My boot time is 2+ minutes
I dont know why but my boot time is 2 minutes, like the time from starting the pc and seeing my desktop light up is pretty long. Is this normal? I thought manjaro was supposed to start up faster than windows but its like way slower for some reason. How do I deal with this? I can post logs or some important info if you want.
Please don’t use invented abbreviations and run-on sentences. This is a support forum, not a social network or instant messenger.
Notice at least 4 volunteer forum members who are very knowledgable read your post, marked it with an :ok: emoji and passed on. There’s a reason for that. Help us help you.
Please see:
How about you do a journalctl -xb snf look for fail or long time between actions.
That might give a start.
This may help as well:
inxi -zav7
and post that info. of course with the surround the output.
Post here the output of this command, and we can see which processes are too slow:
systemd-analyze blame
systemd-analyze blame         ✔
15.027s systemd-journal-flush.service
11.294s NetworkManager-wait-online.service
 8.899s dev-sda5.device
 6.910s systemd-fsck@dev-disk-by\x2duuid-8C0D\x2dE4E6.service
 4.031s cups.service
 2.839s tlp.service
 2.783s apparmor.service
 2.422s udisks2.service
 1.975s ModemManager.service
 1.930s systemd-udevd.service
 1.889s polkit.service
 1.744s upower.service
 1.737s lvm2-monitor.service
 1.632s avahi-daemon.service
 1.561s bluetooth.service
 1.553s systemd-tmpfiles-setup-dev.service
 1.553s dbus.service
 1.552s systemd-logind.service
 1.271s user@1000.service
 1.120s wpa_supplicant.service
 1.075s systemd-modules-load.service
 1.015s NetworkManager.service
  609ms logrotate.service
  448ms systemd-tmpfiles-setup.service
  397ms pkgfile-update.service
  376ms systemd-udev-trigger.service
  358ms systemd-random-seed.service
  307ms boot-efi.mount
  236ms systemd-backlight@backlight:intel_backlight.service
  206ms linux-module-cleanup.service
  189ms systemd-binfmt.service
  181ms systemd-journald.service
  145ms systemd-sysctl.service
  144ms modprobe@fuse.service
  108ms kmod-static-nodes.service
  106ms modprobe@drm.service
  103ms systemd-rfkill.service
  101ms systemd-update-utmp.service
   98ms alsa-restore.service
   95ms dev-hugepages.mount
   94ms dev-mqueue.mount
   93ms sys-kernel-debug.mount
   92ms sys-kernel-tracing.mount
   87ms systemd-remount-fs.service
   66ms user-runtime-dir@1000.service
   66ms tmp.mount
   62ms sys-fs-fuse-connections.mount
   62ms modprobe@configfs.service
   61ms sys-kernel-config.mount
   59ms rtkit-daemon.service
   58ms systemd-user-sessions.service
    2ms proc-sys-fs-binfmt_misc.mount
inxi -zav7
  Kernel: 5.19.17-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
    root=UUID=01a339bf-1b65-42a9-adec-e0ab1d401eca rw quiet apparmor=1
  Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: LENOVO product: 20DF004NMC v: ThinkPad E550
  Mobo: LENOVO model: 20DF004NMC v: SDK0E50512 STD
    serial: <superuser required> UEFI: LENOVO v: J5ET64WW (1.35 )
    date: 10/31/2019
  ID-1: BAT0 charge: 37.3 Wh (99.2%) condition: 37.6/47.5 Wh (79.1%)
    volts: 12.0 min: 10.8 model: LGC LNV-45N1 type: Li-ion serial: <filter>
    status: not charging
  RAM: total: 7.68 GiB used: 2.29 GiB (29.8%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: Intel Core i5-5200U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1474 high: 2700 min/max: 500/2700 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 2196 2: 2700 3: 500
    4: 500 bogomips: 17566
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu
    fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
    mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
    rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
    sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer vme
    x2apic xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
    class-ID: 0300
  Device-2: AMD Opal XT [Radeon R7 M265/M365X/M465] vendor: Lenovo
    driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 2
    speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s lanes: 8
    bus-ID: 05:00.0 chip-ID: 1002:6604 class-ID: 0380 temp: 46.0 C
  Device-3: Chicony Lenovo Integrated Webcam type: USB driver: uvcvideo
    bus-ID: 2-8:5 chip-ID: 04f2:b444 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: X:
    loaded: modesetting,radeon alternate: fbdev,vesa dri: iris,radeonsi
    gpu: i915 display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 model: AU Optronics 0x36ed built: 2013 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
    ratio: 16:9 modes: 1920x1080
  API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel HD Graphics 5500 (BDW
    GT2) direct render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  Sound API: ALSA v: k5.19.17-2-MANJARO running: yes
  Sound Server-3: PipeWire v: 0.3.65 running: yes
  Device-1: Intel Ethernet I218-V vendor: Lenovo driver: e1000e v: kernel
    port: 4080 bus-ID: 00:19.0 chip-ID: 8086:15a3 class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b4 class-ID: 0280
  IF: wlp4s0 state: up mac: <filter>
    bus-ID: 2-7:4 chip-ID: 8087:07dc class-ID: e001
  Local Storage: total: 931.51 GiB used: 605.54 GiB (65.0%)
  ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A7E630
    type: HDD rpm: 5400 serial: <filter> rev: C4A0 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUA0N rev: LZ20
    dev-links: cdrom
  ID-1: / raw-size: 321.17 GiB size: 315.06 GiB (98.10%)
    used: 120.5 GiB (38.2%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
    uuid: 01a339bf-1b65-42a9-adec-e0ab1d401eca
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 58.3 MiB (22.8%) fs: vfat dev: /dev/sda2 maj-min: 8:2
    label: SYSTEM_DRV uuid: 8C0D-E4E6
  ID-3: /run/media/admin_/Windows8_OS raw-size: 593.67 GiB
    size: 593.67 GiB (100.00%) used: 484.97 GiB (81.7%) fs: ntfs dev: /dev/sda4
    maj-min: 8:4 label: Windows8_OS uuid: D2BE0F9DBE0F796D
  ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: ntfs label: WINRE_DRV
    uuid: AE800CFD800CCDB1
  ID-2: /dev/sda3 maj-min: 8:3 size: 128 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda6 maj-min: 8:6 size: 15.32 GiB fs: ntfs
    label: Lenovo_Recovery uuid: B6440AF1440AB3E1
  Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s
    chip-ID: 8087:8001 class-ID: 0900
  Hub-3: 2-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-1:2 info: Razer USA DeathAdder V2 Mini type: Mouse,Keyboard
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 1532:008c class-ID: 0300
  Device-2: 2-6:3 info: Validity Sensors VFS5011 Fingerprint Reader
    type: <vendor specific> driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
    power: 100mA chip-ID: 138a:0011 class-ID: ff00 serial: <filter>
  Device-3: 2-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
  Device-4: 2-8:5 info: Chicony Lenovo Integrated Webcam type: Video
  Hub-4: 3-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  System Temperatures: cpu: 51.0 C pch: 46.5 C mobo: N/A gpu: radeon
    temp: 46.0 C
  Fan Speeds (RPM): cpu: 0 fan-2: 0
  Processes: 180 Uptime: 14m wakeups: 1 Init: systemd v: 252
  default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
  Packages: pm: pacman pkgs: 1535 libs: 406 tools: pamac,yay pm: flatpak
  pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
  inxi: 3.3.24
This doesnt seem to work it says that snf is an invalid argument, failed to add match.
If you use the Preformated text option, your info will look like this (which is much easier for everyone to read):
inxi -zav7
serial: Chassis: type: 10 serial:
serial: UEFI: LENOVO v: J5ET64WW (1.35 )
date: 10/31/2019
required.
Type: spectre_v1 mitigation: usercopy/swapgs barriers and _user pointer
class-ID: 0300
class-ID: 0403
IP v4: type: dynamic noprefixroute scope: global
broadcast:
IP v6: type: noprefixroute scope: link
WAN IP:
type: HDD rpm: 5400 serial: rev: C4A0 scheme: GPT
dev-links: cdrom
ID-3: /run/media/admin/Windows8_OS raw-size: 593.67 GiB
type: driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s
temp: 46.0 C
inxi: 3.3.24
You’re using an EOL kernel (5.19), may be a good idea upgrading to 6.1 and then see if the problem persists or it’s solved.
I agree on the kernel. Either switch to a 6.1 kernel which will soon be LTS, or 5.15 which is LTS. No swap file or swap partition? I would recommend one or the other. You have a 5400 RPM HDD. I would consider switching to a SSD, if possible. You may be limited by the hard drive specs. Regarding the current issue:
NetworkManager-wait-online.service- I would try masking this
one and see how it goes. I always mask on a new install with no
 ill effects with broadband service here:
systemctl mask NetworkManager-wait-online.service
ModemManager.service is for dial-up. Do you have dial-up internet? If not:
systemctl disable ModemManager.service
lvm2-monitor.service is only needed for logical partitions. Do you have logical
partitions? If not:
systemctl mask lvm2-monitor.service
Check status of systemd-journal-flush.service:
systemctl status systemd-journal-flush.service
A quick search of this forum should also help in sorting this out.
    ~  systemctl status systemd-journal-flush.service         ✔
● systemd-journal-flush.service - Flush Journal to Persistent Storage
     Loaded: loaded (/usr/lib/systemd/system/systemd-journal-flush.service; static)
     Active: active (exited) since Tue 2023-02-14 14:57:45 GMT; 1h 49min ago
       Docs: man:systemd-journald.service(8)
             man:journald.conf(5)
    Process: 277 ExecStart=journalctl --flush (code=exited, status=0/SUCCESS)
   Main PID: 277 (code=exited, status=0/SUCCESS)
        CPU: 7ms
úno 14 14:57:30 winzar-20df004nmc systemd[1]: Starting Flush Journal to Persistent Storage...
úno 14 14:57:45 winzar-20df004nmc systemd[1]: Finished Flush Journal to Persistent Storage.
Try and run these then reboot.
sudo systemctl disable NetworkManager-wait-online.service
sudo journalctl --vacuum-size=1G --vacuum-time=5d --vacuum-files=5
your sda5 is also taking a long time to respond, so maybe try updating it’s firmware or unplug it. I had for a long time occasional 5-20 second delay on bootup, and it was in initializing sd device, and it vanished when i realized to do a firmware upgrade on the drive.
The problem persists. I think I changed the version but nothing happened.
My sda5 is where I have manjaro, how would I go about upgrading it? Since I dont want to unplug it, because I want to keep using manjaro right?? Also I used the two commands u sent (one of them cleared 2.9 gigs of ram), but the boot time is still pretty slow, when I measured the time from pressing the button and the icons on the desktop appearing, it was 1:59.
post
systemd-analyze critical-chain
If nothing else, at least the network wait service should not take time now.
You could check sudo dmesg and look at the timestamps where the delay is if it happens in kernel
After that i don’t have other suggestions than updating the firmware on your sda drive. Though even before that things should not add up to two minutes of boot time.
edit: i might have been reading wrong the blame output, like others in this thread. The critical-path should show true delays any service causes. If your system spends 9 seconds waiting on your hdd to read data during the whole boot process, that is not abnormal if you have a slow drive. You might also want to
sudo systemctl enable NetworkManager-wait-online.service
The time when unit became active or started is printed after the "@" character.
The time the unit took to start is printed after the "+" character.
graphical.target @24.325s
└─multi-user.target @24.325s
  └─ModemManager.service @21.864s +2.460s
    └─polkit.service @20.264s +1.597s
      └─basic.target @20.166s
        └─sockets.target @20.166s
          └─dbus.socket @20.166s
            └─sysinit.target @20.151s
              └─systemd-update-utmp.service @20.061s +89ms
                └─systemd-tmpfiles-setup.service @19.793s +245ms
                  └─local-fs.target @19.642s
                    └─run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount @19.797s
                      └─local-fs-pre.target @8.541s
                        └─systemd-tmpfiles-setup-dev.service @7.129s +1.411s
                          └─kmod-static-nodes.service @6.719s +251ms
                            └─systemd-journald.socket @6.684s
                              └─system.slice @6.516s
                                └─-.slice @6.501s
There seems to be a big jump from 96 to 954 right here:
[   96.558210] audit: type=1131 audit(1676395621.575:122): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  945.828274] audit: type=1130 audit(1676396470.845:123): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
This is a part of the log.
[    2.565144] EXT4-fs (sda5): mounted filesystem with ordered data mode. Quota mode: none.
[    4.405087] systemd[1]: systemd 252.5-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    4.405094] systemd[1]: Detected architecture x86-64.
[    4.424726] systemd[1]: Hostname set to <winzar-20df004nmc>.
[    5.143931] systemd[1]: bpf-lsm: LSM BPF program attached
[   10.451820] systemd[1]: Queued start job for default target Graphical Interface.
[   10.488979] systemd[1]: Created slice Slice /system/getty.
[   10.489333] systemd[1]: Created slice Slice /system/modprobe.
[   10.489584] systemd[1]: Created slice Slice /system/systemd-fsck.
[   10.489813] systemd[1]: Created slice User and Session Slice.
[   10.489890] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   10.489942] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.490105] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.490137] systemd[1]: Reached target Local Encrypted Volumes.
[   10.490152] systemd[1]: Reached target Login Prompts.
[   10.490164] systemd[1]: Reached target Local Integrity Protected Volumes.
[   10.490188] systemd[1]: Reached target Remote File Systems.
[   10.490201] systemd[1]: Reached target Slice Units.
[   10.490221] systemd[1]: Reached target Swaps.
[   10.490236] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.490305] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   10.505451] systemd[1]: Listening on LVM2 poll daemon socket.
[   10.506780] systemd[1]: Listening on Process Core Dump Socket.
[   10.506967] systemd[1]: Listening on Journal Audit Socket.
[   10.507087] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.507215] systemd[1]: Listening on Journal Socket.
[   10.509671] systemd[1]: Listening on udev Control Socket.
[   10.509828] systemd[1]: Listening on udev Kernel Socket.
[   10.510897] systemd[1]: Mounting Huge Pages File System...
[   10.512021] systemd[1]: Mounting POSIX Message Queue File System...
[   10.513147] systemd[1]: Mounting Kernel Debug File System...
[   10.514126] systemd[1]: Mounting Kernel Trace File System...
[   10.540373] systemd[1]: Mounting Temporary Directory /tmp...
[   10.541482] systemd[1]: Starting Load AppArmor profiles...
[   10.542738] systemd[1]: Starting Create List of Static Device Nodes...
[   10.543736] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   10.545003] systemd[1]: Starting Load Kernel Module configfs...
[   10.546102] systemd[1]: Starting Load Kernel Module drm...
[   10.547717] systemd[1]: Starting Load Kernel Module fuse...
[   10.547878] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   10.747281] fuse: init (API version 7.37)
[   10.764947] systemd[1]: Starting Load Kernel Modules...
[   10.766499] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.766623] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[   10.767710] systemd[1]: Starting Coldplug All udev Devices...
[   10.769432] systemd[1]: Mounted Huge Pages File System.
[   10.769535] systemd[1]: Mounted POSIX Message Queue File System.
[   10.769617] systemd[1]: Mounted Kernel Debug File System.
[   10.769698] systemd[1]: Mounted Kernel Trace File System.
[   10.769782] systemd[1]: Mounted Temporary Directory /tmp.
[   10.794239] systemd[1]: Finished Create List of Static Device Nodes.
[   10.794676] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.796254] EXT4-fs (sda5): re-mounted. Quota mode: none.
[   10.824800] systemd[1]: Finished Load Kernel Module configfs.
[   10.825820] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   10.851541] systemd[1]: Finished Load Kernel Module drm.
[   10.851929] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   10.878169] systemd[1]: Finished Load Kernel Module fuse.
[   10.898102] systemd[1]: Finished Remount Root and Kernel File Systems.
[   10.918065] systemd[1]: Mounting FUSE Control File System...
[   10.919161] systemd[1]: Mounting Kernel Configuration File System...
[   10.919248] systemd[1]: First Boot Wizard was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   10.950735] systemd[1]: Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   10.951877] systemd[1]: Starting Load/Save Random Seed...
[   10.951964] systemd[1]: Create System Users was skipped because no trigger condition checks were met.
[   10.953050] systemd[1]: Starting Create Static Device Nodes in /dev...
[   10.954144] systemd[1]: Mounted FUSE Control File System.
[   10.955266] systemd[1]: Mounted Kernel Configuration File System.
[   11.239263] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   11.239339] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   11.364715] systemd[1]: Finished Coldplug All udev Devices.
[   11.438047] systemd[1]: Finished Load/Save Random Seed.
[   11.438187] systemd[1]: First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   11.528083] systemd[1]: Finished Load Kernel Modules.
[   11.568166] systemd[1]: Starting Apply Kernel Variables...
[   11.709466] audit: type=1400 audit(1676395536.725:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=243 comm="apparmor_parser"
[   11.710569] audit: type=1400 audit(1676395536.725:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=243 comm="apparmor_parser"
[   11.714763] systemd[1]: Finished Apply Kernel Variables.
[   11.723794] audit: type=1400 audit(1676395536.739:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=242 comm="apparmor_parser"
[   11.874119] audit: type=1400 audit(1676395536.889:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=240 comm="apparmor_parser"
[   11.890553] audit: type=1400 audit(1676395536.905:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-bgqd" pid=247 comm="apparmor_parser"
[   11.895172] audit: type=1400 audit(1676395536.912:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=248 comm="apparmor_parser"
[   11.899721] audit: type=1400 audit(1676395536.915:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=244 comm="apparmor_parser"
[   11.998439] audit: type=1400 audit(1676395537.015:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=249 comm="apparmor_parser"
[   12.039459] audit: type=1400 audit(1676395537.055:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=252 comm="apparmor_parser"
[   12.070617] audit: type=1400 audit(1676395537.085:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd-classic" pid=250 comm="apparmor_parser"
[   12.111456] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   12.364790] systemd[1]: Finished Create Static Device Nodes in /dev.
[   12.365002] systemd[1]: Reached target Preparation for Local File Systems.
[   12.365058] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[   12.365085] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[   12.381630] systemd[1]: Starting Journal Service...
[   12.383192] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   12.538880] systemd[1]: Started Journal Service.
[   12.611616] systemd-journald[270]: Received client request to flush runtime journal.
[   14.980120] e1000e: Intel(R) PRO/1000 Network Driver
[   14.980124] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[   14.980360] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[   14.982507] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[   14.982797] i2c i2c-0: 1/2 memory slots populated (from DMI)
[   14.984489] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.984924] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.986671] input: PC Speaker as /devices/platform/pcspkr/input/input9
[   15.122234] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   15.122239] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   15.122242] RAPL PMU: hw unit of domain package 2^-14 Joules
[   15.122244] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   15.122245] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   15.159677] e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock
[   15.225242] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 68:f7:28:93:62:40
[   15.225255] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[   15.225280] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[   15.226021] thinkpad_acpi: ThinkPad ACPI Extras v0.26
[   15.226027] thinkpad_acpi: http://ibm-acpi.sf.net/
[   15.226029] thinkpad_acpi: ThinkPad BIOS J5ET64WW (1.35 ), EC unknown
[   15.226030] thinkpad_acpi: Lenovo ThinkPad E550, model 20DF004NMC
[   15.227306] thinkpad_acpi: This ThinkPad has standard ACPI backlight brightness control, supported by the ACPI video driver
[   15.227311] thinkpad_acpi: Disabling thinkpad-acpi brightness events by default...
[   15.238561] thinkpad_acpi: rfkill switch tpacpi_bluetooth_sw: radio is unblocked
[   15.238709] Intel(R) Wireless WiFi driver for Linux
[   15.257722] thinkpad_acpi: secondary fan control detected & enabled
[   15.274681] thinkpad_acpi: battery 1 registered (start 93, stop 95, behaviours: 0x7)
[   15.274699] ACPI: battery: new extension: ThinkPad Battery Extension
[   15.275816] input: ThinkPad Extra Buttons as /devices/platform/thinkpad_acpi/input/input10
[   15.370474] cryptd: max_cpu_qlen set to 1000
[   15.429896] iwlwifi 0000:04:00.0: loaded firmware version 17.3216344376.0 3160-17.ucode op_mode iwlmvm
[   15.734463] AVX2 version of gcm_enc/dec engaged.
[   15.734503] AES CTR mode by8 optimization enabled
[   15.841932] iTCO_vendor_support: vendor-support=0
[   15.862335] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[   15.862633] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[   15.862637] snd_hda_codec_conexant hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   15.862639] snd_hda_codec_conexant hdaudioC1D0:    hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[   15.862641] snd_hda_codec_conexant hdaudioC1D0:    mono: mono_out=0x0
[   15.862642] snd_hda_codec_conexant hdaudioC1D0:    inputs:
[   15.862644] snd_hda_codec_conexant hdaudioC1D0:      Internal Mic=0x1a
[   15.862645] snd_hda_codec_conexant hdaudioC1D0:      Mic=0x19
[   15.877754] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input11
[   15.877823] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input12
[   15.920858] input: AlpsPS/2 ALPS DualPoint Stick as /devices/platform/i8042/serio1/input/input13
[   15.937334] input: AlpsPS/2 ALPS DualPoint TouchPad as /devices/platform/i8042/serio1/input/input8
[   15.940887] e1000e 0000:00:19.0 enp0s25: renamed from eth0
[   15.996811] iTCO_wdt iTCO_wdt.1.auto: Found a Wildcat Point_LP TCO device (Version=2, TCOBASE=0x1860)
[   15.997057] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[   16.035046] mousedev: PS/2 mouse device common for all mice
[   16.410690] spi-nor: probe of spi0.0 failed with error -22
[   16.413370] iwlwifi 0000:04:00.0: Detected Intel(R) Dual Band Wireless AC 3160, REV=0x164
[   16.441015] iwlwifi 0000:04:00.0: base HW address: f4:06:69:4a:11:72, OTP minor version: 0x0
[   16.554880] ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
[   16.595773] [drm] radeon kernel modesetting enabled.
[   16.595790] vga_switcheroo: detected switching method \_SB_.PCI0.VID_.ATPX handle
[   16.595831] ATPX version 1, functions 0x00000033
[   16.595864] ATPX Hybrid Graphics
[   16.596021] Console: switching to colour dummy device 80x25
[   16.596314] [drm] initializing kernel modesetting (OLAND 0x1002:0x6604 0x17AA:0x5021 0x00).
[   16.637956] iwlwifi 0000:04:00.0 wlp4s0: renamed from wlan0
[   16.671499] ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [TBF3] at bit offset/length 262144/32768 exceeds size of target Buffer (262144 bits) (20220331/dsopcode-198)
[   16.671509] ACPI Error: Aborting method \_SB.PCI0.VID.GETB due to previous error (AE_AML_BUFFER_LIMIT) (20220331/psparse-529)
[   16.671516] ACPI Error: Aborting method \_SB.PCI0.VID.ATRM due to previous error (AE_AML_BUFFER_LIMIT) (20220331/psparse-529)
[   16.671524] failed to evaluate ATRM got AE_AML_BUFFER_LIMIT
[   16.671528] ATOM BIOS: Lenovo
[   16.671542] [drm] GPU not posted. posting now...
[   16.675389] radeon 0000:05:00.0: VRAM: 2048M 0x0000000000000000 - 0x000000007FFFFFFF (2048M used)
[   16.675393] radeon 0000:05:00.0: GTT: 2048M 0x0000000080000000 - 0x00000000FFFFFFFF
[   16.675405] [drm] Detected VRAM RAM=2048M, BAR=256M
[   16.675406] [drm] RAM width 128bits DDR
[   16.675434] [drm] radeon: 2048M of VRAM memory ready
[   16.675436] [drm] radeon: 2048M of GTT memory ready.
[   16.675447] [drm] Loading oland Microcode
[   16.775929] [drm] Internal thermal controller with fan control
[   16.785217] [drm] radeon: dpm initialized
[   16.877089] [drm] GART: num cpu pages 524288, num gpu pages 524288
[   16.878640] [drm] PCIE gen 2 link speeds already enabled
[   16.888296] [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
[   16.888406] radeon 0000:05:00.0: WB enabled
[   16.888409] radeon 0000:05:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
[   16.888412] radeon 0000:05:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
[   16.888413] radeon 0000:05:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
[   16.888414] radeon 0000:05:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
[   16.888415] radeon 0000:05:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
[   16.889229] radeon 0000:05:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
[   16.889324] radeon 0000:05:00.0: radeon: MSI limited to 32-bit
[   16.889383] radeon 0000:05:00.0: radeon: using MSI.
[   16.889422] [drm] radeon: irq initialized.
[   17.083751] [drm] ring test on 0 succeeded in 1 usecs
[   17.083758] [drm] ring test on 1 succeeded in 1 usecs
[   17.083763] [drm] ring test on 2 succeeded in 1 usecs
[   17.083772] [drm] ring test on 3 succeeded in 4 usecs
[   17.083779] [drm] ring test on 4 succeeded in 4 usecs
[   17.164068] i915 0000:00:02.0: enabling device (0006 -> 0007)
[   17.164352] i915 0000:00:02.0: vgaarb: deactivate vga console
[   17.165810] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=mem
[   17.262684] [drm] ring test on 5 succeeded in 2 usecs
[   17.262694] [drm] UVD initialized successfully.
[   17.262880] [drm] ib test on ring 0 succeeded in 0 usecs
[   17.262925] [drm] ib test on ring 1 succeeded in 0 usecs
[   17.262967] [drm] ib test on ring 2 succeeded in 0 usecs
[   17.263009] [drm] ib test on ring 3 succeeded in 0 usecs
[   17.263050] [drm] ib test on ring 4 succeeded in 0 usecs
[   17.424820] intel_rapl_common: Found RAPL domain package
[   17.424824] intel_rapl_common: Found RAPL domain core
[   17.424826] intel_rapl_common: Found RAPL domain uncore
[   17.424827] intel_rapl_common: Found RAPL domain dram
[   17.924711] [drm] ib test on ring 5 succeeded
[   17.924964] [drm] Radeon Display Connectors
[   17.936608] [drm] Initialized radeon 2.50.0 20080528 for 0000:05:00.0 on minor 0
[   17.937960] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
[   17.938914] ACPI: video: Video Device [VID] (multi-head: yes  rom: no  post: no)
[   17.939279] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input14
[   17.939459] ACPI: video: Video Device [VID1] (multi-head: yes  rom: yes  post: no)
[   17.939650] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:09/LNXVIDEO:01/input/input15
[   17.939740] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   17.940007] vga_switcheroo: enabled
[   17.944401] fbcon: i915drmfb (fb0) is primary device
[   19.090008] Console: switching to colour frame buffer device 240x67
[   19.112627] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[   19.201573] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[   19.201642] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input17
[   19.201705] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input18
[   19.461484] kauditd_printk_skb: 100 callbacks suppressed
[   19.461487] audit: type=1130 audit(1676395544.479:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.928188] audit: type=1131 audit(1676395546.945:67): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.033996] mc: Linux media interface: v0.10
[   22.041374] [drm] amdgpu kernel modesetting enabled.
[   22.041391] amdgpu: vga_switcheroo: detected switching method \_SB_.PCI0.VID_.ATPX handle
[   22.041436] ATPX version 1, functions 0x00000033
[   22.041469] ATPX Hybrid Graphics
[   22.041597] amdgpu: CRAT table not found
[   22.041601] amdgpu: Virtual CRAT table created for CPU
[   22.041616] amdgpu: Topology: Add CPU node
[   22.489862] videodev: Linux video capture interface: v2.00
[   22.537376] Bluetooth: Core ver 2.22
[   22.537400] NET: Registered PF_BLUETOOTH protocol family
[   22.537402] Bluetooth: HCI device and connection manager initialized
[   22.537407] Bluetooth: HCI socket layer initialized
[   22.537409] Bluetooth: L2CAP socket layer initialized
[   22.537415] Bluetooth: SCO socket layer initialized
[   22.798177] audit: type=1130 audit(1676395547.819:68): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   22.836708] usb 2-8: Found UVC 1.00 device Integrated Camera (04f2:b444)
[   22.849122] input: Integrated Camera: Integrated C as /devices/pci0000:00/0000:00:14.0/usb2/2-8/2-8:1.0/input/input19
[   22.849187] usbcore: registered new interface driver uvcvideo
[   22.852150] usbcore: registered new interface driver btusb
[   22.864524] Bluetooth: hci0: Legacy ROM 2.5 revision 0.0 build 1 week 45 2013
[   22.982514] audit: type=1130 audit(1676395548.002:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.015087] Bluetooth: hci0: Intel Bluetooth firmware file: intel/ibt-hw-37.7.10-fw-1.0.1.2d.d.bseq
[   23.176611] Bluetooth: hci0: Intel BT fw patch 0x27 completed & activated
[   23.258290] audit: type=1130 audit(1676395548.279:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-fsck@dev-disk-by\x2duuid-8C0D\x2dE4E6 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.704900] audit: type=1130 audit(1676395548.725:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.861668] audit: type=1130 audit(1676395548.882:72): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.919620] audit: type=1127 audit(1676395548.939:73): pid=658 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[   23.974931] audit: type=1130 audit(1676395548.995:74): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   24.083330] audit: type=1130 audit(1676395549.102:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.326399] kauditd_printk_skb: 6 callbacks suppressed
[   25.326404] audit: type=1130 audit(1676395550.342:82): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=dbus comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.345331] audit: type=1130 audit(1676395550.365:83): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.345483] audit: type=1130 audit(1676395550.365:84): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-logind comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.345654] audit: type=1130 audit(1676395550.365:85): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=avahi-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.600041] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   25.600047] Bluetooth: BNEP filters: protocol multicast
[   25.600053] Bluetooth: BNEP socket layer initialized
[   25.602410] Bluetooth: MGMT ver 1.22
[   25.618311] audit: type=1334 audit(1676395550.635:86): prog-id=32 op=LOAD
[   25.618474] audit: type=1334 audit(1676395550.635:87): prog-id=33 op=LOAD
[   25.618526] audit: type=1334 audit(1676395550.635:88): prog-id=34 op=LOAD
[   25.654838] NET: Registered PF_ALG protocol family
[   25.685562] audit: type=1130 audit(1676395550.702:89): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   25.766960] audit: type=1130 audit(1676395550.782:90): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   26.373224] audit: type=1130 audit(1676395551.389:91): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   28.147346] NET: Registered PF_QIPCRTR protocol family
[   28.840535] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840542] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840544] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840546] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840548] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840550] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   28.840551] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.045648] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.045887] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.045895] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.045903] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.045908] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.046257] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.046265] ACPI: \: failed to evaluate _DSM bf0212f2-788f-c64d-a5b3-1f738e285ade (0x1001)
[   29.188990] [drm] PCIE gen 2 link speeds already enabled
[   29.202220] [drm] PCIE GART of 2048M enabled (table at 0x0000000000165000).
[   29.202329] radeon 0000:05:00.0: WB enabled
[   29.202335] radeon 0000:05:00.0: fence driver on ring 0 use gpu addr 0x0000000080000c00
[   29.202337] radeon 0000:05:00.0: fence driver on ring 1 use gpu addr 0x0000000080000c04
[   29.202339] radeon 0000:05:00.0: fence driver on ring 2 use gpu addr 0x0000000080000c08
[   29.202340] radeon 0000:05:00.0: fence driver on ring 3 use gpu addr 0x0000000080000c0c
[   29.202341] radeon 0000:05:00.0: fence driver on ring 4 use gpu addr 0x0000000080000c10
[   29.203154] radeon 0000:05:00.0: fence driver on ring 5 use gpu addr 0x0000000000075a18
[   29.203717] debugfs: File 'radeon_ring_gfx' in directory '0' already present!
[   29.203721] debugfs: File 'radeon_ring_cp1' in directory '0' already present!
[   29.203724] debugfs: File 'radeon_ring_cp2' in directory '0' already present!
[   29.203726] debugfs: File 'radeon_ring_dma1' in directory '0' already present!
[   29.203728] debugfs: File 'radeon_ring_dma2' in directory '0' already present!
[   29.398277] [drm] ring test on 0 succeeded in 1 usecs
[   29.398285] [drm] ring test on 1 succeeded in 1 usecs
[   29.398290] [drm] ring test on 2 succeeded in 1 usecs
[   29.398298] [drm] ring test on 3 succeeded in 4 usecs
[   29.398306] [drm] ring test on 4 succeeded in 4 usecs
[   29.398309] debugfs: File 'radeon_ring_uvd' in directory '0' already present!
[   29.575406] [drm] ring test on 5 succeeded in 2 usecs
[   29.575412] [drm] UVD initialized successfully.
[   29.575464] [drm] ib test on ring 0 succeeded in 0 usecs
[   29.575510] [drm] ib test on ring 1 succeeded in 0 usecs
[   29.575555] [drm] ib test on ring 2 succeeded in 0 usecs
[   29.575587] [drm] ib test on ring 3 succeeded in 0 usecs
[   29.575620] [drm] ib test on ring 4 succeeded in 0 usecs
[   30.244703] [drm] ib test on ring 5 succeeded
[   30.808436] kauditd_printk_skb: 6 callbacks suppressed
[   30.808441] audit: type=1130 audit(1676395555.829:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=tlp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   30.809262] audit: type=1130 audit(1676395555.829:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.371488] audit: type=1131 audit(1676395563.392:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   38.908556] audit: type=1100 audit(1676395563.929:101): pid=875 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit acct="admin_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   38.979087] audit: type=1101 audit(1676395563.999:102): pid=875 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="admin_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   38.980310] audit: type=1103 audit(1676395563.999:103): pid=875 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit acct="admin_" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[   38.980535] audit: type=1006 audit(1676395563.999:104): pid=875 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[   38.980550] audit: type=1300 audit(1676395563.999:104): arch=c000003e syscall=1 success=yes exit=4 a0=8 a1=7ffdefae9910 a2=4 a3=0 items=0 ppid=712 pid=875 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=1 comm="sddm-helper" exe="/usr/lib/sddm/sddm-helper" subj=unconfined key=(null)
[   38.980561] audit: type=1327 audit(1676395563.999:104): proctitle=2F7573722F6C69622F7364646D2F7364646D2D68656C706572002D2D736F636B6574002F746D702F7364646D2D6175746863373739396239352D643064622D343732642D623830362D393063386338366566396338002D2D69640031002D2D7374617274002F7573722F62696E2F7374617274706C61736D612D783131002D2D
[   39.138404] audit: type=1130 audit(1676395564.159:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.170868] audit: type=1101 audit(1676395564.185:106): pid=877 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="admin_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   39.170903] audit: type=1103 audit(1676395564.185:107): pid=877 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="admin_" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   51.295721] kauditd_printk_skb: 6 callbacks suppressed
[   51.295727] audit: type=1130 audit(1676395576.312:112): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   56.474774] audit: type=1131 audit(1676395581.492:113): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   56.554640] audit: type=1334 audit(1676395581.572:114): prog-id=34 op=UNLOAD
[   56.554650] audit: type=1334 audit(1676395581.572:115): prog-id=33 op=UNLOAD
[   56.554654] audit: type=1334 audit(1676395581.572:116): prog-id=32 op=UNLOAD
[   60.276571] audit: type=1334 audit(1676395585.292:117): prog-id=35 op=LOAD
[   60.276635] audit: type=1334 audit(1676395585.292:118): prog-id=36 op=LOAD
[   63.140816] audit: type=1130 audit(1676395588.155:119): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   67.841302] audit: type=1130 audit(1676395592.855:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   76.326251] ntfs3: Max link count 4000
[   76.326264] ntfs3: Enabled Linux POSIX ACLs support
[   76.326265] ntfs3: Read-only LZX/Xpress compression included
[   76.327513] ntfs3: Unknown parameter 'windows_names'
[   82.969867] Bluetooth: RFCOMM TTY layer initialized
[   82.969883] Bluetooth: RFCOMM socket layer initialized
[   82.969893] Bluetooth: RFCOMM ver 1.11
[   85.636820] wlp4s0: authenticate with 5c:6a:80:4c:37:f1
[   85.636838] wlp4s0: 80 MHz not supported, disabling VHT
[   85.644615] wlp4s0: send auth to 5c:6a:80:4c:37:f1 (try 1/3)
[   85.647775] wlp4s0: authenticated
[   85.651244] wlp4s0: associate with 5c:6a:80:4c:37:f1 (try 1/3)
[   85.654893] wlp4s0: RX AssocResp from 5c:6a:80:4c:37:f1 (capab=0x411 status=0 aid=4)
[   85.666473] wlp4s0: associated
[   85.818481] IPv6: ADDRCONF(NETDEV_CHANGE): wlp4s0: link becomes ready
[   86.517697] audit: type=1130 audit(1676395611.532:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  945.828284] audit: type=1131 audit(1676396470.845:124): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6909.419401] wlp4s0: Connection to AP 5c:6a:80:4c:37:f1 lost
[ 6913.000027] wlp4s0: authenticate with 5c:6a:80:4c:37:f1
[ 6913.000044] wlp4s0: 80 MHz not supported, disabling VHT
[ 6913.005590] wlp4s0: send auth to 5c:6a:80:4c:37:f1 (try 1/3)
[ 6913.008384] wlp4s0: authenticated
[ 6913.009982] wlp4s0: associate with 5c:6a:80:4c:37:f1 (try 1/3)
[ 6913.013605] wlp4s0: RX AssocResp from 5c:6a:80:4c:37:f1 (capab=0x411 status=0 aid=1)
[ 6913.027924] wlp4s0: associated
[ 6913.619666] iwlwifi 0000:04:00.0: No beacon heard and the time event is over already...
[ 6913.619724] wlp4s0: Connection to AP 5c:6a:80:4c:37:f1 lost
[ 6917.000890] wlp4s0: authenticate with 5c:6a:80:4c:37:f1
[ 6917.000908] wlp4s0: 80 MHz not supported, disabling VHT
[ 6917.006765] wlp4s0: send auth to 5c:6a:80:4c:37:f1 (try 1/3)
[ 6917.011920] wlp4s0: authenticated
[ 6917.013342] wlp4s0: associate with 5c:6a:80:4c:37:f1 (try 1/3)
[ 6917.017132] wlp4s0: RX AssocResp from 5c:6a:80:4c:37:f1 (capab=0x411 status=0 aid=1)
[ 6917.018298] wlp4s0: associated
[ 6917.623016] iwlwifi 0000:04:00.0: No beacon heard and the time event is over already...
[ 6917.623031] wlp4s0: Connection to AP 5c:6a:80:4c:37:f1 lost
[ 6917.681607] audit: type=1130 audit(1676402442.699:125): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6921.011067] wlp4s0: authenticate with 5c:6a:80:4c:37:f1
[ 6921.011085] wlp4s0: 80 MHz not supported, disabling VHT
[ 6921.017042] wlp4s0: send auth to 5c:6a:80:4c:37:f1 (try 1/3)
[ 6921.019773] wlp4s0: authenticated
[ 6921.023325] wlp4s0: associate with 5c:6a:80:4c:37:f1 (try 1/3)
[ 6921.027093] wlp4s0: RX AssocResp from 5c:6a:80:4c:37:f1 (capab=0x411 status=0 aid=1)
[ 6921.038438] wlp4s0: associated
[ 6927.696881] audit: type=1131 audit(1676402452.716:126): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6935.248504] audit: type=1100 audit(1676402460.266:127): pid=4567 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_permit,pam_faillock acct="admin_" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 6935.248698] audit: type=1101 audit(1676402460.266:128): pid=4567 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="admin_" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 6935.249512] audit: type=1110 audit(1676402460.266:129): pid=4567 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 6935.249660] audit: type=1105 audit(1676402460.266:130): pid=4567 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 6935.684499] audit: type=1334 audit(1676402460.702:131): prog-id=37 op=LOAD
[ 6935.684526] audit: type=1334 audit(1676402460.702:132): prog-id=29 op=UNLOAD
[ 6935.684629] audit: type=1334 audit(1676402460.702:133): prog-id=38 op=LOAD
[ 6935.684664] audit: type=1334 audit(1676402460.702:134): prog-id=39 op=LOAD
[ 6935.684686] audit: type=1334 audit(1676402460.702:135): prog-id=30 op=UNLOAD
[ 6935.684699] audit: type=1334 audit(1676402460.702:136): prog-id=31 op=UNLOAD
[ 7006.303656] kauditd_printk_skb: 16 callbacks suppressed
[ 7006.303659] audit: type=1101 audit(1676402531.322:153): pid=4605 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="admin_" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 7006.305354] audit: type=1110 audit(1676402531.322:154): pid=4605 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 7006.305924] audit: type=1105 audit(1676402531.322:155): pid=4605 uid=1000 auid=1000 ses=2 subj=unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
You probably can disable ModemManager.
that jump is clearly outside the boot process, as the timestamp is seconds since kernel started.
All i can gather is that everything seems to happen very slowly, and quite some places take significant time without any obvious debug info.
Once the kernel has booted and userspace starts to load, everything works fine based on analyze critical chain
Only thing i can suggest is to update your BIOS, as there were quite some errors related to it.
I found this online
Should you update the BIOS?
But before we explain how to do it, an important warning.
If something goes wrong during the BIOS update, your PC or laptop could be rendered useless. If there’s a power cut, or the computer gets turned off while updating, it could mean that it’s unable to boot at all. It’s unlikely, but not out of the question.
So, unless you have a good reason to, we’d advise you not to update the BIOS at all.
Valid reasons for updating include adding support for a new processor that you plan to install, to fix a bug, performance issue or vulnerability, or to add new features that you want or need.
Also it seems like its pretty complex for a guy like me.
complexity depends on the manufacturer. Many can be updated from windows, some from linux, and the rest need you to make an usb stick with the update.
If I were to update my thinkpad could I do it from linux or windows?
