I’m clueless
journalctl -p err -b
fev 08 23:10:04 rohan kernel:
fev 08 23:10:06 rohan bluetoothd[944]: Failed to set mode: Not Supported (0x0c)
fev 08 23:10:18 rohan kwin_x11[1123]: kwin_core: Compositing is not possible
fev 08 23:10:19 rohan pulseaudio[1503]: Failed to find a working profile.
fev 08 23:10:19 rohan pulseaudio[1503]: Failed to load module "module-alsa-card" (argument: "device_id="3" name="usb-046d_Lo
data:
inxi -Fxxxz
Kernel: 5.10.96-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: Z390-A PRO (MS-7B98) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.D0 date: 01/19/2021
Info: 6-core model: Intel Core i5-9600K bits: 64 type: MCP
smt: <unsupported> arch: Coffee Lake rev: C cache: L1: 384 KiB L2: 1.5 MiB
L3: 9 MiB
Speed (MHz): avg: 800 min/max: 800/4700 volts: 0.9 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 bogomips: 44412
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: eVga.com. driver: nvidia
v: 510.47.03 bus-ID: 01:00.0 chip-ID: 10de:2503 class-ID: 0300
Device-2: Logitech Logitech Webcam C925e type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-2.4:9 chip-ID: 046d:085b
class-ID: 0102 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia resolution: 1920x1080 s-dpi: 81
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Device-2: NVIDIA vendor: eVga.com. driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-3: Bose Bose PC Desktop Controller type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:7 chip-ID: 05a7:4040
class-ID: 0300 serial: <filter>
Device-4: Logitech Logitech Webcam C925e type: USB
Sound Server-1: ALSA v: k5.10.96-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
IF-ID-1: br-232fd21ea23b state: down mac: <filter>
IF-ID-2: br-5d01cbb2628b state: down mac: <filter>
IF-ID-3: docker0 state: down mac: <filter>
driver: btusb v: 0.8 bus-ID: 1-2.2:6 chip-ID: 0a12:0001 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: <filter>
Local Storage: total: 1.76 TiB used: 297.79 GiB (16.5%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: KB.3 temp: 29 C scheme: GPT
ID-2: /dev/sdb vendor: Samsung model: SSD 840 EVO 500GB size: 465.76 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: DB6Q scheme: GPT
ID-3: /dev/sdc vendor: Kingston model: SA400S37480G size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0102 temp: 35 C scheme: GPT
ID-4: /dev/sdd vendor: A-Data model: SU630 size: 447.13 GiB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4c12 temp: 34 C scheme: GPT
ID-1: / size: 439.11 GiB used: 263.99 GiB (60.1%) fs: ext4 dev: /dev/sdc1
ID-2: /boot/efi size: 96 MiB used: 37.3 MiB (38.9%) fs: vfat
dev: /dev/sdb2
ID-1: swap-1 type: file size: 4 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 27.8 C pch: 38.0 C mobo: N/A gpu: nvidia
temp: 44 C
Processes: 270 Uptime: 2m wakeups: 0 Memory: 31.3 GiB used: 2.58 GiB (8.3%)
Init: systemd v: 250 Compilers: gcc: 11.1.0 alt: 10/8/9 clang: 13.0.0
Packages: 2072 pacman: 2066 snap: 6 Shell: Bash (su) v: 5.1.16
