At first, I thought that my GPU was failing because I have it working with a SATA adapter to 6 pins power. The failure consisted in opening blender and run some file moderately complex graphics and Cemu in Zelda when I took the viewer, the pc was froze.
I decided to install Optimizus Manager since I have 2 monitors and through Corectrl I see that the use of the pc is static as if it was not being used. However, when using Cemu and play if you use the GPU, the use of the pc is static if you use the GPU.
OS: Manjaro Linux x86_64
ββββββββββββββββββ ββββββββ Kernel: 6.1.26-1-MANJARO
ββββββββ ββββββββ Uptime: 12 mins
ββββββββ ββββββββ ββββββββ Packages: 1182 (pacman)
ββββββββ ββββββββ ββββββββ Shell: zsh 5.9
ββββββββ ββββββββ ββββββββ Resolution: 1366x768, 1366x768
ββββββββ ββββββββ ββββββββ DE: GNOME 43.5
ββββββββ ββββββββ ββββββββ WM: Mutter
ββββββββ ββββββββ ββββββββ WM Theme: Adwaita
ββββββββ ββββββββ ββββββββ Theme: Adw-dark [GTK2/3]
ββββββββ ββββββββ ββββββββ Icons: Papirus-Dark-Maia [GTK2/3]
ββββββββ ββββββββ ββββββββ Terminal: gnome-terminal
CPU: Intel i7-4790S (8) @ 4.000GHz
GPU: AMD ATI Radeon R7 370 / R9 270/370 OEM
GPU: Intel HD Graphics
Memory: 2480MiB / 7834MiB
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Removed useless screenshots
Hello @liltingle
What do you expect? There is the Intel GPU which is used by default and ab Amd GPU which can be used on demand. When you start blender without targeting the AMD, it will use Intel.
well thatβs what you would expect to happen, it just never happens, it only happens in the cemu emulator that gives you the option to specify which graphic to use.
Moderator edit: Useless images removed. Again.
What is your main gpu now? Where is what connected? Which GLX are you using by default? You provide zero information about that. See what @cscs linked plus:
glxinfo | grep "OpenGL renderer"
DRI_PRIME=1 glxinfo | grep "OpenGL renderer"
What cemu emulator actually does is switching GLX. It applies DRI_PRIME=1 before launching emulation, which is what I call βused on demandβ.
Or use xrandr (if you use xorg, not wayland) to set the βrender offload sinkβ, see here: PRIME - ArchWiki
$ glxinfo | grep "OpenGL renderer"
OpenGL renderer string: Mesa Intel(R) HD Graphics 4600 (HSW GT2)
$ DRI_PRIME=1 glxinfo | grep "OpenGL renderer"`
OpenGL renderer string: AMD Radeon R7 370 Series (pitcairn, LLVM 15.0.7, DRM 3.49, 6.1.26-1-MANJARO)
So you understand now what I mean? It does not switch automatically βOpenGLβ β βGLXβ.
ooo great using DRI_PRIME=1 before running blender I get the expected result, to transpolate that function to the whole system I have to use which command?
xrandr.
xrandr --listproviders
xrandr --setprovideroffloadsink radeon Intel
xrandr --setprovideroffloadsink 1 0
More information see man xrandr
$ DRI_PRIME=pci-0000_06_00_0 glxinfo | grep 'OpenGL renderer'
Providers: number : 2
Provider 0: id: 0x46 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 3 outputs: 5 associated providers: 1 name:modesetting
Provider 1: id: 0x87 cap: 0xf, Source Output, Sink Output, Source Offload, Sink Offload crtcs: 6 outputs: 4 associated providers: 1 name:modesetting
$ xrandr --setprovideroffloadsink radeon Intel`
Could not find provider with name radeon
$ xrandr --setprovideroffloadsink 1 0
Please read the link I provided:
There is also an example for a xorg config mentioned for a permanent solution.
what I donβt understand is why xrandr --listproviders gives me 2 modesetting, instead of 1 amd and 1 intel.
Because both are running with xorg modesetting (Kernel Mode Setting) driver, which is the default nowadays. Yeah I understand, it can be confusing, but early there were actually 2 different drivers.
yes, but I think there is something not specified or wrong with my pc configuration.
xrandr --listactivemonitors ξ²
Monitors: 2
0: +*VGA-1 1366/413x768/234+1366+0 VGA-1
1: +HDMI-1-3 1366/410x768/230+0+0 HDMI-1-3
as I understood this command is to invert the order but as the option of the names is discarded because they are the same, the numbers could be an alternative however it gives this error
xrandr --setprovideroffloadsink 0 1
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 34 (RRSetProviderOffloadSink)
Value in failed request: 0x46
Serial number of failed request: 16
Current serial number in output stream: 17
