Hello everyone,
I would like some help to fix a problem I have with Manjaro booting in a desktop pc, sitting along a window$ ten (rarely used and updated).This is the brief of the situation:
- nov19, normal day, usual routine update with
sudo pacman -Syu, after rebooting the system GRUB menu is showing the Manjaro option but nothing happens when trying to boot, I only see the motherboard logo; - I tried some magic following this tutorial but after reboot GRUB no longer works (I don’t see any menu, the machine stays at the motherboard logo);
- exploring a little bit more I found and followed the instructions to Restore the GRUB Bootloader without success, nor with this older how-to (I don’t have a separate partition for /boot -I believe-, just for EFI and the system, so I just mounted the EFI and the root system partitions).
Tis is the machine, output for inxi --full --admin --verbosity=7 --filter --no-host:
System: Kernel: 5.8.16-2-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=es tz=America/Argentina utc=yes
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1 misobasedir=manjaro
misolabel=MANJARO_GNOME_2012 quiet systemd.show_status=1 apparmor=1 security=apparmor
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3 Distro: Manjaro Linux
Machine: Type: Desktop Mobo: Gigabyte model: B450 AORUS M v: x.x serial: <filter> UEFI: American Megatrends
v: F50a date: 11/08/2019
Memory: RAM: total: 7.78 GiB used: 3.25 GiB (41.7%)
CPU: Topology: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: N/A microcode: 8701013 L2 cache: 3072 KiB bogomips: 91067
Speed: 2244 MHz min/max: 2200/3800 MHz boost: enabled Core speeds (MHz): 1: 3344 2: 1948 3: 2068 4: 2107
5: 2013 6: 2299 7: 2069 8: 2120 9: 3304 10: 1979 11: 1963 12: 2319
Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu fsgsbase
fxsr fxsr_opt ht hw_pstate ibpb ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdpid rdpru rdrand
rdseed rdt_a rdtscp rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a
ssse3 stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif vmcb_clean
vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: ASUSTeK driver: nouveau v: kernel bus ID: 06:00.0
chip ID: 10de:1d01
Display: wayland server: X.org 1.20.9 compositor: gnome-shell driver: nouveau
note: display driver n/a - try sudo/root display ID: 0 resolution: <xdpyinfo missing>
OpenGL: renderer: NV138 v: 4.3 Mesa 20.1.8 direct render: Yes
Audio: Device-1: NVIDIA GP108 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus ID: 06:00.1 chip ID: 10de:0fb8
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 08:00.4 chip ID: 1022:1487
Sound Server: ALSA v: k5.8.16-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte driver: r8169 v: kernel
port: f000 bus ID: 03:00.0 chip ID: 10ec:8168
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Drives: Local Storage: total: 240.50 GiB used: 89.40 GiB (37.2%)
ID-1: /dev/sda vendor: Western Digital model: WDS250G2B0B-00YS70 size: 232.89 GiB block size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 00WD scheme: GPT
ID-2: /dev/sdb type: USB vendor: Generic model: Flash Disk size: 7.62 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 8.07 scheme: MBR
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: N/A size: 5.84 GiB used: 219.4 MiB (3.7%) fs: overlay source: ERR-102 label: N/A
uuid: N/A
ID-2: /run/media/manjaro/10de1d38-749f-4be2-91cd-98a67e745183 raw size: 138.67 GiB
size: 135.49 GiB (97.71%) used: 54.25 GiB (40.0%) fs: ext4 dev: /dev/sda6 label: N/A
uuid: 10de1d38-749f-4be2-91cd-98a67e745183
ID-3: /run/media/manjaro/6E7EF14C7EF10E19 raw size: 85.77 GiB size: 85.77 GiB (100.00%)
used: 34.94 GiB (40.7%) fs: ntfs dev: /dev/sda4 label: N/A uuid: 6E7EF14C7EF10E19
Swap: Alert: No Swap data was found.
Unmounted: ID-1: /dev/sda1 size: 529.0 MiB fs: ntfs label: Recuperaci\xc3\xb3n uuid: 4E92EB0292EAED81
ID-2: /dev/sda2 size: 99.0 MiB fs: vfat label: N/A uuid: 6CEB-2DFC
ID-3: /dev/sda3 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-4: /dev/sda5 size: 7.81 GiB fs: swap label: N/A uuid: 68ec6328-4e61-45a8-af0d-5b5c8ebaf44c
ID-5: /dev/sdb1 size: 2.59 GiB fs: iso9660 label: MANJARO_GNOME_2012 uuid: 2020-10-19-12-09-32-00
ID-6: /dev/sdb2 size: 4.0 MiB fs: vfat label: MISO_EFI uuid: 0854-9541
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-4:2 info: Alcor Micro Flash Drive type: Mass Storage driver: usb-storage interfaces: 1
rev: 2.0 speed: 480 Mb/s chip ID: 058f:6387 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 3-1:2 info: Primax Dell N889 Optical Mouse type: Mouse driver: hid-generic,usbhid interfaces: 1
rev: 2.0 speed: 1.5 Mb/s chip ID: 0461:4d81
Device-2: 3-2:3 info: Microdia USB Keyboard type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2
rev: 2.0 speed: 1.5 Mb/s chip ID: 0c45:7663
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 53.9 C mobo: N/A gpu: nouveau temp: 41 C
Info: Processes: 297 Uptime: 1d 1h 40m Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1202 lib: 303
flatpak: 0 Shell: Zsh v: 5.8 running in: gnome-terminal inxi: 3.1.05
Here’s the pacman log, from one week before the problem in november 19, until 10 days after that, performing updates in chroot:
[2020-11-12T16:54:53-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-12T16:54:53-0300] [PACMAN] synchronizing package lists
[2020-11-12T16:54:59-0300] [PACMAN] starting full system upgrade
[2020-11-12T16:55:05-0300] [ALPM] transaction started
[2020-11-12T16:55:05-0300] [ALPM] upgraded manjaro-gnome-extension-settings (20201030-2 -> 20201110-2)
[2020-11-12T16:55:05-0300] [ALPM] upgraded manjaro-gnome-settings (20201030-2 -> 20201110-2)
[2020-11-12T16:55:05-0300] [ALPM] transaction completed
[2020-11-12T16:55:05-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-12T16:55:05-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-12T16:55:05-0300] [ALPM] running 'manjaro-extensions.hook'...
[2020-11-12T16:55:06-0300] [ALPM] running 'manjaro-gnome-messages.hook'...
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET]
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] ==> Printing support installed
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] ==> We have switched into qgnomeplatform instead qt5ct so now
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> qt5ct
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> qt5-styleplugins
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] are marked as orphans. If you want you can continue to use this two packages but
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] if you want use qgnomeplatform engine you need to modify your /etc/environment
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] with this changes:
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] remove or comment this:
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=qt5ct
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] add:
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> QT_AUTO_SCREEN_SCALE_FACTOR=1
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=gnome
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] -> QT_STYLE_OVERRIDE=kvantum
[2020-11-12T16:55:06-0300] [ALPM-SCRIPTLET] This is all
[2020-11-12T16:55:10-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-12T16:55:10-0300] [PACMAN] synchronizing package lists
[2020-11-12T16:55:13-0300] [PACMAN] starting full system upgrade
[2020-11-19T19:11:17-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-19T19:11:17-0300] [PACMAN] synchronizing package lists
[2020-11-19T19:11:23-0300] [PACMAN] starting full system upgrade
[2020-11-19T19:15:01-0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2020-11-19T19:15:01-0300] [ALPM] running 'firefox-pre.hook'...
[2020-11-19T19:15:01-0300] [ALPM] running 'kernel-alive-pre.hook'...
[2020-11-19T19:15:02-0300] [ALPM] transaction started
[2020-11-19T19:15:02-0300] [ALPM] upgraded adobe-source-code-pro-fonts (2.030ro+1.050it-6 -> 2.032ro+1.052it+1.012var-1)
[2020-11-19T19:15:02-0300] [ALPM] upgraded libdrm (2.4.102-1 -> 2.4.103-2)
[2020-11-19T19:15:02-0300] [ALPM] upgraded libxml2 (2.9.10-2 -> 2.9.10-6)
[2020-11-19T19:15:02-0300] [ALPM] upgraded libffi (3.3-3 -> 3.3-4)
[2020-11-19T19:15:03-0300] [ALPM] upgraded llvm-libs (10.0.1-3 -> 11.0.0-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded vulkan-icd-loader (1.2.153-2 -> 1.2.158-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded bzip2 (1.0.8-3 -> 1.0.8-4)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libldap (2.4.53-1 -> 2.4.54-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded pam (1.4.0-3 -> 1.5.0-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libcap (2.44-1 -> 2.45-2)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libunistring (0.9.10-2 -> 0.9.10-3)
[2020-11-19T19:15:03-0300] [ALPM] upgraded ca-certificates-mozilla (3.58-1 -> 3.59-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded xorg-xkbcomp (1.4.3-1 -> 1.4.4-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded xorg-server-common (1.20.9-2 -> 1.20.9-3)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libnftnl (1.1.7-1 -> 1.1.8-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded iptables (1:1.8.5-2 -> 1:1.8.6-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libwacom (1.5-1 -> 1.6-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libinput (1.16.2-1 -> 1.16.3-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded xorg-server (1.20.9-2 -> 1.20.9-3)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libassuan (2.5.3-2 -> 2.5.4-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded perl-file-listing (6.04-8 -> 6.11-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded perl-uri (1.76-4 -> 5.05-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded mhwd-nvidia-455xx (455.38-1 -> 455.45.01-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded gdk-pixbuf2 (2.40.0+6+g5432316df-1 -> 2.42.0-2)
[2020-11-19T19:15:03-0300] [ALPM] upgraded mesa (20.2.1-1 -> 20.2.2-2)
[2020-11-19T19:15:03-0300] [ALPM] upgraded adwaita-qt (1.1.90-1 -> 1.1.91-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded amd-ucode (20201023.r1747.dae4b4c-1 -> 20201113.r1774.2ea8667-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded asciidoc (9.0.3-1 -> 9.0.4-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded btrfs-progs (5.7-1 -> 5.9-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded nss (3.58-1 -> 3.59-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded libmfx (20.2.1-1 -> 20.3.1-1)
[2020-11-19T19:15:03-0300] [ALPM] upgraded hidapi (0.9.0-2 -> 0.10.0-2)
[2020-11-19T19:15:04-0300] [ALPM] upgraded libibus (1.5.22+8+gf591381e-1 -> 1.5.23+1+gdd4cc5b0-1)
[2020-11-19T19:15:04-0300] [ALPM] upgraded sdl2 (2.0.12-2 -> 2.0.12-3)
[2020-11-19T19:15:04-0300] [ALPM] upgraded js78 (78.4.0-1 -> 78.5.0-1)
[2020-11-19T19:15:04-0300] [ALPM] upgraded colord (1.4.4+9+g1ce26da-2 -> 1.4.5-1)
[2020-11-19T19:15:04-0300] [ALPM] upgraded pango (1:1.46.2-3 -> 1:1.48.0-1)
[2020-11-19T19:15:04-0300] [ALPM] upgraded chromium (86.0.4240.111-2 -> 87.0.4280.66-1)
[2020-11-19T19:15:04-0300] [ALPM] upgraded net-snmp (5.8-6 -> 5.9-1)
[2020-11-19T19:15:05-0300] [ALPM] upgraded sane (1.0.31-2 -> 1.0.31-3)
[2020-11-19T19:15:05-0300] [ALPM] upgraded colord-sane (1.4.4+9+g1ce26da-2 -> 1.4.5-1)
[2020-11-19T19:15:05-0300] [ALPM] upgraded dhcpcd (9.3.1-1 -> 9.3.2-1)
[2020-11-19T19:15:05-0300] [ALPM] upgraded enchant (2.2.11-1 -> 2.2.11-2)
[2020-11-19T19:15:06-0300] [ALPM] upgraded firefox (82.0.3-0.1 -> 83.0-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded pipewire (0.3.14-1 -> 0.3.15-2)
[2020-11-19T19:15:06-0300] [ALPM] upgraded libmm-glib (1.14.6-1 -> 1.14.8-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded flatpak (1.8.1-1 -> 1.8.3-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded fzf (0.24.1-1 -> 0.24.3-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded glslang (8.13.3743-1 -> 11.0.0-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded libhandy (1.0.1-1 -> 1.0.2-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded openal (1.20.1-2 -> 1.21.0-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded libde265 (1.0.7-1 -> 1.0.8-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded imagemagick (7.0.10.35-1 -> 7.0.10.38-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded zbar (0.23.1-2 -> 0.23.1-3)
[2020-11-19T19:15:06-0300] [ALPM] upgraded raptor (2.0.15-13 -> 2.0.15-14)
[2020-11-19T19:15:06-0300] [ALPM] upgraded gnome-contacts (3.38-1 -> 3.38.1-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded xorg-server-xwayland (1.20.9-2 -> 1.20.9-3)
[2020-11-19T19:15:06-0300] [ALPM] upgraded gnome-shell-extension-desktop-icons-ng (0.13.0-1 -> 0.14.0-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded gnome-shell-extension-gsconnect (43-1 -> 44-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded gnome-shell-extension-material-shell (9.4-1 -> 10-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded pop-shell-shortcuts (0.1-1 -> 0.2-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded gnome-shell-extension-pop-shell (1.0.0-1 -> 1.0.2-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded grep (3.5-1 -> 3.6-1)
[2020-11-19T19:15:06-0300] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2020-11-19T19:15:06-0300] [ALPM] upgraded grub (2.04-11.1 -> 2.04-12)
[2020-11-19T19:15:06-0300] [ALPM] upgraded perl-alien-build (2.33-1 -> 2.37-1)
[2020-11-19T19:15:06-0300] [ALPM] upgraded perl-alien-libxml2 (0.16-2 -> 0.17-1)
[2020-11-19T19:15:07-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/__pycache__/
filesystem: 700 package: 755
[2020-11-19T19:15:07-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/base/pexpect/__pycache__/
filesystem: 777 package: 755
[2020-11-19T19:15:07-0300] [ALPM] warning: directory permissions differ on /usr/share/hplip/prnt/__pycache__/
[2020-11-19T19:15:07-0300] [ALPM] upgraded hplip (1:3.20.9-1 -> 1:3.20.9-2)
[2020-11-19T19:15:07-0300] [ALPM] upgraded intel-gmmlib (20.2.5-1 -> 20.3.3-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded intel-media-driver (20.2.0-1 -> 20.4.1-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded intel-media-sdk (20.2.1-1 -> 20.3.1-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded kcoreaddons (5.75.0-1 -> 5.76.0-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded kauth (5.75.0-1 -> 5.76.0-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded kitemmodels (5.75.0-1 -> 5.76.0-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded kwindowsystem (5.75.0-1 -> 5.76.0-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded less (551-3 -> 563-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded lib32-gdk-pixbuf2 (2.40.0+6+g5432316df-1 -> 2.42.0-2)
[2020-11-19T19:15:07-0300] [ALPM] upgraded lib32-libldap (2.4.53-1 -> 2.4.54-1)
[2020-11-19T19:15:07-0300] [ALPM] installed lib32-libtirpc (1.2.6-1)
[2020-11-19T19:15:07-0300] [ALPM] installed lib32-libnsl (1.3.0-1)
[2020-11-19T19:15:07-0300] [ALPM] installed lib32-pam (1.4.0-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded lib32-libcap (2.44-1 -> 2.45-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded lib32-libdrm (2.4.102-1 -> 2.4.103-1)
[2020-11-19T19:15:07-0300] [ALPM] upgraded lib32-libgcrypt (1.8.6-1 -> 1.8.7-1)
[2020-11-19T19:15:08-0300] [ALPM] upgraded lib32-llvm-libs (10.0.1-1 -> 11.0.0-1)
[2020-11-19T19:15:08-0300] [ALPM] upgraded lib32-mesa (20.2.1-1 -> 20.2.2-2)
[2020-11-19T19:15:09-0300] [ALPM] upgraded lib32-nss (3.58-1 -> 3.59-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded lib32-openal (1.20.1-1 -> 1.21.0-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded lib32-pango (1:1.46.2-1 -> 1:1.48.0-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded lib32-vulkan-icd-loader (1.2.153-2 -> 1.2.158-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded libixion (0.15.0-1 -> 0.16.1-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded libmagick6 (6.9.11.34-1 -> 6.9.11.38-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded liborcus (0.15.4-1 -> 0.16.1-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded shaderc (2020.0-1 -> 2020.3-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded libplacebo (1.29.1-3 -> 2.72.2-1)
[2020-11-19T19:15:09-0300] [ALPM] upgraded rasqal (1:0.9.33-3 -> 1:0.9.33-4)
[2020-11-19T19:15:13-0300] [ALPM] upgraded libreoffice-still (6.4.7-1 -> 6.4.7-2)
[2020-11-19T19:15:18-0300] [ALPM] upgraded linux-firmware (20201023.r1747.dae4b4c-1 -> 20201113.r1774.2ea8667-1)
[2020-11-19T19:15:19-0300] [ALPM] installed linux59 (5.9.8-2)
[2020-11-19T19:15:19-0300] [ALPM] upgraded linux-latest (5.8-2 -> 5.9-1)
[2020-11-19T19:15:20-0300] [ALPM] upgraded linux54 (5.4.74-1 -> 5.4.77-1)
[2020-11-19T19:15:20-0300] [ALPM] upgraded linux-lts (1:5.4-3 -> 1:5.4-4)
[2020-11-19T19:15:20-0300] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.16-3 -> 6.1.16-5)
[2020-11-19T19:15:24-0300] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2020-11-19T19:15:24-0300] [ALPM] upgraded linux-lts-virtualbox-host-modules (1:5.4-3 -> 1:5.4-4)
[2020-11-19T19:15:25-0300] [ALPM] upgraded man-pages (5.08-1 -> 5.09-2)
[2020-11-19T19:15:25-0300] [ALPM] upgraded manjaro-browser-settings (20200629-1 -> 20201114-1)
[2020-11-19T19:15:25-0300] [ALPM] installed web-installer-url-handler (1.0.2-1)
[2020-11-19T19:15:25-0300] [ALPM] upgraded manjaro-hello (0.6.5-15 -> 0.6.6-2)
[2020-11-19T19:15:25-0300] [ALPM] upgraded matcha-gtk-theme (20201018-1 -> 20201111-1)
[2020-11-19T19:15:25-0300] [ALPM] upgraded sbcl (2.0.8-1 -> 2.0.10-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded maxima (5.44.0-3 -> 5.44.0-4)
[2020-11-19T19:15:26-0300] [ALPM] upgraded mercurial (5.5.2-1 -> 5.6-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded modemmanager (1.14.6-1 -> 1.14.8-1)
[2020-11-19T19:15:26-0300] [ALPM] installed lua53 (5.3.6-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded nmap (7.80-3 -> 7.91-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded openblas (0.3.10-1 -> 0.3.12-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded openvpn (2.4.9-2 -> 2.5.0-3)
[2020-11-19T19:15:26-0300] [ALPM-SCRIPTLET] :: OpenVPN now uses a netlink interface for network configuration. The systemd
[2020-11-19T19:15:26-0300] [ALPM-SCRIPTLET] units start the process with a dedicated unprivileged user 'openvpn', with
[2020-11-19T19:15:26-0300] [ALPM-SCRIPTLET] extra capabilities(7). The configuration should no longer drop privileges,
[2020-11-19T19:15:26-0300] [ALPM-SCRIPTLET] so remove 'user' and 'group' directives.
[2020-11-19T19:15:26-0300] [ALPM-SCRIPTLET] Scripts that require elevated privileges may need a workaround.
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-html5lib (1.1-1 -> 1.1-4)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-more-itertools (8.5.0-1 -> 8.6.0-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-numpy (1.19.2-1 -> 1.19.4-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-pep517 (0.8.2-1 -> 0.9.1-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-resolvelib (0.4.0-1 -> 0.5.1-1)
[2020-11-19T19:15:26-0300] [ALPM] installed python-ply (3.11-5)
[2020-11-19T19:15:26-0300] [ALPM] installed python-pycparser (2.20-1)
[2020-11-19T19:15:26-0300] [ALPM] installed python-cffi (1.14.3-1)
[2020-11-19T19:15:26-0300] [ALPM] installed python-asn1crypto (1.4.0-1)
[2020-11-19T19:15:26-0300] [ALPM] installed python-cryptography (3.2.1-1)
[2020-11-19T19:15:26-0300] [ALPM] installed python-pyopenssl (19.1.0-2)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-pip (20.1.1-1 -> 20.2-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded smbclient (4.13.1-1 -> 4.13.2-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded python-pysmbc (1.0.20-1 -> 1.0.23-1)
[2020-11-19T19:15:26-0300] [ALPM] upgraded qgnomeplatform (0.6.90+2+gd87c71b-1 -> 0.6.90+3+gd5a01ea-1)
[2020-11-19T19:15:27-0300] [ALPM] upgraded seahorse (1:3.37.2+29+g1d84684a-1 -> 1:3.38.0.1-1)
[2020-11-19T19:15:27-0300] [ALPM] upgraded seamonkey (2.53.3-2 -> 2.53.5-1)
[2020-11-19T19:15:27-0300] [ALPM-SCRIPTLET] SeaMonkey 2.53.5 makes changes to your profile that can't be reverted in case
[2020-11-19T19:15:27-0300] [ALPM-SCRIPTLET] you want to go back to a previous version of SeaMonkey. Make a full backup of
[2020-11-19T19:15:27-0300] [ALPM-SCRIPTLET] your profile and thoroughly read and follow the Release Notes at
[2020-11-19T19:15:27-0300] [ALPM-SCRIPTLET] https://www.seamonkey-project.org/releases/seamonkey2.53.5."
[2020-11-19T19:15:27-0300] [ALPM] upgraded usbutils (012-2 -> 013-1)
[2020-11-19T19:15:27-0300] [ALPM] upgraded steam-manjaro (1.0.0.66-1 -> 1.0.0.66-2)
[2020-11-19T19:15:27-0300] [ALPM] upgraded system-config-printer (1.5.12+33+g23b454ef-1 -> 1.5.13-1)
[2020-11-19T19:15:27-0300] [ALPM] upgraded timeshift (20.03.r8.gad3c01c-1 -> 20.11.1.r1.g3391f69-2)
[2020-11-19T19:15:27-0300] [ALPM-SCRIPTLET] ==> Attempting to enable Cronie services...
[2020-11-19T19:15:27-0300] [ALPM] upgraded unrar (1:6.0.1-1 -> 1:6.0.2-1)
[2020-11-19T19:15:28-0300] [ALPM] upgraded vlc (3.0.11.1-4 -> 3.0.11.1-6)
[2020-11-19T19:15:28-0300] [ALPM] upgraded wxmaxima (20.07.0-1 -> 20.09.0-1)
[2020-11-19T19:15:49-0300] [ALPM] transaction completed
[2020-11-19T19:15:50-0300] [ALPM] running '20-systemd-sysusers.hook'...
[2020-11-19T19:15:50-0300] [ALPM-SCRIPTLET] Creating group openvpn with gid 968.
[2020-11-19T19:15:50-0300] [ALPM-SCRIPTLET] Creating user openvpn (OpenVPN) with uid 968 and gid 968.
[2020-11-19T19:15:50-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-11-19T19:15:50-0300] [ALPM] running '30-systemd-hwdb.hook'...
[2020-11-19T19:15:52-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-11-19T19:15:52-0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-11-19T19:15:52-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-19T19:15:52-0300] [ALPM] running '40-update-ca-trust.hook'...
[2020-11-19T19:15:53-0300] [ALPM] running '60-depmod.hook'...
[2020-11-19T19:16:01-0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2020-11-19T19:16:01-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
[2020-11-19T19:16:01-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.77-1-MANJARO
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:03-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:03-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.77-1-MANJARO
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:04-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:07-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:07-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:07-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:07-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:09-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:09-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'default'
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> ERROR: '/lib/modules/5.7.19-2-MANJARO' is not a valid kernel module directory
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: 'fallback'
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'default'
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.8.18-1-MANJARO
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:14-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64.img
[2020-11-19T19:16:15-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:15-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: 'fallback'
[2020-11-19T19:16:15-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
[2020-11-19T19:16:15-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.8.18-1-MANJARO
[2020-11-19T19:16:15-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:16-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:16-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:16-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:18-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:19-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:19-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:19-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:21-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:21-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.8-x86_64-fallback.img
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.8-2-MANJARO
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:26-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.8-2-MANJARO
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-19T19:16:27-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-19T19:16:30-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-19T19:16:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-19T19:16:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-19T19:16:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-19T19:16:33-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-19T19:16:33-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-19T19:16:36-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-19T19:16:36-0300] [ALPM] running '99-grub.hook'...
[2020-11-19T19:16:37-0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2020-11-19T19:16:38-0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2020-11-19T19:16:39-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.9-x86_64
[2020-11-19T19:16:39-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.8-x86_64
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.7-x86_64
[2020-11-19T19:16:40-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
[2020-11-19T19:16:41-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
[2020-11-19T19:16:41-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.4-x86_64
[2020-11-19T19:16:41-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
[2020-11-19T19:16:41-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-19T19:16:43-0300] [ALPM-SCRIPTLET] Found Windows Boot Manager on /dev/sda2@/EFI/Microsoft/Boot/bootmgfw.efi
[2020-11-19T19:16:44-0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2020-11-19T19:16:44-0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] done
[2020-11-19T19:16:45-0300] [ALPM] running 'dbus-reload.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'firefox-post.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'fontconfig.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'fontconfig-32.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-11-19T19:16:45-0300] [ALPM] running 'kernel-alive-post.hook'...
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] ==> Warning:
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2020-11-19T19:16:45-0300] [ALPM-SCRIPTLET] -> at next boot.
[2020-11-19T19:16:45-0300] [ALPM] running 'manjaro-extensions.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'manjaro-printer.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'texinfo-install.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'update-desktop-database.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'update-mime-database.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2020-11-19T19:16:48-0300] [ALPM] running 'xorg-mkfontscale.hook'...
[2020-11-21T09:20:20-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-21T09:20:20-0300] [PACMAN] synchronizing package lists
[2020-11-21T09:20:26-0300] [PACMAN] starting full system upgrade
[2020-11-21T09:20:49-0300] [ALPM] transaction started
[2020-11-21T09:20:49-0300] [ALPM] downgraded gnome-wallpapers (20201023-1 -> 20201020-1)
[2020-11-21T09:20:49-0300] [ALPM] upgraded manjaro-application-utility (1.3.3-1 -> 1.3.3-2)
[2020-11-21T09:20:49-0300] [ALPM] upgraded manjaro-gnome-extension-settings (20201110-2 -> 20201120-3)
[2020-11-21T09:20:49-0300] [ALPM] upgraded manjaro-gnome-settings (20201110-2 -> 20201120-3)
[2020-11-21T09:20:49-0300] [ALPM] transaction completed
[2020-11-21T09:20:49-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-21T09:20:49-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-21T09:20:49-0300] [ALPM] running 'manjaro-extensions.hook'...
[2020-11-21T09:20:49-0300] [ALPM] running 'manjaro-gnome-messages.hook'...
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET]
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] ==> Printing support installed
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] ==> We have switched into qgnomeplatform instead qt5ct so now
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> qt5ct
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> qt5-styleplugins
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] are marked as orphans. If you want you can continue to use this two packages but
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] if you want use qgnomeplatform engine you need to modify your /etc/environment
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] with this changes:
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] remove or comment this:
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=qt5ct
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] add:
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> QT_AUTO_SCREEN_SCALE_FACTOR=1
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=gnome
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] -> QT_STYLE_OVERRIDE=kvantum
[2020-11-21T09:20:49-0300] [ALPM-SCRIPTLET] This is all
[2020-11-21T08:31:59-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-21T08:31:59-0300] [PACMAN] synchronizing package lists
[2020-11-21T08:32:04-0300] [PACMAN] starting full system upgrade
[2020-11-21T10:46:28-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-21T10:46:28-0300] [PACMAN] synchronizing package lists
[2020-11-21T10:46:33-0300] [PACMAN] starting full system upgrade
[2020-11-21T10:47:33-0300] [PACMAN] Running 'pacman -Syu grup'
[2020-11-21T10:47:33-0300] [PACMAN] synchronizing package lists
[2020-11-21T10:47:37-0300] [PACMAN] Running 'pacman -Syu grub'
[2020-11-21T10:47:37-0300] [PACMAN] synchronizing package lists
[2020-11-21T10:47:39-0300] [PACMAN] starting full system upgrade
[2020-11-21T10:47:53-0300] [ALPM] transaction started
[2020-11-21T10:47:53-0300] [ALPM] reinstalled grub (2.04-12)
[2020-11-21T10:47:53-0300] [ALPM] transaction completed
[2020-11-21T10:47:53-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-21T10:47:53-0300] [ALPM] running 'texinfo-install.hook'...
[2020-11-23T23:04:40-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-23T23:04:40-0300] [PACMAN] synchronizing package lists
[2020-11-23T23:04:46-0300] [PACMAN] starting full system upgrade
[2020-11-23T23:06:30-0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2020-11-23T23:06:30-0300] [ALPM] running 'kernel-alive-pre.hook'...
[2020-11-23T23:06:30-0300] [ALPM] transaction started
[2020-11-23T23:06:30-0300] [ALPM] upgraded amd-ucode (20201113.r1774.2ea8667-1 -> 20201120.r1785.bc9cd0b-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded archlinux-appstream-data (20200720-1.1 -> 20201020-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded xorg-server-common (1.20.9-3 -> 1.20.9.r21.g5c400cae1-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded xorg-server (1.20.9-3 -> 1.20.9.r21.g5c400cae1-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded gnome-control-center (3.38.1-1.1 -> 3.38.2-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded xorg-server-xwayland (1.20.9-3 -> 1.20.9.r21.g5c400cae1-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded gnome-shell-extension-pop-shell (1.0.2-1 -> 1.0.3-1)
[2020-11-23T23:06:30-0300] [ALPM] upgraded grub-theme-manjaro (20.2-9 -> 20.2-10)
[2020-11-23T23:06:31-0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2020-11-23T23:06:33-0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2020-11-23T23:06:34-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.8-x86_64
[2020-11-23T23:06:34-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
[2020-11-23T23:06:34-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
[2020-11-23T23:06:35-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.7-x86_64
[2020-11-23T23:06:35-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
[2020-11-23T23:06:35-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
[2020-11-23T23:06:37-0300] [ALPM-SCRIPTLET] grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
[2020-11-23T23:06:37-0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] done
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] ==> Installation: Theme is added to your /etc/default/grub: GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] ==> Default resolution "auto"
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] ==> If an OS icon doesn't appear probably not present in /usr/share/grub/themes/manjaro/icons simply add it or merge in
[2020-11-23T23:06:38-0300] [ALPM-SCRIPTLET] ==> https://gitlab.manjaro.org/artwork/branding/grub-theme
[2020-11-23T23:06:39-0300] [ALPM] upgraded linux-firmware (20201113.r1774.2ea8667-1 -> 20201120.r1785.bc9cd0b-1)
[2020-11-23T23:06:40-0300] [ALPM] upgraded linux54 (5.4.77-1 -> 5.4.78-1)
[2020-11-23T23:06:40-0300] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.16-5 -> 6.1.16-6)
[2020-11-23T23:06:45-0300] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2020-11-23T23:06:46-0300] [ALPM] upgraded linux59 (5.9.8-2 -> 5.9.10-1)
[2020-11-23T23:06:46-0300] [ALPM] upgraded manjaro-gnome-extension-settings (20201120-3 -> 20201121-1)
[2020-11-23T23:06:46-0300] [ALPM] upgraded manjaro-gnome-settings (20201120-3 -> 20201121-1)
[2020-11-23T23:06:46-0300] [ALPM] upgraded pamac-common (9.5.12-1 -> 9.5.12-2)
[2020-11-23T23:06:46-0300] [ALPM] upgraded manjaro-hello (0.6.6-2 -> 0.6.6-3)
[2020-11-23T23:06:46-0300] [ALPM] upgraded manjaro-release (20.2pre-1 -> 20.2rc-1)
[2020-11-23T23:06:46-0300] [ALPM] upgraded qgnomeplatform (0.6.90+3+gd5a01ea-1 -> 0.6.90+4+gee864df-1)
[2020-11-23T23:06:46-0300] [ALPM] upgraded snapd (2.47.1-1 -> 2.48-1)
[2020-11-23T23:06:47-0300] [ALPM] upgraded timeshift (20.11.1.r1.g3391f69-2 -> 20.11.1.r1.g3391f69-3)
[2020-11-23T23:06:47-0300] [ALPM-SCRIPTLET] ==> Attempting to enable Cronie services...Running in chroot, ignoring command 'is-active'
[2020-11-23T23:06:47-0300] [ALPM] transaction completed
[2020-11-23T23:06:47-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-11-23T23:06:47-0300] [ALPM-SCRIPTLET] Skipped: Current root is not booted.
[2020-11-23T23:06:47-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-11-23T23:06:47-0300] [ALPM-SCRIPTLET] Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
[2020-11-23T23:06:47-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-23T23:06:47-0300] [ALPM] running '60-depmod.hook'...
[2020-11-23T23:06:56-0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2020-11-23T23:06:56-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
[2020-11-23T23:06:56-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2020-11-23T23:06:56-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.78-1-MANJARO
[2020-11-23T23:06:56-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-23T23:06:56-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-23T23:06:57-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2020-11-23T23:06:58-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-23T23:06:58-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
[2020-11-23T23:06:58-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2020-11-23T23:06:58-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.78-1-MANJARO
[2020-11-23T23:06:58-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-23T23:06:59-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-23T23:06:59-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-23T23:06:59-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-23T23:07:01-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-23T23:07:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-23T23:07:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-23T23:07:02-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-23T23:07:04-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-23T23:07:04-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.10-1-MANJARO
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-23T23:07:08-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-23T23:07:09-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-23T23:07:09-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.10-1-MANJARO
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-23T23:07:10-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-23T23:07:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-23T23:07:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-23T23:07:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-23T23:07:13-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-23T23:07:15-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-23T23:07:15-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-23T23:07:19-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-23T23:07:19-0300] [ALPM] running '99-grub.hook'...
[2020-11-23T23:07:20-0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2020-11-23T23:07:21-0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2020-11-23T23:07:22-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.9-x86_64
[2020-11-23T23:07:22-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.8-x86_64
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.7-x86_64
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.4-x86_64
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
[2020-11-23T23:07:23-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-23T23:07:25-0300] [ALPM-SCRIPTLET] grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
[2020-11-23T23:07:26-0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2020-11-23T23:07:26-0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2020-11-23T23:07:26-0300] [ALPM-SCRIPTLET] done
[2020-11-23T23:07:26-0300] [ALPM] running 'dbus-reload.hook'...
[2020-11-23T23:07:26-0300] [ALPM-SCRIPTLET] Skipped: Current root is not booted.
[2020-11-23T23:07:26-0300] [ALPM] running 'fix-appstream-data.hook'...
[2020-11-23T23:07:26-0300] [ALPM-SCRIPTLET] archive usr/share/app-info/xmls/community.xml.gz fixed
[2020-11-23T23:07:26-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-23T23:07:26-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-11-23T23:07:27-0300] [ALPM] running 'kernel-alive-post.hook'...
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] ls: cannot access 'backup': No such file or directory
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] ==> Warning:
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> Kernel has been updated. Modules of the current kernel
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> have been backed up so you can continue to use your
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> computer. However, the new kernel will only work
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> at next boot.
[2020-11-23T23:07:27-0300] [ALPM] running 'manjaro-extensions.hook'...
[2020-11-23T23:07:27-0300] [ALPM] running 'manjaro-gnome-messages.hook'...
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] ==> Printing support installed
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] ==> We have switched into qgnomeplatform instead qt5ct so now
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> qt5ct
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> qt5-styleplugins
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] are marked as orphans. If you want you can continue to use this two packages but
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] if you want use qgnomeplatform engine you need to modify your /etc/environment
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] with this changes:
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] remove or comment this:
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=qt5ct
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] add:
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> QT_AUTO_SCREEN_SCALE_FACTOR=1
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> QT_QPA_PLATFORMTHEME=gnome
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] -> QT_STYLE_OVERRIDE=kvantum
[2020-11-23T23:07:27-0300] [ALPM-SCRIPTLET] This is all
[2020-11-23T23:07:27-0300] [ALPM] running 'update-desktop-database.hook'...
[2020-11-23T23:07:27-0300] [ALPM] running 'update-mime-database.hook'...
[2020-11-23T22:58:41-0300] [PACMAN] Running 'pacman -Syu grub'
[2020-11-23T22:58:41-0300] [PACMAN] synchronizing package lists
[2020-11-23T22:58:43-0300] [PACMAN] starting full system upgrade
[2020-11-23T22:58:52-0300] [ALPM] transaction started
[2020-11-23T22:58:53-0300] [ALPM] reinstalled grub (2.04-12)
[2020-11-23T22:58:53-0300] [ALPM] transaction completed
[2020-11-23T22:58:53-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-23T22:58:53-0300] [ALPM] running 'texinfo-install.hook'...
[2020-11-23T23:10:52-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-23T23:10:52-0300] [PACMAN] synchronizing package lists
[2020-11-23T23:10:55-0300] [PACMAN] starting full system upgrade
[2020-11-24T09:07:10-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-24T09:07:10-0300] [PACMAN] synchronizing package lists
[2020-11-24T09:07:16-0300] [PACMAN] starting full system upgrade
[2020-11-24T09:13:10-0300] [PACMAN] Running 'pacman -Syyuu'
[2020-11-24T09:13:10-0300] [PACMAN] synchronizing package lists
[2020-11-24T09:13:16-0300] [PACMAN] starting full system upgrade
[2020-11-28T15:25:53-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-28T15:25:53-0300] [PACMAN] synchronizing package lists
[2020-11-28T15:25:59-0300] [PACMAN] starting full system upgrade
[2020-11-28T15:27:56-0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2020-11-28T15:27:56-0300] [ALPM] running 'kernel-alive-pre.hook'...
[2020-11-28T15:27:56-0300] [ALPM] transaction started
[2020-11-28T15:27:56-0300] [ALPM] upgraded alsa-card-profiles (13.99.3-1 -> 14.0-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded amd-ucode (20201120.r1785.bc9cd0b-1 -> 20201124.r1786.b362fd4-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded c-ares (1.16.1-2 -> 1.17.1-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded util-linux-libs (2.36-4 -> 2.36.1-3)
[2020-11-28T15:27:56-0300] [ALPM] upgraded libjpeg-turbo (2.0.5-3 -> 2.0.6-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded libcups (2.3.3-3 -> 2.3.3+121+g63ffc5cd7-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded qpdf (10.0.3-1 -> 10.0.4-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded libraqm (0.7.0-2 -> 0.7.1-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded libx11 (1.6.12-1 -> 1.7.0-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded imagemagick (7.0.10.38-1 -> 7.0.10.43-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded util-linux (2.36-4 -> 2.36.1-3)
[2020-11-28T15:27:56-0300] [ALPM] upgraded cups-filters (1.28.5-1 -> 1.28.5-3)
[2020-11-28T15:27:56-0300] [ALPM] upgraded cups (2.3.3-3 -> 2.3.3+121+g63ffc5cd7-1)
[2020-11-28T15:27:56-0300] [ALPM-SCRIPTLET] >>> Cups systemd socket and service files have been
[2020-11-28T15:27:56-0300] [ALPM-SCRIPTLET] >>> renamed by upstream decision. Please make sure
[2020-11-28T15:27:56-0300] [ALPM-SCRIPTLET] >>> to disable/reenable the services to your need.
[2020-11-28T15:27:56-0300] [ALPM-SCRIPTLET] >>> hint: "pacman -Ql cups | grep systemd" and
[2020-11-28T15:27:56-0300] [ALPM-SCRIPTLET] >>> "ls -lR /etc/systemd/ | grep cups"
[2020-11-28T15:27:56-0300] [ALPM] upgraded gpgme (1.14.0-1 -> 1.15.0-1)
[2020-11-28T15:27:56-0300] [ALPM] upgraded perl-http-cookies (6.08-3 -> 6.09-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded mesa (20.2.2-2 -> 20.2.3-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded librsvg (2:2.50.1-1 -> 2:2.50.2-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded libxkbcommon (1.0.1-1 -> 1.0.3-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded dconf-editor (3.38.0-1 -> 3.38.2-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded dhcpcd (9.3.2-1 -> 9.3.3-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded gnome-desktop (1:3.38.1-1 -> 1:3.38.2-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded webkit2gtk (2.30.2-1 -> 2.30.3-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded evolution-data-server (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded evolution (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded libgdm (3.38.1-3 -> 3.38.2-1.2)
[2020-11-28T15:27:57-0300] [ALPM] upgraded libpulse (13.99.3-1 -> 14.0-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded pulseaudio (13.99.3-1 -> 14.0-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded pulseaudio-bluetooth (13.99.3-1 -> 14.0-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded libxkbcommon-x11 (1.0.1-1 -> 1.0.3-1)
[2020-11-28T15:27:57-0300] [ALPM] warning: directory permissions differ on /var/lib/gdm/.local/
filesystem: 755 package: 700
[2020-11-28T15:27:57-0300] [ALPM] upgraded gdm (3.38.1-3 -> 3.38.2-1.2)
[2020-11-28T15:27:57-0300] [ALPM] upgraded libsigc++ (2.10.4-2 -> 2.10.6-1)
[2020-11-28T15:27:57-0300] [ALPM] upgraded glibmm (2.64.2-1 -> 2.64.4-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded gnome-calculator (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded yelp-xsl (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded yelp (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded gnome-getting-started-docs (3.36.2-1 -> 3.38.0-1)
[2020-11-28T15:27:58-0300] [ALPM] warning: directory permissions differ on /usr/share/gls/
filesystem: 655 package: 755
[2020-11-28T15:27:58-0300] [ALPM] upgraded gnome-layout-switcher (0.8.15-1 -> 0.8.16-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded gnome-maps (3.38.1.1-1 -> 3.38.2-1)
[2020-11-28T15:27:58-0300] [ALPM] upgraded gnome-shell-extension-material-shell (10-1 -> 10-2)
[2020-11-28T15:27:59-0300] [ALPM] upgraded gnome-user-docs (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded grub-theme-manjaro (20.2-10 -> 20.2-12)
[2020-11-28T15:27:59-0300] [ALPM] upgraded lib32-libjpeg-turbo (2.0.5-1 -> 2.0.6-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded lib32-util-linux (2.36-1 -> 2.36.1-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded lib32-libx11 (1.6.12-1 -> 1.7.0-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded lib32-libpulse (13.99.3-1 -> 14.0-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded lib32-mesa (20.2.2-2 -> 20.2.3-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded libimagequant (2.13.0-1 -> 2.13.1-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded libmagick6 (6.9.11.38-1 -> 6.9.11.41-1)
[2020-11-28T15:27:59-0300] [ALPM] upgraded libnautilus-extension (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:28:01-0300] [ALPM] upgraded linux-firmware (20201120.r1785.bc9cd0b-1 -> 20201124.r1786.b362fd4-1)
[2020-11-28T15:28:02-0300] [ALPM] upgraded linux54 (5.4.78-1 -> 5.4.80-2)
[2020-11-28T15:28:02-0300] [ALPM] upgraded linux54-virtualbox-host-modules (6.1.16-6 -> 6.1.16-8)
[2020-11-28T15:28:07-0300] [ALPM-SCRIPTLET] In order to use the new version, reload all virtualbox modules manually.
[2020-11-28T15:28:08-0300] [ALPM] upgraded linux59 (5.9.10-1 -> 5.9.11-3)
[2020-11-28T15:28:08-0300] [ALPM] upgraded lsof (4.93.2-3 -> 4.94.0-1)
[2020-11-28T15:28:08-0300] [ALPM] upgraded matcha-gtk-theme (20201111-1 -> 20201123-1)
[2020-11-28T15:28:08-0300] [ALPM] upgraded nautilus (3.38.1-1 -> 3.38.2-1)
[2020-11-28T15:28:08-0300] [ALPM] upgraded pkcs11-helper (1.26.0-2 -> 1.27.0-1)
[2020-11-28T15:28:08-0300] [ALPM] upgraded xorg-xprop (1.2.4-2 -> 1.2.5-1)
[2020-11-28T15:28:08-0300] [ALPM] upgraded qt5-base (5.15.1-3 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded python-pyqt5 (5.15.1-2 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded pulseaudio-equalizer (13.99.3-1 -> 14.0-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded pulseaudio-jack (13.99.3-1 -> 14.0-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded pulseaudio-lirc (13.99.3-1 -> 14.0-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded pulseaudio-zeroconf (13.99.3-1 -> 14.0-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded python-gpgme (1.14.0-1 -> 1.15.0-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded qt5-declarative (5.15.1-1 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded qt5-styleplugins (5.0.0.20170311-24 -> 5.0.0.20170311-25)
[2020-11-28T15:28:09-0300] [ALPM] upgraded qt5-svg (5.15.1-1 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded qt5-wayland (5.15.1-1 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded qt5-x11extras (5.15.1-1 -> 5.15.2-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded remmina (1:1.4.8-1 -> 1:1.4.9-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded steam-manjaro (1.0.0.66-2 -> 1.0.0.67-1)
[2020-11-28T15:28:09-0300] [ALPM] upgraded system-config-printer (1.5.13-1 -> 1.5.13-3)
[2020-11-28T15:28:09-0300] [ALPM] upgraded tepl (5.0.0-1 -> 5.0.1-1)
[2020-11-28T15:28:09-0300] [ALPM] transaction completed
[2020-11-28T15:28:10-0300] [ALPM] running '20-systemd-sysusers.hook'...
[2020-11-28T15:28:10-0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2020-11-28T15:28:10-0300] [ALPM-SCRIPTLET] Skipped: Current root is not booted.
[2020-11-28T15:28:10-0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2020-11-28T15:28:10-0300] [ALPM-SCRIPTLET] Failed to open file "/sys/devices/system/cpu/microcode/reload": Read-only file system
[2020-11-28T15:28:10-0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2020-11-28T15:28:10-0300] [ALPM-SCRIPTLET] Skipped: Device manager is not running.
[2020-11-28T15:28:10-0300] [ALPM] running '30-systemd-update.hook'...
[2020-11-28T15:28:10-0300] [ALPM] running '60-depmod.hook'...
[2020-11-28T15:28:19-0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2020-11-28T15:28:19-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'default'
[2020-11-28T15:28:19-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64.img
[2020-11-28T15:28:19-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.80-2-MANJARO
[2020-11-28T15:28:19-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-28T15:28:19-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-28T15:28:20-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64.img
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux54.preset: 'fallback'
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.4-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.4-x86_64-fallback.img -S autodetect
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.4.80-2-MANJARO
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-28T15:28:22-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-28T15:28:24-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-28T15:28:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-28T15:28:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-28T15:28:25-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-28T15:28:27-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-28T15:28:27-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.11-3-MANJARO
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [autodetect]
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-28T15:28:31-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-28T15:28:32-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] -> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] ==> Starting build: 5.9.11-3-MANJARO
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] -> Running build hook: [base]
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] -> Running build hook: [udev]
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] -> Running build hook: [modconf]
[2020-11-28T15:28:33-0300] [ALPM-SCRIPTLET] -> Running build hook: [block]
[2020-11-28T15:28:36-0300] [ALPM-SCRIPTLET] -> Running build hook: [keyboard]
[2020-11-28T15:28:37-0300] [ALPM-SCRIPTLET] -> Running build hook: [keymap]
[2020-11-28T15:28:37-0300] [ALPM-SCRIPTLET] -> Running build hook: [resume]
[2020-11-28T15:28:37-0300] [ALPM-SCRIPTLET] -> Running build hook: [filesystems]
[2020-11-28T15:28:39-0300] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2020-11-28T15:28:39-0300] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-28T15:28:43-0300] [ALPM-SCRIPTLET] ==> Image generation successful
[2020-11-28T15:28:43-0300] [ALPM] running '99-grub.hook'...
[2020-11-28T15:28:44-0300] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2020-11-28T15:28:45-0300] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2020-11-28T15:28:46-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.9-x86_64
[2020-11-28T15:28:46-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.9-x86_64.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.9-x86_64-fallback.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.8-x86_64
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.8-x86_64.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.7-x86_64
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.7-x86_64.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-5.4-x86_64
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
[2020-11-28T15:28:47-0300] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
[2020-11-28T15:28:49-0300] [ALPM-SCRIPTLET] grub-probe: error: cannot find a GRUB drive for /dev/sdb1. Check your device.map.
[2020-11-28T15:28:50-0300] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2020-11-28T15:28:50-0300] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2020-11-28T15:28:50-0300] [ALPM-SCRIPTLET] done
[2020-11-28T15:28:50-0300] [ALPM] running 'dbus-reload.hook'...
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] Skipped: Current root is not booted.
[2020-11-28T15:28:51-0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'glib-compile-schemas.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'kernel-alive-post.hook'...
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] ==> Warning:
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] -> This computer hasn't been restarted for a while.
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] -> You are running an old kernel. In order to use a
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] -> new version of the kernel, please restart your
[2020-11-28T15:28:51-0300] [ALPM-SCRIPTLET] -> computer as soon as possible.
[2020-11-28T15:28:51-0300] [ALPM] running 'manjaro-extensions.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'manjaro-printer.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'texinfo-install.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'update-desktop-database.hook'...
[2020-11-28T15:28:51-0300] [ALPM] running 'update-mime-database.hook'...
[2020-11-29T14:01:45-0300] [PACMAN] Running 'pacman -Syu'
[2020-11-29T14:01:45-0300] [PACMAN] synchronizing package lists
[2020-11-29T14:01:47-0300] [PACMAN] starting full system upgrade
My problem is very similar to the one discussed in this topic Manjaro not showing in GRUB. After messing around, cannot get into GRUB at all and I think I followed a very similar path before finding it. So, I’ll provide the information I saw presented there:
lsblk -fs before chroot
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINT
loop0 squashfs 4.0 0 100% /run/miso/sfs/livefs
loop1 squashfs 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squashfs 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squashfs 4.0 0 100% /run/miso/sfs/rootfs
sda1 ntfs Recuperación 4E92EB0292EAED81
└─sda
sda2 vfat FAT32 6CEB-2DFC
└─sda
sda3
└─sda
sda4 ntfs 6E7EF14C7EF10E19 50.8G 41% /run/media/manjaro/6E7EF14C7EF10E19
└─sda
sda5 swap 1 68ec6328-4e61-45a8-af0d-5b5c8ebaf44c
└─sda
sda6 ext4 1.0 10de1d38-749f-4be2-91cd-98a67e745183 74.3G 40% /run/media/manjaro/10de1d38-749f-4be2-91cd-98a67e745183
└─sda
sdb1 iso9660 Joliet Extension MANJARO_GNOME_2012 2020-10-19-12-09-32-00
└─sdb iso9660 Joliet Extension MANJARO_GNOME_2012 2020-10-19-12-09-32-00 0 100% /run/miso/bootmnt
sdb2 vfat FAT12 MISO_EFI 0854-9541
as well as fdisk -l
Disk /dev/sda: 232.89 GiB, 250059350016 bytes, 488397168 sectors
Disk model: WDC WDS250G2B0B
Disklabel type: gpt
Disk identifier: 10373556-0239-4A38-9F9E-41584EB41EE3
Device Start End Sectors Size Type
/dev/sda1 2048 1085439 1083392 529M Windows recovery environment
/dev/sda2 1085440 1288191 202752 99M EFI System
/dev/sda3 1288192 1320959 32768 16M Microsoft reserved
/dev/sda4 1320960 181196799 179875840 85.8G Microsoft basic data
/dev/sda5 181196800 197580799 16384000 7.8G Linux swap
/dev/sda6 197580800 488397134 290816335 138.7G Linux filesystem
Disk /dev/loop0: 68.83 MiB, 72175616 bytes, 140968 sectors
Disk /dev/loop1: 569.75 MiB, 597426176 bytes, 1166848 sectors
Disk /dev/loop2: 1.28 GiB, 1379057664 bytes, 2693472 sectors
Disk /dev/loop3: 630.15 MiB, 660762624 bytes, 1290552 sectors
Disk /dev/sdb: 7.62 GiB, 8178892800 bytes, 15974400 sectors
Disk model: Flash Disk
Disklabel type: dos
Disk identifier: 0x00000000
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 64 5425319 5425256 2.6G 0 Empty
/dev/sdb2 5425320 5433511 8192 4M ef EFI (FAT-12/16/32)
This is cat /etc/fstab under chroot
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=6CEB-2DFC /boot/efi vfat umask=0077 0 2
UUID=68ec6328-4e61-45a8-af0d-5b5c8ebaf44c swap swap defaults,noatime,discard 0 2
UUID=10de1d38-749f-4be2-91cd-98a67e745183 / ext4 defaults,noatime,discard 0 1
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
sudo parted -l
Model: ATA WDC WDS250G2B0B (scsi)
Disk /dev/sda: 250GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 556MB 555MB ntfs Basic data partition hidden, diag
2 556MB 660MB 104MB fat32 EFI system partition boot, esp
3 660MB 676MB 16.8MB Microsoft reserved partition msftres
4 676MB 92.8GB 92.1GB ntfs Basic data partition msftdata
5 92.8GB 101GB 8389MB linux-swap(v1) swap
6 101GB 250GB 149GB ext4
Model: Generic Flash Disk (scsi)
Disk /dev/sdb: 8179MB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2778MB 2782MB 4194kB primary esp
ans sudo efibootmgr -v
BootCurrent: 0003
Timeout: 1 seconds
BootOrder: 0002,0000,0003,0004,0001,0005
Boot0000* Windows Boot Manager HD(2,GPT,045ba8f5-a82a-4d89-97fc-09cde2b0f788,0x109000,0x31800)/File(\EFI\MICROSOFT\BOOT\BOOTMGFW.EFI)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...9................
Boot0001* WDC WDS250G2B0B-00YS70 BBS(HD,,0x0)..BO
Boot0002* manjaro HD(2,GPT,045ba8f5-a82a-4d89-97fc-09cde2b0f788,0x109000,0x31800)/File(\EFI\MANJARO\GRUBX64.EFI)
Boot0003* UEFI: Generic Flash Disk 8.07 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(7,0)/CDROM(1,0x52c8a8,0x8000)..BO
Boot0004* UEFI: Generic Flash Disk 8.07, Partition 2 PciRoot(0x0)/Pci(0x1,0x3)/Pci(0x0,0x0)/USB(7,0)/HD(2,MBR,0x0,0x52c8a8,0x2000)..BO
Boot0005* Generic Flash Disk 8.07 BBS(HD,,0x0)..BO
I read in some of the references I cited that the output of mkinitcpio -P might be relevant:
==> ERROR: '/lib/modules/5.8.18-1-MANJARO' is not a valid kernel module directory
I’m really sorry for this really long post. I can do a clean reainstall of Manjaro (that would be the straightforward and brute force fix since my level of expertise and understanding in GNU/Linux is low) but I want to learn how to fix the problem instead. I don’t think I have two boot managers as concluded (at least partially concluded) in Manjaro not showing in GRUB. After messing around, cannot get into GRUB at all - #13 by Soup . Even if I do, I wouldn’t know what to do next to fix that.
Any advice or suggestion is welcomed. Cheers.
