Journalctl:
Sep 18 12:04:55 HP-Manjaro-8760W kernel: x86/cpu: VMX (outside TXT) disabled by BIOS
Sep 18 12:04:55 HP-Manjaro-8760W kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
Sep 18 12:04:55 HP-Manjaro-8760W kernel: #2 #3 #4 #5 #6 #7
Sep 18 12:04:55 HP-Manjaro-8760W kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Sep 18 12:04:55 HP-Manjaro-8760W kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20210730/utaddress-204)
Sep 18 12:04:55 HP-Manjaro-8760W kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Sep 18 12:04:55 HP-Manjaro-8760W kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Sep 18 12:04:55 HP-Manjaro-8760W kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20210730/utaddress-204)
Sep 18 12:04:55 HP-Manjaro-8760W kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Sep 18 12:04:56 HP-Manjaro-8760W kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Sep 18 12:04:56 HP-Manjaro-8760W systemd-udevd[339]: could not read from '/sys/module/pcc_cpufreq/initstate': No such device
Sep 18 12:04:56 HP-Manjaro-8760W kernel: iwlwifi 0000:25:00.0: can't disable ASPM; OS doesn't have ASPM control
Sep 18 12:04:56 HP-Manjaro-8760W kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
Sep 18 12:04:56 HP-Manjaro-8760W kernel: iwlwifi 0000:25:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
Sep 18 12:04:56 HP-Manjaro-8760W systemd[454]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 18 12:05:01 HP-Manjaro-8760W kernel: kauditd_printk_skb: 33 callbacks suppressed
Sep 18 12:05:08 HP-Manjaro-8760W ModemManager[488]: <warn> [plugin/ericsson-mbm] could not grab port cdc-wdm1: Cannot add port 'usbmisc/cdc-wdm1', unhandled port type
Sep 18 12:05:08 HP-Manjaro-8760W ModemManager[488]: <warn> [plugin/ericsson-mbm] could not grab port cdc-wdm0: Cannot add port 'usbmisc/cdc-wdm0', unhandled port type
Sep 18 12:05:08 HP-Manjaro-8760W ModemManager[488]: <warn> [modem0] modem couldn't be initialized: Couldn't check unlock status: SIM not inserted
Sep 18 12:05:42 HP-Manjaro-8760W kernel: kauditd_printk_skb: 18 callbacks suppressed
Sep 18 12:06:17 HP-Manjaro-8760W kernel: kauditd_printk_skb: 12 callbacks suppressed
Sep 18 12:06:31 HP-Manjaro-8760W kernel: nvidia: loading out-of-tree module taints kernel.
Sep 18 12:06:31 HP-Manjaro-8760W kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 18 12:06:31 HP-Manjaro-8760W kernel: Disabling lock debugging due to kernel taint
Sep 18 12:06:31 HP-Manjaro-8760W kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 390.154 Wed Jun 22 04:50:54 UTC 2022 (using threaded interrupts)
Sep 18 12:06:31 HP-Manjaro-8760W kernel: ACPI Warning: \_SB.PCI0.PEGP.DGFX._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Sep 18 12:06:34 HP-Manjaro-8760W systemd[957]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Sep 18 12:06:34 HP-Manjaro-8760W systemd[957]: Failed to start Update XDG user dir configuration.
Sep 18 12:06:34 HP-Manjaro-8760W sddm-greeter[966]: QFont::fromString: Invalid description '(empty)'
Sep 18 12:06:35 HP-Manjaro-8760W sddm-greeter[966]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7fff6f8c4600), parent's thread is QThread(0x5652b51e44b0), current thread is QThread(0x5652b52ca270)
Sep 18 12:06:35 HP-Manjaro-8760W sddm-greeter[966]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Sep 18 12:06:38 HP-Manjaro-8760W kernel: kauditd_printk_skb: 26 callbacks suppressed
Sep 18 12:06:38 HP-Manjaro-8760W sddm-greeter[966]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Sep 18 12:06:38 HP-Manjaro-8760W sddm-greeter[966]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:127:5: Type Keyboard unavailable
Sep 18 12:06:38 HP-Manjaro-8760W sddm-greeter[966]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 18 12:06:39 HP-Manjaro-8760W sddm-greeter[966]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Sep 18 12:06:39 HP-Manjaro-8760W sddm-greeter[966]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.30'
Sep 18 12:06:43 HP-Manjaro-8760W startplasma-x11[1005]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Sep 18 12:06:43 HP-Manjaro-8760W startplasma-x11[1005]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Sep 18 12:06:44 HP-Manjaro-8760W ksplashqml[1017]: file:///usr/share/plasma/look-and-feel/com.github.varlesh.arc-dark/contents/splash/Splash.qml:89: ReferenceError: bottomRect is not defined
Sep 18 12:06:44 HP-Manjaro-8760W ksplashqml[1017]: file:///usr/share/plasma/look-and-feel/com.github.varlesh.arc-dark/contents/splash/Splash.qml:88: ReferenceError: bottomRect is not defined
Sep 18 12:06:44 HP-Manjaro-8760W ksmserver[1041]: Qt: Session management error: networkIdsList argument is NULL
Sep 18 12:06:44 HP-Manjaro-8760W kwin_x11[1044]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 18 12:06:44 HP-Manjaro-8760W kwin_x11[1044]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 18 12:06:44 HP-Manjaro-8760W ksmserver[1041]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Sep 18 12:06:45 HP-Manjaro-8760W plasmashell[1079]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 18 12:06:45 HP-Manjaro-8760W plasmashell[1079]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 18 12:06:45 HP-Manjaro-8760W kwin_x11[1044]: QObject::connect(KWin::InputMethod, KWin::EffectsHandlerImpl): invalid nullptr parameter
Sep 18 12:06:45 HP-Manjaro-8760W org_kde_powerdevil[1104]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Sep 18 12:06:45 HP-Manjaro-8760W kded5[1043]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.12'
Sep 18 12:06:45 HP-Manjaro-8760W org_kde_powerdevil[1104]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: "file:///home/niekkamer/.local/share/plasma/wallpapers/com.github.zren.inactiveblur/contents/ui/main.qml"
"Error loading QML file.\n28: Type ImageBaseMain unavailable\n85: Wallpaper.Image is not a type\n"
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 18 12:06:46 HP-Manjaro-8760W pipewire[1285]: mod.rt: Can't find xdg-portal: (null)
Sep 18 12:06:46 HP-Manjaro-8760W pipewire[1285]: mod.rt: found session bus but no portal
Sep 18 12:06:46 HP-Manjaro-8760W pipewire-media-session[1286]: mod.rt: Can't find xdg-portal: (null)
Sep 18 12:06:46 HP-Manjaro-8760W pipewire-media-session[1286]: mod.rt: found session bus but no portal
Sep 18 12:06:46 HP-Manjaro-8760W pipewire-media-session[1286]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 18 12:06:46 HP-Manjaro-8760W pipewire-media-session[1286]: mod.rt: could not make thread 1287 realtime using RTKit: Permission denied
Sep 18 12:06:46 HP-Manjaro-8760W pipewire[1285]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 18 12:06:46 HP-Manjaro-8760W pipewire[1285]: mod.rt: could not make thread 1290 realtime using RTKit: Permission denied
Sep 18 12:06:46 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1427, resource id: 4194325, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Sep 18 12:06:46 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55ae33d55620)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55ae33d5ce00)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55ae33b0c440)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x55ae33d5a1f0)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x55ae33d5c090)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x55ae33c10800)
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Sep 18 12:06:47 HP-Manjaro-8760W pulseaudio[1304]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 18 12:06:47 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Sep 18 12:06:48 HP-Manjaro-8760W plasmashell[1079]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 18 12:06:49 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:49 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Sep 18 12:06:50 HP-Manjaro-8760W systemd-coredump[1334]: [🡕] Process 1331 (firefox) of user 1000 dumped core.
Module /usr/lib/firefox/libmozsandbox.so with build-id dc456eafbc413227cd7785ba1d8463eeb66b9c5d
Module linux-vdso.so.1 with build-id 1686649ed9e6cab45b7f5fc7ec9ba72cdd893077
Module libGLX.so.0 with build-id 1d664a1f03d6c5c9ac997c4b73f3e8a11424cc74
Module libGLdispatch.so.0 with build-id 9901dca23d6ccd49929b5f44c81cd671f1ec6757
Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
Module libGL.so.1 with build-id a3025d7d2cce51ecb2d47c076bfddefbf7e081f0
Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
Module libdrm.so.2 with build-id 356062bd182635dcd90b1bcc5c260c08d00c034f
Module libva.so.2 with build-id 86f6af953ddbabe2cec3a48dec22c013b1729ff0
Module libva-drm.so.2 with build-id a98ca6baacddfc0c4f7cd380a5e8b3e76e6f36fd
Module libnvidia-eglcore.so.390.154 without build-id.
Module libnvidia-glsi.so.390.154 without build-id.
Module libdl.so.2 with build-id 3b5b9c7c3efd20001319657d1972e90e853984e2
Module librt.so.1 with build-id d5760a2d214d5bd2703337bdc13d500144f29b52
Module libpthread.so.0 with build-id 135923f9a38592e2e90692c8191278a166f86569
Module libplds4.so with build-id 35c8b19ee309f8a4c2a4409568d2ab4f11a6557a
Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
Module libnssutil3.so with build-id ea147ded2a6ce242e8035ab85ef599ac8dc7513f
Module libnss3.so with build-id 9c5ee273b0fdf590dfb5ec8548f1c4bcbd1c8b57
Module libsmime3.so with build-id 0bb1ee6db00884d0821db7e6ca004f3f92ffd012
Module libssl3.so with build-id c569984be2cf1314ad48f8a4aca98a5a374b65aa
Module libplc4.so with build-id d3b585736c213f75d6d1071f8db9a6219f1dd429
Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
Module libxul.so with build-id f31af8c8d89b678ff8de3f73acb17bd670384dd4
Module libmozwayland.so with build-id 4062e7cfa98a1684c8e6c403c5e4b08a47cc596a
Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
Module liblz4.so.1 with build-id 84ea95d811dad359e94e100ebe6a746294ffe8a7
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 1f87347b85b55db2f75a2ecea5cb45d846dc7093
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libsystemd.so.0 with build-id f53e01cd7b3e5ff8757530ed7a65324ae12df5c8
Module liblzma.so.5 with build-id d08f5868cd5adcc6b7c53bf1725aac65bd4539cd
Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
Module libXau.so.6 with build-id d9d5e8277140f1a86d3a07d9b52b1703c0a2f9a8
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id fb2c5d3c17aac74758a3eb80a2bc1c16bcf183b1
Module libxml2.so.2 with build-id 49868de417eee9052facae410a866ebfbd5cceb8
Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
Module libsqlite3.so.0 with build-id 9af0762dc0b9aa82565f566ef69424a8e4af58da
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libtiff.so.5 with build-id 62a8aefb339c3cbe35d1089c66c527a7b090804c
Module libjpeg.so.8 with build-id 46dfd8b2cbe8a10d13cd3182a7b490d0959534f9
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libmount.so.1 with build-id 9064fc3620c42e6f7aed38119f0a3ec39fca9a37
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpcre.so.1 with build-id 10d377210d07112c78388fd15b6c25f2bf4110c4
Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
Module libtracker-sparql-3.0.so.0 with build-id 75ab4f2e3b5c479b5c4fc62793bf398ee28f4ab7
Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
Module libgdk_pixbuf-2.0.so.0 with build-id b2822dc16bd1470683ce421978ad142c4f3c3f89
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libpangoft2-1.0.so.0 with build-id 4a5a975bc9e397294c88738430515901a51c304c
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libharfbuzz.so.0 with build-id 236ab65053439e673a39fcb7aadedb28b17a338a
Module libpango-1.0.so.0 with build-id a971a5fed3b8b9cf076fe5edb9a9f04ced3da211
Module libpangocairo-1.0.so.0 with build-id 37f75358f8778498bcc26a1658107953d9495255
Module libgio-2.0.so.0 with build-id 23198c3347999718bef2a6da6c1ee43671698b4e
Module libgobject-2.0.so.0 with build-id 7a75492959a9cada07d07098aea7fe4f2378ad01
Module libglib-2.0.so.0 with build-id 898773b9f59cbaa435131f67db1ce0537d75647a
Module libgmodule-2.0.so.0 with build-id 1d277e7565a07e17f8b93c576b82f59f3b1332da
Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
Module libmozgtk.so with build-id 15edb2fe44745048d3cd643c25557e8f623d74fd
Module libmozsqlite3.so with build-id 0e8f838d5836da9a1abbc29e058707937094fa4b
Module liblgpllibs.so with build-id b4dd45cc8526658f4726474413d4dd63f9a41a97
Module libnspr4.so with build-id 64bc745fdf99e414eeda94b9345af6fa6fcce329
Module ld-linux-x86-64.so.2 with build-id da64753d57bf3801827448f53d911b041568e727
Module libc.so.6 with build-id 9c28cfc869012ebbd43cdb0f1eebcd14e1b8bdd8
Module libgcc_s.so.1 with build-id 85db482c4585a328d95ec41124337a967bb24d8f
Module libm.so.6 with build-id 0b8d43ea2dae21a1c5e44c3f0a9dc2fb292d27c0
Module libstdc++.so.6 with build-id 735a3d0cc7699fd69337361cba4aedb644b2a7ed
Module firefox with build-id 793597793d78d994f75277bbc7b144f3f8252700
Stack trace of thread 1331:
#0 0x00007f85c4eb6814 XDisplayString (libX11.so.6 + 0x2b814)
#1 0x00007f85b81b1a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
#2 0x00007f85b7e53c8a n/a (libva.so.2 + 0x3c8a)
#3 0x00007f85b7e59be1 vaInitialize (libva.so.2 + 0x9be1)
#4 0x00007f85c075b6c7 n/a (libxul.so + 0x85a16c7)
#5 0x00007f85c075c2d9 n/a (libxul.so + 0x85a22d9)
#6 0x00007f85bc6a228e n/a (libxul.so + 0x44e828e)
#7 0x00007f85bc6a0095 n/a (libxul.so + 0x44e6095)
#8 0x00007f85bc692cc5 n/a (libxul.so + 0x44d8cc5)
#9 0x00007f85bc691e7d n/a (libxul.so + 0x44d7e7d)
#10 0x000055dbc526fa92 n/a (firefox + 0x55a92)
#11 0x00007f85c6cb22d0 n/a (libc.so.6 + 0x232d0)
#12 0x00007f85c6cb238a __libc_start_main (libc.so.6 + 0x2338a)
#13 0x000055dbc527f305 _start (firefox + 0x65305)
Sep 18 12:06:50 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:51 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:51 HP-Manjaro-8760W plasmashell[1079]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 18 12:06:52 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:53 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:06:54 HP-Manjaro-8760W plasmashell[1079]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 18 12:08:16 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Sep 18 12:08:17 HP-Manjaro-8760W plasmashell[1079]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:385: Unable to assign [undefined] to QString
Sep 18 12:08:17 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 24661, resource id: 27263049, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:08:17 HP-Manjaro-8760W konsole[1694]: QFSFileEngine::open: No file name specified
Sep 18 12:08:17 HP-Manjaro-8760W konsole[1694]: QIODevice::read (QFile, ""): device not open
Sep 18 12:08:34 HP-Manjaro-8760W kernel: kauditd_printk_skb: 2 callbacks suppressed
Sep 18 12:09:01 HP-Manjaro-8760W dolphin[1684]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Sep 18 12:09:01 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31485, resource id: 4194326, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:09:20 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36090, resource id: 69206024, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:09:20 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36094, resource id: 67109058, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:09:20 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 36117, resource id: 4194327, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:12:47 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2916, resource id: 65011720, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:14:14 HP-Manjaro-8760W dolphin[1684]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Sep 18 12:17:22 HP-Manjaro-8760W org_kde_powerdevil[1104]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Sep 18 12:18:27 HP-Manjaro-8760W kwin_x11[1044]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 29249, resource id: 65011720, major code: 18 (ChangeProperty), minor code: 0
Sep 18 12:18:37 HP-Manjaro-8760W org_kde_powerdevil[1104]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
Sep 18 12:19:52 HP-Manjaro-8760W org_kde_powerdevil[1104]: org.kde.powerdevil: Unsatisfied policies, the action has been aborted
dmesg nvidia:
[ 102.465477] nvidia: loading out-of-tree module taints kernel.
[ 102.465486] nvidia: module license 'NVIDIA' taints kernel.
[ 102.470522] nvidia: module verification failed: signature and/or required key missing - tainting kernel
[ 102.487923] nvidia-nvlink: Nvlink Core is being initialized, major device number 508
[ 102.488274] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=io+mem
[ 102.552381] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 390.154 Wed Jun 22 04:42:33 UTC 2022
[ 102.614789] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 102.614793] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 0
Grub’s CMDLINE:
GRUB_CMDLINE_LINUX_DEFAULT="quiet resume=UUID=d5291e4f-366e-4c90-beb4-d46c1e4dd94c nouveau.modeset=0 udev.log_priority=3"
GRUB_CMDLINE_LINUX="nouveau.modeset=0"
I changed the CMDLINE to nouveau.modeset=0 because that fixed my other laptop. Doesnt seem to do anything for this one
