Good afternoon guys,
I use Nvidia GeForce 410M graphics card. It works well with windows and even with CloudReady I installed in the past. I was able to control everything in it. But in Manjaro I am not able to control the brightness.
When I run this command:
sudo mhwd -a pci nonfree 0300
It says:
> Skipping already installed config 'video-nvidia-390xx' for device: 0000:01:00.0 (0300:10de:1055) Display controller nVidia Corporation GF119M [GeForce 410M]
Brightness control is still not working.
Please help me.
Thanks in advance.
kisun
8 July 2023 07:56
2
Hello @Msw ,
Msw:
GeForce 410M
… seems to be a notebook graphic chip. So its possibly that you tune on the false settings.
Please provide the output from this command:
inxi --admin --verbosity=7 --filter --width
With this output the people here have an overview over your system and can help better.
it says:
`System:
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=588c270e-cf3f-49ba-ad3e-1beceab535af rw quiet splash apparmor=1
security=apparmor resume=UUID=1709f72c-3bc5-4a4d-ba1c-8f178cf4b8e8
udev.log_priority=3
Desktop: GNOME v: 44.1 tk: GTK v: 3.24.37 wm: gnome-shell dm: 1: GDM
v: 44.1 2: LightDM v: 1.32.0 note: stopped Distro: Manjaro Linux
base: Arch Linux
Type: Laptop System: Sony product: VPCEH36EN v: C1073NWK
Mobo: Sony model: VAIO serial: <superuser required> BIOS: INSYDE v: R0200Z9
date: 04/19/2012
ID-1: BAT0 charge: 22.9 Wh (84.8%) condition: 27.0/45.4 Wh (59.5%) volts: 3.7
min: 10.8 model: SONY Corp. VGP-BPS26 type: Li-ion serial: <filter>
status: discharging
System RAM: available: 3.81 GiB used: 1.93 GiB (50.8%)
Info: model: Intel Core i3-2350M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 high: 800 min/max: 800/2300 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 799 3: 798 4: 800
bogomips: 18367
Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GF119M [GeForce 410M] vendor: Sony driver: nvidia v: 390.157
alternate: nouveau,nvidia_drm non-free: series: 390.xx+ status: legacy-active
(EOL~late 2022) arch: Fermi code: GF1xx process: 40/28nm built: 2010-16
pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1055
class-ID: 0300
Device-2: Chicony Sony Visual Communication Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.2:3
chip-ID: 04f2:b28a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31") monitors: <missing: xrandr>
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
vendor: Sony 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF119 HDMI Audio vendor: Sony driver: snd_hda_intel
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:0e08 class-ID: 0403
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off tools: pw-cli
type: plugin tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Sony
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 13:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp19s0 state: down mac: <filter>
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
driver: rtl8188fu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 2-1.1:3 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF: p2p0 state: down mac: <filter>
IF-ID-1: wlp0s29u1u1 state: up mac: <filter>
Device-1: Qualcomm Atheros AR3011 Bluetooth driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.5:5 chip-ID: 0cf3:3005
class-ID: e001
Local Storage: total: 280.88 GiB used: 20.97 GiB (7.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD Green 2.5 240GB size: 223.57 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 9100
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Cruzer Force
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 1.00
scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GT50N rev: SK04
dev-links: cdrom
ID-1: / raw-size: 48.92 GiB size: 47.85 GiB (97.81%) used: 20.97 GiB (43.8%)
fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: N/A
uuid: 588c270e-cf3f-49ba-ad3e-1beceab535af
ID-1: swap-1 type: partition size: 8.39 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: swap
uuid: 1709f72c-3bc5-4a4d-ba1c-8f178cf4b8e8
ID-1: /dev/sda1 maj-min: 8:1 size: 50 MiB fs: ntfs label: System Reserved
uuid: DCEA9C52EA9C2B32
ID-2: /dev/sda2 maj-min: 8:2 size: 125.34 GiB fs: ntfs label: N/A
uuid: 5CDEA639DEA60AFA
ID-3: /dev/sda3 maj-min: 8:3 size: 540 MiB fs: ntfs label: N/A
uuid: AE4A5E2F4A5DF495
ID-4: /dev/sda4 maj-min: 8:4 size: 97.66 GiB fs: ntfs label: N/A
uuid: 6276B25176B225A7
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Device-1: 1-1.2:3 info: Chicony Sony Visual Communication Camera
type: video driver: uvcvideo interfaces: 2 rev: 2.0
Device-2: 1-1.5:5 info: Qualcomm Atheros AR3011 Bluetooth type: bluetooth
driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 0cf3:3005 class-ID: e001
Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.1:3 info: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN
Adapter type: Network driver: rtl8188fu interfaces: 1 rev: 2.0
Device-2: 2-1.5:4 info: SanDisk Cruzer Force type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 200mA chip-ID: 0781:557d class-ID: 0806
serial: <filter>
System Temperatures: cpu: 55.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 231 Uptime: 1m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1264
pm: pacman pkgs: 1252 libs: 370 tools: gnome-software,pamac,yay pm: flatpak
pkgs: 5 pm: snap pkgs: 7 Shell: Bash v: 5.1.16 running-in: kgx inxi: 3.3.27`
In addition to what @kisun said, please also provide the output of:
mhwd --list
and:
mhwd --listinstalled
Looks installed. Reports as installed. Where doesn’t it show as installed?
Yes sure,
First One:
`> 0000:13:00.0 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
> 0000:01:00.0 (0300:10de:1055) Display controller nVidia Corporation:
video-nvidia-390xx 2023.03.23 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
Second one:
`> Installed PCI configs:
I am not able to change the brightness … that is the main cause
Does this open when you run it:
nvidia-settings
So can’t I just change it directly from the gnome settings app?
Do I always have to do it this way?
There is two packages which provides the possibility of changing backlight if supported by the display.
The latter is a replacement for xbacklight based on acpi.
Which one will work best with your system I don’t know - in some cases it requires some experimentation to get it working.
Since backlight is part of power saving features it may require the acpid package installed and the acipd.service enabled and running.
There is also kernel modules providing calls to ACPI directly - there are named linux$VERSION-acpi_call .
As noted - it may require some experimentation.
Since I neither use Gnome nor ever changed my brightness, so I’m obviously unsure about everything, but AFAIK the Gnome settinggs app won’t work, no, and you have to do it this way because of the Nvidia drivers.
Once again, I’m not on this.
Olli
8 July 2023 10:19
17
edit /etc/default/grub as described here:
Hey folks! Yet another problem with adjusting screen (and keyboard) brightness. I have a nvidia GPU and amd CPU in my new laptop
inxi -Fy System:
Host: lucas-notebook Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.5 Distro: Manjaro Linux
Type: Laptop System: Dell product: Dell G15 5525 v: 1.6.1
Mobo: Dell model: 03MJW9 v: A01 serial: <superuser required> UEFI: Dell
v: 1.6.1 date: 12/15/2022
cscs
8 July 2023 21:39
18
Better to give them the whole suite of options and explanations:
Backlight - ArchWiki
(also I think at least one of them is warned against now … but I cant find the docs …)
I had the same Issue, my fix was to add i915.enable_dpcd_backlight=0 to your GRUB_CMDLINE_LINUX_DEFAULT in /etc/default/grub on.
and maybe also add i915 nvidia in MODULES=() at /etc/mkinitcpio.conf then run update-grub
