The speakers work ,but the 3.5mm jack on the laptop doesn’t. I have resorted to using a adapter, can someone help me pls.
I ran an alsa info script
sorry but with this lack of information no one can assist.
what more info should i add? i am new to linux
!!ALSA Information Script v 0.5.1
!!Script ran on: Sun Jul 31 03:11:45 UTC 2022
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Google
Product Name: Phaser360
Product Version: rev4
Firmware Version: MrChromebox-4.17.2
System SKU: sku5
Board Vendor: Google
Board Name: Phaser360
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI0003:00/status 15
/sys/bus/acpi/devices/BOOT0000:00/status 11
/sys/bus/acpi/devices/DLGS7219:00/status 15
/sys/bus/acpi/devices/ELAN0000:00/status 15
/sys/bus/acpi/devices/ELAN0001:00/status 15
/sys/bus/acpi/devices/GOOG0003:00/status 11
/sys/bus/acpi/devices/GOOG0004:00/status 15
/sys/bus/acpi/devices/GOOG0006:00/status 11
/sys/bus/acpi/devices/GOOG000A:00/status 15
/sys/bus/acpi/devices/INT33D3:00/status 15
/sys/bus/acpi/devices/INT33D6:00/status 15
/sys/bus/acpi/devices/INT3400:00/status 15
/sys/bus/acpi/devices/INT3403:00/status 15
/sys/bus/acpi/devices/INT3403:01/status 15
/sys/bus/acpi/devices/INT3403:02/status 15
/sys/bus/acpi/devices/INT3403:03/status 15
/sys/bus/acpi/devices/INT3453:00/status 15
/sys/bus/acpi/devices/INT3453:01/status 15
/sys/bus/acpi/devices/INT3453:02/status 15
/sys/bus/acpi/devices/INT3453:03/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 1
/sys/bus/acpi/devices/MX98357A:00/status 15
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:01/status 15
/sys/bus/acpi/devices/PNP0C02:02/status 15
/sys/bus/acpi/devices/PNP0C0A:00/status 31
/sys/bus/acpi/devices/PRP0001:00/status 15
/sys/bus/acpi/devices/device:16/status 15
/sys/bus/acpi/devices/device:2e/status 15
/sys/bus/acpi/devices/device:2f/status 15
!!Kernel Information
Kernel release: 5.15.57-2-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.15.57-2-MANJARO
Library version: 1.2.7.2
Utilities version: 1.2.7
!!Loaded ALSA modules
snd_soc_sst_bxt_da7219_max98357a (card 1)
!!Sound Servers on this system
PipeWire:
Installed - Yes (/usr/bin/pipewire)
Running - Yes
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
1 [sofglkda7219max]: sof-glkda7219ma - sof-glkda7219max
Google-Phaser360-rev4
!!PCI Soundcards installed in the system
00:0e.0 Multimedia audio controller [0401]: Intel Corporation Celeron/Pentium Silver Processor High Definition Audio [8086:3198] (rev 06)
DeviceName: Multimedia audio controller
!!Loaded sound module options
!!Module: snd_soc_sst_bxt_da7219_max98357a
!!Sysfs card info
!!Card: /sys/class/sound/card1
Driver: /sys/bus/platform/drivers/bxt_da7219_max98357a
Tree:
!!HDA-Intel Codec information
--startcollapse--
Codec: Intel Geminilake HDMI
Address: 2
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x8086280d
Subsystem Id: 0x80860101
Revision Id: 0x100000
No Modem Function Group found
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D3 CLKSTOP EPSS
Power: setting=D0, actual=D0, Clock-stop-OK
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x6611: 8-Channels Digital
Converter: stream=0, channel=0
Digital: Enabled KAE
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
bits [0x1a]: 16 24 32
formats [0x5]: PCM AC3
Power states: D0 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x04 [Audio Output] wcaps 0x6611: 8-Channels Digital
PCM:
Node 0x05 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-Out vals: [0x00 0x00]
Pincap 0x0b000094: OUT Detect HBR HDMI DP
Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x00:
Unsolicited: tag=00, enabled=0
Devices: 0
Connection: 0
Node 0x06 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
Node 0x07 [Pin Complex] wcaps 0x40778d: 8-Channels Digital Amp-Out CP
Pin-ctls: 0x00:
Devices: 0
Connection: 0
--endcollapse--
!!ALSA Device nodes
crw-rw---- 1 root audio 116, 13 Jul 31 11:06 /dev/snd/controlC1
crw-rw---- 1 root audio 116, 12 Jul 31 11:06 /dev/snd/hwC1D2
crw-rw---- 1 root audio 116, 5 Jul 31 13:08 /dev/snd/pcmC1D0p
crw-rw---- 1 root audio 116, 7 Jul 31 11:06 /dev/snd/pcmC1D1c
crw-rw---- 1 root audio 116, 6 Jul 31 11:06 /dev/snd/pcmC1D1p
crw-rw---- 1 root audio 116, 9 Jul 31 11:06 /dev/snd/pcmC1D5p
crw-rw---- 1 root audio 116, 10 Jul 31 11:06 /dev/snd/pcmC1D6p
crw-rw---- 1 root audio 116, 11 Jul 31 11:06 /dev/snd/pcmC1D7p
crw-rw---- 1 root audio 116, 8 Jul 31 11:06 /dev/snd/pcmC1D99c
crw-rw---- 1 root audio 116, 1 Jul 31 11:06 /dev/snd/seq
crw-rw---- 1 root audio 116, 33 Jul 31 11:06 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 60 Jul 31 13:03 .
drwxr-xr-x 3 root root 280 Jul 31 13:03 ..
lrwxrwxrwx 1 root root 12 Jul 31 11:06 pci-0000:00:0e.0-platform-glk_da7219_mx98357a -> ../controlC1
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 1: sofglkda7219max [sof-glkda7219max], device 0: Speakers (*) []
Subdevices: 0/1
Subdevice #0: subdevice #0
card 1: sofglkda7219max [sof-glkda7219max], device 1: Headset (*) []
Subdevices: 1/1
card 1: sofglkda7219max [sof-glkda7219max], device 5: HDMI1 (*) []
Subdevices: 1/1
card 1: sofglkda7219max [sof-glkda7219max], device 6: HDMI2 (*) []
Subdevices: 1/1
card 1: sofglkda7219max [sof-glkda7219max], device 7: HDMI3 (*) []
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 1: sofglkda7219max [sof-glkda7219max], device 99: DMIC (*) []
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card sofglkda7219max
Card sysdefault:1 'sofglkda7219max'/'Google-Phaser360-rev4'
Mixer name : 'Intel Geminilake HDMI'
Components : 'HDA:8086280d,80860101,00100000'
Controls : 108
Simple ctrls : 84
Simple mixer control 'Headphone',0
Capabilities: volume pswitch
Limits: 0 - 63
Front Left: 0 [0%] [-57.00dB] Playback [on]
Front Right: 0 [0%] [-57.00dB] Playback [on]
Simple mixer control 'Headphone Gain Ramp',0
Capabilities: pswitch
Mono:
Front Left: Playback [on]
Front Right: Playback [on]
Simple mixer control 'Headphone Jack',0
Capabilities: pswitch pswitch-joined
Playback channels: Mono
Mono: Playback [on]
Simple mixer control 'Headphone ZC Gain',0
Mono:
Front Left: Playback [off]
Front Right: Playback [off]
Simple mixer control 'ToneGen',0
Capabilities: volume volume-joined
Capture channels: Mono
Limits: 0 - 15
Mono: 0 [0%] [-45.00dB]
Simple mixer control 'ToneGen DTMF',0
Mono: Playback [off]
Simple mixer control 'ToneGen DTMF Key',0
Capabilities: enum
Items: '0' '1' '2' '3' '4' '5' '6' '7' '8' '9' 'A' 'B' 'C' 'D' '*' '#'
Item0: '0'
Simple mixer control 'ToneGen Off Time',0
Limits: 0 - 63
Mono: 1 [2%]
Simple mixer control 'ToneGen On Time',0
Limits: 0 - 63
Mono: 2 [3%]
Simple mixer control 'ToneGen Sinewave Gen Type',0
Capabilities: enum
Items: 'Sum' 'SWG1' 'SWG2' 'SWG1_1-Cos'
Item0: 'Sum'
Simple mixer control 'ToneGen Sinewave1 Freq',0
Limits: 0 - 65535
Mono: 5461 [8%]
Simple mixer control 'ToneGen Sinewave2 Freq',0
Limits: 0 - 65535
Mono: 16384 [25%]
Simple mixer control 'Sidetone',0
Capabilities: volume volume-joined pswitch pswitch-joined
Limits: 0 - 14
Mono: 14 [100%] [0.00dB] Playback [off]
Simple mixer control 'Mic',0
Limits: 0 - 7
Mono: 1 [14%] [0.00dB] Playback [off]
Simple mixer control 'IEC958',0
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Playback Digital',0
Limits: 0 - 127
Front Left: 111 [87%] [0.00dB] Playback [off]
Front Right: 111 [87%] [0.00dB] Playback [off]
Simple mixer control 'Playback Digital Gain Ramp',0
Mono:
Simple mixer control 'Capture Digital',0
Limits: 0 - 127
Mono: 111 [87%] [0.00dB] Playback [off]
Simple mixer control 'Capture Digital Gain Ramp',0
Mono: Playback [on]
Simple mixer control 'Mixer In Mic',0
Simple mixer control 'Mixer Out FilterL DACL',0
Simple mixer control 'Mixer Out FilterR DACR',0
Simple mixer control 'Mixin',0
Limits: 0 - 15
Mono: 3 [20%] [0.00dB] Playback [off]
Simple mixer control 'Mixin Gain Ramp',0
Mono: Playback [on]
Simple mixer control 'Mixin ZC Gain',0
Simple mixer control 'ADC HPF Corner Audio',0
Capabilities: enum
Items: '2Hz' '4Hz' '8Hz' '16Hz'
Item0: '2Hz'
Simple mixer control 'ADC HPF Corner Voice',0
Capabilities: enum
Items: '2.5Hz' '25Hz' '50Hz' '100Hz' '150Hz' '200Hz' '300Hz' '400Hz'
Item0: '2.5Hz'
Simple mixer control 'ADC HPF Mode',0
Capabilities: enum
Items: 'Disabled' 'Audio' 'Voice'
Item0: 'Audio'
Simple mixer control 'ALC',0
Simple mixer control 'ALC Anticlip',0
Simple mixer control 'ALC Anticlip Step',0
Capabilities: enum
Items: '0.034dB/fs' '0.068dB/fs' '0.136dB/fs' '0.272dB/fs'
Item0: '0.034dB/fs'
Simple mixer control 'ALC Attack Rate',0
Capabilities: enum
Items: '7.33/fs' '14.66/fs' '29.32/fs' '58.64/fs' '117.3/fs' '234.6/fs' '469.1/fs' '938.2/fs' '1876/fs' '3753/fs' '7506/fs' '15012/fs' '30024/fs'
Item0: '7.33/fs'
Simple mixer control 'ALC Envelope Attack Rate',0
Capabilities: enum
Items: '1/4' '1/16' '1/256' '1/65536'
Item0: '1/4'
Simple mixer control 'ALC Envelope Release Rate',0
Capabilities: enum
Item0: '1/4'
Simple mixer control 'ALC Hold Time',0
Capabilities: enum
Items: '62/fs' '124/fs' '248/fs' '496/fs' '992/fs' '1984/fs' '3968/fs' '7936/fs' '15872/fs' '31744/fs' '63488/fs' '126976/fs' '253952/fs' '507904/fs' '1015808/fs' '2031616/fs'
Item0: '62/fs'
Simple mixer control 'ALC Max',0
Limits: 0 - 15
Mono: 15 [100%] [90.00dB]
Simple mixer control 'ALC Max Analog',0
Limits: 0 - 6
Mono: 6 [100%] [36.00dB]
Simple mixer control 'ALC Max Attenuation',0
Limits: 0 - 15
Mono: 15 [100%]
Simple mixer control 'ALC Max Threshold',0
Limits: 0 - 63
Mono: 63 [100%]
Simple mixer control 'ALC Min Analog',0
Limits: 0 - 6
Mono: 0 [0%] [0.00dB]
Simple mixer control 'ALC Min Threshold',0
Limits: 0 - 63
Mono: 0 [0%]
Simple mixer control 'ALC Noise Threshold',0
Limits: 0 - 63
Mono: 0 [0%]
Simple mixer control 'ALC Release Rate',0
Capabilities: enum
Items: '28.66/fs' '57.33/fs' '114.6/fs' '229.3/fs' '458.6/fs' '917.1/fs' '1834/fs' '3668/fs' '7337/fs' '14674/fs' '29348/fs'
Item0: '28.66/fs'
Simple mixer control 'Charge Pump Threshold',0
Limits: 0 - 63
Mono: 14 [22%]
Simple mixer control 'Charge Pump Track Mode',0
Capabilities: enum
Items: 'Largest Volume' 'DAC Volume' 'Signal Magnitude'
Item0: 'DAC Volume'
Simple mixer control 'DAC EQ',0
Simple mixer control 'DAC EQ Band1',0
Limits: 0 - 15
Mono: 8 [53%] [1.50dB]
Simple mixer control 'DAC EQ Band2',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band3',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band4',0
Limits: 0 - 15
Simple mixer control 'DAC EQ Band5',0
Limits: 0 - 15
Simple mixer control 'DAC HPF Corner Audio',0
Capabilities: enum
Item0: '2Hz'
Simple mixer control 'DAC HPF Corner Voice',0
Capabilities: enum
Item0: '2.5Hz'
Simple mixer control 'DAC HPF Mode',0
Capabilities: enum
Item0: 'Audio'
Simple mixer control 'DAC NG',0
Simple mixer control 'DAC NG Off Threshold',0
Limits: 0 - 7
Mono: 0 [0%]
Simple mixer control 'DAC NG On Threshold',0
Limits: 0 - 7
Mono: 0 [0%]
Simple mixer control 'DAC NG Rampdown Rate',0
Capabilities: enum
Items: '0.88ms/dB' '14.08ms/dB'
Item0: '0.88ms/dB'
Simple mixer control 'DAC NG Rampup Rate',0
Capabilities: enum
Items: '0.22ms/dB' '0.0138ms/dB'
Item0: '0.22ms/dB'
Simple mixer control 'DAC NG Setup Time',0
Capabilities: enum
Items: '256 Samples' '512 Samples' '1024 Samples' '2048 Samples'
Item0: '256 Samples'
Simple mixer control 'DAC Soft Mute',0
Simple mixer control 'DAC Soft Mute Rate',0
Capabilities: enum
Items: '1 Sample' '2 Samples' '4 Samples' '8 Samples' '16 Samples' '32 Samples' '64 Samples'
Item0: '1 Sample'
Simple mixer control 'Gain Ramp Rate',0
Capabilities: enum
Items: 'Nominal Rate * 8' 'Nominal Rate' 'Nominal Rate / 8' 'Nominal Rate / 16'
Item0: 'Nominal Rate * 8'
Simple mixer control 'Headset Mic',0
Mono: Playback [on]
Simple mixer control 'Out DACL Mux',0
Capabilities: enum
Items: 'ADC' 'Tone Generator' 'DAIL' 'DAIR'
Item0: 'DAIL'
Simple mixer control 'Out DACR Mux',0
Capabilities: enum
Item0: 'DAIR'
Simple mixer control 'Out DAIL Mux',0
Capabilities: enum
Item0: 'ADC'
Simple mixer control 'Out DAIR Mux',0
Capabilities: enum
Item0: 'Tone Generator'
Simple mixer control 'PGA1.0 1 Master',0
Capabilities: pvolume
Limits: Playback 0 - 32
Mono:
Front Left: Playback 32 [100%] [0.00dB]
Front Right: Playback 32 [100%] [0.00dB]
Simple mixer control 'PGA2.0 2 Master',0
Mono:
Simple mixer control 'PGA3.0 3 Master',0
Capabilities: cvolume
Limits: Capture 0 - 80
Front Left: Capture 50 [62%] [0.00dB]
Front Right: Capture 50 [62%] [0.00dB]
Simple mixer control 'PGA4.0 4 Master',0
Simple mixer control 'PGA5.0 5 Master',0
Mono:
Simple mixer control 'PGA6.0 6 Master',0
Mono:
Simple mixer control 'PGA7.0 7 Master',0
Mono:
Simple mixer control 'ST Mixer Out FilterL Out FilterL',0
Mono: Playback [on]
Simple mixer control 'ST Mixer Out FilterL Out FilterR',0
Simple mixer control 'ST Mixer Out FilterL Sidetone',0
Simple mixer control 'ST Mixer Out FilterR Out FilterL',0
Simple mixer control 'ST Mixer Out FilterR Out FilterR',0
Mono: Playback [on]
Simple mixer control 'ST Mixer Out FilterR Sidetone',0
Simple mixer control 'Spk',0
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.sofglkda7219max {
control.1 {
iface MIXER
name 'Mic Volume'
value 1
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -600
dbmax 3600
dbvalue.0 0
control.2 {
iface MIXER
name 'Mic Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.3 {
iface MIXER
name 'Mixin Volume'
value 3
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -450
dbmax 1800
dbvalue.0 0
control.4 {
iface MIXER
name 'Mixin Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.5 {
iface MIXER
name 'Mixin Gain Ramp Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface MIXER
name 'Mixin ZC Gain Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.7 {
iface MIXER
name 'Capture Digital Volume'
value 111
comment {
access 'read write'
type INTEGER
count 1
range '0 - 127'
dbmin -8325
dbmax 1200
dbvalue.0 0
control.8 {
iface MIXER
name 'Capture Digital Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Capture Digital Gain Ramp Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.10 {
iface MIXER
name 'ALC Attack Rate'
value '7.33/fs'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '7.33/fs'
item.1 '14.66/fs'
item.2 '29.32/fs'
item.3 '58.64/fs'
item.4 '117.3/fs'
item.5 '234.6/fs'
item.6 '469.1/fs'
item.7 '938.2/fs'
item.8 '1876/fs'
item.9 '3753/fs'
item.10 '7506/fs'
item.11 '15012/fs'
item.12 '30024/fs'
control.11 {
iface MIXER
name 'ALC Release Rate'
value '28.66/fs'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '28.66/fs'
item.1 '57.33/fs'
item.2 '114.6/fs'
item.3 '229.3/fs'
item.4 '458.6/fs'
item.5 '917.1/fs'
item.6 '1834/fs'
item.7 '3668/fs'
item.8 '7337/fs'
item.9 '14674/fs'
item.10 '29348/fs'
control.12 {
iface MIXER
name 'ALC Hold Time'
value '62/fs'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '62/fs'
item.1 '124/fs'
item.2 '248/fs'
item.3 '496/fs'
item.4 '992/fs'
item.5 '1984/fs'
item.6 '3968/fs'
item.7 '7936/fs'
item.8 '15872/fs'
item.9 '31744/fs'
item.10 '63488/fs'
item.11 '126976/fs'
item.12 '253952/fs'
item.13 '507904/fs'
item.14 '1015808/fs'
item.15 '2031616/fs'
control.13 {
iface MIXER
name 'ALC Envelope Attack Rate'
value '1/4'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '1/4'
item.1 '1/16'
item.2 '1/256'
item.3 '1/65536'
control.14 {
iface MIXER
name 'ALC Envelope Release Rate'
value '1/4'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '1/4'
item.1 '1/16'
item.2 '1/256'
item.3 '1/65536'
control.15 {
iface MIXER
name 'ALC Noise Threshold'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
dbmin -9450
dbmax 0
dbvalue.0 -9450
control.16 {
iface MIXER
name 'ALC Min Threshold'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
dbmin -9450
dbmax 0
dbvalue.0 -9450
control.17 {
iface MIXER
name 'ALC Max Threshold'
value 63
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
dbmin -9450
dbmax 0
dbvalue.0 0
control.18 {
iface MIXER
name 'ALC Max Attenuation'
value 15
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin 0
dbmax 9000
dbvalue.0 9000
control.19 {
iface MIXER
name 'ALC Max Volume'
value 15
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin 0
dbmax 9000
dbvalue.0 9000
control.20 {
iface MIXER
name 'ALC Min Analog Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 6'
dbmin 0
dbmax 3600
dbvalue.0 0
control.21 {
iface MIXER
name 'ALC Max Analog Volume'
value 6
comment {
access 'read write'
type INTEGER
count 1
range '0 - 6'
dbmin 0
dbmax 3600
dbvalue.0 3600
control.22 {
iface MIXER
name 'ALC Anticlip Step'
value '0.034dB/fs'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '0.034dB/fs'
item.1 '0.068dB/fs'
item.2 '0.136dB/fs'
item.3 '0.272dB/fs'
control.23 {
iface MIXER
name 'ALC Anticlip Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface MIXER
name 'ALC Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.25 {
iface MIXER
name 'ADC HPF Mode'
value Audio
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Audio
item.2 Voice
control.26 {
iface MIXER
name 'ADC HPF Corner Audio'
value '2Hz'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2Hz'
item.1 '4Hz'
item.2 '8Hz'
item.3 '16Hz'
control.27 {
iface MIXER
name 'ADC HPF Corner Voice'
value '2.5Hz'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2.5Hz'
item.1 '25Hz'
item.2 '50Hz'
item.3 '100Hz'
item.4 '150Hz'
item.5 '200Hz'
item.6 '300Hz'
item.7 '400Hz'
control.28 {
iface MIXER
name 'Sidetone Volume'
value 14
comment {
access 'read write'
type INTEGER
count 1
range '0 - 14'
dbmin -4200
dbmax 0
dbvalue.0 0
control.29 {
iface MIXER
name 'Sidetone Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface MIXER
name 'ToneGen Volume'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -4500
dbmax 0
dbvalue.0 -4500
control.31 {
iface MIXER
name 'ToneGen DTMF Key'
value '0'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '0'
item.1 '1'
item.2 '2'
item.3 '3'
item.4 '4'
item.5 '5'
item.6 '6'
item.7 '7'
item.8 '8'
item.9 '9'
item.10 A
item.11 B
item.12 C
item.13 D
item.14 '*'
item.15 '#'
control.32 {
iface MIXER
name 'ToneGen DTMF Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'ToneGen Sinewave Gen Type'
value Sum
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Sum
item.1 SWG1
item.2 SWG2
item.3 SWG1_1-Cos
control.34 {
iface MIXER
name 'ToneGen Sinewave1 Freq'
value 5461
comment {
access 'read write'
type INTEGER
count 1
range '0 - 65535'
control.35 {
iface MIXER
name 'ToneGen Sinewave2 Freq'
value 16384
comment {
access 'read write'
type INTEGER
count 1
range '0 - 65535'
control.36 {
iface MIXER
name 'ToneGen On Time'
value 2
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
control.37 {
iface MIXER
name 'ToneGen Off Time'
value 1
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
control.38 {
iface MIXER
name 'Gain Ramp Rate'
value 'Nominal Rate * 8'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Nominal Rate * 8'
item.1 'Nominal Rate'
item.2 'Nominal Rate / 8'
item.3 'Nominal Rate / 16'
control.39 {
iface MIXER
name 'DAC HPF Mode'
value Audio
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Audio
item.2 Voice
control.40 {
iface MIXER
name 'DAC HPF Corner Audio'
value '2Hz'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2Hz'
item.1 '4Hz'
item.2 '8Hz'
item.3 '16Hz'
control.41 {
iface MIXER
name 'DAC HPF Corner Voice'
value '2.5Hz'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '2.5Hz'
item.1 '25Hz'
item.2 '50Hz'
item.3 '100Hz'
item.4 '150Hz'
item.5 '200Hz'
item.6 '300Hz'
item.7 '400Hz'
control.42 {
iface MIXER
name 'DAC EQ Band1 Volume'
value 8
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1050
dbmax 1200
dbvalue.0 150
control.43 {
iface MIXER
name 'DAC EQ Band2 Volume'
value 8
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1050
dbmax 1200
dbvalue.0 150
control.44 {
iface MIXER
name 'DAC EQ Band3 Volume'
value 8
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1050
dbmax 1200
dbvalue.0 150
control.45 {
iface MIXER
name 'DAC EQ Band4 Volume'
value 8
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1050
dbmax 1200
dbvalue.0 150
control.46 {
iface MIXER
name 'DAC EQ Band5 Volume'
value 8
comment {
access 'read write'
type INTEGER
count 1
range '0 - 15'
dbmin -1050
dbmax 1200
dbvalue.0 150
control.47 {
iface MIXER
name 'DAC EQ Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.48 {
iface MIXER
name 'DAC Soft Mute Rate'
value '1 Sample'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '1 Sample'
item.1 '2 Samples'
item.2 '4 Samples'
item.3 '8 Samples'
item.4 '16 Samples'
item.5 '32 Samples'
item.6 '64 Samples'
control.49 {
iface MIXER
name 'DAC Soft Mute Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.50 {
iface MIXER
name 'DAC NG Setup Time'
value '256 Samples'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '256 Samples'
item.1 '512 Samples'
item.2 '1024 Samples'
item.3 '2048 Samples'
control.51 {
iface MIXER
name 'DAC NG Rampup Rate'
value '0.22ms/dB'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '0.22ms/dB'
item.1 '0.0138ms/dB'
control.52 {
iface MIXER
name 'DAC NG Rampdown Rate'
value '0.88ms/dB'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 '0.88ms/dB'
item.1 '14.08ms/dB'
control.53 {
iface MIXER
name 'DAC NG Off Threshold'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -10200
dbmax -6000
dbvalue.0 -10200
control.54 {
iface MIXER
name 'DAC NG On Threshold'
value 0
comment {
access 'read write'
type INTEGER
count 1
range '0 - 7'
dbmin -10200
dbmax -6000
dbvalue.0 -10200
control.55 {
iface MIXER
name 'DAC NG Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.56 {
iface MIXER
name 'Playback Digital Volume'
value.0 111
value.1 111
comment {
access 'read write'
type INTEGER
count 2
range '0 - 127'
dbmin -9999999
dbmax 1200
dbvalue.0 0
dbvalue.1 0
control.57 {
iface MIXER
name 'Playback Digital Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.58 {
iface MIXER
name 'Playback Digital Gain Ramp Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.59 {
iface MIXER
name 'Charge Pump Track Mode'
value 'DAC Volume'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Largest Volume'
item.1 'DAC Volume'
item.2 'Signal Magnitude'
control.60 {
iface MIXER
name 'Charge Pump Threshold'
value 14
comment {
access 'read write'
type INTEGER
count 1
range '0 - 63'
control.61 {
iface MIXER
name 'Headphone Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -5700
dbmax 600
dbvalue.0 -5700
dbvalue.1 -5700
control.62 {
iface MIXER
name 'Headphone Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.63 {
iface MIXER
name 'Headphone Gain Ramp Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.64 {
iface MIXER
name 'Headphone ZC Gain Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.65 {
iface MIXER
name 'Headphone Jack Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.66 {
iface MIXER
name 'Headset Mic Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.67 {
iface MIXER
name 'Spk Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.68 {
iface CARD
name 'HDMI/DP,pcm=5 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.69 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.70 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.71 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.72 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.73 {
iface PCM
device 5
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.74 {
iface CARD
name 'HDMI/DP,pcm=6 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.75 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.76 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.77 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.78 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.79 {
iface PCM
device 6
name ELD
value ''
comment {
type BYTES
count 0
control.80 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.81 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.82 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.83 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.84 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.85 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.86 {
iface PCM
device 5
name 'Playback Channel Map'
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.87 {
iface PCM
device 6
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.88 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.89 {
iface MIXER
name 'PGA1.0 1 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.90 {
iface MIXER
name 'PGA2.0 2 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.91 {
iface MIXER
name 'PGA3.0 3 Master Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -9999999
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.92 {
iface MIXER
name 'PGA4.0 4 Master Capture Volume'
value.0 50
value.1 50
comment {
access 'read write'
type INTEGER
count 2
range '0 - 80'
dbmin -9999999
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.93 {
iface MIXER
name 'PGA5.0 5 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.94 {
iface MIXER
name 'PGA6.0 6 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.95 {
iface MIXER
name 'PGA7.0 7 Master Playback Volume'
value.0 32
value.1 32
comment {
access 'read write'
type INTEGER
count 2
range '0 - 32'
dbmin -9999999
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.96 {
iface MIXER
name 'Mixer In Mic Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.97 {
iface MIXER
name 'Out DAIL Mux'
value ADC
comment {
access 'read write'
type ENUMERATED
count 1
item.0 ADC
item.1 'Tone Generator'
item.2 DAIL
item.3 DAIR
control.98 {
iface MIXER
name 'Out DAIR Mux'
value 'Tone Generator'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 ADC
item.2 DAIL
item.3 DAIR
control.99 {
iface MIXER
name 'Out DACL Mux'
value DAIL
comment {
access 'read write'
type ENUMERATED
count 1
item.0 ADC
item.2 DAIL
item.3 DAIR
control.100 {
iface MIXER
name 'Out DACR Mux'
value DAIR
comment {
access 'read write'
type ENUMERATED
count 1
item.0 ADC
item.2 DAIL
item.3 DAIR
control.101 {
iface MIXER
name 'Mixer Out FilterL DACL Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.102 {
iface MIXER
name 'Mixer Out FilterR DACR Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.103 {
iface MIXER
name 'ST Mixer Out FilterL Out FilterL Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.104 {
iface MIXER
name 'ST Mixer Out FilterL Out FilterR Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.105 {
iface MIXER
name 'ST Mixer Out FilterL Sidetone Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.106 {
iface MIXER
name 'ST Mixer Out FilterR Out FilterL Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.107 {
iface MIXER
name 'ST Mixer Out FilterR Out FilterR Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.108 {
iface MIXER
name 'ST Mixer Out FilterR Sidetone Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
--endcollapse--
!!All Loaded Modules
8250_dw
ac97_bus
acpi_thermal_rel
aesni_intel
af_alg
algif_hash
algif_skcipher
apple_mfi_fastcharge
atkbd
bluetooth
bnep
btbcm
btintel
btrtl
btusb
ccm
cfg80211
chromeos_tbmc
cmac
coreboot_table
coretemp
cqhci
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cros_ec
cros_ec_chardev
cros_ec_debugfs
cros_ec_dev
cros_ec_lid_angle
cros_ec_lpcs
cros_ec_sensorhub
cros_ec_sensors
cros_ec_sensors_core
cros_ec_sysfs
cros_peripheral_charger
cros_usbpd_charger
cros_usbpd_logger
cros_usbpd_notify
cryptd
crypto_simd
crypto_user
dw_dmac
ecdh_generic
elan_i2c
elants_i2c
ext4
fat
fuse
ghash_clmulni_intel
i2c_i801
i2c_smbus
i8042
i915
iTCO_vendor_support
iTCO_wdt
idma64
industrialio
industrialio_triggered_buffer
int3400_thermal
int3403_thermal
int340x_thermal_zone
intel_cstate
intel_gtt
intel_lpss
intel_lpss_pci
intel_pmc_bxt
intel_powerclamp
intel_punit_ipc
intel_rapl_common
intel_rapl_msr
intel_soc_dts_iosf
intel_spi
intel_spi_platform
intel_telemetry_core
intel_telemetry_debugfs
intel_telemetry_pltdrv
intel_vbtn
ip_tables
irqbypass
iwlmvm
iwlwifi
jbd2
joydev
kfifo_buf
kvm
kvm_intel
ledtrig_audio
libarc4
libps2
loop
lpc_ich
mac80211
mac_hid
mbcache
mc
mmc_block
mmc_core
mousedev
mtd
ns
pcspkr
processor_thermal_device
processor_thermal_device_pci_legacy
processor_thermal_mbox
processor_thermal_rapl
processor_thermal_rfim
qrtr
rapl
rfcomm
rfkill
rng_core
sdhci
sdhci_pci
serio
serio_raw
snd
snd_compress
snd_hda_codec
snd_hda_codec_hdmi
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hwdep
snd_intel_dspcfg
snd_intel_sdw_acpi
snd_pcm
snd_pcm_dmaengine
snd_rawmidi
snd_seq_device
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_da7219
snd_soc_dmic
snd_soc_hdac_hda
snd_soc_hdac_hdmi
snd_soc_intel_hda_dsp_common
snd_soc_max98357a
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_pci
snd_sof_pci_intel_apl
snd_sof_xtensa_dsp
snd_timer
snd_usb_audio
snd_usbmidi_lib
soc_button_array
soundcore
soundwire_bus
soundwire_cadence
soundwire_generic_allocation
soundwire_intel
sparse_keymap
spi_nor
spi_pxa2xx_platform
squashfs
tpm
tpm_tis_core
tpm_tis_spi
ttm
usbhid
uvcvideo
vfat
video
videobuf2_common
videobuf2_memops
videobuf2_v4l2
videobuf2_vmalloc
videodev
x86_pkg_temp_thermal
x_tables
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC1D2/init_pin_configs:
0x05 0x18560010
0x06 0x18560010
0x07 0x18560010
/sys/class/sound/hwC1D2/driver_pin_configs:
/sys/class/sound/hwC1D2/user_pin_configs:
/sys/class/sound/hwC1D2/init_verbs:
/sys/class/sound/hwC1D2/hints:
!!ALSA/HDA dmesg
[ 0.163804] ACPI: Added _OSI(Linux-Dell-Video)
[ 0.163805] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[ 0.163807] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[ 4.600549] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[ 4.641316] snd_hda_intel 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 4.646450] iTCO_vendor_support: vendor-support=0
[ 4.768531] i915 0000:00:02.0: [drm] RC6 and powersaving disabled by BIOS
[ 4.796462] usbcore: registered new interface driver snd-usb-audio
[ 4.800471] usb 1-7: Found UVC 1.00 device EasyCamera 1M (30c9:001c)
[ 4.991202] usbcore: registered new interface driver btusb
[ 4.995767] snd_soc_skl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 4.998223] Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
[ 5.609821] audit: type=1130 audit(1659229582.786:42): pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 5.681545] sof-audio-pci-intel-apl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if info 0x040100
[ 5.682627] sof-audio-pci-intel-apl 0000:00:0e.0: DSP detected with PCI class/subclass/prog-if 0x040100
[ 5.682807] sof-audio-pci-intel-apl 0000:00:0e.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[ 5.688892] sof-audio-pci-intel-apl 0000:00:0e.0: use msi interrupt mode
[ 5.728011] sof-audio-pci-intel-apl 0000:00:0e.0: hda codecs found, mask 4
[ 5.731130] intel_telemetry_core Init
[ 5.733427] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware info: version 2:2:0-57864
[ 5.733436] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 5.733439] sof-audio-pci-intel-apl 0000:00:0e.0: warn: FW ABI is more recent than kernel
[ 5.733447] sof-audio-pci-intel-apl 0000:00:0e.0: unknown sof_ext_man header type 3 size 0x30
[ 5.745379] intel_punit_ipc intel_punit_ipc.2.auto: Invalid IRQ, using polling mode
[ 5.745435] intel_punit_ipc intel_punit_ipc.2.auto: invalid resource
[ 5.784367] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware info: version 2:2:0-57864
[ 5.784378] sof-audio-pci-intel-apl 0000:00:0e.0: Firmware: ABI 3:22:1 Kernel ABI 3:18:0
[ 5.784381] sof-audio-pci-intel-apl 0000:00:0e.0: warn: FW ABI is more recent than kernel
[ 5.820920] sof-audio-pci-intel-apl 0000:00:0e.0: Topology: ABI 3:22:1 Kernel ABI 3:18:0
[ 5.820930] sof-audio-pci-intel-apl 0000:00:0e.0: warn: topology ABI is more recent than kernel
[ 5.831276] sof-audio-pci-intel-apl 0000:00:0e.0: ASoC: Parent card not yet available, widget card binding deferred
[ 5.832558] da7219 i2c-DLGS7219:00: supply VDD not found, using dummy regulator
[ 5.867411] bxt_da7219_max98357a glk_da7219_mx98357a: ASoC: source widget Capture overwritten
[ 5.955008] input: sof-glkda7219max Headset Jack as /devices/pci0000:00/0000:00:0e.0/glk_da7219_mx98357a/sound/card1/input13
[ 5.955130] input: sof-glkda7219max HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:0e.0/glk_da7219_mx98357a/sound/card1/input14
[ 5.955202] input: sof-glkda7219max HDMI/DP,pcm=6 as /devices/pci0000:00/0000:00:0e.0/glk_da7219_mx98357a/sound/card1/input15
[ 5.955498] input: sof-glkda7219max HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:0e.0/glk_da7219_mx98357a/sound/card1/input16
[ 6.480572] audit: type=1100 audit(1659229583.660:43): pid=796 uid=0 auid=4294967295 ses=4294967295 msg='op=PAM:authentication grantors=pam_permit acct="sddm" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
Please, take a few minutes to look up and find and read
how to provide information and how to post.
Also:
please format your posted data as code
to make it readable.
Can you post the output of alsamixer
it just brings up volume mixer
just for your information: post the output and not what you guess that might be interesting !
You mean amixer
Info is already there, just without formatting
and he doesn’t seem to bother or plan on changing that
Simple mixer control 'Master',0
Capabilities: pvolume pswitch pswitch-joined
Limits: Playback 0 - 65536
Mono:
Front Left: Playback 40632 [62%] [on]
Front Right: Playback 40632 [62%] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cvolume-joined cswitch cswitch-joined
Limits: Capture 0 - 65536
Mono: Capture 28172 [43%] [on]`
hey i’m just new to linux, when i popped the command in the terminal it just showed volume controls
alsa-info.sh
data includes mixer controls for onboard audio device from amixer
Data shows mixer control for Headphone is unmuted but level is set to 0%
Simple mixer control 'Headphone',0 Capabilities: volume pswitch Playback channels: Front Left - Front Right Capture channels: Front Left - Front Right Limits: 0 - 63 Front Left: 0 [0%] [-57.00dB] Playback [on] Front Right: 0 [0%] [-57.00dB] Playback [on]
Use this command to set Headphone level to 50%
amixer --card=1 sset Headphone 50% unmute
Or use alsamixer:
alsamixer --card=1
Use ↑ and ↓ on keyboard to adjust level
And use this command to save changes to ALSA settings
sudo alsactl store
The command returns with Invalid card number ‘1’.
using the command cat /proc/asound/cards
Only this output is returned
0 [sofglkda7219max]: sof-glkda7219ma - sof-glkda7219max
is it detecting the presence of the headphone jack
With only 1 audio device on a system, device should normally be recognised as card 0
But data from aplay
arecord
and amixer
in alsa-info
was showing card 1
If device is now recognised as card 0, previous commands should work if the card number is corrected
Or the audio device can be located in alsamixer by pressing F6
thats not even working replacing 1 w/ 0 still doesn’t allow any sound to play. It just defualts to the inbuilt speakers
No, I mean alsamixer
… but that just brings up the TUI - the GUI in the terminal
not any text output
but if you wanted that …
