My dvd isn't detected on Manjaro
Hi there! I’m using Manjaro KDE edition.
When I was trying to use one of my dvds; I can’t find it on my file manager(dophin).
I don’t know what’s the reason of that.
Please help me :pray:
Is this only one specific dvd,
or all dvds inserted ?
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
[HowTo] Provide System Information
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already searched for your problem in the forum ?
(Wisdom lies in reading :wink: )
Is it an external DVD? Is it a data disk or movie? Do you understand how to mount drives? Checked in the Devices panel of Dolphin to see if it’s there? Do you have the kio-slaves installed? If it’s a movie, can you play it with a media player?
for all dvds
no that’s built-in.
data disk.
Yes I do but my computer doesn’t notify me that the dvd is detected.
It doesn’t show my dvd.
How can I install that?
I can’t find the dvd on dolphin.
Only a partial answer to @andreas85 post.
The output of the command:
should list, among other things, the optical drive
  Kernel: 6.1.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=db6a5684-f11a-49e3-9947-c42265718ac8 rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.8 wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: Gigabyte model: P75-D3 v: x.x serial: N/A
    UEFI: American Megatrends v: F11 date: 11/04/2013
  RAM: total: 7.71 GiB used: 4.13 GiB (53.6%)
  Array-1: capacity: 32 GiB slots: 4 EC: None max-module-size: 8 GiB
    note: est.
  Device-1: ChannelB-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM1 type: no module installed
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: 99P5474-013.A00LF serial: <filter>
  Device-4: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Core i3-2120 bits: 64 type: MT MCP arch: Sandy Bridge
    gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
    model-id: 0x2A (42) stepping: 7 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 3221 high: 3293 min/max: 1600/3300 base/boost: 3300/7000
    scaling: driver: intel_cpufreq governor: schedutil volts: 1.1 V
    ext-clock: 100 MHz cores: 1: 3293 2: 3083 3: 3216 4: 3292 bogomips: 26349
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs lahf_lm lm mca mce md_clear
    mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good sep ssbd sse
    sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_deadline_timer vme vmx vnmi vpid xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GF119 [GeForce GT 610] vendor: Gigabyte driver: nvidia
    v: 390.157 alternate: nouveau,nvidia_drm non-free: series: 390.xx+
    status: legacy-active (EOL~late 2022) arch: Fermi code: GF1xx
    process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:104a class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 84 s-size: 413x232mm (16.26x9.13")
    s-diag: 474mm (18.65")
  Monitor-1: VGA-0 res: 1366x768 hz: 60 dpi: 85 size: 410x230mm (16.14x9.06")
    diag: 470mm (18.51") modes: N/A
  API: OpenGL v: 4.6.0 NVIDIA 390.157 renderer: GeForce GT 610/PCIe/SSE2
    direct-render: Yes
  Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
    class-ID: 0403
  Device-2: NVIDIA GF119 HDMI Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:0e08 class-ID: 0403
  API: ALSA v: k6.1.25-1-MANJARO status: kernel-api with: aoss
    type: oss-emulator tools: alsamixer,amixer
  Server-2: PipeWire v: 0.3.70 status: off with: pipewire-media-session
    status: off tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: active (root, process)
    with: pulseaudio-jack type: module tools: pacat,pactl
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 931.51 GiB used: 167.84 GiB (18.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZRX-00D8PB0
    family: Green size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
    sata: 3.0 speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0A80
    temp: 28 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 295d 9h cycles: 4307
  Optical-1: /dev/sr0 vendor: ATAPI model: iHAS122 W rev: PL01
    dev-links: cdrom
  Features: speed: 62 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 167.84 GiB (18.3%) fs: ext4 block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2 label: N/A uuid: db6a5684-f11a-49e3-9947-c42265718ac8
    used: 312 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
    label: NO_LABEL uuid: 3DF1-D34E
  Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
  Device-1: 1-1.5:3 info: SINO WEALTH USB KEYBOARD type: Keyboard,HID
    power: 100mA chip-ID: 258a:0001 class-ID: 0300
  Device-2: 1-1.6:4 info: Avago Pte. ADNS-5700 Optical Mouse Controller
    (3-button) type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s power: 98mA chip-ID: 192f:0416 class-ID: 0301
  Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 90.0 C mobo: N/A
  Processes: 210 Uptime: 22h 55m wakeups: 32 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1553 libs: 400 tools: pamac pm: flatpak pkgs: 0
  Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16 running-in: yakuake
  inxi: 3.3.26
use the package-manager and install “k3b”. mark all additional packages you are questioned to install.
after installation open a konsole and post the output of
cdrecord dev=/dev/sr0 -checkdrive
scsidev: '/dev/sr0'
devname: '/dev/sr0'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
Using libscg version 'schily-0.9'.
Device type    : Removable CD-ROM
Version        : 5
Response Format: 2
Capabilities   :
Vendor_info    : 'ATAPI   '
Identifikation : 'iHAS122   W     '
Revision       : 'PL01'
Device seems to be: Generic mmc2 DVD-R/DVD-RW/DVD-RAM.
Using generic SCSI-3/mmc   CD-R/CD-RW driver (mmc_cdr).
Driver flags   : MMC-3 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R LAYER_JUMP
cdrecord: Warning: Cannot read drive buffer.
cdrecord: Warning: The DMA speed test has been skipped.```
I just tried that and I can read my dvds now.
thanks a lot for your help :pray:
