Hey guys.
I installed Manjaro kde like 3 months ago, but last week since i turn it on it cant connect to WIFI, only by ethernet cable. It doesnt show any wifi in connections. What should i do?
Thanks in advance for the help
Hey guys.
What kind of information do I need to show here? Im new to manjaro so i dont know what to do.
What should i write in terminal?
Welcome to Manjaro! ![]()
inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information for us to be able to help you. (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command):+1
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=2bd8df94-ab5d-40e2-a7b0-1c954b56bf2c rw quiet apparmor=1
security=apparmor resume=UUID=71f24179-5ad5-4bc9-a136-c783a2ea78a7
udev.log_priority=3
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: Modern 14 A10RAS v: REV:1.0
Mobo: Micro-Star model: MS-14B3 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E14B3IMS.50E date: 01/10/2020
ID-1: BAT1 charge: 4.8 Wh (14.9%) condition: 32.2/50.0 Wh (64.4%)
volts: 14.1 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Discharging
RAM: total: 15.47 GiB used: 2.56 GiB (16.5%)
RAM Report:
Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 936 high: 994 min/max: 400/4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 994 2: 944 3: 907 4: 903
5: 916 6: 954 7: 971 8: 900 bogomips: 36812
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: srbds mitigation: TSX disabled
Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1d16 class-ID: 0302
Device-3: Acer HD Webcam type: USB driver: uvcvideo bus-ID: 1-7:3
chip-ID: 5986:211b class-ID: 0e02
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158
size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
Device-1: Intel Comet Lake PCH-LP cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: yes
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
Device-2: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
type: USB driver: r8152 bus-ID: 2-3:3 chip-ID: 2357:0601 class-ID: 0000
serial: <filter>
IF: enp0s20f0u3 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-10:4 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 953.87 GiB used: 24.56 GiB (2.6%)
model: PC SN730 SDBPNTY-1T00-1032 size: 953.87 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 11110000 temp: 30.9 C scheme: GPT
ID-1: / raw-size: 936.55 GiB size: 920.78 GiB (98.32%)
used: 24.56 GiB (2.7%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 2bd8df94-ab5d-40e2-a7b0-1c954b56bf2c
label: NO_LABEL uuid: 6AC5-F7AC
ID-1: swap-1 type: partition size: 17.02 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 71f24179-5ad5-4bc9-a136-c783a2ea78a7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-7:3 info: Acer HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 5986:211b
class-ID: 0e02
Device-3: 1-10:4 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.1 speed: 10 Gb/s
Device-1: 2-3:3
info: TP-Link UE300 10/100/1000 LAN (ethernet mode) [Realtek RTL8153]
type: Network driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s
power: 256mA chip-ID: 2357:0601 class-ID: 0000 serial: <filter>
System Temperatures: cpu: 40.0 C pch: 42.0 C mobo: N/A gpu: nouveau
temp: 24.0 C
Processes: 260 Uptime: 19m wakeups: 20 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1269 pacman: 1264 lib: 342
flatpak: 0 snap: 5 Shell: Zsh v: 5.8 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.12
1, You should update the kernel to version 5.15.
2. Install another LTS kernel like 5.10.
ok i installed version 5.15. now how do i “use” it?
Reboot and select kernel 5.15 with “advanced menu” of Grub.
how do I go to the grub menu when rebooting? it goes automatically?
Oh, i need to go to BIOS right
Press Esc during boot to get into grub menu > advanced options and boot with 5.15.
Nope!
I confirmed and im in linux 5.15, but still doesnt show any connections in wifi? Does anyone now the problem or it may be a hardware problem?
Can you show ip addr on console ?
Hey!
I hope you are all well. I have a MSI MODERN A10RAS. I installed manjaro kde in October, but since last week network doesnt shoew any connections available, so i can only connect to WIFI by using an ethernet cable. Can someone help me?
I wrote this code “inxi --admin --verbosity=7 --filter --no-host --width” in terminal and i have this info.
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
udev.log_priority=3
ID-1: BAT1 charge: 17.1 Wh (53.1%) condition: 32.2/50.0 Wh (64.4%)
volts: 15.8 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: Charging
RAM: total: 15.47 GiB used: 1.88 GiB (12.1%)
RAM Report:
Speed (MHz): avg: 800 min/max: 400/4900 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 36812
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
serial: <filter>
Local Storage: total: 953.87 GiB used: 25.45 GiB (2.7%)
used: 25.45 GiB (2.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
class-ID: 0e02
Device-1: 2-3:3
System Temperatures: cpu: 43.0 C pch: 41.0 C mobo: N/A
Processes: 259 Uptime: 29m wakeups: 153 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: 1273 pacman: 1268 lib: 342
Thanks in advance
Please do not start any new threads about the same topic in order to bump your issue. It’s antisocial.
Oh ok, sorry for that.
I tried rebooting my laptop but it still does not work. Any suggestions?
