ALPM-SCRIPTLET] Rebuilding 32-bit fontconfig cache...
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-libcanberra (0.30+2+gc0620e4-4 -> 0.30+2+gc0620e4-5)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-libpcap (1.10.0-1 -> 1.10.1-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-libtasn1 (4.16.0-2 -> 4.17.0-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-mesa-vdpau (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-mpg123 (1.28.0-1 -> 1.28.1-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-p11-kit (0.23.22-1 -> 0.24.0-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-pango (1:1.48.5-1 -> 1:1.48.7-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-sqlite (3.35.5-1 -> 3.36.0-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-vulkan-intel (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded lib32-vulkan-radeon (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded libcmis (0.5.2-7 -> 0.5.2-8)
[2021-07-21T17:57:50+0200] [ALPM] upgraded libixion (0.16.1-5 -> 0.16.1-6)
[2021-07-21T17:57:50+0200] [ALPM] upgraded libzen (0.4.38-2 -> 0.4.39-1)
[2021-07-21T17:57:50+0200] [ALPM] installed tinyxml2 (9.0.0-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded libmediainfo (20.09-2 -> 21.03-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded liborcus (0.16.1-6 -> 0.16.1-7)
[2021-07-21T17:57:50+0200] [ALPM] upgraded shaderc (2021.0-1 -> 2021.1-1)
[2021-07-21T17:57:50+0200] [ALPM] upgraded libplacebo (3.120.3-1 -> 3.120.3-2)
[2021-07-21T17:57:54+0200] [ALPM] upgraded libreoffice-still (7.0.6-2 -> 7.0.6-3)
[2021-07-21T17:57:54+0200] [ALPM] upgraded libva-mesa-driver (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:57:58+0200] [ALPM] upgraded linux-firmware (20210518.r1928.f846292-1 -> 20210629.r1978.d79c267-1)
[2021-07-21T17:57:58+0200] [ALPM] upgraded mkinitcpio-busybox (1.32.1-3 -> 1.33.1-1)
[2021-07-21T17:57:59+0200] [ALPM] upgraded linux414 (4.14.235-1 -> 4.14.239-1)
[2021-07-21T17:57:59+0200] [ALPM] upgraded linux414-virtualbox-host-modules (6.1.22-6 -> 6.1.22-11)
[2021-07-21T17:58:03+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-07-21T17:58:04+0200] [ALPM] upgraded linux510 (5.10.42-1 -> 5.10.49-1)
[2021-07-21T17:58:04+0200] [ALPM] upgraded linux510-virtualbox-host-modules (6.1.22-12 -> 6.1.22-20)
[2021-07-21T17:58:09+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-07-21T17:58:09+0200] [ALPM] upgraded python-pillow (8.2.0-2 -> 8.3.1-1)
[2021-07-21T17:58:09+0200] [ALPM] upgraded lollypop (1.4.19-1 -> 1.4.20-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded python-setuptools (1:57.0.0-2 -> 1:57.1.0-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded lutris (0.5.8.3-2 -> 0.5.8.4-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded m4 (1.4.18-3 -> 1.4.19-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded man-db (2.9.4-1 -> 2.9.4-2)
[2021-07-21T17:58:10+0200] [ALPM] upgraded man-pages (5.11-1 -> 5.12-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-application-utility (1.3.3-4.1 -> 1.3.3-5)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-gdm-branding (20201029-1 -> 20210529-2)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-gdm-theme (20210326-1 -> 20210528-1)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-gnome-extension-settings (20210403-1 -> 20210530-2)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-gnome-settings (20210403-2 -> 20210530-2)
[2021-07-21T17:58:10+0200] [ALPM] upgraded manjaro-release (21.0.7-1 -> 21.1.0rc1-2)
[2021-07-21T17:58:10+0200] [ALPM] upgraded mariadb-libs (10.5.10-1 -> 10.5.11-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded matcha-gtk-theme (20210708-0.1 -> 20210720-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded mediainfo (20.09-1 -> 21.03-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded memtest86+ (5.01-4 -> 5.31b-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded mesa-vdpau (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded mhwd-nvidia (465.31-1 -> 470.42.01-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded mujs (1.1.2-1 -> 1.1.3-1)
[2021-07-21T17:58:11+0200] [ALPM] warning: /etc/nanorc installed as /etc/nanorc.pacnew
[2021-07-21T17:58:11+0200] [ALPM] upgraded nano (5.7-1 -> 5.8-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded ncdu (1.15.1-2 -> 1.16-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded networkmanager (1.30.4-3 -> 1.32.2-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded nfsidmap (2.5.3-1 -> 2.5.4-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded nfs-utils (2.5.3-1 -> 2.5.4-1)
[2021-07-21T17:58:11+0200] [ALPM] upgraded nlopt (2.7.0-1 -> 2.7.0-2)
[2021-07-21T17:58:20+0200] [ALPM] upgraded onlyoffice-desktopeditors (6.2.0-1 -> 6.3.1-1)
[2021-07-21T17:58:20+0200] [ALPM] upgraded openvdb (8.0.1-4 -> 8.1.0-1)
[2021-07-21T17:58:20+0200] [ALPM] upgraded openvpn (2.5.2-1 -> 2.5.3-1)
[2021-07-21T17:58:20+0200] [ALPM] installed libpamac-flatpak-plugin (11.0.1-2)
[2021-07-21T17:58:21+0200] [ALPM] upgraded pamac-gnome-integration (10.0.6-2 -> 10.1.3-3)
[2021-07-21T17:58:21+0200] [ALPM] upgraded snapd (2.51-1 -> 2.51.1-1)
[2021-07-21T17:58:21+0200] [ALPM] installed libpamac-snap-plugin (11.0.1-2)
[2021-07-21T17:58:26+0200] [ALPM] upgraded papirus-icon-theme (20210601-1 -> 20210701-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded perl-alien-build (2.40-3 -> 2.41-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded pulseaudio-ctl (1.67-1 -> 1.70-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded python-cffi (1.14.5-1 -> 1.14.6-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded python-docutils (0.16-4 -> 0.17.1-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded python-fasteners (0.15-5 -> 0.16-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded python-protobuf (3.16.0-1 -> 3.17.3-1)
[2021-07-21T17:58:26+0200] [ALPM] upgraded python-google-api-core (1.28.0-1 -> 1.30.0-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-google-api-python-client (2.5.0-1 -> 2.10.0-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-gpgme (1.15.1-1 -> 1.16.0-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-resolvelib (0.5.4-1 -> 0.5.5-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-pip (20.3.1-1 -> 20.3.4-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-reportlab (3.5.67-1 -> 3.5.68-2)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-sphinx (4.0.2-1 -> 4.1.0-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded python-xlib (0.30-1 -> 0.31-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded qt5-declarative (5.15.2+kde+r28-1 -> 5.15.2+kde+r29-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded qt5-wayland (5.15.2+kde+r23-1 -> 5.15.2+kde+r28-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded qgnomeplatform (0.7.1-1 -> 0.8.0-1)
[2021-07-21T17:58:27+0200] [ALPM] upgraded qt5-tools (5.15.2+kde+r17-2 -> 5.15.2+kde+r17-3)
[2021-07-21T17:58:27+0200] [ALPM] upgraded qt5-webengine (5.15.4-3 -> 5.15.5-1)
[2021-07-21T17:58:28+0200] [ALPM] upgraded ripgrep (12.1.1-1 -> 13.0.0-2)
[2021-07-21T17:58:31+0200] [ALPM] upgraded rust (1:1.52.1-3 -> 1:1.53.0-2)
[2021-07-21T17:58:32+0200] [ALPM] upgraded sof-firmware (1.7-2 -> 1.8-1)
[2021-07-21T17:58:32+0200] [ALPM] upgraded sudo (1.9.7-1 -> 1.9.7.p1-1)
[2021-07-21T17:58:32+0200] [ALPM] upgraded texinfo (6.7-3 -> 6.8-1)
[2021-07-21T17:58:32+0200] [ALPM] upgraded tor (0.4.5.8-2 -> 0.4.6.6-1)
[2021-07-21T17:58:32+0200] [ALPM] upgraded torbrowser-launcher (0.3.3-2 -> 0.3.4-2)
[2021-07-21T17:58:33+0200] [ALPM] upgraded totem (3.38.0-1 -> 3.38.1-1)
[2021-07-21T17:58:33+0200] [ALPM] upgraded tracker3-miners (3.1.1-2 -> 3.1.2-1)
[2021-07-21T17:58:33+0200] [ALPM] upgraded umockdev (0.15.5-1 -> 0.16.0-1)
[2021-07-21T17:58:33+0200] [ALPM] upgraded unrar (1:6.0.6-1 -> 1:6.0.7-1)
[2021-07-21T17:58:33+0200] [ALPM] upgraded virtualbox (6.1.22-2 -> 6.1.22-3)
[2021-07-21T17:58:34+0200] [ALPM] upgraded vlc (3.0.14-1 -> 3.0.16-2)
[2021-07-21T17:58:34+0200] [ALPM] upgraded vulkan-intel (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:58:34+0200] [ALPM] upgraded vulkan-radeon (21.1.2-1 -> 21.1.4-1)
[2021-07-21T17:58:34+0200] [ALPM] upgraded xapp (2.0.7-1 -> 2.2.2-1)
[2021-07-21T17:58:34+0200] [ALPM] upgraded webapp-manager (1.1.1.r8.ga0d9181-1 -> 1.1.5-1)
[2021-07-21T17:58:36+0200] [ALPM] upgraded wine-staging (6.10-1 -> 6.12.1-1)
[2021-07-21T17:58:36+0200] [ALPM] upgraded wireless-regdb (2020.11.20-1 -> 2021.04.21-1)
[2021-07-21T17:58:36+0200] [ALPM] upgraded xf86-input-libinput (1.0.1-1 -> 1.1.0-1)
[2021-07-21T17:58:36+0200] [ALPM] upgraded zsh-theme-powerlevel10k (1.14.6-1 -> 1.15.0-2)
[2021-07-21T17:58:38+0200] [ALPM] transaction completed
[2021-07-21T17:58:44+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '30-systemd-binfmt.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T17:58:44+0200] [ALPM] running '40-update-ca-trust.hook'...
[2021-07-21T17:58:45+0200] [ALPM] running '60-depmod.hook'...
[2021-07-21T17:58:56+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'default'
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64.img
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.14.239-1-MANJARO
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T17:58:56+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T17:58:57+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T17:58:57+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T17:58:57+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64.img
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux414.preset: 'fallback'
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-4.14-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-4.14-x86_64-fallback.img -S autodetect
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] ==> Starting build: 4.14.239-1-MANJARO
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T17:58:58+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T17:59:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T17:59:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T17:59:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T17:59:00+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T17:59:01+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T17:59:02+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T17:59:02+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.49-1-MANJARO
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T17:59:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T17:59:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T17:59:08+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T17:59:08+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.49-1-MANJARO
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T17:59:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T17:59:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T17:59:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T17:59:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T17:59:12+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T17:59:13+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T17:59:14+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T17:59:14+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T17:59:19+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T17:59:19+0200] [ALPM] running '99-grub.hook'...
[2021-07-21T17:59:20+0200] [ALPM-SCRIPTLET] Création du fichier de configuration GRUB…
[2021-07-21T17:59:21+0200] [ALPM-SCRIPTLET] Thème trouvé : /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-21T17:59:21+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.10-x86_64
[2021-07-21T17:59:21+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-4.14-x86_64
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.10-x86_64
[2021-07-21T17:59:22+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-4.14-x86_64
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Attention : le sondeur de systèmes d'exploitation sera exécuté pour détecter d'autres partitions amorçables.
[2021-07-21T17:59:23+0200] [ALPM-SCRIPTLET] Sa sortie sera utilisée pour détecter les binaires amorçables qu'elles contiennent et créer de nouvelles entrées d'amorçage.
[2021-07-21T17:59:24+0200] [ALPM-SCRIPTLET] Windows Boot Manager trouvé sur /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-21T17:59:25+0200] [ALPM-SCRIPTLET] Ajout de l'entrée du menu d'amorçage pour les paramètres du firmware UEFI …
[2021-07-21T17:59:25+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-21T17:59:25+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe : attention : type de périphérique nvme0n1 inconnu.
[2021-07-21T17:59:25+0200] [ALPM-SCRIPTLET] fait
[2021-07-21T17:59:25+0200] [ALPM] running 'dbus-reload.hook'...
[2021-07-21T17:59:25+0200] [ALPM] running 'dconf-update.hook'...
[2021-07-21T17:59:25+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-07-21T17:59:25+0200] [ALPM] running 'fontconfig.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'fontconfig-32.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'gdm-theme-backup.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'gdm-theme-maia-install.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'gtk-query-immodules-3.0.hook'...
[2021-07-21T17:59:26+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-21T17:59:30+0200] [ALPM] running 'gtk4-querymodules.hook'...
[2021-07-21T17:59:30+0200] [ALPM] running 'kernel-alive-post.hook'...
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET]
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET] ==> Warning:
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-07-21T17:59:31+0200] [ALPM-SCRIPTLET] -> at next boot.
[2021-07-21T17:59:31+0200] [ALPM] running 'manjaro-extensions.hook'...
[2021-07-21T17:59:32+0200] [ALPM] running 'manjaro-gdm-branding-install.hook'...
[2021-07-21T17:59:32+0200] [ALPM] running 'manjaro-gnome-messages.hook'...
[2021-07-21T17:59:32+0200] [ALPM-SCRIPTLET]
[2021-07-21T17:59:32+0200] [ALPM-SCRIPTLET] ==> Printing support installed
[2021-07-21T17:59:32+0200] [ALPM] running 'networkmanager-connectivity.hook'...
[2021-07-21T17:59:32+0200] [ALPM] running 'texinfo-install.hook'...
[2021-07-21T17:59:32+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-07-21T17:59:32+0200] [ALPM] running 'update-mime-database.hook'...
[2021-07-21T17:59:33+0200] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2021-07-21T17:59:33+0200] [ALPM] running 'xorg-mkfontscale.hook'...
[2021-07-21T20:32:57+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux513 linux513-virtualbox-host-modules'
[2021-07-21T20:33:15+0200] [ALPM] transaction started
[2021-07-21T20:33:15+0200] [ALPM] installed linux513 (5.13.1-3)
[2021-07-21T20:33:15+0200] [ALPM] installed linux513-virtualbox-host-modules (6.1.22-5)
[2021-07-21T20:33:15+0200] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2021-07-21T20:33:15+0200] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2021-07-21T20:33:22+0200] [ALPM] transaction completed
[2021-07-21T20:33:22+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T20:33:22+0200] [ALPM] running '60-depmod.hook'...
[2021-07-21T20:33:30+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.13.1-3-MANJARO
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T20:33:30+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T20:33:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T20:33:31+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T20:33:31+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T20:33:31+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.13.1-3-MANJARO
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T20:33:32+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T20:33:34+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T20:33:35+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T20:33:35+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T20:33:35+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T20:33:36+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T20:33:38+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T20:33:38+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:33:43+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T20:33:43+0200] [ALPM] running '99-grub.hook'...
[2021-07-21T20:33:44+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-07-21T20:33:45+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-21T20:33:45+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T20:33:45+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.14-x86_64
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T20:33:46+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.14-x86_64
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-07-21T20:33:47+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-07-21T20:33:48+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-21T20:33:49+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-07-21T20:33:49+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-21T20:33:49+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-07-21T20:33:49+0200] [ALPM-SCRIPTLET] done
[2021-07-21T20:35:30+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux510 linux510-virtualbox-host-modules'
[2021-07-21T20:35:30+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-07-21T20:35:30+0200] [ALPM] transaction started
[2021-07-21T20:35:30+0200] [ALPM] removed linux510-virtualbox-host-modules (6.1.22-20)
[2021-07-21T20:35:37+0200] [ALPM] removed linux510 (5.10.49-1)
[2021-07-21T20:35:37+0200] [ALPM] transaction completed
[2021-07-21T20:35:37+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T20:35:37+0200] [ALPM] running '60-depmod.hook'...
[2021-07-21T20:35:37+0200] [ALPM] running '99-grub.hook'...
[2021-07-21T20:35:38+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-07-21T20:35:38+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.14-x86_64
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T20:35:39+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-4.14-x86_64
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-4.14-x86_64.img
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-4.14-x86_64-fallback.img
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-07-21T20:35:40+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-07-21T20:35:41+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-21T20:35:42+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-07-21T20:35:42+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-21T20:35:42+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-07-21T20:35:42+0200] [ALPM-SCRIPTLET] done
[2021-07-21T20:35:55+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -R linux414 linux414-virtualbox-host-modules'
[2021-07-21T20:35:55+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-07-21T20:35:55+0200] [ALPM] transaction started
[2021-07-21T20:35:55+0200] [ALPM] removed linux414-virtualbox-host-modules (6.1.22-11)
[2021-07-21T20:36:00+0200] [ALPM] removed linux414 (4.14.239-1)
[2021-07-21T20:36:00+0200] [ALPM] transaction completed
[2021-07-21T20:36:00+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T20:36:00+0200] [ALPM] running '60-depmod.hook'...
[2021-07-21T20:36:00+0200] [ALPM] running '99-grub.hook'...
[2021-07-21T20:36:00+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-07-21T20:36:01+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-21T20:36:02+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T20:36:02+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T20:36:02+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:36:03+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T20:36:03+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-07-21T20:36:03+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-07-21T20:36:04+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-21T20:36:05+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-07-21T20:36:05+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-21T20:36:05+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-07-21T20:36:05+0200] [ALPM-SCRIPTLET] done
[2021-07-21T21:03:35+0200] [PACMAN] Running '/usr/bin/pacman --noconfirm --noprogressbar -S linux510 linux510-virtualbox-host-modules'
[2021-07-21T21:03:36+0200] [ALPM] transaction started
[2021-07-21T21:03:37+0200] [ALPM] installed linux510 (5.10.49-1)
[2021-07-21T21:03:37+0200] [ALPM] installed linux510-virtualbox-host-modules (6.1.22-20)
[2021-07-21T21:03:37+0200] [ALPM-SCRIPTLET] ===> You must load vboxdrv module before starting VirtualBox:
[2021-07-21T21:03:37+0200] [ALPM-SCRIPTLET] ===> # modprobe vboxdrv
[2021-07-21T21:03:42+0200] [ALPM] transaction completed
[2021-07-21T21:03:42+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T21:03:42+0200] [ALPM] running '60-depmod.hook'...
[2021-07-21T21:03:47+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.49-1-MANJARO
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T21:03:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T21:03:48+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.49-1-MANJARO
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-21T21:03:49+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-21T21:03:51+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-21T21:03:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-21T21:03:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-21T21:03:52+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-21T21:03:53+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-21T21:03:54+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-21T21:03:54+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T21:03:58+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-21T21:03:58+0200] [ALPM] running '99-grub.hook'...
[2021-07-21T21:03:59+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2021-07-21T21:04:00+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-21T21:04:00+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T21:04:00+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.10-x86_64
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.13-x86_64
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Warning: os-prober will be executed to detect other bootable partitions.
[2021-07-21T21:04:01+0200] [ALPM-SCRIPTLET] Its output will be used to detect bootable binaries on them and create new boot entries.
[2021-07-21T21:04:03+0200] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-21T21:04:04+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2021-07-21T21:04:04+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-21T21:04:04+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme0n1.
[2021-07-21T21:04:05+0200] [ALPM-SCRIPTLET] done
[2021-07-21T21:05:51+0200] [PACMAN] Running 'pacman -Syu'
[2021-07-21T21:05:51+0200] [PACMAN] synchronizing package lists
[2021-07-21T21:05:53+0200] [PACMAN] starting full system upgrade
[2021-07-21T22:43:32+0200] [ALPM] transaction started
[2021-07-21T22:43:33+0200] [ALPM] removed xorg-xinput (1.6.3-2)
[2021-07-21T22:43:33+0200] [ALPM] removed libhandy0 (0.0.13+12+gaa6b6f4-3)
[2021-07-21T22:43:33+0200] [ALPM] removed box2d (2.4.1-1)
[2021-07-21T22:43:33+0200] [ALPM] removed wxgtk3 (3.0.5.1-2)
[2021-07-21T22:43:33+0200] [ALPM] removed umockdev (0.16.0-1)
[2021-07-21T22:43:33+0200] [ALPM] removed nerd-fonts-terminus (2.1.0-4)
[2021-07-21T22:43:33+0200] [ALPM-SCRIPTLET] Updating font cache... done
[2021-07-21T22:43:33+0200] [ALPM] removed gtkspell3 (3.0.10-2)
[2021-07-21T22:43:33+0200] [ALPM] removed cmus (2.9.1-1)
[2021-07-21T22:43:33+0200] [ALPM] removed asciidoc (9.1.0-1)
[2021-07-21T22:43:33+0200] [ALPM] removed lib32-dconf (0.40.0-1)
[2021-07-21T22:43:33+0200] [ALPM] removed adobe-source-sans-fonts (3.042-1)
[2021-07-21T22:43:33+0200] [ALPM] removed mediainfo (21.03-1)
[2021-07-21T22:43:33+0200] [ALPM] removed qca-qt5 (2.3.3-1)
[2021-07-21T22:43:33+0200] [ALPM] removed ueberzug (18.1.9-2)
[2021-07-21T22:43:33+0200] [ALPM] removed atool (0.39.0-7)
[2021-07-21T22:43:33+0200] [ALPM] removed java11-openjfx (11.0.10.u1-1)
[2021-07-21T22:43:33+0200] [ALPM] removed lib32-libgusb (0.3.7-1)
[2021-07-21T22:43:33+0200] [ALPM] removed libquvi (0.9.4-6)
[2021-07-21T22:43:33+0200] [ALPM] removed gulp (4.0.2-3)
[2021-07-21T22:43:33+0200] [ALPM] removed perl-image-exiftool (12.26-2)
[2021-07-21T22:43:33+0200] [ALPM] removed stoken (0.92-4)
[2021-07-21T22:43:33+0200] [ALPM] removed lshw (B.02.19.2-1)
[2021-07-21T22:43:33+0200] [ALPM] removed python-monotonic (1.6-1)
[2021-07-21T22:43:33+0200] [ALPM] removed qhull (2020.2-4)
[2021-07-21T22:43:33+0200] [ALPM] removed openvdb (8.1.0-1)
[2021-07-21T22:43:33+0200] [ALPM] removed nlopt (2.7.0-2)
[2021-07-21T22:43:34+0200] [ALPM] removed cgal (4.14.3-2)
[2021-07-21T22:43:34+0200] [ALPM] removed yarn (1.22.10-1)
[2021-07-21T22:43:34+0200] [ALPM] removed gobject-introspection (1.68.0-1)
[2021-07-21T22:43:34+0200] [ALPM] removed boost (1.76.0-1)
[2021-07-21T22:43:34+0200] [ALPM] removed gestures (0.2.5-1)
[2021-07-21T22:43:34+0200] [ALPM] removed highlight (4.1-1)
[2021-07-21T22:43:34+0200] [ALPM] removed lib32-libgudev (236-1)
[2021-07-21T22:43:34+0200] [ALPM] removed ncdu (1.16-1)
[2021-07-21T22:43:34+0200] [ALPM] removed gtk-doc (1.33.2-1)
[2021-07-21T22:43:35+0200] [ALPM] removed meson (0.58.1-1)
[2021-07-21T22:43:35+0200] [ALPM] removed lib32-polkit (0.119-1)
[2021-07-21T22:43:35+0200] [ALPM] removed electron (13.1.6-1)
[2021-07-21T22:43:35+0200] [ALPM] transaction completed
[2021-07-21T22:43:35+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'fontconfig.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'fontconfig-32.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'gio-querymodules-32.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-07-21T22:43:35+0200] [ALPM] running 'xorg-mkfontscale.hook'...
[2021-07-21T22:44:25+0200] [ALPM] transaction started
[2021-07-21T22:44:25+0200] [ALPM] removed libinput-gestures (2.67-1)
[2021-07-21T22:44:25+0200] [ALPM] removed jemalloc (1:5.2.1-3)
[2021-07-21T22:44:25+0200] [ALPM] removed log4cplus (2.0.6-1)
[2021-07-21T22:44:25+0200] [ALPM] removed glib2-docs (2.68.3-1)
[2021-07-21T22:44:25+0200] [ALPM] removed wxgtk-common (3.0.5.1-2)
[2021-07-21T22:44:25+0200] [ALPM] removed python-mako (1.1.4-1)
[2021-07-21T22:44:25+0200] [ALPM] removed libquvi-scripts (0.9.20131130-5)
[2021-07-21T22:44:25+0200] [ALPM] removed docbook-xsl (1.79.2-7)
[2021-07-21T22:44:25+0200] [ALPM] removed libdiscid (0.6.2-3)
[2021-07-21T22:44:25+0200] [ALPM] removed lib32-libusb (1.0.24-1)
[2021-07-21T22:44:25+0200] [ALPM] removed python-attrs (21.2.0-1)
[2021-07-21T22:44:25+0200] [ALPM] removed python-anytree (2.8.0-3)
[2021-07-21T22:44:25+0200] [ALPM] removed ninja (1.10.2-1)
[2021-07-21T22:44:25+0200] [ALPM] removed libmediainfo (21.03-1)
[2021-07-21T22:44:25+0200] [ALPM] removed blosc (1.21.0-1)
[2021-07-21T22:44:25+0200] [ALPM] transaction completed
[2021-07-21T22:44:26+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T22:44:26+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-21T22:44:26+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-07-21T22:44:35+0200] [ALPM] transaction started
[2021-07-21T22:44:35+0200] [ALPM] removed python-beaker (1.11.0-6)
[2021-07-21T22:44:35+0200] [ALPM] removed libzen (0.4.39-1)
[2021-07-21T22:44:35+0200] [ALPM] removed docbook-xml (4.5-9)
[2021-07-21T22:44:35+0200] [ALPM] removed lua52-luajson (1.3.4-3)
[2021-07-21T22:44:35+0200] [ALPM] removed lua52-bitop (1.0.2-9)
[2021-07-21T22:44:35+0200] [ALPM] removed lua52-expat (1.3.0-5)
[2021-07-21T22:44:35+0200] [ALPM] removed tinyxml2 (9.0.0-1)
[2021-07-21T22:44:36+0200] [ALPM] transaction completed
[2021-07-21T22:44:36+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T22:44:42+0200] [ALPM] transaction started
[2021-07-21T22:44:42+0200] [ALPM] removed lua52-lpeg (1.0.2-3)
[2021-07-21T22:44:42+0200] [ALPM] transaction completed
[2021-07-21T22:44:42+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T23:33:12+0200] [ALPM] running 'gdm-theme-maia-remove.hook'...
[2021-07-21T23:33:12+0200] [ALPM] running 'manjaro-gdm-branding-remove.hook'...
[2021-07-21T23:33:12+0200] [ALPM] transaction started
[2021-07-21T23:33:12+0200] [ALPM] removed manjaro-gnome-assets (20210518-1)
[2021-07-21T23:33:13+0200] [ALPM] removed manjaro-gdm-branding (20210529-2)
[2021-07-21T23:33:13+0200] [ALPM] removed manjaro-gdm-theme (20210528-1)
[2021-07-21T23:33:13+0200] [ALPM] transaction completed
[2021-07-21T23:33:13+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T23:33:13+0200] [ALPM] running 'dconf-update.hook'...
[2021-07-21T23:33:13+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-21T23:37:53+0200] [PAMAC] synchronizing package lists
[2021-07-21T23:38:06+0200] [ALPM] transaction started
[2021-07-21T23:38:06+0200] [ALPM] installed manjaro-gdm-branding (20210529-2)
[2021-07-21T23:38:06+0200] [ALPM] installed manjaro-gdm-theme (20210528-1)
[2021-07-21T23:38:06+0200] [ALPM] installed manjaro-gnome-assets (20210518-1)
[2021-07-21T23:38:06+0200] [ALPM] transaction completed
[2021-07-21T23:38:06+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-21T23:38:06+0200] [ALPM] running 'dconf-update.hook'...
[2021-07-21T23:38:06+0200] [ALPM] running 'gdm-theme-maia-install.hook'...
[2021-07-21T23:38:06+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-21T23:38:06+0200] [ALPM] running 'manjaro-gdm-branding-install.hook'...
[2021-07-22T20:11:23+0200] [PAMAC] synchronizing package lists
[2021-07-22T20:11:31+0200] [ALPM] transaction started
[2021-07-22T20:11:31+0200] [ALPM] upgraded inxi (3.3.05.1-1 -> 3.3.06.1-1)
[2021-07-22T20:11:31+0200] [ALPM] transaction completed
[2021-07-22T20:11:31+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-23T14:47:05+0200] [PAMAC] synchronizing package lists
[2021-07-23T14:51:45+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2021-07-23T14:51:45+0200] [ALPM] running 'kernel-alive-pre.hook'...
[2021-07-23T14:51:46+0200] [ALPM] transaction started
[2021-07-23T14:51:46+0200] [ALPM] upgraded alsa-card-profiles (1:0.3.31-1 -> 1:0.3.32-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded btrfs-progs (5.12.1-1 -> 5.13-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded systemd-libs (248.3-3 -> 248.5-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded ca-certificates-mozilla (3.67-1 -> 3.68-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded nss (3.67-1 -> 3.68-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded systemd (248.3-3 -> 248.5-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded zimg (3.0.1-2 -> 3.0.2-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded vulkan-icd-loader (1.2.182-1 -> 1.2.184-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded mesa (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:47+0200] [ALPM] upgraded tdb (1.4.3-4 -> 1.4.4-1)
[2021-07-23T14:51:48+0200] [ALPM] upgraded chromium (91.0.4472.114-1 -> 92.0.4515.107-3)
[2021-07-23T14:51:48+0200] [ALPM] upgraded ckbcomp (1.194-1 -> 1.204-1)
[2021-07-23T14:51:48+0200] [ALPM] upgraded libuv (1.41.0-1 -> 1.42.0-1)
[2021-07-23T14:51:48+0200] [ALPM] upgraded rhash (1.4.1-1 -> 1.4.2-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded cmake (3.20.5-1 -> 3.21.0-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded ethtool (1:5.12-1 -> 1:5.13-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded js78 (78.11.0-1 -> 78.12.0-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded libbytesize (2.5-1 -> 2.6-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded gnupg (2.2.29-0.1 -> 2.2.29-1)
[2021-07-23T14:51:49+0200] [ALPM] upgraded evince (40.2-1 -> 40.3-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded firefox (90.0.1-0.1 -> 90.0.1-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded libwacom (1.10-1 -> 1.11-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded flameshot (0.9.0-1 -> 0.10.0-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded pipewire (1:0.3.31-1 -> 1:0.3.32-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded pipewire-media-session (1:0.3.31-1 -> 1:0.3.32-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded gst-plugin-pipewire (1:0.3.31-1 -> 1:0.3.32-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded libnm (1.32.2-1 -> 1.32.4-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded gst-plugins-bad-libs (1.18.4-8 -> 1.18.4-9)
[2021-07-23T14:51:50+0200] [ALPM] upgraded vulkan-headers (1:1.2.182-1 -> 1:1.2.184-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded gnome-shell-extension-appindicator (40-0 -> 40-2)
[2021-07-23T14:51:50+0200] [ALPM] upgraded gnome-shell-extension-desktop-icons-ng (0.18.0-1 -> 20-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded gparted (1.3.0-4 -> 1.3.1-1)
[2021-07-23T14:51:50+0200] [ALPM] upgraded graphviz (2.47.3-1 -> 2.48.0-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded imath (3.0.5-1 -> 3.1.1-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded openexr (3.0.5-1 -> 3.0.5-2)
[2021-07-23T14:51:52+0200] [ALPM] upgraded mpg123 (1.28.0-1 -> 1.28.2-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded hwloc (2.4.1-1 -> 2.5.0-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded imagemagick (7.1.0.2-2 -> 7.1.0.4-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded gst-plugins-bad (1.18.4-8 -> 1.18.4-9)
[2021-07-23T14:51:52+0200] [ALPM] upgraded gtksourceview-pkgbuild (4-2 -> 4+1+g69f930f-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded python-more-itertools (8.7.0-1 -> 8.8.0-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded python-setuptools (1:57.1.0-1 -> 1:57.4.0-1)
[2021-07-23T14:51:52+0200] [ALPM] upgraded hplip (1:3.21.4-1 -> 1:3.21.6-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded jre11-openjdk-headless (11.0.11.u9-1 -> 11.0.12.u7-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded jre11-openjdk (11.0.11.u9-1 -> 11.0.12.u7-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded jdk11-openjdk (11.0.11.u9-1 -> 11.0.12.u7-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded kvantum-qt5 (0.19.0-1 -> 0.20.1-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded talloc (2.3.2-1 -> 2.3.3-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded tevent (1:0.10.2-3 -> 1:0.11.0-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded ldb (1:2.3.0-1 -> 1:2.4.0-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded less (1:581.2-1 -> 1:590-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded lib32-systemd (248.3-1 -> 248.5-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded lib32-at-spi2-core (2.40.2-1 -> 2.40.3-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.182-1 -> 1.2.184-1)
[2021-07-23T14:51:53+0200] [ALPM] upgraded lib32-mesa (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-tdb (1.4.3-1 -> 1.4.4-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-nettle (3.7.2-1 -> 3.7.3-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-gtk3 (3.24.29-1 -> 3.24.30-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-mesa-vdpau (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-mpg123 (1.28.1-1 -> 1.28.2-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-vulkan-intel (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded lib32-vulkan-radeon (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:54+0200] [ALPM] upgraded libjcat (0.1.6-1 -> 0.1.8-1)
[2021-07-23T14:51:55+0200] [ALPM] upgraded libmwaw (0.3.19-1 -> 0.3.20-1)
[2021-07-23T14:51:55+0200] [ALPM] upgraded libva-mesa-driver (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:51:55+0200] [ALPM] upgraded libxmlb (0.3.0-1 -> 0.3.2-1)
[2021-07-23T14:52:00+0200] [ALPM] upgraded linux-firmware (20210629.r1978.d79c267-1 -> 20210719.r1990.168452e-1)
[2021-07-23T14:52:01+0200] [ALPM] upgraded linux510 (5.10.49-1 -> 5.10.52-1)
[2021-07-23T14:52:01+0200] [ALPM] upgraded linux510-virtualbox-host-modules (6.1.22-20 -> 6.1.24-1)
[2021-07-23T14:52:09+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-07-23T14:52:10+0200] [ALPM] upgraded linux513 (5.13.1-3 -> 5.13.4-1)
[2021-07-23T14:52:10+0200] [ALPM] upgraded linux513-virtualbox-host-modules (6.1.22-5 -> 6.1.24-1)
[2021-07-23T14:52:19+0200] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2021-07-23T14:52:19+0200] [ALPM] upgraded python-requests (2.25.1-1 -> 2.26.0-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded pacman (6.0.0-1 -> 6.0.0-2)
[2021-07-23T14:52:19+0200] [ALPM] upgraded lollypop (1.4.20-1 -> 1.4.22-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded manjaro-hello (0.6.6-5 -> 0.6.7-2)
[2021-07-23T14:52:19+0200] [ALPM] upgraded manjaro-release (21.1.0rc1-2 -> 21.1.0rc2-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded mariadb-libs (10.5.11-1 -> 10.6.3-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded mesa-vdpau (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded mhwd-nvidia-390xx (390.143-1 -> 390.144-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded mhwd-nvidia (470.42.01-1 -> 470.57.02-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded mhwd-db (0.6.5-9 -> 0.6.5-10)
[2021-07-23T14:52:19+0200] [ALPM] upgraded networkmanager (1.32.2-1 -> 1.32.4-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded nodejs-lts-fermium (14.16.0-2 -> 14.17.3-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded noto-fonts-emoji (20200916-1 -> 20210625-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded ostree (2021.2-1 -> 2021.3-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded perl-http-message (6.32-2 -> 6.33-1)
[2021-07-23T14:52:19+0200] [ALPM] installed python-tomli (1.0.4-1)
[2021-07-23T14:52:19+0200] [ALPM] upgraded python-pep517 (0.10.0-2 -> 0.11.0-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded python-sphinx (4.1.0-1 -> 4.1.1-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded qt5-wayland (5.15.2+kde+r28-1 -> 5.15.2+kde+r29-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded rpcbind (1.2.5-3 -> 1.2.6-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded smbclient (4.14.5-1 -> 4.14.6-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded snapd (2.51.1-1 -> 2.51.3-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded systemd-sysvcompat (248.3-3 -> 248.5-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded torbrowser-launcher (0.3.4-2 -> 0.3.5-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded virtualbox (6.1.22-3 -> 6.1.24-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded vulkan-intel (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:52:20+0200] [ALPM] upgraded vulkan-radeon (21.1.4-1 -> 21.1.5-1)
[2021-07-23T14:52:25+0200] [ALPM] upgraded wine-staging (6.12.1-1 -> 6.13-1)
[2021-07-23T14:52:26+0200] [ALPM] upgraded wireshark-cli (3.4.6-1 -> 3.4.7-1)
[2021-07-23T14:52:26+0200] [ALPM] upgraded wireshark-qt (3.4.6-1 -> 3.4.7-1)
[2021-07-23T14:52:26+0200] [ALPM] transaction completed
[2021-07-23T14:52:27+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2021-07-23T14:52:27+0200] [ALPM] running '30-systemd-binfmt.hook'...
[2021-07-23T14:52:27+0200] [ALPM] running '30-systemd-catalog.hook'...
[2021-07-23T14:52:27+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '30-systemd-hwdb.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '30-systemd-sysctl.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '30-systemd-update.hook'...
[2021-07-23T14:52:28+0200] [ALPM] running '40-update-ca-trust.hook'...
[2021-07-23T14:52:29+0200] [ALPM] running '60-depmod.hook'...
[2021-07-23T14:52:46+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2021-07-23T14:52:46+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default'
[2021-07-23T14:52:46+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
[2021-07-23T14:52:46+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.52-1-MANJARO
[2021-07-23T14:52:46+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-23T14:52:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-23T14:52:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-23T14:52:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-23T14:52:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-23T14:52:47+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-23T14:52:48+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.10.52-1-MANJARO
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-23T14:52:50+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-23T14:52:55+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-23T14:52:57+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-23T14:52:57+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-23T14:52:57+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-23T14:52:59+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-23T14:53:01+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-23T14:53:01+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-23T14:53:06+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-23T14:53:06+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'default'
[2021-07-23T14:53:06+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
[2021-07-23T14:53:06+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.13.4-1-MANJARO
[2021-07-23T14:53:06+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-23T14:53:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-23T14:53:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2021-07-23T14:53:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-23T14:53:07+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-23T14:53:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-23T14:53:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-23T14:53:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-23T14:53:08+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-23T14:53:09+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-23T14:53:09+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-23T14:53:09+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
[2021-07-23T14:53:10+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-23T14:53:10+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: 'fallback'
[2021-07-23T14:53:10+0200] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
[2021-07-23T14:53:10+0200] [ALPM-SCRIPTLET] ==> Starting build: 5.13.4-1-MANJARO
[2021-07-23T14:53:10+0200] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2021-07-23T14:53:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2021-07-23T14:53:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2021-07-23T14:53:11+0200] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2021-07-23T14:53:17+0200] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2021-07-23T14:53:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2021-07-23T14:53:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [plymouth]
[2021-07-23T14:53:20+0200] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2021-07-23T14:53:22+0200] [ALPM-SCRIPTLET] -> Running build hook: [fsck]
[2021-07-23T14:53:24+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2021-07-23T14:53:25+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-23T14:53:32+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2021-07-23T14:53:32+0200] [ALPM] running '99-grub.hook'...
[2021-07-23T14:53:34+0200] [ALPM-SCRIPTLET] Création du fichier de configuration GRUB…
[2021-07-23T14:53:37+0200] [ALPM-SCRIPTLET] Thème trouvé : /usr/share/grub/themes/AnarchyGrub/theme.txt
[2021-07-23T14:53:39+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.13-x86_64
[2021-07-23T14:53:39+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-23T14:53:41+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-23T14:53:41+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.10-x86_64
[2021-07-23T14:53:41+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-23T14:53:41+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-23T14:53:42+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.13-x86_64
[2021-07-23T14:53:42+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.13-x86_64.img
[2021-07-23T14:53:44+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.13-x86_64-fallback.img
[2021-07-23T14:53:44+0200] [ALPM-SCRIPTLET] Image Linux trouvée : /boot/vmlinuz-5.10-x86_64
[2021-07-23T14:53:44+0200] [ALPM-SCRIPTLET] Image mémoire initiale trouvée : /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
[2021-07-23T14:53:44+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
[2021-07-23T14:53:45+0200] [ALPM-SCRIPTLET] Attention : le sondeur de systèmes d'exploitation sera exécuté pour détecter d'autres partitions amorçables.
[2021-07-23T14:53:45+0200] [ALPM-SCRIPTLET] Sa sortie sera utilisée pour détecter les binaires amorçables qu'elles contiennent et créer de nouvelles entrées d'amorçage.
[2021-07-23T14:53:49+0200] [ALPM-SCRIPTLET] Windows Boot Manager trouvé sur /dev/nvme0n1p1@/EFI/Microsoft/Boot/bootmgfw.efi
[2021-07-23T14:53:51+0200] [ALPM-SCRIPTLET] Ajout de l'entrée du menu d'amorçage pour les paramètres du firmware UEFI …
[2021-07-23T14:53:52+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2021-07-23T14:53:52+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe : attention : type de périphérique nvme0n1 inconnu.
[2021-07-23T14:53:52+0200] [ALPM-SCRIPTLET] fait
[2021-07-23T14:53:52+0200] [ALPM] running 'dbus-reload.hook'...
[2021-07-23T14:53:53+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2021-07-23T14:53:53+0200] [ALPM] running 'fontconfig.hook'...
[2021-07-23T14:53:53+0200] [ALPM] running 'fontconfig-32.hook'...
[2021-07-23T14:53:53+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2021-07-23T14:53:53+0200] [ALPM] running 'gtk-query-immodules-3.0-32.hook'...
[2021-07-23T14:53:54+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2021-07-23T14:53:54+0200] [ALPM] running 'kernel-alive-post.hook'...
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET]
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] ==> Warning:
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] -> at next boot.
[2021-07-23T14:53:56+0200] [ALPM] running 'manjaro-extensions.hook'...
[2021-07-23T14:53:56+0200] [ALPM-SCRIPTLET] Aucun fichier schéma trouvé : fichier de sortie existant supprimé.
[2021-07-23T14:53:56+0200] [ALPM] running 'networkmanager-connectivity.hook'...
[2021-07-23T14:53:56+0200] [ALPM] running 'texinfo-install.hook'...
[2021-07-23T14:53:56+0200] [ALPM] running 'update-desktop-database.hook'...
[2021-07-23T14:53:56+0200] [ALPM] running 'update-mime-database.hook'...
[2021-07-23T14:53:56+0200] [ALPM] running 'xorg-mkfontscale.hook'...
Make sure to merge your pacnews.
Ok, I have done the merge now, but the problem persists. Another problem, when I call sudo in a command terminal for the first time it takes about 15 seconds before asking for my password, maybe the problem is with an authentication service? (same thing when I want to modify system parameters and a password window should appear, it takes a long time to appear (before the update it was done instantly))
Hi, there does not seem to be anything terribly wrong as far as I can see from the logs.
One thing to check is if you have the right gdm installed, is gdm-plymouth
installed?
Check for failed services:
systemctl --failed
A look through the stable update thread with common solutions might be worth a try but the above check for the right gdm is the only solution that seems appropriate to me.
Hello Hanzei, thanks for your help.
gdm was installed but not gdm-plymouth. I tried installing it and replacing gdm with this one. I also look at the failed services. There was the fprintd daemon. I didn’t need it anymore so I deleted it. Now everything work properly. I don’t realy know if the problem was gdm or fprintd but now it’s ok! Thank you very much for your solutions.
Thanks for the feedback and the steps you took to fix your issue, others will benefit from your example
Thanks, I did not have a failing fprintd daemon. But I had the same Issue as you after updating and removing fprintd (which I don’t need because I don’t use the fingerprint scanner) fixed the issue.
I did not have to install gdm-plymouth thought. (I don’t use plymouth)
But fprintd should not be breaking gdm…
I had the same problem with my PC (AMD CPU+Nvidia GPU) and this post saved me. I removed fprintd and every works again. I also have a laptop with intel cpu and no dedicated gpu. I did not have this problem at all. I suspect it is related to either AMD or Nvidia.
