Try running:
startplasma-x11
Try running:
startplasma-x11
DISPLAY=:0 startplasma-x11
caused this popup to show up:
Other than that, had no visible effect.
HMMMmmmâŚWelpâŚ
It seems Iâm either being cursed by your PC in arabic or something, or itâs possessed and you need an exorcist.
Either way, I donât know what to do. Sorry.
Just thought of this: try running it without the prefix:
startplasma-x11
I meant these:
That was the first thing I tried. Just gives me the error:
$DISPLAY is not set or cannot connect to the X server.
That didnât help.
I rebooted, entered the password, and the issue persists.
rerun update again:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
if you are up to date, and there are no errors, check with:
sudo ldconfig
it should return nothing, if it does, create a new test user, reboot, log in with it and see if it has the same issues
There have been some recent forum posts suggesting that corruption of a KDE configuration file was to blame for some similar issues. You could try renaming the file; plasma will create a fresh one after logging out and back in.
mv ~/.config/plasma-org.kde.plasma.desktop-appletsrc ~/.config/plasma-org.kde.plasma.desktop-appletsrc.bak
If things work properly afterwards, you could try to restore your original desktop appearance with the relevant lines from the original config file.
Indeed, that was the issue.
I just found this:
I didnât need to move/remove the file, just deleting the [ScreenMapping] section was enough.
My gosh the KDE people really need to get their s*** together
some process(es) after autologin failed to start, from what I can see
(looks like telegram.desktop)
you could try to disable autologin
it (in theory) should not affect the display manager itself
have you tried stopping and then starting the service?
but perhaps what @Takakage said
I donât run KDE (only in a VM) and have never experienced a problem
but I also never had autologin - too many problems with apps that want or need authentication before they start
I used KDE5/Plasma for a brief time, and during that time, I routinely backed up:
to $HOME/kdeSaves.
I restored when the desktop seemed to , ârandomly lose the desktop settingsâ. Never found the root cause, but was leaning towards multiple monitors. Interesting that it is still necessary to backup config files.
