I was installed manjaro 21.0.7
seems like now everything work fine except for
- when my bluetooth
scan onit not found any devices - when suspend it will black screen forever (help with hold power button and then reopen my laptop)
anyone have the solution?
more infomation
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8e78d3ea-384b-41e8-87b0-0dc5afe832b9 rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 82JW v: Legion 5 15ACH6
serial: <filter> Chassis: type: 10 v: Legion 5 15ACH6 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55756 WIN serial: <filter>
UEFI: LENOVO v: HHCN14WW date: 07/18/2021
ID-1: BAT0 charge: 81.2 Wh (99.0%) condition: 82.0/80.0 Wh (102.5%)
volts: 17.6 min: 15.4 model: Celxpert L20C4PC1 type: Li-poly
serial: <filter> status: Charging cycles: 20
RAM: total: 15.55 GiB used: 2.37 GiB (15.3%)
Info: 8-Core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 3 family: 19 (25) model-id: 50 (80) stepping: 0
microcode: A50000C cache: L2: 4 MiB bogomips: 102241
Speed: 2955 MHz min/max: 1200/3200 MHz boost: enabled Core speeds (MHz):
1: 2955 2: 1597 3: 2434 4: 3242 5: 3315 6: 1786 7: 3215 8: 1707 9: 2987
10: 1596 11: 3470 12: 3948 13: 2665 14: 2931 15: 3083 16: 1944
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Ti Mobile] vendor: Lenovo
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:25e0 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: picom v: git-dac85 driver:
Screen-1: 0 s-res: 2560x2160 s-dpi: 143 s-size: 454x381mm (17.9x15.0")
s-diag: 593mm (23.3")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 81 size: 798x334mm (31.4x13.1")
diag: 865mm (34.1")
Monitor-2: DP-4 res: 1920x1080 hz: 165 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 3050 Ti Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 10de:2291 class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
vendor: Lenovo driver: r8168 v: 8.049.02-NAPI modules: r8169 port: 2000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek vendor: Lenovo driver: rtw89_pci v: N/A modules: rtw89pci
port: 1000 bus-ID: 04:00.0 chip-ID: 10ec:8852 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 0bda:4852 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 3 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 12.59 GiB (2.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: HFS512GDE9X084N
lanes: 4 type: SSD serial: <filter> rev: 41010C22 temp: 48.9 C scheme: GPT
ID-1: / raw-size: 96.68 GiB size: 94.6 GiB (97.85%) used: 12.56 GiB (13.3%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 8e78d3ea-384b-41e8-87b0-0dc5afe832b9
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 33.1 MiB (12.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: SYSTEM_DRV uuid: 9288-7158
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 379.01 GiB fs: ntfs
label: Windows-SSD uuid: 04AC88ECAC88DA16
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 1000 MiB fs: ntfs label: WINRE_DRV
uuid: 8460897F608978A6
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 3 rev: 2.1 speed: 480 Mb/s
Device-1: 1-4:3 info: Integrated Express ITE Device(8910) type: Keyboard
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 048d:c101 class-ID: 0301
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 2-2:2 info: Genesys Logic USB3.2 Hub ports: 3 rev: 3.2 speed: 5 Gb/s
chip-ID: 05e3:0620 class-ID: 0900
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 3-3:2 info: Integrated Express ITE Device(8295) type: Keyboard,HID
power: 100mA chip-ID: 048d:c965 class-ID: 0300
Device-2: 3-4:3 info: Realtek Bluetooth Radio type: Bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s power: 500mA chip-ID: 0bda:4852
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
Message: No sensor data found. Is lm-sensors configured?
Processes: 283 Uptime: 1h 28m wakeups: 1 Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 Packages: 1122 pacman: 1119 lib: 289
snap: 3 Shell: Zsh v: 5.8 running-in: urxvtd inxi: 3.3.06
