I have looked at a few posts, but have not found any of them to be helpful. I have a laptop with two video cards. And I also have one monitor that is connected via HDMI. However, in the display settings it shows. Physically, however, the monitor does nothing. Even if I turn on duplication of screens for example. So the monitor is black.
I have a second laptop where I also have Manjaro, where both screens work normally. And I also have a second drive on my current computer (the one where the screen doesn’t work) where I have Windows 10, where the screen also works normally. At the very beginning (after installation), it didn’t show me the monitor even in the display settings. But then I messed around with the drivers and installed 1.15 Kernel, Majnaro headers and cuda. And then the monitor started showing up in the settings, but it still didn’t work.
- xrandr ✔
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
1920x1080 60.16*+
1680x1050 60.16
1280x1024 60.16
1440x900 60.16
1280x800 60.16
1280x720 60.16
1024x768 60.16
800x600 60.16
640x480 60.16
HDMI-1-0 connected (normal left inverted right x axis y axis)
1920x1080 60.00 + 59.94
1280x1024 75.02 60.02
1280x720 59.94
1152x864 75.00
1024x768 75.03 60.00
800x600 75.00 60.32
720x480 59.94 59.94
640x480 75.00 59.94
Device-1: NVIDIA TU117M vendor: Lenovo driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
class-ID: 0300
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-3:3 chip-ID: 04f2:b6c2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.org 1.21.1.3 compositor: gnome-shell driver:
loaded: amdgpu,ati,nvidia unloaded: modesetting,nouveau,radeon
alternate: fbdev,nv,vesa resolution: <missing: xdpyinfo>
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.16-1-MANJARO LLVM 13.0.0)
v: 4.6 Mesa 21.3.4 direct render: Yes
, if you change your mind and want to try troubleshoot this concern further post up the errors optimus-manager throws you, if not we wish you the best of luck in your journey ahead and hope you get your issue resolved by changing operating system
