None of my microphones work. I tried to use 3.5mm jack clipping microphone and I tried internal microphone - it didnt work, scilence. Tried to test the sound through Audacity. I have pipewire
installed.
We need hardware info - else we are as blind as you are.
Search for “How to post” and “how to provide information”.
inxi -Fxz
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.11 Distro: Manjaro base: Arch Linux
Type: Laptop System: ASUSTeK product: GL752VW v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: GL752VW v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: GL752VW.303 date: 04/29/2019
ID-1: BAT0 charge: 0 Wh (0.0%) condition: 14.0/38.5 Wh (36.3%) volts: 14.8
min: 14.8 model: ASUSTeK ASUS Battery status: charging
Info: quad core model: Intel Core i7-6700HQ bits: 64 type: MT MCP
arch: Skylake-S rev: 3 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 1736 high: 2485 min/max: 800/3500 cores: 1: 2112
2: 800 3: 2219 4: 2485 5: 2372 6: 800 7: 2300 8: 800 bogomips: 41621
Device-1: Intel HD Graphics 530 vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-9 bus-ID: 00:02.0
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK
driver: nvidia v: 550.67 arch: Maxwell bus-ID: 01:00.0
Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6 driver:
X: loaded: modesetting,nvidia dri: iris gpu: i915
resolution: 1920x1080~60Hz
API: EGL v: 1.5 drivers: iris,nvidia,swrast platforms:
active: x11,surfaceless,device inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 960M/PCIe/SSE2
API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib devices: 1
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api
Server-1: sndiod v: N/A status: off
Server-2: JACK v: 1.9.22 status: off
Server-3: PipeWire v: 1.0.3 status: active
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel bus-ID: 02:00.0
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel port: d000
bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8
type: USB bus-ID: 1-9:4
Local Storage: total: 2.96 TiB used: 2.3 TiB (77.7%)
ID-1: /dev/sda vendor: Samsung model: SSD 860 EVO M.2 250GB
ID-2: /dev/sdb vendor: Western Digital model: WD10JPVX-22JC3T0
ID-3: /dev/sdc vendor: Western Digital model: WD20SPZX-22UA7T0
size: 1.82 TiB type: USB
ID-1: / size: 61.94 GiB used: 50.38 GiB (81.3%) fs: ext4 dev: /dev/sda4
ID-2: /boot/efi size: 510.9 MiB used: 25.7 MiB (5.0%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 441.85 GiB used: 361.97 GiB (81.9%) fs: ext4
dev: /dev/sdb6
ID-1: swap-1 type: partition size: 18 GiB used: 0 KiB (0.0%)
dev: /dev/sdb2
System Temperatures: cpu: 61.0 C pch: 48.5 C mobo: N/A gpu: nvidia
temp: 54 C
Fan Speeds (rpm): cpu: 2100
Memory: total: 16 GiB available: 15.52 GiB used: 6.3 GiB (40.6%)
Processes: 273 Uptime: 2h 14m Init: systemd
Packages: 1909 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
v: 5.2.26 inxi: 3.3.34
I can also try sudo lshw
This post isnt dead yet
I will not be able to help here - I could only fumble in the dark.
Only try this and that without really knowing what I’m doing.
… but you could try this too - other people have had audio issues as well and you can read all about it here
Ok, sure, I will try. Thank you.
I found some more ways to get the info about my system, I hope this would be of help:
$ inxi --admin --verbosity=8 --filter --no-host --width
Kernel: 6.7.0-1-rt6-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-rt-x86_64
root=UUID=5497af2c-f35c-4354-8d68-65516923c4ef rw quiet splash
udev.log_priority=3 intel_iommu=on vfio-pci.ids=10de:139b
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
part-nu: ASUS-NotebookSKU uuid: <superuser required>
min: 14.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 36
System RAM: total: 16 GiB available: 15.52 GiB used: 3.57 GiB (23.0%)
Array-1: capacity: 64 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: 1201 part-no: R748G2400S2S serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 801 2: 800 3: 800 4: 800
5: 800 6: 800 7: 800 8: 800 bogomips: 41599
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0
chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: ASUSTeK driver: nvidia
v: 550.67 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
(as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:139b class-ID: 0302
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 75 s-size: 652x366mm (25.67x14.41")
s-diag: 748mm (29.44")
Monitor-1: eDP-1 mapped: eDP-1-1 model: ChiMei InnoLux 0x1735 built: 2014
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 chroma: red: x: 0.639 y: 0.333
green: x: 0.314 y: 0.616 blue: x: 0.153 y: 0.059 white: x: 0.314 y: 0.329
size: 381x214mm (15x8.43") diag: 437mm (17.2") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
drv: nvidia x11: drv: nvidia inactive: gbm,wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67 glx-v: 1.4
memory: 1.95 GiB
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 960M driver: nvidia v: 550.67 device-ID: 10de:139b
surfaces: xcb,xlib
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.7.0-1-rt6-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off with: nsmd status: off tools: N/A
Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
vendor: ASUSTeK RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.1 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:4 chip-ID: 8087:0a2a
class-ID: e001
Local Storage: total: 2.96 TiB used: 2.3 TiB (77.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10JPVX-22JC3T0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD20SPZX-22UA7T0 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0
tech: HDD rpm: 5400 serial: <filter> scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUE1N rev: AS00
dev-links: cdrom
ID-1: / raw-size: 64 GiB size: 61.94 GiB (96.79%) used: 51.03 GiB (82.4%)
fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: LinuxSSD
uuid: 5497af2c-f35c-4354-8d68-65516923c4ef
ID-2: /boot/efi raw-size: 512 MiB size: 510.9 MiB (99.80%)
used: 25.7 MiB (5.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: LINUXGRUB
uuid: 9634-52B8
ID-3: /home raw-size: 450 GiB size: 441.85 GiB (98.19%)
used: 368.27 GiB (83.3%) fs: ext4 dev: /dev/sdb6 maj-min: 8:22
label: LinuxHDD uuid: d0fa418d-adb6-4d14-9346-183bd7bc422d
ID-4: /mnt/2E6B542A4CD0DCF6 raw-size: 200 GiB size: 200 GiB (100.00%)
used: 119.58 GiB (59.8%) fs: ntfs dev: /dev/sdb5 maj-min: 8:21
label: WinStorage uuid: 2E6B542A4CD0DCF6
ID-5: /mnt/6224CB7524CB4AAD raw-size: 80 GiB size: 80 GiB (100.00%)
used: 46.74 GiB (58.4%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 6224CB7524CB4AAD
ID-6: /mnt/77FE-53D6 raw-size: 150 GiB size: 149.99 GiB (100.00%)
used: 148.61 GiB (99.1%) fs: exfat dev: /dev/sdb1 maj-min: 8:17
label: Dualshare uuid: 77FE-53D6
ID-7: /run/media/jakus/Transcend raw-size: 1.82 TiB
size: 1.82 TiB (100.00%) used: 1.59 TiB (87.2%) fs: ntfs dev: /dev/sdc1
maj-min: 8:33 label: Transcend uuid: 231A07AC7388D266
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 18 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: d320795e-e79b-43e7-b2a4-fcc7229274ed
ID-1: /dev/sda3 maj-min: 8:3 size: 16 MiB fs: ext4 label: LinuxSSDtemp
uuid: a81e8a93-ca6b-4601-b458-eacc54c375be
Hub-2: 1-5:2 info: Manufacturer hub ports: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA chip-ID: 0a05:7211
Device-1: 1-5.3:5 info: SINOWEALTH Game Mouse type: mouse,keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 256mA chip-ID: 258a:1007 class-ID: 0301
Device-2: 1-6:3 info: Transcend Information StoreJet 25H3
type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8564:7000
class-ID: 0806 serial: <filter>
Device-3: 1-9:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
Hub-3: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 63.0 C pch: 46.5 C mobo: N/A gpu: nvidia temp: 53 C
Fan Speeds (rpm): cpu: 2200
Packages: 1913 pm: pacman pkgs: 1872 libs: 526 tools: pamac,yay pm: flatpak
pkgs: 41
1: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://muug.ca/mirror/manjaro/stable/$repo/$arch
3: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
5: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
6: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
7: https://mirror.dc.uz/manjaro/stable/$repo/$arch
8: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 313
1: cpu: 42.5% command: firefox pid: 1760 mem: 115.2 MiB (0.7%)
2: cpu: 29.3% command: firefox pid: 1257 mem: 563.9 MiB (3.5%)
3: cpu: 17.4% command: kwin_x11 pid: 852 mem: 162.4 MiB (1.0%)
4: cpu: 15.8% command: firefox pid: 3448 mem: 247.6 MiB (1.5%)
5: cpu: 6.7% command: firefox pid: 3041 mem: 327.5 MiB (2.0%)
Memory top: 5 of 313
1: mem: 563.9 MiB (3.5%) command: firefox pid: 1257 cpu: 29.3%
2: mem: 485.9 MiB (3.0%) command: firefox pid: 2472 cpu: 5.2%
3: mem: 484.5 MiB (3.0%) command: firefox pid: 2552 cpu: 6.3%
4: mem: 426.9 MiB (2.6%) command: plasmashell pid: 886 cpu: 1.6%
5: mem: 369.0 MiB (2.3%) command: firefox pid: 2669 cpu: 4.8%
Processes: 313 Power: uptime: 40m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 16.0.6 gcc: 13.2.1 alt: 12 Shell: Bash v: 5.2.26
running-in: konsole inxi: 3.3.34
$ amixer -c0 && amixer -c1
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 74
Mono: Playback 67 [91%] [-7.00dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-74.00dB] [off]
Front Right: Playback 0 [0%] [-74.00dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 74 [100%] [0.00dB] [on]
Front Right: Playback 74 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 251 [98%] [-0.80dB]
Front Right: Playback 251 [98%] [-0.80dB]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 3 [100%] [36.00dB]
Front Right: 3 [100%] [36.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'Beep',0
Mono: Playback 3 [43%] [-16.00dB] [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 80
Front Left: Capture 80 [100%] [6.00dB] [on]
Front Right: Capture 80 [100%] [6.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Digital',0
Limits: Capture 0 - 120
Front Left: Capture 60 [50%] [0.00dB]
Front Right: Capture 60 [50%] [0.00dB]
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Invalid card number '1'.
This looks wrong.
How did you do that?
The correct way to install pipewire on manjaro is with the metapackage:
sudo pacman -Syu manjaro-pipewire
I did it just now
$ sudo pacman -Syu manjaro-pipewire
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
:: pipewire-pulse and pulseaudio are in conflict. Remove pulseaudio? [y/N] y
Packages (3) pipewire-pulse-1:1.0.3-1 pulseaudio-17.0-3 [removal]
manjaro-pipewire-20231009-1
Total Installed Size: 0,48 MiB
Net Upgrade Size: -5,54 MiB
:: Proceed with installation? [Y/n] y
(2/2) checking keys in keyring [####################] 100%
(2/2) checking package integrity [####################] 100%
(2/2) loading package files [####################] 100%
(2/2) checking for file conflicts [####################] 100%
(3/3) checking available disk space [####################] 100%
Removed "/etc/systemd/user/sockets.target.wants/pulseaudio.socket".
(1/1) removing pulseaudio [####################] 100%
(1/2) installing pipewire-pulse [####################] 100%
Created symlink /etc/systemd/user/sockets.target.wants/pipewire-pulse.socket → /usr/lib/systemd/user/pipewire-pulse.socket.
(2/2) installing manjaro-pipewire [####################] 100%
Optional dependencies for manjaro-pipewire
easyeffects: advanced equalizer and effects
pipewire-jack: Jack support
pipewire-v4l2: V4L2 interceptor
pipewire-x11-bell: X11 bell
pipewire-zeroconf: Zeroconf support
realtime-privileges: Realtime privileges for users
(1/6) Reloading user manager configuration...
(2/6) Reloading device manager configuration...
(3/6) Arming ConditionNeedsUpdate...
(4/6) Refreshing PackageKit...
(5/6) Reloading system bus configuration...
(6/6) Compiling GSettings XML schema files...
But nothing changed
Speed (MHz): avg: 800 min/max: 800/3500 cores: 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 bogomips: 41599
bus-ID: 03:00.1
Local Storage: total: 2.96 TiB used: 2.3 TiB (77.8%)
ID-1: / size: 61.94 GiB used: 50.95 GiB (82.3%) fs: ext4 dev: /dev/sda4
dev: /dev/sda1
ID-3: /home size: 441.85 GiB used: 366.65 GiB (83.0%) fs: ext4
dev: /dev/sdb6
dev: /dev/sdb2
System Temperatures: cpu: 64.0 C pch: 46.0 C mobo: N/A gpu: nvidia
temp: 53 C
Memory: total: 16 GiB available: 15.52 GiB used: 6.18 GiB (39.8%)
Processes: 339 Uptime: 1h 19m Init: systemd
Packages: 1913 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Bash
And I am currently on kernel-67-rt instead of kernel-66, I looked at the posts of other people and they said that the problem was resolved after updating the kernel, but its back in 2022, it didnt work for me.
Please make sure to reboot.
Also switch to a regular kernel.
rt
is for specific needs like audio production.
Well, that certainly gives information about your system; perhaps too much, depending upon how security-conscious you might be. Technically speaking, it might be possible to trace purchases using hardware serial numbers, if someone had access to that information.
I would usually suggest something like:
With this command the --filter
and --no-host
portions effectively filter out any personally identifiable information from the output. Try it yourself (with and without) for comparison.
Cheers.
Please post more information about audio devices and microphone sources detected in PipeWire
pactl list cards; pactl list sources
Also suggest turning off pipewire-pulse service to test if Audacity can record direct from ALSA microphone sources without PipeWire
Audacity problem with monitor while recording
systemctl --user stop pipewire-pulse.socket pipewire-pulse.service
If direct recording from ALSA sources does not work get a full ALSA diagnostic
sudo alsa-info,sh --upload
and post link to uploaded data
I have edited the post, thank you for your advice!
$ pactl list cards; pactl list sources
Card #39
Driver: alsa
Owner Module: n/a
Properties:
device.enum.api = "udev"
device.api = "alsa"
media.class = "Audio/Device"
api.alsa.path = "hw:0"
api.alsa.card = "0"
api.alsa.card.name = "HDA Intel PCH"
api.alsa.card.longname = "HDA Intel PCH at 0xdf328000 irq 133"
device.plugged.usec = "7780027"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.subsystem = "sound"
device.vendor.id = "0x8086"
device.product.id = "0xa170"
device.product.name = "100 Series/C230 Series Chipset Family HD Audio Controller"
device.name = "alsa_card.pci-0000_00_1f.3"
device.description = "Built-in Audio"
device.nick = "HDA Intel PCH"
device.icon_name = "audio-card-pci"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
factory.id = "14"
client.id = "32"
object.id = "39"
object.serial = "39"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xdf328000 irq 133"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: no)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5765, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 665, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
pro-audio: Pro Audio (sinks: 4, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:analog-stereo
Ports:
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, availability group: Legacy 1, availability unknown)
Properties:
port.type = "mic"
port.availability-group = "Legacy 1"
card.profile.port = "0"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1+input:analog-stereo, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2+input:analog-stereo
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
port.availability-group = "Legacy 2"
card.profile.port = "1"
analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability group: Legacy 3, availability unknown)
Properties:
port.type = "speaker"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "headphones"
port.availability-group = "Legacy 4"
card.profile.port = "3"
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
card.profile.port = "5"
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-stereo-extra1+input:analog-stereo, output:hdmi-surround-extra1, output:hdmi-surround-extra1+input:analog-stereo, output:hdmi-surround71-extra1, output:hdmi-surround71-extra1+input:analog-stereo
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 7, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 7"
card.profile.port = "6"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-stereo-extra2+input:analog-stereo, output:hdmi-surround-extra2, output:hdmi-surround-extra2+input:analog-stereo, output:hdmi-surround71-extra2, output:hdmi-surround71-extra2+input:analog-stereo
Card #57
Driver: module-bluez5-device.c
Owner Module: n/a
Properties:
device.api = "bluez5"
device.bus = "bluetooth"
device.name = "bluez_card.D8_37_3B_8B_4A_FB"
device.description = "JBL Flip 5"
device.alias = "JBL Flip 5"
device.form_factor = "speaker"
device.string = "D8:37:3B:8B:4A:FB"
api.bluez5.icon = "audio-card"
api.bluez5.path = "/org/bluez/hci0/dev_D8_37_3B_8B_4A_FB"
api.bluez5.address = "D8:37:3B:8B:4A:FB"
api.bluez5.device = ""
api.bluez5.class = "0x240414"
api.bluez5.connection = "connected"
device.icon_name = "audio-speakers-bluetooth"
bluez5.auto-connect = "[ hfp_hf hsp_hs a2dp_sink ]"
factory.id = "14"
client.id = "32"
object.id = "57"
object.serial = "57"
Profiles:
a2dp-sink: High Fidelity Playback (A2DP Sink, codec SBC) (sinks: 1, sources: 0, priority: 18, available: yes)
a2dp-sink-sbc_xq: High Fidelity Playback (A2DP Sink, codec SBC-XQ) (sinks: 1, sources: 0, priority: 17, available: yes)
Active Profile: a2dp-sink
Ports:
speaker-output: Speaker (type: Speaker, priority: 0, latency offset: 0 usec, available)
Properties:
Part of profile(s): a2dp-sink, a2dp-sink-sbc_xq
Source #40
State: SUSPENDED
Description: Monitor of Built-in Audio Analog Stereo
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0,00 dB, front-right: 65536 / 100% / 0,00 dB
balance 0,00
Base Volume: 65536 / 100% / 0,00 dB
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:front:0:playback"
api.alsa.path = "front:0"
api.alsa.pcm.card = "0"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "2"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "monitor"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "CX20751/2 Analog"
alsa.id = "CX20751/2 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
card.profile.device = "6"
device.id = "39"
factory.name = "api.alsa.pcm.sink"
priority.driver = "1009"
priority.session = "1009"
media.class = "Audio/Sink"
node.nick = "HDA Intel PCH"
node.name = "alsa_output.pci-0000_00_1f.3.analog-stereo"
device.icon_name = "audio-card-analog"
device.bus = "pci"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "33"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "40"
object.serial = "40"
api.alsa.card = "0"
device.string = "0"
Ports:
analog-output-speaker: Speakers (type: Speaker, priority: 10000, availability group: Legacy 3, availability unknown)
analog-output-headphones: Headphones (type: Headphones, priority: 9900, availability group: Legacy 4, not available)
Active Port: analog-output-speaker
Formats:
pcm
Source #41
State: RUNNING
Description: Built-in Audio Analog Stereo
Driver: PipeWire
Mute: no
balance 0,00
Base Volume: 13076 / 20% / -42,00 dB
Monitor of Sink: n/a
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:0:front:0:capture"
api.alsa.pcm.stream = "capture"
device.routes = "2"
device.api = "alsa"
device.class = "sound"
alsa.device = "0"
alsa.card = "0"
card.profile.device = "0"
device.id = "39"
factory.name = "api.alsa.pcm.source"
priority.driver = "2009"
priority.session = "2009"
media.class = "Audio/Source"
node.name = "alsa_input.pci-0000_00_1f.3.analog-stereo"
device.icon_name = "audio-input-microphone-analog"
device.bus = "pci"
factory.id = "18"
client.id = "33"
factory.mode = "split"
object.id = "41"
object.serial = "41"
node.max-latency = "16384/48000"
api.alsa.period-size = "1024"
api.alsa.period-num = "32"
api.alsa.headroom = "32"
api.alsa.card = "0"
device.string = "0"
Ports:
analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, availability group: Legacy 1, availability unknown)
analog-input-mic: Microphone (type: Mic, priority: 8700, availability group: Legacy 2, not available)
Active Port: analog-input-internal-mic
Formats:
pcm
Source #58
State: SUSPENDED
Description: Monitor of JBL Flip 5
Driver: PipeWire
Sample Specification: s16le 2ch 44100Hz
Mute: no
balance 0,00
Monitor of Sink: bluez_output.D8_37_3B_8B_4A_FB.a2dp-sink
Properties:
api.bluez5.transport = ""
api.bluez5.profile = "a2dp-sink"
api.bluez5.codec = "sbc"
device.routes = "1"
card.profile.device = "1"
device.id = "57"
node.name = "bluez_output.D8_37_3B_8B_4A_FB.a2dp-sink"
factory.name = "api.bluez5.a2dp.sink"
priority.driver = "1010"
priority.session = "1010"
factory.id = "8"
media.name = "JBL Flip 5"
object.id = "58"
object.serial = "58"
client.id = "32"
Ports:
speaker-output: Speaker (type: Speaker, priority: 0, available)
Active Port: speaker-output
Formats:
pcm
It didnt work for me, I try using every record device in Audacity, but most of them dont work or bug out.
$ sudo alsa-info.sh --upload
/usr/bin/alsa-info.sh: line 659: tree: command not found
Uploading information to www.alsa-project.org ... Done!
Your ALSA information is located at http://alsa-project.org/db/?f=fd802dcf42b986afdb2cd3ed9be29ab5b50b6361
Please inform the person helping you.
I tried using JBL Tune 720TB to record the audio with 3.5mm jack connected to the mic port and Audacity started catching the actual recording. Its pretty poor quality, but I can hear my recording.
The internal microphone and the clipping pin mic that I can use only on my phone are not working in my laptop. For recording purposes I could go and find if there are any mics sold in electronic market so it could be compatible with my laptop.
check your manual of the laptop of the 3,5mm jack is a 3-pin (only headphone) or a 4-pin (headphone and mic) connection before you go shopping. i’m suspicious that your laptop-3,5mm jack is only a 3-pin headphone jack.
The JBL headset has a 4-pin jack connection cable so the microphone jack socket on laptop is probably compatible with any 2-pin or 3-pin jack plug but only one type of 4-pin jack
CTIA Vs OMTP: Understanding Headphone Jack Standards
If the other external microphone works with a mobile phone but not the laptop it is probably using the other wiring standard. This can be fixed by getting an adaptor to swap the connections:
Considering the comment about poor audio quality from the JBL microphone, it is probably not worth bothering about the internal microphone because it is not likely to be any better than the
headset microphone. It could be worse for electrical noise within laptop or vibrational noise from fans or using keyboard/touchpad
Both devices will have a sub-miniature (3-6mm) omnidirectional microphone that is too small to pick up bass frequencies but will pick background noise in the room
Lack of bass is not a major problem if microphone is only used for VOIP calls (less bass can improve intelligibility for VOIP calls)
To reduce moderate background noise, use a unidirectional microphone,
For high levels of background noise, use a dynamic microphone (stage microphone) and a pre-amplifier or audio interface
@cscs
sndio is for MIDI audio and unlikely to be relevant to microphone issues even if it was running
Thank you very much, I will look it up in the market.
