Can you post inxi -Fza
on console ?
Kernel: 5.15.57-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=7deb59f0-959a-431d-ac4c-9428f9f3de46 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1
Type: Laptop System: Google product: Phaser360 v: rev4
serial: <superuser required> Chassis: type: 9 serial: <superuser required>
Mobo: Google model: Phaser360 v: rev4 serial: <superuser required>
UEFI: coreboot v: MrChromebox-4.17.2 date: 07/18/2022
ID-1: BAT0 charge: 37.2 Wh (99.5%) condition: 37.4/41.8 Wh (89.3%)
volts: 12.6 min: 11.2 model: SMP L17M3PB type: Li-ion serial: <filter>
status: discharging cycles: 257
Info: model: Intel Celeron N4020 bits: 64 type: MCP arch: Goldmont Plus
built: 2017 process: Intel 14nm family: 6 model-id: 0x7A (122) stepping: 8
microcode: 0x1E
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 112 KiB
desc: d-2x24 KiB; i-2x32 KiB L2: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1084 high: 1299 min/max: 800/2800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 870 2: 1299
bogomips: 4378
Flags: ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel GeminiLake [UHD Graphics 600] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1,DP-2 bus-ID: 00:02.0 chip-ID: 8086:3185 class-ID: 0380
Device-2: Luxvisions Innotech EasyCamera 1M type: USB driver: uvcvideo
bus-ID: 1-7:2 chip-ID: 30c9:001c class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x635c built: 2017 res: 1366x768
hz: 60 dpi: 136 gamma: 1.2 size: 256x144mm (10.08x5.67")
diag: 294mm (11.6") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel UHD Graphics 600 (GLK 2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Celeron/Pentium Silver Processor High Definition Audio
driver: sof-audio-pci-intel-apl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_apl
bus-ID: 00:0e.0 chip-ID: 8086:3198 class-ID: 0401
Sound Server-1: ALSA v: k5.15.57-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Gemini Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:0c.0 chip-ID: 8086:31dc class-ID: 0280
IF: wlp0s12f0 state: up mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-9:3 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 58.24 GiB used: 19.78 GiB (34.0%)
ID-1: /dev/mmcblk0 maj-min: 179:0 vendor: SanDisk model: DA4064
size: 58.24 GiB block-size: physical: 512 B logical: 512 B type: SSD
serial: <filter> rev: 0x8 scheme: GPT
SMART Message: Unknown smartctl error. Unable to generate data.
ID-1: / raw-size: 57.95 GiB size: 56.74 GiB (97.91%) used: 19.78 GiB
(34.9%) fs: ext4 dev: /dev/mmcblk0p2 maj-min: 179:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/mmcblk0p1 maj-min: 179:1
System Temperatures: cpu: 40.0 C mobo: N/A
Processes: 224 Uptime: 1h 4m wakeups: 30979 Memory: 3.7 GiB used: 1.63 GiB
(44.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1236 pacman: 1230 lib: 339
flatpak: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.20
alsamixer
without a card or device option will only show level controls for default sound server.
I expect that default in alsamixer
and aplay -L
is probably PulseAudio rather than PipeWire
If you are unable to locate ALSA settings for audio card in alsamixer
with F6 try using these commands:
alsamixer -c sofglkda7219max
alsamixer -D sysdefault
If you still cannot access ALSA settings with either alsamixer
or amixer
I suggest you install qastools
and try using qasmixer
to turn up level to headphone jack
i just came back from somewhere and it doesn’t work. i am so confused
should i rerun the info script?
I do not understand comment in post #24 and #25
But I can at least compare latest ALSA data with data in post #5
Audio device is now detected as card 0 instead of card 1:
"**** List of PLAYBACK Hardware Devices ****"]
card 0: sofglkda7219max [sof-glkda7219max], device 0: Speakers (*) []
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: sofglkda7219max [sof-glkda7219max], device 1: Headset (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 5: HDMI1 (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 6: HDMI2 (*) []
Subdevices: 1/1
card 0: sofglkda7219max [sof-glkda7219max], device 7: HDMI3 (*) []
Subdevices: 1/1
Audio levels for headphone output have been increased but levels for left and right channels are mismatched. output is now muted [off]
so you managed to access audio control ?
Simple mixer control 'Headphone',0
Capabilities: volume pswitch
Limits: 0 - 63
Front Left: 44 [70%] [-13.00dB] Playback [off]
Front Right: 52 [83%] [-5.00dB] Playback [off]
A modprobe option has been added to system:
!!Modprobe options (Sound related)
snd_hda_intel: model=headset-mode
Kernel documentation shows this modprobe option is intended for Realtek ALC298 audio codec
This system has Dialog DA7219 audio codec + Maxim MAX98357A amplifiier
I suggest you remove that if it is not working
I also suggest installing kernel v5.18 or v5.19 to see if the audio codec is supported on a later kernel
